RTEMS 6.1-rc4
Data Structures | Macros | Typedefs
rtl-indirect-ptr.h File Reference
RTEMS Run-Time Linker Indirect Pointer Management allows memory compaction in the allocator. More...
#include <rtems/chain.h>
struct  rtems_rtl_ptr
struct  rtems_rtl_sptr
struct  rtems_rtl_ptr_chain
struct  rtems_rtl_sptr_chain
#define rtems_rtl_ptr_type_get(_h, _t)   ((_t*) rtems_rtl_ptr_get (_h))
#define rtems_rtl_sptr_type_get(_h, _t)   ((_t*) rtems_rtl_sptr_get (_h))
typedef struct rtems_rtl_ptr rtems_rtl_ptr
typedef struct rtems_rtl_sptr rtems_rtl_sptr
typedef struct rtems_rtl_ptr_chain rtems_rtl_ptr_chain
typedef struct rtems_rtl_sptr_chain rtems_rtl_sptr_chain
◆ rtems_rtl_ptr_type_get
#define rtems_rtl_ptr_type_get (   _h,
  _t
Return the pointer as the type provided.
Parameters
_hThe handle.
_tThe type.
◆ rtems_rtl_sptr_type_get
#define rtems_rtl_sptr_type_get (   _h,
  _t
Parameters
_hThe handle.
_tThe type.
