#define | RTEMS_IDE_SECTOR_BITS 9 |
#define | RTEMS_IDE_SECTOR_SIZE 512 |
#define | RTEMS_IDE_PARTITION_DESCRIPTOR_SIZE 16 |
#define | RTEMS_IDE_PARTITION_MAX_PARTITION_NUMBER 63 |
#define | RTEMS_IDE_PARTITION_MAX_SUB_PARTITION_NUMBER 4 |
#define | RTEMS_IDE_PARTITION_DEV_NAME_LENGTH_MAX 16 |
#define | RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_DATA1 0x55 |
#define | RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_DATA2 0xaa |
#define | RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_OFFSET 0x1fe |
#define | RTEMS_IDE_PARTITION_TABLE_OFFSET 0x1be |
#define | RTEMS_IDE_PARTITION_TABLE_SIZE (4 * 16) |
#define | RTEMS_IDE_PARTITION_BOOTABLE_OFFSET 0 |
#define | RTEMS_IDE_PARTITION_SYS_TYPE_OFFSET 4 |
#define | RTEMS_IDE_PARTITION_START_OFFSET 8 |
#define | RTEMS_IDE_PARTITION_SIZE_OFFSET 12 |
#define | LE_TO_CPU_U16(v) le16toh(v) |
#define | LE_TO_CPU_U32(v) le32toh(v) |
#define | CPU_TO_LE_U16(v) htole16(v) |
#define | CPU_TO_LE_U32(v) htole32(v) |
"MS-DOS-style" Partition Tables Support
