RTEMS 6.1-rc4
Macros | Functions
processormask.h File Reference
This header file provides the interfaces of the Processor Mask. More...
#include <rtems/score/cpu.h>
#include <sys/_bitset.h>
#define __BIT_AND2   BIT_AND2
#define __BIT_CLR   BIT_CLR
#define __BIT_CMP   BIT_CMP
#define __BIT_COPY   BIT_COPY
#define __BIT_COUNT   BIT_COUNT
#define __BITSET_DEFINE   BITSET_DEFINE
#define __BIT_EMPTY   BIT_EMPTY
#define __BIT_FILL   BIT_FILL
#define __BIT_FLS   BIT_FLS
#define __BIT_ISSET   BIT_ISSET
#define __BIT_OR2   BIT_OR2
#define __BIT_OVERLAP   BIT_OVERLAP
#define __BIT_SET   BIT_SET
#define __BIT_SETOF   BIT_SETOF
#define __BIT_SUBSET   BIT_SUBSET
#define __BIT_XOR2   BIT_XOR2
#define __BIT_ZERO   BIT_ZERO
typedef __BITSET_DEFINE (Processor_mask, CPU_MAXIMUM_PROCESSORS) Processor_mask
 A bit map which is large enough to provide one bit for each processor in the system.
