RTEMS 6.1-rc4
spi-sd-card.h File Reference
SD Card LibI2C driver. More...
#include <stdint.h>
#include <stdbool.h>
#include <rtems/libi2c.h>
struct  sd_card_driver_entry
#define SD_CARD_IDLE_TOKEN   0xff
#define SD_CARD_COMMAND_SIZE   18
#define SD_CARD_TRANSFER_MODE_DEFAULT   { .baudrate = 400000, .bits_per_char = 8, .lsb_first = FALSE, .clock_inv = FALSE, .clock_phs = FALSE, .idle_char = SD_CARD_IDLE_TOKEN }
#define SD_CARD_COMMAND_DEFAULT
#define SD_CARD_N_AC_MAX_DEFAULT   5000
rtems_status_code sd_card_register (void)
sd_card_driver_entry sd_card_driver_table []
size_t sd_card_driver_table_size
◆ SD_CARD_COMMAND_DEFAULT
Value:
SD_CARD_IDLE_TOKEN, \
0x40, 0, 0, 0, 0, 0x95, \
SD_CARD_IDLE_TOKEN, SD_CARD_IDLE_TOKEN, \
SD_CARD_IDLE_TOKEN \
◆ SD_CARD_COMMAND_SIZE
1 idle token before command 6 bytes for the command 1 to 8 bytes for response start (N_CR) 1 to 2 bytes for response 1 idle token after command (minimum N_RC)
