RTEMS 6.1-rc4
Data Structures | Macros | Typedefs | Enumerations | Functions
stm32h7xx_hal_usart.h File Reference
Header file of USART HAL module. More...
#include "stm32h7xx_hal_def.h"
#include "stm32h7xx_hal_usart_ex.h"
struct  USART_InitTypeDef
 USART Init Structure definition. More...
struct  __USART_HandleTypeDef
 USART handle Structure definition. More...
#define HAL_USART_ERROR_NONE   (0x00000000U)
#define HAL_USART_ERROR_PE   (0x00000001U)
#define HAL_USART_ERROR_NE   (0x00000002U)
#define HAL_USART_ERROR_FE   (0x00000004U)
#define HAL_USART_ERROR_ORE   (0x00000008U)
#define HAL_USART_ERROR_DMA   (0x00000010U)
#define HAL_USART_ERROR_UDR   (0x00000020U)
#define HAL_USART_ERROR_RTO   (0x00000080U)
#define USART_STOPBITS_0_5   USART_CR2_STOP_0
#define USART_STOPBITS_1   0x00000000U
#define USART_STOPBITS_1_5   (USART_CR2_STOP_0 | USART_CR2_STOP_1)
#define USART_STOPBITS_2   USART_CR2_STOP_1
#define USART_PARITY_NONE   0x00000000U
#define USART_PARITY_EVEN   USART_CR1_PCE
#define USART_PARITY_ODD   (USART_CR1_PCE | USART_CR1_PS)
#define USART_MODE_RX   USART_CR1_RE
#define USART_MODE_TX   USART_CR1_TE
#define USART_MODE_TX_RX   (USART_CR1_TE |USART_CR1_RE)
#define USART_CLOCK_DISABLE   0x00000000U
#define USART_CLOCK_ENABLE   USART_CR2_CLKEN
#define USART_POLARITY_LOW   0x00000000U
#define USART_POLARITY_HIGH   USART_CR2_CPOL
#define USART_PHASE_1EDGE   0x00000000U
#define USART_PHASE_2EDGE   USART_CR2_CPHA
#define USART_LASTBIT_DISABLE   0x00000000U
#define USART_LASTBIT_ENABLE   USART_CR2_LBCL
#define USART_PRESCALER_DIV1   0x00000000U
#define USART_PRESCALER_DIV2   0x00000001U
#define USART_PRESCALER_DIV4   0x00000002U
#define USART_PRESCALER_DIV6   0x00000003U
#define USART_PRESCALER_DIV8   0x00000004U
#define USART_PRESCALER_DIV10   0x00000005U
#define USART_PRESCALER_DIV12   0x00000006U
#define USART_PRESCALER_DIV16   0x00000007U
#define USART_PRESCALER_DIV32   0x00000008U
#define USART_PRESCALER_DIV64   0x00000009U
#define USART_PRESCALER_DIV128   0x0000000AU
#define USART_PRESCALER_DIV256   0x0000000BU
#define USART_RXDATA_FLUSH_REQUEST   USART_RQR_RXFRQ
#define USART_TXDATA_FLUSH_REQUEST   USART_RQR_TXFRQ
#define USART_FLAG_TXFT   USART_ISR_TXFT
#define USART_FLAG_RXFT   USART_ISR_RXFT
#define USART_FLAG_RXFF   USART_ISR_RXFF
#define USART_FLAG_TXFE   USART_ISR_TXFE
#define USART_FLAG_REACK   USART_ISR_REACK
#define USART_FLAG_TEACK   USART_ISR_TEACK
#define USART_FLAG_BUSY   USART_ISR_BUSY
#define USART_FLAG_UDR   USART_ISR_UDR
#define USART_FLAG_TXE   USART_ISR_TXE_TXFNF
#define USART_FLAG_TXFNF   USART_ISR_TXE_TXFNF
#define USART_FLAG_RTOF   USART_ISR_RTOF
#define USART_FLAG_TC   USART_ISR_TC
#define USART_FLAG_RXNE   USART_ISR_RXNE_RXFNE
#define USART_FLAG_RXFNE   USART_ISR_RXNE_RXFNE
#define USART_FLAG_IDLE   USART_ISR_IDLE
#define USART_FLAG_ORE   USART_ISR_ORE
#define USART_FLAG_NE   USART_ISR_NE
#define USART_FLAG_FE   USART_ISR_FE
#define USART_FLAG_PE   USART_ISR_PE
#define USART_IT_PE   0x0028U
#define USART_IT_TXE   0x0727U
#define USART_IT_TXFNF   0x0727U
#define USART_IT_TC   0x0626U
#define USART_IT_RXNE   0x0525U
#define USART_IT_RXFNE   0x0525U
#define USART_IT_IDLE   0x0424U
#define USART_IT_ERR   0x0060U
#define USART_IT_ORE   0x0300U
#define USART_IT_NE   0x0200U
#define USART_IT_FE   0x0100U
#define USART_IT_RXFF   0x183FU
#define USART_IT_TXFE   0x173EU
#define USART_IT_RXFT   0x1A7CU
#define USART_IT_TXFT   0x1B77U
#define USART_CLEAR_PEF   USART_ICR_PECF
#define USART_CLEAR_FEF   USART_ICR_FECF
#define USART_CLEAR_NEF   USART_ICR_NECF
#define USART_CLEAR_OREF   USART_ICR_ORECF
#define USART_CLEAR_IDLEF   USART_ICR_IDLECF
#define USART_CLEAR_TCF   USART_ICR_TCCF
#define USART_CLEAR_UDRF   USART_ICR_UDRCF
#define USART_CLEAR_TXFECF   USART_ICR_TXFECF
#define USART_CLEAR_RTOF   USART_ICR_RTOCF
#define USART_IT_MASK   0x001FU
#define USART_CR_MASK   0x00E0U
#define USART_CR_POS   5U
#define USART_ISR_MASK   0x1F00U
#define USART_ISR_POS   8U
#define __HAL_USART_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_USART_STATE_RESET)
 Reset USART handle state.
#define __HAL_USART_GET_FLAG(__HANDLE__, __FLAG__)   (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__))
 Check whether the specified USART flag is set or not.
#define __HAL_USART_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->ICR = (__FLAG__))
 Clear the specified USART pending flag.
#define __HAL_USART_CLEAR_PEFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_PEF)
 Clear the USART PE pending flag.
#define __HAL_USART_CLEAR_FEFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_FEF)
 Clear the USART FE pending flag.
#define __HAL_USART_CLEAR_NEFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_NEF)
 Clear the USART NE pending flag.
#define __HAL_USART_CLEAR_OREFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_OREF)
 Clear the USART ORE pending flag.
#define __HAL_USART_CLEAR_IDLEFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_IDLEF)
 Clear the USART IDLE pending flag.
#define __HAL_USART_CLEAR_TXFECF(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_TXFECF)
 Clear the USART TX FIFO empty clear flag.
#define __HAL_USART_CLEAR_UDRFLAG(__HANDLE__)   __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_UDRF)
 Clear SPI slave underrun error flag.
#define __HAL_USART_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enable the specified USART interrupt.
#define __HAL_USART_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disable the specified USART interrupt.
#define __HAL_USART_GET_IT(__HANDLE__, __INTERRUPT__)
 Check whether the specified USART interrupt has occurred or not.
#define __HAL_USART_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified USART interrupt source is enabled or not.
#define __HAL_USART_CLEAR_IT(__HANDLE__, __IT_CLEAR__)   ((__HANDLE__)->Instance->ICR = (uint32_t)(__IT_CLEAR__))
 Clear the specified USART ISR flag, in setting the proper ICR register flag.
#define __HAL_USART_SEND_REQ(__HANDLE__, __REQ__)   ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__))
 Set a specific USART request flag.
#define __HAL_USART_ONE_BIT_SAMPLE_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT)
 Enable the USART one bit sample method.
#define __HAL_USART_ONE_BIT_SAMPLE_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR3 &= ~USART_CR3_ONEBIT)
 Disable the USART one bit sample method.
#define __HAL_USART_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE)
 Enable USART.
#define __HAL_USART_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE)
 Disable USART.
#define USART_GET_DIV_FACTOR(__CLOCKPRESCALER__)
 Get USART clock division factor from clock prescaler value.
#define USART_DIV_SAMPLING8(__PCLK__, __BAUD__, __CLOCKPRESCALER__)
 BRR division operation to set BRR register in 8-bit oversampling mode.
#define USART_GETCLOCKSOURCE(__HANDLE__, __CLOCKSOURCE__)
 Report the USART clock source.
#define IS_USART_BAUDRATE(__BAUDRATE__)   ((__BAUDRATE__) <= 12500000U)
 Check USART Baud rate.
#define IS_USART_STOPBITS(__STOPBITS__)
 Ensure that USART frame number of stop bits is valid.
#define IS_USART_PARITY(__PARITY__)
 Ensure that USART frame parity is valid.
#define IS_USART_MODE(__MODE__)   ((((__MODE__) & 0xFFFFFFF3U) == 0x00U) && ((__MODE__) != 0x00U))
 Ensure that USART communication mode is valid.
#define IS_USART_CLOCK(__CLOCK__)
 Ensure that USART clock state is valid.
#define IS_USART_POLARITY(__CPOL__)   (((__CPOL__) == USART_POLARITY_LOW) || ((__CPOL__) == USART_POLARITY_HIGH))
 Ensure that USART frame polarity is valid.
#define IS_USART_PHASE(__CPHA__)   (((__CPHA__) == USART_PHASE_1EDGE) || ((__CPHA__) == USART_PHASE_2EDGE))
 Ensure that USART frame phase is valid.
#define IS_USART_LASTBIT(__LASTBIT__)
 Ensure that USART frame last bit clock pulse setting is valid.
#define IS_USART_REQUEST_PARAMETER(__PARAM__)
 Ensure that USART request parameter is valid.
#define IS_USART_PRESCALER(__CLOCKPRESCALER__)
 Ensure that USART Prescaler is valid.
typedef struct __USART_HandleTypeDef USART_HandleTypeDef
enum  HAL_USART_StateTypeDef {
  HAL_USART_STATE_RESET = 0x00U , HAL_USART_STATE_READY = 0x01U , HAL_USART_STATE_BUSY = 0x02U , HAL_USART_STATE_BUSY_TX = 0x12U ,
  HAL_USART_STATE_BUSY_RX = 0x22U , HAL_USART_STATE_BUSY_TX_RX = 0x32U , HAL_USART_STATE_TIMEOUT = 0x03U , HAL_USART_STATE_ERROR = 0x04U
 HAL USART State structures definition. More...
enum  USART_ClockSourceTypeDef {
  USART_CLOCKSOURCE_D2PCLK1 = 0x00U , USART_CLOCKSOURCE_D2PCLK2 = 0x01U , USART_CLOCKSOURCE_PLL2 = 0x02U , USART_CLOCKSOURCE_PLL3 = 0x04U ,
  USART_CLOCKSOURCE_HSI = 0x08U , USART_CLOCKSOURCE_CSI = 0x10U , USART_CLOCKSOURCE_LSE = 0x20U , USART_CLOCKSOURCE_UNDEFINED = 0x40U
 USART clock sources definitions. More...
HAL_StatusTypeDef HAL_USART_Init (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USART_DeInit (USART_HandleTypeDef *husart)
void HAL_USART_MspInit (USART_HandleTypeDef *husart)
void HAL_USART_MspDeInit (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USART_Transmit (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_USART_Receive (USART_HandleTypeDef *husart, uint8_t *pRxData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_USART_TransmitReceive (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_USART_Transmit_IT (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint16_t Size)
HAL_StatusTypeDef HAL_USART_Receive_IT (USART_HandleTypeDef *husart, uint8_t *pRxData, uint16_t Size)
HAL_StatusTypeDef HAL_USART_TransmitReceive_IT (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size)
HAL_StatusTypeDef HAL_USART_Transmit_DMA (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint16_t Size)
HAL_StatusTypeDef HAL_USART_Receive_DMA (USART_HandleTypeDef *husart, uint8_t *pRxData, uint16_t Size)
HAL_StatusTypeDef HAL_USART_TransmitReceive_DMA (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size)
HAL_StatusTypeDef HAL_USART_DMAPause (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USART_DMAResume (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USART_DMAStop (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USART_Abort (USART_HandleTypeDef *husart)
HAL_StatusTypeDef HAL_USART_Abort_IT (USART_HandleTypeDef *husart)
void HAL_USART_IRQHandler (USART_HandleTypeDef *husart)
void HAL_USART_TxHalfCpltCallback (USART_HandleTypeDef *husart)
void HAL_USART_TxCpltCallback (USART_HandleTypeDef *husart)
void HAL_USART_RxCpltCallback (USART_HandleTypeDef *husart)
void HAL_USART_RxHalfCpltCallback (USART_HandleTypeDef *husart)
void HAL_USART_TxRxCpltCallback (USART_HandleTypeDef *husart)
void HAL_USART_ErrorCallback (USART_HandleTypeDef *husart)
void HAL_USART_AbortCpltCallback (USART_HandleTypeDef *husart)
HAL_USART_StateTypeDef HAL_USART_GetState (const USART_HandleTypeDef *husart)
uint32_t HAL_USART_GetError (const USART_HandleTypeDef *husart)
Author
MCD Application Team
Attention
