RTEMS 6.1-rc4
Soc_src
struct  _src_setpoint_authentication
 The structure of setpoint authentication. More...
struct  _src_domain_mode_authentication
 The stucture of domain mode authentication. More...
Driver version
enum  _src_core_name { kSRC_CM7Core = 0x1U , kSRC_CM4Core = 0x2U }
 System core. More...
enum  _src_boot_fuse_selection { kSRC_SerialDownloaderBootFlow = 0U , kSRC_NormalBootFlow = 1U }
 The enumeration of the boot fuse selection. More...
enum  _src_global_system_reset_source {
  kSRC_WdogReset = 0U , kSRC_Wdog3Reset = 2U , kSRC_Wdog4Reset = 4U , kSRC_M4LockUpReset = 6U ,
  kSRC_M7LockUpReset = 8U , kSRC_M4RequestReset = 10U , kSRC_M7RequestReset = 12U , kSRC_TempsenseReset = 14U ,
  kSRC_CSUReset = 16U , kSRC_JageSoftwareReset = 18U , kSRC_OverVoltageReset = 20U
 The enumeration of global system reset sources. More...
enum  _src_global_system_reset_status_flags {
  kSRC_M7CoreIppResetFlag = 1UL << 0UL , kSRC_M7CoreM7RequestResetFlag = 1UL << 1UL , kSRC_M7CoreM7LockUpResetFlag = 1UL << 2UL , kSRC_M7CoreCSUResetFlag = 1UL << 3UL ,
  kSRC_M7CoreIppUserResetFlag = 1UL << 4UL , kSRC_M7CoreWdogResetFlag = 1UL << 5UL , kSRC_M7CoreJtagResetFlag = 1UL << 6UL , kSRC_M7CoreJtagSWResetFlag = 1UL << 7UL ,
  kSRC_M7CoreWdog3ResetFlag = 1UL << 8UL , kSRC_M7CoreWdog4ResetFlag = 1UL << 9UL , kSRC_M7CoreTempsenseResetFlag = 1UL << 10UL , kSRC_M7CoreM4RequestResetFlag = 1UL << 11UL ,
  kSRC_M7CoreM4LockUpResetFlag = 1UL << 12UL , kSRC_M7CoreOverVoltageResetFlag = 1UL << 13UL , kSRC_M7CoreCdogResetFlag = 1UL << 14UL , kSRC_M4CoreIppResetFlag = 1UL << 16UL ,
  kSRC_M4CoreM4RequestResetFlag = 1UL << 17UL , kSRC_M4CoreM4LockUpResetFlag = 1UL << 18UL , kSRC_M4CoreCSUResetFlag = 1UL << 19UL , kSRC_M4CoreIppUserResetFlag = 1UL << 20UL ,
  kSRC_M4CoreWdogResetFlag = 1UL << 21UL , kSRC_M4CoreJtagResetFlag = 1UL << 22UL , kSRC_M4CoreJtagSWResetFlag = 1UL << 23UL , kSRC_M4CoreWdog3ResetFlag = 1UL << 24UL ,
  kSRC_M4CoreWdog4ResetFlag = 1UL << 25UL , kSRC_M4CoreTempsenseResetFlag = 1UL << 26UL , kSRC_M4CoreM7RequestResetFlag = 1UL << 27UL , kSRC_M4CoreM7LockUpResetFlag = 1UL << 28UL ,
  kSRC_M4CoreOverVoltageResetFlag = 1UL << 29UL , kSRC_M4CoreCdogResetFlag = 1UL << 30UL
 The enumeration of reset status flags. More...
enum  _src_global_system_reset_mode { kSRC_ResetSystem = 0x0U , kSRC_DoNotResetSystem = 0x3U }
 The enumeration of global system reset mode. More...
enum  _src_reset_slice_name {
  kSRC_MegaSlice = 0x0U , kSRC_DisplaySlice = 0x1U , kSRC_WakeUpSlice = 0x2U , kSRC_LpsrSlice = 0x3U ,
  kSRC_M4CoreSlice = 0x4U , kSRC_M7CoreSlice = 0x5U , kSRC_M4DebugSlice = 0x6U , kSRC_M7DebugSlice = 0x7U ,
  kSRC_Usbphy1Slice = 0x8U , kSRC_Usbphy2Slice = 0x9U
 The enumeration of the slice name. More...
enum  _src_domain_mode_selection {
  kSRC_Cpu0RunModeAssertReset = 1UL << 0UL , kSRC_Cpu0WaitModeAssertReset = 1UL << 1UL , kSRC_Cpu0StopModeAssertReset = 1UL << 2UL , kSRC_Cpu0SuspendModeAssertReset = 1UL << 3UL ,
  kSRC_Cpu1RunModeAssertReset = 1UL << 4UL , kSRC_Cpu1WaitModeAssertReset = 1UL << 5UL , kSRC_Cpu1StopModeAssertReset = 1UL << 6UL , kSRC_Cpu1SuspendModeAssertReset = 1UL << 7UL
 The enumeration of the domain mode. More...
enum  _src_setpoint_selection {
  kSRC_SetPoint0AssertReset = 1UL << 0UL , kSRC_SetPoint1AssertReset = 1UL << 1UL , kSRC_SetPoint2AssertReset = 1UL << 2UL , kSRC_SetPoint3AssertReset = 1UL << 3UL ,
  kSRC_SetPoint4AssertReset = 1UL << 4UL , kSRC_SetPoint5AssertReset = 1UL << 5UL , kSRC_SetPoint6AssertReset = 1UL << 6UL , kSRC_SetPoint7AssertReset = 1UL << 7UL ,
  kSRC_SetPoint8AssertReset = 1UL << 8UL , kSRC_SetPoint9AssertReset = 1UL << 9UL , kSRC_SetPoint10AssertReset = 1UL << 10UL , kSRC_SetPoint11AssertReset = 1UL << 11UL ,
  kSRC_SetPoint12AssertReset = 1UL << 12UL , kSRC_SetPoint13AssertReset = 1UL << 13UL , kSRC_SetPoint14AssertReset = 1UL << 14UL , kSRC_SetPoint15AssertReset = 1UL << 15UL
 The enumeration of setpoint. More...
enum  _src_general_purpose_register_index {
  kSRC_GeneralPurposeRegister1 = 0U , kSRC_GeneralPurposeRegister2 , kSRC_GeneralPurposeRegister3 , kSRC_GeneralPurposeRegister4 ,
  kSRC_GeneralPurposeRegister5 , kSRC_GeneralPurposeRegister6 , kSRC_GeneralPurposeRegister7 , kSRC_GeneralPurposeRegister8 ,
  kSRC_GeneralPurposeRegister9 , kSRC_GeneralPurposeRegister10 , kSRC_GeneralPurposeRegister11 , kSRC_GeneralPurposeRegister12 ,
  kSRC_GeneralPurposeRegister13 , kSRC_GeneralPurposeRegister14 , kSRC_GeneralPurposeRegister15 , kSRC_GeneralPurposeRegister16 ,
  kSRC_GeneralPurposeRegister17 , kSRC_GeneralPurposeRegister18 , kSRC_GeneralPurposeRegister19 , kSRC_GeneralPurposeRegister20
 The index of each general purpose register. More...
enum  _src_slice_reset_source { kSRC_SoftwareReset = SRC_SLICE_STAT_RST_BY_SW_MASK , kSRC_PowerModeTransferReset = SRC_SLICE_STAT_RST_BY_HW_MASK }
 The enumeration of the reset source of each slice. More...
enum  _src_slice_reset_state { kSRC_SliceResetFinished = 0U , kSRC_SliceResetInProcess = 1U }
 The enumeration of the reset state of each slice. More...
typedef enum _src_core_name src_core_name_t
 System core.
typedef enum _src_boot_fuse_selection src_boot_fuse_selection_t
typedef enum _src_global_system_reset_source src_global_system_reset_source_t
typedef enum _src_global_system_reset_mode src_global_system_reset_mode_t
typedef enum _src_reset_slice_name src_reset_slice_name_t
typedef enum _src_general_purpose_register_index src_general_purpose_register_index_t
typedef struct _src_setpoint_authentication src_setpoint_authentication_t
typedef struct _src_domain_mode_authentication src_domain_mode_authentication_t
typedef enum _src_slice_reset_state src_slice_reset_state_t
#define FSL_SRC_DRIVER_VERSION   (MAKE_VERSION(2, 1, 1))
 SRC driver version 2.1.1.
#define SRC_SLICE_ADDRESS_OFFSET   (0x200U)
#define SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET   (0x0U)
#define SRC_SLICE_CONTROL_REGISTER_OFFSET   (0x4U)
#define SRC_SLICE_SETPOINT_CONFIG_REGISTER_OFFSET   (0x8U)
#define SRC_SLICE_DOMAIN_CONFIG_REGISTER_OFFSET   (0x0CU)
#define SRC_SLICE_STATUS_REGISTER_OFFSET   (0x10U)
#define SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, registerOffset)    (((uint32_t)base) + SRC_SLICE_ADDRESS_OFFSET + ((uint32_t)(sliceName) << 5UL) + (registerOffset))
#define SRC_SLICE_STAT_UNDER_RST_MASK   (0x1U)
#define SRC_SLICE_STAT_RST_BY_HW_MASK   (0x4U)
#define SRC_SLICE_STAT_RST_BY_SW_MASK   (0x8U)
#define SRC_WHITE_LIST_VALUE(coreName)   (1UL << (uint32_t)(coreName))
#define SRC_ASSIGN_LIST_VALUE(coreName)   (1UL << (uint32_t)(coreName))
#define SRC_SLICE_AUTHEN_DOMAIN_MODE_MASK   (0x1U)
#define SRC_SLICE_AUTHEN_SETPOINT_MODE_MASK   (0x2U)
#define SRC_SLICE_AUTHEN_LOCK_MODE_MASK   (0x80U)
#define SRC_SLICE_AUTHEN_LOCK_MODE_SHIFT   (7U)
#define SRC_SLICE_AUTHEN_LOCK_MODE(x)    (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_LOCK_MODE_SHIFT)) & SRC_SLICE_AUTHEN_LOCK_MODE_MASK)
#define SRC_SLICE_AUTHEN_ASSIGN_LIST_MASK   (0xF00U)
#define SRC_SLICE_AUTHEN_ASSIGN_LIST_SHIFT   (8U)
#define SRC_SLICE_AUTHEN_ASSIGN_LIST(x)    (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_ASSIGN_LIST_SHIFT)) & SRC_SLICE_AUTHEN_ASSIGN_LIST_MASK)
#define SRC_SLICE_AUTHEN_LOCK_ASSIGN_MASK   (0x8000U)
#define SRC_SLICE_AUTHEN_LOCK_ASSIGN_SHIFT   (15)
#define SRC_SLICE_AUTHEN_LOCK_ASSIGN(x)    (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_LOCK_ASSIGN_SHIFT)) & SRC_SLICE_AUTHEN_LOCK_ASSIGN_MASK)
#define SRC_SLICE_AUTHEN_WHITE_LIST_MASK   (0xF0000U)
#define SRC_SLICE_AUTHEN_WHITE_LIST_SHIFT   (16U)
#define SRC_SLICE_AUTHEN_WHITE_LIST(x)    (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_WHITE_LIST_SHIFT)) & SRC_SLICE_AUTHEN_WHITE_LIST_MASK)
#define SRC_SLICE_AUTHEN_LOCK_LIST_MASK   (0x800000U)
#define SRC_SLICE_AUTHEN_LOCK_LIST_SHIFT   (23U)
#define SRC_SLICE_AUTHEN_LOCK_LIST(x)    (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_LOCK_LIST_SHIFT)) & SRC_SLICE_AUTHEN_LOCK_LIST_MASK)
#define SRC_SLICE_AUTHEN_USER_MASK   (0x1000000U)
#define SRC_SLICE_AUTHEN_USER_SHIFT   (24U)
#define SRC_SLICE_AUTHEN_USER(x)    (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_USER_SHIFT)) & SRC_SLICE_AUTHEN_USER_MASK)
#define SRC_SLICE_AUTHEN_NONSECURE_MASK   (0x2000000U)
#define SRC_SLICE_AUTHEN_NONSECURE_SHIFT   (25U)
#define SRC_SLICE_AUTHEN_NONSECURE(x)    (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_NONSECURE_SHIFT)) & SRC_SLICE_AUTHEN_NONSECURE_MASK)
#define SRC_SLICE_AUTHEN_LOCK_SETTING_MASK   (0x80000000U)
#define SRC_SLICE_AUTHEN_LOCK_SETTING_SHIFT   (31U)
#define SRC_SLICE_AUTHEN_LOCK_SETTING(x)    (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_LOCK_SETTING_SHIFT)) & SRC_SLICE_AUTHEN_LOCK_SETTING_MASK)
Core Reset release
void SRC_ReleaseCoreReset (SRC_Type *base, src_core_name_t coreName)
 Releases related core reset operation.
Global System Related Interfaces
void SRC_SetGlobalSystemResetMode (SRC_Type *base, src_global_system_reset_source_t resetSource, src_global_system_reset_mode_t resetMode)
 Sets the reset mode of global system reset source.
Slice Software Reset Related Interfaces
void SRC_AssertSliceSoftwareReset (SRC_Type *base, src_reset_slice_name_t sliceName)
 Asserts software reset for the selected slice.
Slice Low-Power Mode Transition Related Interfaces
void SRC_SetSliceSetPointConfig (SRC_Type *base, src_reset_slice_name_t sliceName, uint32_t setpointConfig)
 Sets setpoint configuration for the selected reset slice.
void SRC_SetSliceDomainModeConfig (SRC_Type *base, src_reset_slice_name_t sliceName, uint32_t domainConfig)
 Sets domain mode configuration for the selected reset slice.
void SRC_LockSliceMode (SRC_Type *base, src_reset_slice_name_t sliceName)
 Locks the value of SETPOINT_MODE and DOMAIN_MODE for the selected reset slice.
Get Slice Reset State
src_slice_reset_state_t SRC_GetSliceResetState (SRC_Type *base, src_reset_slice_name_t sliceName)
 Gets the reset state of the selected slice.
◆ _src_boot_fuse_selection
The Boot flow jumps directly to the serial downloader.
kSRC_NormalBootFlow
The Boot flow follows the Normal Boot flow.
◆ _src_core_name
System core.
kSRC_CM7Core
System Core CM4.
kSRC_CM4Core
System Core CM7.
◆ _src_domain_mode_selection
CPU0 in run mode will assert slice reset.
CPU0 in wait mode will assert reset.
CPU0 in stop mode will assert reset.
CPU0 in suspend mode will assert reset.
CPU1 in run mode will assert slice reset.
CPU1 in wait mode will assert reset.
CPU1 in stop mode will assert reset.
CPU1 in suspend mode will assert reset.
◆ _src_general_purpose_register_index
The index of General Purpose Register1.
The index of General Purpose Register2.
The index of General Purpose Register3.
The index of General Purpose Register4.
The index of General Purpose Register5.
The index of General Purpose Register6.
The index of General Purpose Register7.
The index of General Purpose Register8.
The index of General Purpose Register9.
The index of General Purpose Register10.
The index of General Purpose Register11.
The index of General Purpose Register12.
The index of General Purpose Register13.
The index of General Purpose Register14.
The index of General Purpose Register15.
The index of General Purpose Register16.
The index of General Purpose Register17.
The index of General Purpose Register18.
The index of General Purpose Register19.
The index of General Purpose Register20.
◆ _src_global_system_reset_mode
kSRC_ResetSystem
Generate the global system reset.
Do not generate the global system reset.
◆ _src_global_system_reset_source
kSRC_WdogReset
WDOG triggers the global system reset.
kSRC_Wdog3Reset
WDOG3 triggers the global system reset.
kSRC_Wdog4Reset
WODG4 triggers the global system reset.
kSRC_M4LockUpReset
M4 core lockup triggers the global system reset.
kSRC_M7LockUpReset
M7 core lockup triggers the global system reset.
kSRC_M4RequestReset
M4 core request triggers the global system reset.
kSRC_M7RequestReset
M7 core request triggers the global system reset.
kSRC_TempsenseReset
Tempsense trigggers the global system reset.
kSRC_CSUReset
CSU triggers the global system reset.
JATG software triggers the global system reset.
Over voltage triggers the global system reset.
◆ _src_global_system_reset_status_flags
The M7 Core reset is the result of ipp_reset_b pin.
The M7 Core reset is the result of M7 core reset request.
The M7 Core reset is the result of M7 core lock up.
The M7 Core reset is the result of csu_reset_b input.
The M7 Core reset is the result of ipp_user_reset_b qualified reset.
The M7 Core reset is the result of the watchdog time-out event.
The M7 Core reset is the result of HIGH-Z reset from JTAG.
The M7 Core reset is the result of software reset from JTAG.
The M7 Core reset is the result of watchdog3 time-out event.
The M7 Core reset is the result of watchdog4 time-out event.
The M7 Core reset is the result of on-chip temperature sensor.
The M7 Core reset is the result of M4 CPU reset request.
The M7 Core reset is the result of M4 CPU lock up.
The M7 Core reset is the result of over voltage.
The M7 Core reset is the result of Cdog.
The M4 Core reset is the result of ipp_reset_b pin.
The M4 Core reset is the result of M4 core reset request.
The M4 Core reset is the result of M4 core lock up.
The M4 Core reset is the result of csu_reset_b input.
The M4 Core reset is the result of ipp_user_reset_b qualified reset.
The M4 Core reset is the result of the watchdog time-out event.
The M4 Core reset is the result of HIGH-Z reset from JTAG.
The M4 Core reset is the result of software reset from JTAG.
The M4 Core reset is the result of watchdog3 time-out event.
The M4 Core reset is the result of watchdog4 time-out event.
The M4 Core reset is the result of on-chip temperature sensor.
The M4 Core reset is the result of M7 CPU reset request.
The M4 Core reset is the result of M7 CPU lock up.
The M4 Core reset is the result of over voltage.
The M4 Core reset is the result of Cdog.
◆ _src_reset_slice_name
kSRC_MegaSlice
Megamix reset slice.
kSRC_DisplaySlice
Displaymix reset slice.
kSRC_WakeUpSlice
Wakeupmix reset slice.
kSRC_LpsrSlice
Lpsrmix reset slice.
kSRC_M4CoreSlice
M4 core reset slice.
kSRC_M7CoreSlice
M7 core reset slice.
kSRC_M4DebugSlice
M4 debug reset slice.
kSRC_M7DebugSlice
M7 debug reset slice.
kSRC_Usbphy1Slice
USBPHY1 reset slice.
kSRC_Usbphy2Slice
USBPHY2 reset slice.
◆ _src_setpoint_selection
In setpoint0 will assert slice reset.
In setpoint1 will assert slice reset.
In setpoint2 will assert slice reset.
In setpoint3 will assert slice reset.
In setpoint4 will assert slice reset.
In setpoint5 will assert slice reset.
In setpoint6 will assert slice reset.
In setpoint7 will assert slice reset.
In setpoint8 will assert slice reset.
In setpoint9 will assert slice reset.
In setpoint10 will assert slice reset.
In setpoint11 will assert slice reset.
In setpoint12 will assert slice reset.
In setpoint13 will assert slice reset.
In setpoint14 will assert slice reset.
In setpoint15 will assert slice reset.
◆ _src_slice_reset_source
kSRC_SoftwareReset
Reset is caused by software setting.
Reset is caused by the power mode transfer.
◆ _src_slice_reset_state
The reset is finished.
The reset is in process.
◆ SRC_AssertSliceSoftwareReset()
void SRC_AssertSliceSoftwareReset ( SRC_Type base,
Note
This function will return as soon as the resset is finished.
Parameters
baseSRC peripheral base address.
sliceNameThe slice to be reset. See src_reset_slice_name_t for more details.
brief Asserts software reset for the selected slice.
param base SRC peripheral base address. param sliceName The selected reset slice. See src_reset_slice_name_t for more details.
◆ SRC_GetSliceResetState()
src_slice_reset_state_t SRC_GetSliceResetState ( SRC_Type base,
Parameters
sliceNameThe selected slice. See src_reset_slice_name_t for more details.
Return values
kSRC_SliceResetInProcessThe reset is in process.
kSRC_SliceResetFinishedThe reset is finished.
brief Gets the reset state of the selected slice.
param base SRC peripheral base address. param sliceName The selected slice. See src_reset_slice_name_t for more details. retval kSRC_SliceResetInProcess The reset is in process. retval kSRC_SliceResetFinished The reset is finished.
◆ SRC_LockSliceMode()
void SRC_LockSliceMode ( SRC_Type base,
Parameters
sliceNameThe selected reset slice. See src_reset_slice_name_t for more details.
brief Locks the value of SETPOINT_MODE and DOMAIN_MODE for the selected reset slice.
◆ SRC_ReleaseCoreReset()
void SRC_ReleaseCoreReset ( SRC_Type base,
The core reset will be held until the boot core to release it.
Parameters
coreNameThe name of the reset core to be released.
brief Release related core reset operation.
The core reset will be held until boot core to release it.
param base SRC peripheral base address. param coreName The name of the reset core to be released.
◆ SRC_SetGlobalSystemResetMode()
void SRC_SetGlobalSystemResetMode ( SRC_Type base,
This function sets the selected mode of the input global system reset sources.
Parameters
resetSourceThe global system reset source. See src_global_system_reset_source_t for more details.
resetModeThe reset mode of each reset source. See src_global_system_reset_mode_t for more details.
brief Sets the reset mode of global system reset source.
This function sets the selected mode of the input global system reset sources. This function will return as soon as the reset if finished.
param base SRC peripheral base address. param resetSource The global system reset source. See src_global_system_reset_source_t for more details. param resetMode The reset mode of each reset source. See src_global_system_reset_mode_t for more details.
◆ SRC_SetSliceDomainModeConfig()
void SRC_SetSliceDomainModeConfig ( SRC_Type base,
Parameters
domainConfigThe logic OR'ed value of _src_domain_mode_selection enumerations.
brief Sets domain mode configuration for the selected reset slice.
param base SRC peripheral base address. param sliceName The selected reset slice. See src_reset_slice_name_t for more details. param domainConfig The logic OR'ed value of _src_domain_mode_selection.
◆ SRC_SetSliceSetPointConfig()
void SRC_SetSliceSetPointConfig ( SRC_Type base,
Parameters
setpointConfigThe logic OR'ed value of _src_setpoint_selection enumeration, when the system in the selected setpoint slice reset will be asserted.
brief Sets setpoint configuration for the selected reset slice.
param base SRC peripheral base address. param sliceName The selected reset slice. See src_reset_slice_name_t for more details. param setPointConfig The logic OR'ed value of _src_setpoint_selection. When the system in the selected setpoint slice reset will be assert.
