RTEMS 6.1-rc4
This header file provides the Stack Checker API. More...
struct | rtems_stack_checker_info |
Stack information provided by the stack checker. More... | |
#define | RTEMS_STACK_CHECKER_EXTENSION |
Stack Checker Extension Set Definition. | |
Typedefs | |
typedef void(* | rtems_stack_checker_visitor) (const rtems_stack_checker_info *info, void *arg) |
Visitor routines invoked by rtems_stack_checker_iterate() shall have this type. | |
typedef void(* | Stack_checker_Reporter_handler) (const rtems_tcb *running, bool pattern_ok) |
The Stack Checker Reporter Initialization Handler. | |
bool | rtems_stack_checker_is_blown (void) |
Checks if current task is blown its stack. | |
void | rtems_stack_checker_report_usage (void) |
Print the stack usage report using printk. | |
void | rtems_stack_checker_report_usage_with_plugin (const rtems_printer *printer) |
Print the stack usage report using caller's routine. | |
void | rtems_stack_checker_iterate (rtems_stack_checker_visitor visit, void *arg) |
Iterates over all stacks used by the system and invokes the visitor routine for each stack. | |
bool | rtems_stack_checker_create_extension (rtems_tcb *running, rtems_tcb *the_thread) |
Stack Checker Task Create Extension. | |
void | rtems_stack_checker_begin_extension (rtems_tcb *executing) |
void | rtems_stack_checker_switch_extension (rtems_tcb *running, rtems_tcb *heir) |
Stack Checker Task Context Switch Extension. | |
void | rtems_stack_checker_reporter_quiet (const rtems_tcb *running, bool pattern_ok) |
A Quiet Version of Stack Checker Reporter. | |
void | rtems_stack_checker_reporter_print_details (const rtems_tcb *running, bool pattern_ok) |
The Default Function to Report a Blown Stack. | |
const Stack_checker_Reporter_handler | Stack_checker_Reporter |
