RTEMS 6.1-rc4
mpu.c File Reference
#include <chip.h>
void MPU_Enable (uint32_t dwMPUEnable)
 Enables the MPU module.
void MPU_SetRegionNum (uint32_t dwRegionNum)
 Set active memory region.
void MPU_DisableRegion (void)
 Disable the current active region.
void MPU_SetRegion (uint32_t dwRegionBaseAddr, uint32_t dwRegionAttr)
 Setup a memory region.
uint32_t MPU_CalMPURegionSize (uint32_t dwActualSizeInBytes)
 Calculate region size for the RASR.
void MPU_UpdateRegions (uint32_t dwRegionNum, uint32_t dwRegionBaseAddr, uint32_t dwRegionAttr)
 Update MPU regions.
◆ MPU_Enable()
void MPU_Enable ( uint32_t  dwMPUEnable)
Parameters
dwMPUEnableEnable/Disable the memory region.
◆ MPU_SetRegion()
void MPU_SetRegion ( uint32_t  dwRegionBaseAddr,
Parameters
dwRegionBaseAddrMemory region base address.
dwRegionAttrMemory region attributes.
◆ MPU_SetRegionNum()
void MPU_SetRegionNum ( uint32_t  dwRegionNum)
Parameters
dwRegionNumThe memory region to be active.
◆ MPU_UpdateRegions()
void MPU_UpdateRegions ( uint32_t  dwRegionNum,
Update MPU regions.
Returns
Unused (ANSI-C compatibility).
