RTEMS
6.1-rc4
include
options.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2020 embedded brains GmbH & Co. KG
13
* Copyright (C) 1989, 2008 On-Line Applications Research Corporation (OAR)
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
38
* This file is part of the RTEMS quality process and was automatically
39
* generated. If you find something that needs to be fixed or
40
* worded better please post a report or patch to an RTEMS mailing list
41
* or raise a bug report:
42
43
* https://www.rtems.org/bugs.html
44
45
* For information on updating and regenerating please refer to the How-To
46
* section in the Software Requirements Engineering chapter of the
47
* RTEMS Software Engineering manual. The manual is provided as a part of
48
* a release. For development sources please refer to the online
49
* documentation at:
50
51
* https://docs.rtems.org
52
53
54
/* Generated from spec:/rtems/option/if/header */
55
56
#ifndef _RTEMS_RTEMS_OPTIONS_H
57
#define _RTEMS_RTEMS_OPTIONS_H
58
59
#include <stdint.h>
60
61
#ifdef __cplusplus
62
extern
"C"
63
#endif
64
65
/* Generated from spec:/rtems/option/if/group */
66
75
/* Generated from spec:/rtems/option/if/default */
76
82
#define RTEMS_DEFAULT_OPTIONS 0x00000000
83
84
/* Generated from spec:/rtems/option/if/event-all */
85
93
#define RTEMS_EVENT_ALL 0x00000000
94
95
/* Generated from spec:/rtems/option/if/event-any */
96
104
#define RTEMS_EVENT_ANY 0x00000002
105
106
/* Generated from spec:/rtems/option/if/no-wait */
107
117
#define RTEMS_NO_WAIT 0x00000001
118
119
/* Generated from spec:/rtems/option/if/option */
120
126
typedef
uint32_t
rtems_option
127
128
/* Generated from spec:/rtems/option/if/wait */
129
139
#define RTEMS_WAIT 0x00000000
140
141
#ifdef __cplusplus
142
143
#endif
144
145
#endif
/* _RTEMS_RTEMS_OPTIONS_H */
rtems_option
uint32_t rtems_option
This type represents a Classic API directive option set.
Definition:
options.h:126
