RTEMS 6.1-rc4
Macros | Typedefs
Directive Options
This group contains the Classic API directive options. More...
#define RTEMS_DEFAULT_OPTIONS   0x00000000
 This option constant represents the default option set.
#define RTEMS_EVENT_ALL   0x00000000
 This option constant indicates that the task wishes to wait until all events of interest are available in rtems_event_receive() and rtems_event_system_receive().
#define RTEMS_EVENT_ANY   0x00000002
 This option constant indicates that the task wishes to wait until at least one of the events of interest is available in rtems_event_receive() and rtems_event_system_receive().
#define RTEMS_NO_WAIT   0x00000001
 This option constant indicates that the task does not want to wait on the resource.
#define RTEMS_WAIT   0x00000000
 This option constant indicates that the task wants to wait on the resource.
typedef uint32_t rtems_option
 This type represents a Classic API directive option set.
◆ RTEMS_NO_WAIT
If the resource is not available, then the directives shall return immediately with a status to indicate that the request is unsatisfied.
◆ RTEMS_WAIT
If the resource is not available, then the task shall block and wait for request completion.
