RTEMS 6.1-rc4
Macros | Enumerations | Functions
pwmss.h File Reference
Shared PWMSS module functions used by PWM, eQEP and eCAP (when added). More...
#define AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
#define AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE   (0x00000003u)
#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST_FUNC   (0x0u)
#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST   (0x00030000u)
enum  BBB_PWMSS { BBB_PWMSS0 = 0 , BBB_PWMSS1 , BBB_PWMSS2 , BBB_PWMSS_COUNT }
 The set of possible PWM subsystem module. More...
rtems_status_code pwmss_module_clk_config (BBB_PWMSS pwmss_id)
 This function configures the L3 and L4_PER system clocks. It also configures the system clocks for the specified ePWMSS instance.
◆ BBB_PWMSS
enum BBB_PWMSS
Enumerated type to define various instance of pwm module.
◆ pwmss_module_clk_config()
rtems_status_code pwmss_module_clk_config ( BBB_PWMSS  pwmss_id)
Parameters
pwmss_idThe instance number of ePWMSS whose system clocks have to be configured.
'pwmss_id' can take one of the following values: (0 <= pwmss_id <= 2)
Returns
True if successful False if Unsuccessful
