RTEMS 6.1-rc4
stm32h7xx_hal_conf.h
1
21/* Define to prevent recursive inclusion -------------------------------------*/
22#ifndef STM32H7xx_HAL_CONF_H
23#define STM32H7xx_HAL_CONF_H
24
25#ifdef __rtems__
26#include <bspopts.h>
27
28#define HSE_VALUE ((uint32_t)STM32H7_HSE_FREQUENCY)
29#endif /* __rtems__ */
30#ifdef __cplusplus
31 extern "C" {
32#endif
33
34/* Exported types ------------------------------------------------------------*/
35/* Exported constants --------------------------------------------------------*/
36
37/* ########################## Module Selection ############################## */
41#define HAL_MODULE_ENABLED
42#define HAL_ADC_MODULE_ENABLED
43#define HAL_CEC_MODULE_ENABLED
44#define HAL_COMP_MODULE_ENABLED
45#define HAL_CORDIC_MODULE_ENABLED
46#define HAL_CORTEX_MODULE_ENABLED
47#define HAL_CRC_MODULE_ENABLED
48#define HAL_CRYP_MODULE_ENABLED
49#define HAL_DAC_MODULE_ENABLED
50#define HAL_DCMI_MODULE_ENABLED
51#define HAL_DFSDM_MODULE_ENABLED
52#define HAL_DMA_MODULE_ENABLED
53#define HAL_DMA2D_MODULE_ENABLED
54#define HAL_DTS_MODULE_ENABLED
55#define HAL_DSI_MODULE_ENABLED
56#define HAL_ETH_MODULE_ENABLED
57#define HAL_EXTI_MODULE_ENABLED
58#define HAL_FDCAN_MODULE_ENABLED
59#define HAL_FLASH_MODULE_ENABLED
60#define HAL_GFXMMU_MODULE_ENABLED
61#define HAL_FMAC_MODULE_ENABLED
62#define HAL_GPIO_MODULE_ENABLED
63#define HAL_HASH_MODULE_ENABLED
64#define HAL_HCD_MODULE_ENABLED
65#define HAL_HRTIM_MODULE_ENABLED
66#define HAL_HSEM_MODULE_ENABLED
67#define HAL_I2C_MODULE_ENABLED
68#define HAL_I2S_MODULE_ENABLED
69#define HAL_IRDA_MODULE_ENABLED
70#define HAL_IWDG_MODULE_ENABLED
71#define HAL_JPEG_MODULE_ENABLED
72#define HAL_LPTIM_MODULE_ENABLED
73#define HAL_LTDC_MODULE_ENABLED
74#define HAL_MDIOS_MODULE_ENABLED
75#define HAL_MDMA_MODULE_ENABLED
76#define HAL_MMC_MODULE_ENABLED
77#define HAL_NAND_MODULE_ENABLED
78#define HAL_NOR_MODULE_ENABLED
79#define HAL_OPAMP_MODULE_ENABLED
80#define HAL_OSPI_MODULE_ENABLED
81#define HAL_OTFDEC_MODULE_ENABLED
82#define HAL_PCD_MODULE_ENABLED
83#define HAL_PWR_MODULE_ENABLED
84#define HAL_PSSI_MODULE_ENABLED
85#define HAL_QSPI_MODULE_ENABLED
86#define HAL_RAMECC_MODULE_ENABLED
87#define HAL_RCC_MODULE_ENABLED
88#define HAL_RNG_MODULE_ENABLED
89#define HAL_RTC_MODULE_ENABLED
90#define HAL_SAI_MODULE_ENABLED
91#define HAL_SD_MODULE_ENABLED
92#define HAL_SDRAM_MODULE_ENABLED
93#define HAL_SMARTCARD_MODULE_ENABLED
94#define HAL_SMBUS_MODULE_ENABLED
95#define HAL_SPDIFRX_MODULE_ENABLED
96#define HAL_SPI_MODULE_ENABLED
97#define HAL_SRAM_MODULE_ENABLED
98#define HAL_SWPMI_MODULE_ENABLED
99#define HAL_TIM_MODULE_ENABLED
100#define HAL_UART_MODULE_ENABLED
101#define HAL_USART_MODULE_ENABLED
102#define HAL_WWDG_MODULE_ENABLED
103
104/* ########################## Oscillator Values adaptation ####################*/
110#if !defined (HSE_VALUE)
111#define HSE_VALUE (25000000UL)
112#endif /* HSE_VALUE */
113
114#if !defined (HSE_STARTUP_TIMEOUT)
115 #define HSE_STARTUP_TIMEOUT (100UL)
116#endif /* HSE_STARTUP_TIMEOUT */
117
122#if !defined (CSI_VALUE)
123 #define CSI_VALUE (4000000UL)
124#endif /* CSI_VALUE */
125
131#if !defined (HSI_VALUE)
132 #define HSI_VALUE (64000000UL)
133#endif /* HSI_VALUE */
134
139#if !defined (LSE_VALUE)
140 #define LSE_VALUE (32768UL)
141#endif /* LSE_VALUE */
142
143
144#if !defined (LSE_STARTUP_TIMEOUT)
145 #define LSE_STARTUP_TIMEOUT (5000UL)
146#endif /* LSE_STARTUP_TIMEOUT */
147
148#if !defined (LSI_VALUE)
149 #define LSI_VALUE (32000UL)
150#endif /* LSI_VALUE */
159#if !defined (EXTERNAL_CLOCK_VALUE)
160 #define EXTERNAL_CLOCK_VALUE 12288000UL
161#endif /* EXTERNAL_CLOCK_VALUE */
162
163/* Tip: To avoid modifying this file each time you need to use different HSE,
164 === you can define the HSE value in your toolchain compiler preprocessor. */
165
166/* ########################### System Configuration ######################### */
170#define VDD_VALUE (3300UL)
171#define TICK_INT_PRIORITY (0x0FUL)
172#define USE_RTOS 0
173#define USE_SD_TRANSCEIVER 0U
174#define USE_SPI_CRC 1U
176#define USE_HAL_ADC_REGISTER_CALLBACKS 0U /* ADC register callback disabled */
177#define USE_HAL_CEC_REGISTER_CALLBACKS 0U /* CEC register callback disabled */
178#define USE_HAL_COMP_REGISTER_CALLBACKS 0U /* COMP register callback disabled */
179#define USE_HAL_CORDIC_REGISTER_CALLBACKS 0U /* CORDIC register callback disabled */
180#define USE_HAL_CRYP_REGISTER_CALLBACKS 0U /* CRYP register callback disabled */
181#define USE_HAL_DAC_REGISTER_CALLBACKS 0U /* DAC register callback disabled */
182#define USE_HAL_DCMI_REGISTER_CALLBACKS 0U /* DCMI register callback disabled */
183#define USE_HAL_DFSDM_REGISTER_CALLBACKS 0U /* DFSDM register callback disabled */
184#define USE_HAL_DMA2D_REGISTER_CALLBACKS 0U /* DMA2D register callback disabled */
185#define USE_HAL_DSI_REGISTER_CALLBACKS 0U /* DSI register callback disabled */
186#define USE_HAL_DTS_REGISTER_CALLBACKS 0U /* DTS register callback disabled */
187#define USE_HAL_ETH_REGISTER_CALLBACKS 0U /* ETH register callback disabled */
188#define USE_HAL_FDCAN_REGISTER_CALLBACKS 0U /* FDCAN register callback disabled */
189#define USE_HAL_FMAC_REGISTER_CALLBACKS 0U /* FMAC register callback disabled */
190#define USE_HAL_NAND_REGISTER_CALLBACKS 0U /* NAND register callback disabled */
191#define USE_HAL_NOR_REGISTER_CALLBACKS 0U /* NOR register callback disabled */
192#define USE_HAL_SDRAM_REGISTER_CALLBACKS 0U /* SDRAM register callback disabled */
193#define USE_HAL_SRAM_REGISTER_CALLBACKS 0U /* SRAM register callback disabled */
194#define USE_HAL_HASH_REGISTER_CALLBACKS 0U /* HASH register callback disabled */
195#define USE_HAL_HCD_REGISTER_CALLBACKS 0U /* HCD register callback disabled */
196#define USE_HAL_GFXMMU_REGISTER_CALLBACKS 0U /* GFXMMU register callback disabled */
197#define USE_HAL_HRTIM_REGISTER_CALLBACKS 0U /* HRTIM register callback disabled */
198#define USE_HAL_I2C_REGISTER_CALLBACKS 0U /* I2C register callback disabled */
199#define USE_HAL_I2S_REGISTER_CALLBACKS 0U /* I2S register callback disabled */
200#define USE_HAL_IRDA_REGISTER_CALLBACKS 0U /* IRDA register callback disabled */
201#define USE_HAL_JPEG_REGISTER_CALLBACKS 0U /* JPEG register callback disabled */
202#define USE_HAL_LPTIM_REGISTER_CALLBACKS 0U /* LPTIM register callback disabled */
203#define USE_HAL_LTDC_REGISTER_CALLBACKS 0U /* LTDC register callback disabled */
204#define USE_HAL_MDIOS_REGISTER_CALLBACKS 0U /* MDIO register callback disabled */
205#define USE_HAL_MMC_REGISTER_CALLBACKS 0U /* MMC register callback disabled */
206#define USE_HAL_OPAMP_REGISTER_CALLBACKS 0U /* MDIO register callback disabled */
207#define USE_HAL_OSPI_REGISTER_CALLBACKS 0U /* OSPI register callback disabled */
208#define USE_HAL_OTFDEC_REGISTER_CALLBACKS 0U /* OTFDEC register callback disabled */
209#define USE_HAL_PCD_REGISTER_CALLBACKS 0U /* PCD register callback disabled */
210#define USE_HAL_QSPI_REGISTER_CALLBACKS 0U /* QSPI register callback disabled */
211#define USE_HAL_RNG_REGISTER_CALLBACKS 0U /* RNG register callback disabled */
212#define USE_HAL_RTC_REGISTER_CALLBACKS 0U /* RTC register callback disabled */
213#define USE_HAL_SAI_REGISTER_CALLBACKS 0U /* SAI register callback disabled */
214#define USE_HAL_SD_REGISTER_CALLBACKS 0U /* SD register callback disabled */
215#define USE_HAL_SMARTCARD_REGISTER_CALLBACKS 0U /* SMARTCARD register callback disabled */
216#define USE_HAL_SPDIFRX_REGISTER_CALLBACKS 0U /* SPDIFRX register callback disabled */
217#define USE_HAL_SMBUS_REGISTER_CALLBACKS 0U /* SMBUS register callback disabled */
218#define USE_HAL_SPI_REGISTER_CALLBACKS 0U /* SPI register callback disabled */
219#define USE_HAL_SWPMI_REGISTER_CALLBACKS 0U /* SWPMI register callback disabled */
220#define USE_HAL_TIM_REGISTER_CALLBACKS 0U /* TIM register callback disabled */
221#define USE_HAL_UART_REGISTER_CALLBACKS 0U /* UART register callback disabled */
222#define USE_HAL_USART_REGISTER_CALLBACKS 0U /* USART register callback disabled */
223#define USE_HAL_WWDG_REGISTER_CALLBACKS 0U /* WWDG register callback disabled */
224
225/* ########################### Ethernet Configuration ######################### */
226#define ETH_TX_DESC_CNT 4U /* number of Ethernet Tx DMA descriptors */
227#define ETH_RX_DESC_CNT 4U /* number of Ethernet Rx DMA descriptors */
228
229#define ETH_MAC_ADDR0 (0x02UL)
230#define ETH_MAC_ADDR1 (0x00UL)
231#define ETH_MAC_ADDR2 (0x00UL)
232#define ETH_MAC_ADDR3 (0x00UL)
233#define ETH_MAC_ADDR4 (0x00UL)
234#define ETH_MAC_ADDR5 (0x00UL)
235
236/* ########################## Assert Selection ############################## */
241/* #define USE_FULL_ASSERT 1 */
242
243
244/* Includes ------------------------------------------------------------------*/
249#ifdef HAL_RCC_MODULE_ENABLED
250 #include "stm32h7xx_hal_rcc.h"
251#endif /* HAL_RCC_MODULE_ENABLED */
252
253#ifdef HAL_GPIO_MODULE_ENABLED
254 #include "stm32h7xx_hal_gpio.h"
255#endif /* HAL_GPIO_MODULE_ENABLED */
256
257#ifdef HAL_DMA_MODULE_ENABLED
258 #include "stm32h7xx_hal_dma.h"
259#endif /* HAL_DMA_MODULE_ENABLED */
260
261#ifdef HAL_MDMA_MODULE_ENABLED
262 #include "stm32h7xx_hal_mdma.h"
263#endif /* HAL_MDMA_MODULE_ENABLED */
264
265#ifdef HAL_HASH_MODULE_ENABLED
266 #include "stm32h7xx_hal_hash.h"
267#endif /* HAL_HASH_MODULE_ENABLED */
268
269#ifdef HAL_DCMI_MODULE_ENABLED
270 #include "stm32h7xx_hal_dcmi.h"
271#endif /* HAL_DCMI_MODULE_ENABLED */
272
273#ifdef HAL_DMA2D_MODULE_ENABLED
274 #include "stm32h7xx_hal_dma2d.h"
275#endif /* HAL_DMA2D_MODULE_ENABLED */
276
277#ifdef HAL_DSI_MODULE_ENABLED
278 #include "stm32h7xx_hal_dsi.h"
279#endif /* HAL_DSI_MODULE_ENABLED */
280
281#ifdef HAL_DFSDM_MODULE_ENABLED
282 #include "stm32h7xx_hal_dfsdm.h"
283#endif /* HAL_DFSDM_MODULE_ENABLED */
284
285#ifdef HAL_DTS_MODULE_ENABLED
286 #include "stm32h7xx_hal_dts.h"
287#endif /* HAL_DTS_MODULE_ENABLED */
288
289#ifdef HAL_ETH_MODULE_ENABLED
290 #include "stm32h7xx_hal_eth.h"
291#endif /* HAL_ETH_MODULE_ENABLED */
292
293#ifdef HAL_EXTI_MODULE_ENABLED
294 #include "stm32h7xx_hal_exti.h"
295#endif /* HAL_EXTI_MODULE_ENABLED */
296
297#ifdef HAL_CORTEX_MODULE_ENABLED
298 #include "stm32h7xx_hal_cortex.h"
299#endif /* HAL_CORTEX_MODULE_ENABLED */
300
301#ifdef HAL_ADC_MODULE_ENABLED
302 #include "stm32h7xx_hal_adc.h"
303#endif /* HAL_ADC_MODULE_ENABLED */
304
305#ifdef HAL_FDCAN_MODULE_ENABLED
306 #include "stm32h7xx_hal_fdcan.h"
307#endif /* HAL_FDCAN_MODULE_ENABLED */
308
309#ifdef HAL_CEC_MODULE_ENABLED
310 #include "stm32h7xx_hal_cec.h"
311#endif /* HAL_CEC_MODULE_ENABLED */
312
313#ifdef HAL_COMP_MODULE_ENABLED
314 #include "stm32h7xx_hal_comp.h"
315#endif /* HAL_COMP_MODULE_ENABLED */
316
317#ifdef HAL_CORDIC_MODULE_ENABLED
318 #include "stm32h7xx_hal_cordic.h"
319#endif /* HAL_CORDIC_MODULE_ENABLED */
320
321#ifdef HAL_CRC_MODULE_ENABLED
322 #include "stm32h7xx_hal_crc.h"
323#endif /* HAL_CRC_MODULE_ENABLED */
324
325#ifdef HAL_CRYP_MODULE_ENABLED
326 #include "stm32h7xx_hal_cryp.h"
327#endif /* HAL_CRYP_MODULE_ENABLED */
328
329#ifdef HAL_DAC_MODULE_ENABLED
330 #include "stm32h7xx_hal_dac.h"
331#endif /* HAL_DAC_MODULE_ENABLED */
332
333#ifdef HAL_FLASH_MODULE_ENABLED
334 #include "stm32h7xx_hal_flash.h"
335#endif /* HAL_FLASH_MODULE_ENABLED */
336
337#ifdef HAL_GFXMMU_MODULE_ENABLED
338 #include "stm32h7xx_hal_gfxmmu.h"
339#endif /* HAL_GFXMMU_MODULE_ENABLED */
340
341#ifdef HAL_FMAC_MODULE_ENABLED
342 #include "stm32h7xx_hal_fmac.h"
343#endif /* HAL_FMAC_MODULE_ENABLED */
344
345#ifdef HAL_HRTIM_MODULE_ENABLED
346 #include "stm32h7xx_hal_hrtim.h"
347#endif /* HAL_HRTIM_MODULE_ENABLED */
348
349#ifdef HAL_HSEM_MODULE_ENABLED
350 #include "stm32h7xx_hal_hsem.h"
351#endif /* HAL_HSEM_MODULE_ENABLED */
352
353#ifdef HAL_SRAM_MODULE_ENABLED
354 #include "stm32h7xx_hal_sram.h"
355#endif /* HAL_SRAM_MODULE_ENABLED */
356
357#ifdef HAL_NOR_MODULE_ENABLED
358 #include "stm32h7xx_hal_nor.h"
359#endif /* HAL_NOR_MODULE_ENABLED */
360
361#ifdef HAL_NAND_MODULE_ENABLED
362 #include "stm32h7xx_hal_nand.h"
363#endif /* HAL_NAND_MODULE_ENABLED */
364
365#ifdef HAL_I2C_MODULE_ENABLED
366 #include "stm32h7xx_hal_i2c.h"
367#endif /* HAL_I2C_MODULE_ENABLED */
368
369#ifdef HAL_I2S_MODULE_ENABLED
370 #include "stm32h7xx_hal_i2s.h"
371#endif /* HAL_I2S_MODULE_ENABLED */
372
373#ifdef HAL_IWDG_MODULE_ENABLED
374 #include "stm32h7xx_hal_iwdg.h"
375#endif /* HAL_IWDG_MODULE_ENABLED */
376
377#ifdef HAL_JPEG_MODULE_ENABLED
378 #include "stm32h7xx_hal_jpeg.h"
379#endif /* HAL_JPEG_MODULE_ENABLED */
380
381#ifdef HAL_MDIOS_MODULE_ENABLED
382 #include "stm32h7xx_hal_mdios.h"
383#endif /* HAL_MDIOS_MODULE_ENABLED */
384
385#ifdef HAL_MMC_MODULE_ENABLED
386 #include "stm32h7xx_hal_mmc.h"
387#endif /* HAL_MMC_MODULE_ENABLED */
388
389#ifdef HAL_LPTIM_MODULE_ENABLED
390#include "stm32h7xx_hal_lptim.h"
391#endif /* HAL_LPTIM_MODULE_ENABLED */
392
393#ifdef HAL_LTDC_MODULE_ENABLED
394#include "stm32h7xx_hal_ltdc.h"
395#endif /* HAL_LTDC_MODULE_ENABLED */
396
397#ifdef HAL_OPAMP_MODULE_ENABLED
398#include "stm32h7xx_hal_opamp.h"
399#endif /* HAL_OPAMP_MODULE_ENABLED */
400
401#ifdef HAL_OSPI_MODULE_ENABLED
402 #include "stm32h7xx_hal_ospi.h"
403#endif /* HAL_OSPI_MODULE_ENABLED */
404
405#ifdef HAL_OTFDEC_MODULE_ENABLED
406#include "stm32h7xx_hal_otfdec.h"
407#endif /* HAL_OTFDEC_MODULE_ENABLED */
408
409#ifdef HAL_PSSI_MODULE_ENABLED
410 #include "stm32h7xx_hal_pssi.h"
411#endif /* HAL_PSSI_MODULE_ENABLED */
412
413#ifdef HAL_PWR_MODULE_ENABLED
414 #include "stm32h7xx_hal_pwr.h"
415#endif /* HAL_PWR_MODULE_ENABLED */
416
417#ifdef HAL_QSPI_MODULE_ENABLED
418 #include "stm32h7xx_hal_qspi.h"
419#endif /* HAL_QSPI_MODULE_ENABLED */
420
421#ifdef HAL_RAMECC_MODULE_ENABLED
422 #include "stm32h7xx_hal_ramecc.h"
423#endif /* HAL_RAMECC_MODULE_ENABLED */
424
425#ifdef HAL_RNG_MODULE_ENABLED
426 #include "stm32h7xx_hal_rng.h"
427#endif /* HAL_RNG_MODULE_ENABLED */
428
429#ifdef HAL_RTC_MODULE_ENABLED
430 #include "stm32h7xx_hal_rtc.h"
431#endif /* HAL_RTC_MODULE_ENABLED */
432
433#ifdef HAL_SAI_MODULE_ENABLED
434 #include "stm32h7xx_hal_sai.h"
435#endif /* HAL_SAI_MODULE_ENABLED */
436
437#ifdef HAL_SD_MODULE_ENABLED
438 #include "stm32h7xx_hal_sd.h"
439#endif /* HAL_SD_MODULE_ENABLED */
440
441#ifdef HAL_SDRAM_MODULE_ENABLED
442 #include "stm32h7xx_hal_sdram.h"
443#endif /* HAL_SDRAM_MODULE_ENABLED */
444
445#ifdef HAL_SPI_MODULE_ENABLED
446 #include "stm32h7xx_hal_spi.h"
447#endif /* HAL_SPI_MODULE_ENABLED */
448
449#ifdef HAL_SPDIFRX_MODULE_ENABLED
450 #include "stm32h7xx_hal_spdifrx.h"
451#endif /* HAL_SPDIFRX_MODULE_ENABLED */
452
453#ifdef HAL_SWPMI_MODULE_ENABLED
454 #include "stm32h7xx_hal_swpmi.h"
455#endif /* HAL_SWPMI_MODULE_ENABLED */
456
457#ifdef HAL_TIM_MODULE_ENABLED
458 #include "stm32h7xx_hal_tim.h"
459#endif /* HAL_TIM_MODULE_ENABLED */
460
461#ifdef HAL_UART_MODULE_ENABLED
462 #include "stm32h7xx_hal_uart.h"
463#endif /* HAL_UART_MODULE_ENABLED */
464
465#ifdef HAL_USART_MODULE_ENABLED
466 #include "stm32h7xx_hal_usart.h"
467#endif /* HAL_USART_MODULE_ENABLED */
468
469#ifdef HAL_IRDA_MODULE_ENABLED
470 #include "stm32h7xx_hal_irda.h"
471#endif /* HAL_IRDA_MODULE_ENABLED */
472
473#ifdef HAL_SMARTCARD_MODULE_ENABLED
475#endif /* HAL_SMARTCARD_MODULE_ENABLED */
476
477#ifdef HAL_SMBUS_MODULE_ENABLED
478 #include "stm32h7xx_hal_smbus.h"
479#endif /* HAL_SMBUS_MODULE_ENABLED */
480
481#ifdef HAL_WWDG_MODULE_ENABLED
482 #include "stm32h7xx_hal_wwdg.h"
483#endif /* HAL_WWDG_MODULE_ENABLED */
484
485#ifdef HAL_PCD_MODULE_ENABLED
486 #include "stm32h7xx_hal_pcd.h"
487#endif /* HAL_PCD_MODULE_ENABLED */
488
489#ifdef HAL_HCD_MODULE_ENABLED
490 #include "stm32h7xx_hal_hcd.h"
491#endif /* HAL_HCD_MODULE_ENABLED */
492
493/* Exported macro ------------------------------------------------------------*/
494#ifdef USE_FULL_ASSERT
503 #define assert_param(expr) ((expr) ? (void)0U : assert_failed((uint8_t *)__FILE__, __LINE__))
504/* Exported functions ------------------------------------------------------- */
505 void assert_failed(uint8_t *file, uint32_t line);
506#else
507 #define assert_param(expr) ((void)0U)
508#endif /* USE_FULL_ASSERT */
509
510#ifdef __cplusplus
511}
512#endif
513
514#endif /* STM32H7xx_HAL_CONF_H */
515
516
517
Header file of ADC HAL module.
Header file of CEC HAL module.
Header file of COMP HAL module.
This file contains all the functions prototypes for the CORDIC firmware library.
Header file of CORTEX HAL module.
Header file of CRC HAL module.
Header file of CRYP HAL module.
Header file of DAC HAL module.
Header file of DCMI HAL module.
Header file of DFSDM HAL module.
Header file of DMA2D HAL module.
Header file of DMA HAL module.
Header file of DSI HAL module.
Header file of DTS HAL module.
Header file of ETH HAL module.
Header file of EXTI HAL module.
Header file of FDCAN HAL module.
Header file of FLASH HAL module.
Header for stm32h7xx_hal_fmac.c module.
Header file of GFXMMU HAL module.
Header file of GPIO HAL module.
Header file of HASH HAL module.
Header file of HCD HAL module.
Header file of HRTIM HAL module.
Header file of HSEM HAL module.
Header file of I2C HAL module.
Header file of I2S HAL module.
Header file of IRDA HAL module.
Header file of IWDG HAL module.
Header file of JPEG HAL module.
Header file of LPTIM HAL module.
Header file of LTDC HAL module.
Header file of MDIOS HAL module.
Header file of MMC HAL module.
Header file of NAND HAL module.
Header file of NOR HAL module.
Header file of OPAMP HAL module.
Header file of OSPI HAL module.
Header file of OTFDEC HAL module.
Header file of PCD HAL module.
Header file of PSSI HAL module.
Header file of PWR HAL module.
Header file of QSPI HAL module.
Header file of RAMECC HAL module.
Header file of RCC HAL module.
Header file of RNG HAL module.
Header file of RTC HAL module.
Header file of SAI HAL module.
Header file of SD HAL module.
Header file of SDRAM HAL module.
Header file of SMARTCARD HAL module.
Header file of SMBUS HAL module.
Header file of SPDIFRX HAL module.
Header file of SPI HAL module.
Header file of SRAM HAL module.
Header file of SWPMI HAL module.
Header file of TIM HAL module.
Header file of UART HAL module.
Header file of USART HAL module.
Header file of WWDG HAL module.
Definition: mongoose.c:448
