RTEMS 6.1-rc4
Pit
struct  _pit_config
 PIT configuration structure. More...
Driver version
enum  _pit_chnl { kPIT_Chnl_0 = 0U , kPIT_Chnl_1 , kPIT_Chnl_2 , kPIT_Chnl_3 }
 List of PIT channels. More...
enum  _pit_interrupt_enable { kPIT_TimerInterruptEnable = PIT_TCTRL_TIE_MASK }
 List of PIT interrupts. More...
enum  _pit_status_flags { kPIT_TimerFlag = PIT_TFLG_TIF_MASK }
 List of PIT status flags. More...
typedef enum _pit_chnl pit_chnl_t
typedef enum _pit_interrupt_enable pit_interrupt_enable_t
typedef enum _pit_status_flags pit_status_flags_t
typedef struct _pit_config pit_config_t
#define FSL_PIT_DRIVER_VERSION   (MAKE_VERSION(2, 0, 4))
 PIT Driver Version 2.0.4.
Initialization and deinitialization
void PIT_Init (PIT_Type *base, const pit_config_t *config)
 Ungates the PIT clock, enables the PIT module, and configures the peripheral for basic operations.
void PIT_Deinit (PIT_Type *base)
 Gates the PIT clock and disables the PIT module.
Typedef Documentation
◆ pit_chnl_t
Note
Actual number of available channels is SoC dependent
◆ pit_config_t
This structure holds the configuration settings for the PIT peripheral. To initialize this structure to reasonable defaults, call the PIT_GetDefaultConfig() function and pass a pointer to your config structure instance.
The configuration structure can be made constant so it resides in flash.
◆ _pit_chnl
enum _pit_chnl
Note
kPIT_Chnl_0
PIT channel number 0
kPIT_Chnl_1
PIT channel number 1
kPIT_Chnl_2
PIT channel number 2
kPIT_Chnl_3
PIT channel number 3
◆ _pit_interrupt_enable
Timer interrupt enable
◆ _pit_status_flags
kPIT_TimerFlag
Timer flag
◆ PIT_Deinit()
void PIT_Deinit ( PIT_Type base)
Parameters
basePIT peripheral base address
brief Gates the PIT clock and disables the PIT module.
param base PIT peripheral base address
◆ PIT_Init()
void PIT_Init ( PIT_Type base,
const pit_config_t config
Note
This API should be called at the beginning of the application using the PIT driver.
Parameters
configPointer to the user's PIT config structure
brief Ungates the PIT clock, enables the PIT module, and configures the peripheral for basic operations.
note This API should be called at the beginning of the application using the PIT driver.
param base PIT peripheral base address param config Pointer to the user's PIT config structure
