#include "chip.h"
#include <stdint.h>
void | SSC_Configure (Ssc *ssc, uint32_t bitRate, uint32_t masterClock) |
| Configures a SSC peripheral.If the divided clock is not used, the master clock frequency can be set to 0.
void | SSC_ConfigureTransmitter (Ssc *ssc, uint32_t tcmr, uint32_t tfmr) |
| Configures the transmitter of a SSC peripheral.
void | SSC_ConfigureReceiver (Ssc *ssc, uint32_t rcmr, uint32_t rfmr) |
| Configures the receiver of a SSC peripheral.
void | SSC_EnableTransmitter (Ssc *ssc) |
| Enables the transmitter of a SSC peripheral.
void | SSC_DisableTransmitter (Ssc *ssc) |
| Disables the transmitter of a SSC peripheral.
void | SSC_EnableReceiver (Ssc *ssc) |
| Enables the receiver of a SSC peripheral.
void | SSC_DisableReceiver (Ssc *ssc) |
| Disables the receiver of a SSC peripheral.
void | SSC_EnableInterrupts (Ssc *ssc, uint32_t sources) |
| Enables one or more interrupt sources of a SSC peripheral.
void | SSC_DisableInterrupts (Ssc *ssc, uint32_t sources) |
| Disables one or more interrupt sources of a SSC peripheral.
void | SSC_Write (Ssc *ssc, uint32_t frame) |
| Sends one data frame through a SSC peripheral. If another frame is currently being sent, this function waits for the previous transfer to complete.
uint32_t | SSC_Read (Ssc *ssc) |
| Waits until one frame is received on a SSC peripheral, and returns it.
uint8_t | SSC_IsRxReady (Ssc *ssc) |
| Return 1 if one frame is received, 0 otherwise.
Interface for Synchronous Serial (SSC) controller.
◆ SSC_Configure()
void SSC_Configure |
Ssc * |
ssc, |
uint32_t |
bitRate, |
uint32_t |
masterClock |
- Note
- The emitter and transmitter are disabled by this function.
- Parameters
ssc | Pointer to an SSC instance. |
bitRate | bit rate. |
masterClock | master clock. |
◆ SSC_ConfigureReceiver()
void SSC_ConfigureReceiver |
Ssc * |
ssc, |
uint32_t |
rcmr, |
uint32_t |
rfmr |
- Parameters
rcmr | Receive Clock Mode Register value. |
rfmr | Receive Frame Mode Register value. |
◆ SSC_ConfigureTransmitter()
void SSC_ConfigureTransmitter |
Ssc * |
ssc, |
uint32_t |
tcmr, |
uint32_t |
tfmr |
- Parameters
tcmr | Transmit Clock Mode Register value. |
tfmr | Transmit Frame Mode Register value. |
◆ SSC_DisableInterrupts()
void SSC_DisableInterrupts |
Ssc * |
ssc, |
uint32_t |
sources |
- Parameters
sources | Bitwise OR of selected interrupt sources. |
◆ SSC_DisableReceiver()
void SSC_DisableReceiver |
Ssc * |
ssc | ) |
- Parameters
◆ SSC_DisableTransmitter()
void SSC_DisableTransmitter |
Ssc * |
ssc | ) |
- Parameters
◆ SSC_EnableInterrupts()
void SSC_EnableInterrupts |
Ssc * |
ssc, |
uint32_t |
sources |
- Parameters
◆ SSC_EnableReceiver()
void SSC_EnableReceiver |
Ssc * |
ssc | ) |
- Parameters
◆ SSC_EnableTransmitter()
void SSC_EnableTransmitter |
Ssc * |
ssc | ) |
- Parameters
◆ SSC_IsRxReady()
uint8_t SSC_IsRxReady |
Ssc * |
ssc | ) |
- Parameters
◆ SSC_Read()
uint32_t SSC_Read |
Ssc * |
ssc | ) |
- Parameters
◆ SSC_Write()
void SSC_Write |
Ssc * |
ssc, |
uint32_t |
frame |
- Parameters
frame | Data frame to send. |
