RTEMS 6.1-rc4
This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are only used by the implementation. More...
#define | SCHEDULER_NODE_OF_WAIT_PRIORITY_NODE(node) RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority.Node.Node.Chain ) |
#define | SCHEDULER_NODE_OF_WAIT_PRIORITY(node) RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority ) |
#define | SCHEDULER_PRIORITY_MAP(priority) ( ( priority ) << 1 ) |
Maps a priority value to support the append indicator. | |
#define | SCHEDULER_PRIORITY_UNMAP(priority) ( ( priority ) >> 1 ) |
Returns the plain priority value. | |
#define | SCHEDULER_PRIORITY_PURIFY(priority) ( ( priority ) & ~( (Priority_Control) PRIORITY_GROUP_LAST ) ) |
Clears the priority append indicator bit. | |
#define | SCHEDULER_PRIORITY_APPEND(priority) ( ( priority ) | ( (Priority_Control) PRIORITY_GROUP_LAST ) ) |
Returns the priority control with the append indicator bit set. | |
#define | SCHEDULER_PRIORITY_IS_APPEND(priority) ( ( ( priority ) & ( (Priority_Control) PRIORITY_GROUP_LAST ) ) != 0 ) |
Returns true, if the item should be appended to its priority group, otherwise returns false and the item should be prepended to its priority group. | |
