RTEMS 6.1-rc4
RTEMS File Systems Bitmap Routines. More...
#define | RTEMS_RFS_BITMAP_WARNINGS 0 |
#define | rtems_rfs_bitmap_check(_c, _sm) |
These functions manage bit maps. A bit map consists of the map of bit allocated in a block and a search map where a bit represents 32 actual bits. The search map allows for a faster search for an available bit as 32 search bits can checked in a test.
#define rtems_rfs_bitmap_check | ( | _c, | |
_sm | |||
#define RTEMS_RFS_BITMAP_WARNINGS 0 |
Set to 1 to enable warnings when developing.
int rtems_rfs_bitmap_close | ( | rtems_rfs_bitmap_control * | control | ) |
Close a bitmap.
[in] | control | is the bit map control. |
0 | Successful operation. |
error_code | An error occurred. |
int rtems_rfs_bitmap_create_search | ( | rtems_rfs_bitmap_control * | control | ) |
Create a search bit map from the actual bit map.
[in] | control | is the map control. |
int rtems_rfs_bitmap_map_alloc | ( | rtems_rfs_bitmap_control * | control, |
rtems_rfs_bitmap_bit | seed, | ||
bool * | allocate, | ||
rtems_rfs_bitmap_bit * | bit | ||
Find a free bit searching from the seed up and down until found. The search is performing by moving up from the seed for the window distance then to search down from the seed for the window distance. This is repeated out from the seed for each window until a free bit is found. The search is performed by checking the search map to see if the map has a free bit.
[in] | seed | is the bit to search out from. |
[out] | allocate | A bit was allocated. |
[out] | bit | will contain the bit found free if true is returned. |
int rtems_rfs_bitmap_map_clear | ( | rtems_rfs_bitmap_control * | control, |
rtems_rfs_bitmap_bit | bit | ||
Clear a bit in a map and make sure the search map bit is clear so a search will find this bit available.
[in] | control | is the control for the map. |
[in] | bit | is the bit in the map to clear. |
int rtems_rfs_bitmap_map_clear_all | ( | rtems_rfs_bitmap_control * | control | ) |
Clear all bits in the bitmap and set the dirty bit.
[in] | control | is the bitmap control. |
int rtems_rfs_bitmap_map_set | ( | rtems_rfs_bitmap_control * | control, |
Set a bit in a map and if all the bits are set, set the search map bit as well.
[in] | bit | is the bit in the map to set. |
int rtems_rfs_bitmap_map_set_all | ( | rtems_rfs_bitmap_control * | control | ) |
Set all bits in the bitmap and set the dirty bit.
int rtems_rfs_bitmap_map_test | ( | rtems_rfs_bitmap_control * | control, |
rtems_rfs_bitmap_bit | bit, | ||
bool * | state | ||
Test a bit in the map.
[in] | bit | is the bit to test. |
[in] | state | is the state of the bit if no error is returned. |
rtems_rfs_bitmap_element rtems_rfs_bitmap_mask | ( | unsigned int | size | ) |
Create a bit mask with the specified number of bits up to an element's size. The mask is aligned to bit 0 of the element.
[in] | size | is the number of bits in the mask. |
rtems_rfs_bitmap_element rtems_rfs_bitmap_mask_section | ( | unsigned int | start, |
unsigned int | end | ||
Create a bit mask section. A mask section is a mask that is not aligned to an end of the element.
[in] | start | is the first bit of the mask numbered from 0. |
[in] | end | is the end bit of the mask numbered from 0. |
int rtems_rfs_bitmap_open | ( | rtems_rfs_bitmap_control * | control, |
rtems_rfs_file_system * | fs, | ||
rtems_rfs_buffer_handle * | buffer, | ||
size_t | size, | ||
rtems_rfs_buffer_block | block | ||
Open a bitmap control with a map and search map.
[in] | fs | is the file system data. |
[in] | buffer | is a pointer to the buffer handle the map is stored in. |
[in] | size | is the number of bits in the map. |
