RTEMS 6.1-rc4
RTEMS Flattened Device Tree Shell Command. More...
#include <rtems/rtems-fdt.h>
Typedefs | |
typedef void(* | rtems_fdt_write_handler) (uintptr_t address, uint32_t value) |
typedef uint32_t(* | rtems_fdt_read_handler) (uintptr_t address) |
void | rtems_fdt_add_shell_command (void) |
rtems_fdt_handle * | rtems_fdt_get_shell_handle (void) |
rtems_fdt_write_handler | rtems_fdt_set_shell_write_handler (rtems_fdt_write_handler handler) |
rtems_fdt_read_handler | rtems_fdt_set_shell_read_handler (rtems_fdt_read_handler handler) |
Support for loading, managing and accessing FDT blobs in RTEMS.
typedef uint32_t(* rtems_fdt_read_handler) (uintptr_t address) |
Read handler call to read from the address property.
typedef void(* rtems_fdt_write_handler) (uintptr_t address, uint32_t value) |
Write handler call to write from the address property.
void rtems_fdt_add_shell_command | ( | void | ) |
Add a shell command to access memory and registers associated with the DTF.
rtems_fdt_handle * rtems_fdt_get_shell_handle | ( | void | ) |
Get a pointer to the handle. You can use this to load files or register blobs and have the shell command access them.
rtems_fdt_read_handler rtems_fdt_set_shell_read_handler | ( | rtems_fdt_read_handler | handler | ) |
Set the read handler returning the current handler.
rtems_fdt_write_handler rtems_fdt_set_shell_write_handler | ( | rtems_fdt_write_handler | handler | ) |
Set the write handler returning the current handler.
