RTEMS 6.1-rc4
The Barrier Manager provides a unique synchronization capability which can be used to have a set of tasks block and be unblocked as a set. More...
rtems_status_code | rtems_barrier_create (rtems_name name, rtems_attribute attribute_set, uint32_t maximum_waiters, rtems_id *id) |
Creates a barrier. | |
rtems_status_code | rtems_barrier_ident (rtems_name name, rtems_id *id) |
Identifies a barrier by the object name. | |
rtems_status_code | rtems_barrier_delete (rtems_id id) |
Deletes the barrier. | |
rtems_status_code | rtems_barrier_wait (rtems_id id, rtems_interval timeout) |
Waits at the barrier. | |
rtems_status_code | rtems_barrier_release (rtems_id id, uint32_t *released) |
Releases the barrier. | |
rtems_status_code rtems_barrier_create | ( | rtems_name | name, |
rtems_attribute | attribute_set, | ||
uint32_t | maximum_waiters, | ||
rtems_id * | id | ||
Creates a barrier.
name | is the object name of the barrier. |
attribute_set | is the attribute set of the barrier. |
maximum_waiters | is the maximum count of waiters on an automatic release barrier. |
id | is the pointer to an rtems_id object. When the directive call is successful, the identifier of the created barrier will be stored in this object. |
This directive creates a barrier which resides on the local node. The barrier has the user-defined object name specified in name
and the initial count specified in attribute_set
. The assigned object identifier is returned in id
. This identifier is used to access the barrier with other barrier related directives.
The attribute set specified in attribute_set
is built through a bitwise or of the attribute constants described below. Not all combinations of attributes are allowed. Some attributes are mutually exclusive. If mutually exclusive attributes are combined, the behaviour is undefined. Attributes not mentioned below are not evaluated by this directive and have no effect. Default attributes can be selected by using the RTEMS_DEFAULT_ATTRIBUTES constant.
The barrier class is selected by the mutually exclusive RTEMS_BARRIER_MANUAL_RELEASE and RTEMS_BARRIER_AUTOMATIC_RELEASE attributes.
maximum_waiters
minus one tasks waiting at the barrier. When the maximum_waiters
task invokes the rtems_barrier_wait() directive, the previous maximum_waiters
- 1 tasks are automatically released and the caller returns.RTEMS_SUCCESSFUL | The requested operation was successful. |
RTEMS_INVALID_NAME | The name parameter was invalid. |
RTEMS_INVALID_ADDRESS | The id parameter was NULL. |
RTEMS_INVALID_NUMBER | The maximum_waiters parameter was 0 for an automatic release barrier. |
RTEMS_TOO_MANY | There was no inactive object available to create a barrier. The number of barriers available to the application is configured through the CONFIGURE_MAXIMUM_BARRIERS application configuration option. |
The following constraints apply to this directive:
rtems_status_code rtems_barrier_delete | ( | rtems_id | id | ) |
id | is the barrier identifier. |
This directive deletes the barrier specified by id
. All tasks blocked waiting for the barrier to be released will be readied and returned a status code which indicates that the barrier was deleted.
RTEMS_INVALID_ID | There was no barrier associated with the identifier specified by id . |
rtems_status_code rtems_barrier_ident | ( | rtems_name | name, |
name | is the object name to look up. | |
[out] | id | is the pointer to an rtems_id object. When the directive call is successful, the object identifier of an object with the specified name will be stored in this object. |
This directive obtains a barrier identifier associated with the barrier name specified in name
RTEMS_INVALID_NAME | The name parameter was 0. |
RTEMS_INVALID_NAME | There was no object with the specified name on the local node. |
If the barrier name is not unique, then the barrier identifier will match the first barrier with that name in the search order. However, this barrier identifier is not guaranteed to correspond to the desired barrier.
The objects are searched from lowest to the highest index. Only the local node is searched.
The barrier identifier is used with other barrier related directives to access the barrier.
rtems_status_code rtems_barrier_release | ( | rtems_id | id, |
uint32_t * | released | ||
id | is the barrier identifier. | |
[out] | released | is the pointer to an uint32_t object. When the directive call is successful, the number of released tasks will be stored in this object. |
This directive releases the barrier specified by id
. All tasks waiting at the barrier will be unblocked. The number of released tasks will be returned in released
RTEMS_INVALID_ADDRESS | The released parameter was NULL. |
rtems_status_code rtems_barrier_wait | ( | rtems_id | id, |
rtems_interval | timeout | ||
timeout | is the timeout in clock ticks. Use RTEMS_NO_TIMEOUT to wait potentially forever. |
This directive waits at the barrier specified by id
. The timeout
parameter defines how long the calling task is willing to wait. Use RTEMS_NO_TIMEOUT to wait potentially forever, otherwise set a timeout interval in clock ticks.
Conceptually, the calling task should always be thought of as blocking when it makes this call and being unblocked when the barrier is released. If the barrier is configured for manual release, this rule of thumb will always be valid. If the barrier is configured for automatic release, all callers will block except for the one which trips the automatic release condition.
RTEMS_TIMEOUT | The timeout happened while the calling task was waiting at the barrier. |
RTEMS_OBJECT_WAS_DELETED | The barrier was deleted while the calling task was waiting at the barrier. |
