RTEMS 6.1-rc4
This header file provides parts of the application configuration information API. More...
struct | rtems_api_configuration_table |
This structure contains a summary of the Classic API configuration. More... | |
uint32_t | rtems_configuration_get_maximum_barriers (void) |
Gets the resource number of Barrier Manager objects configured for this application. | |
uint32_t | rtems_configuration_get_maximum_message_queues (void) |
Gets the resource number of Message Manager objects configured for this application. | |
uint32_t | rtems_configuration_get_maximum_partitions (void) |
Gets the resource number of Partition Manager objects configured for this application. | |
uint32_t | rtems_configuration_get_maximum_periods (void) |
Gets the resource number of Rate-Monotonic Manager objects configured for this application. | |
uint32_t | rtems_configuration_get_maximum_ports (void) |
Gets the resource number of Dual-Ported Memory Manager objects configured for this application. | |
uint32_t | rtems_configuration_get_maximum_regions (void) |
Gets the resource number of Region Manager objects configured for this application. | |
uint32_t | rtems_configuration_get_maximum_semaphores (void) |
Gets the resource number of Semaphore Manager objects configured for this application. | |
uint32_t | rtems_configuration_get_maximum_tasks (void) |
Gets the resource number of Task Manager objects configured for this application. | |
uint32_t | rtems_configuration_get_maximum_timers (void) |
Gets the resource number of Timer Manager objects configured for this application. | |
const rtems_api_configuration_table * | rtems_configuration_get_rtems_api_configuration (void) |
Gets the Classic API Configuration Table of this application. | |
