RTEMS 6.1-rc4
Files | Data Structures | Enumerator | Variables
Tempmon
file  fsl_tempmon.h
struct  _tempmon_config
 TEMPMON temperature structure. More...
uint16_t _tempmon_config::frequency
int8_t _tempmon_config::highAlarmTemp
int8_t _tempmon_config::panicAlarmTemp
int8_t _tempmon_config::lowAlarmTemp
Driver version
enum  _tempmon_alarm_mode { kTEMPMON_HighAlarmMode = 0U , kTEMPMON_PanicAlarmMode = 1U , kTEMPMON_LowAlarmMode = 2U }
 TEMPMON alarm mode. More...
typedef struct _tempmon_config tempmon_config_t
typedef enum _tempmon_alarm_mode tempmon_alarm_mode
 TEMPMON alarm mode.
void TEMPMON_Init (TEMPMON_Type *base, const tempmon_config_t *config)
 Initializes the TEMPMON module.
void TEMPMON_Deinit (TEMPMON_Type *base)
 Deinitializes the TEMPMON module.
void TEMPMON_GetDefaultConfig (tempmon_config_t *config)
 Gets the default configuration structure.
float TEMPMON_GetCurrentTemperature (TEMPMON_Type *base)
 Get current temperature with the fused temperature calibration data.
void TEMPMON_SetTempAlarm (TEMPMON_Type *base, int8_t tempVal, tempmon_alarm_mode alarmMode)
 Set the temperature count (raw sensor output) that will generate an alarm interrupt.
#define FSL_TEMPMON_DRIVER_VERSION   (MAKE_VERSION(2, 1, 1))
 TEMPMON driver version.
◆ _tempmon_alarm_mode
TEMPMON alarm mode.
The high alarm temperature interrupt mode.
The panic alarm temperature interrupt mode.
The low alarm temperature interrupt mode.
◆ TEMPMON_Deinit()
void TEMPMON_Deinit ( TEMPMON_Type base)
Parameters
baseTEMPMON base pointer
brief Deinitializes the TEMPMON module.
param base TEMPMON base pointer
◆ TEMPMON_GetCurrentTemperature()
float TEMPMON_GetCurrentTemperature ( TEMPMON_Type base)
Parameters
Returns
current temperature with degrees Celsius.
brief Get current temperature with the fused temperature calibration data.
param base TEMPMON base pointer return current temperature with degrees Celsius.
◆ TEMPMON_GetDefaultConfig()
void TEMPMON_GetDefaultConfig ( tempmon_config_t config)
This function initializes the TEMPMON configuration structure to a default value. The default values are: tempmonConfig->frequency = 0x02U; tempmonConfig->highAlarmTemp = 44U; tempmonConfig->panicAlarmTemp = 90U; tempmonConfig->lowAlarmTemp = 39U;
Parameters
configPointer to a configuration structure.
brief Gets the default configuration structure.
param config Pointer to a configuration structure.
◆ TEMPMON_Init()
void TEMPMON_Init ( TEMPMON_Type base,
const tempmon_config_t config
Parameters
configPointer to configuration structure.
brief Initializes the TEMPMON module.
param base TEMPMON base pointer param config Pointer to configuration structure.
◆ TEMPMON_SetTempAlarm()
void TEMPMON_SetTempAlarm ( TEMPMON_Type base,
int8_t  tempVal,
Parameters
tempValThe alarm temperature with degrees Celsius
alarmModeThe alarm mode.
brief Set the temperature count (raw sensor output) that will generate an alarm interrupt.
param base TEMPMON base pointer param tempVal The alarm temperature with degrees Celsius param alarmMode The alarm mode.
Variable Documentation
◆ frequency
The temperature measure frequency.
◆ highAlarmTemp
The high alarm temperature.
◆ lowAlarmTemp
The low alarm temperature.
◆ panicAlarmTemp
The panic alarm temperature.
