RTEMS 6.1-rc4
RTEMS File System Mutex. More...
Typedefs | |
typedef uint32_t | rtems_rfs_mutex |
int | rtems_rfs_mutex_create (rtems_rfs_mutex *mutex) |
Create the mutex. | |
int | rtems_rfs_mutex_destroy (rtems_rfs_mutex *mutex) |
Destroy the mutex. | |
It may be suprising we abstract this for the RTEMS file system but this code is designed to be run on host operating systems.
typedef uint32_t rtems_rfs_mutex |
RFS Mutex type.
int rtems_rfs_mutex_create | ( | rtems_rfs_mutex * | mutex | ) |
Create the mutex.
[in] | mutex | is pointer to the mutex handle returned to the caller. |
0 | Successful operation. |
EIO | An error occurred. |
int rtems_rfs_mutex_destroy | ( | rtems_rfs_mutex * | mutex | ) |
Destroy the mutex.
[in] | mutex | Reference to the mutex handle returned to the caller. |
