RTEMS 6.1-rc4
Mecc
struct  _mecc_config
 MECC user configuration. More...
struct  _mecc_single_error_info
 MECC ocram single error information, including single error address, ECC code, error data and error bit position. More...
struct  _mecc_multi_error_info
 MECC ocram multiple error information, including multiple error address, ECC code, error data. More...
Driver version
enum  { kStatus_MECC_BankMiss = MAKE_STATUS(kStatusGroup_MECC, 0) }
 Error codes for the MECC driver. More...
enum  {
  kMECC_SingleError0InterruptEnable , kMECC_SingleError1InterruptEnable , kMECC_SingleError2InterruptEnable , kMECC_SingleError3InterruptEnable ,
  kMECC_MultiError0InterruptEnable , kMECC_MultiError1InterruptEnable , kMECC_MultiError2InterruptEnable , kMECC_MultiError3InterruptEnable ,
  kMECC_StrobeError0InterruptEnable , kMECC_StrobeError1InterruptEnable , kMECC_StrobeError2InterruptEnable , kMECC_StrobeError3InterruptEnable ,
  kMECC_AccessError0InterruptEnable , kMECC_AccessError1InterruptEnable , kMECC_AccessError2InterruptEnable , kMECC_AccessError3InterruptEnable ,
  kMECC_AllInterruptsEnable = 0xFFFF
 MECC interrupt configuration structure, default settings all disabled. More...
enum  {
  kMECC_SingleError0InterruptStatusEnable , kMECC_SingleError1InterruptStatusEnable , kMECC_SingleError2InterruptStatusEnable , kMECC_SingleError3InterruptStatusEnable ,
  kMECC_MultiError0InterruptStatusEnable , kMECC_MultiError1InterruptStatusEnable , kMECC_MultiError2InterruptStatusEnable , kMECC_MultiError3InterruptStatusEnable ,
  kMECC_StrobeError0InterruptStatusEnable , kMECC_StrobeError1InterruptStatusEnable , kMECC_StrobeError2InterruptStatusEnable , kMECC_StrobeError3InterruptStatusEnable ,
  kMECC_AccessError0InterruptStatusEnable , kMECC_AccessError1InterruptStatusEnable , kMECC_AccessError2InterruptStatusEnable , kMECC_AccessError3InterruptStatusEnable ,
  kMECC_AllInterruptsStatusEnable = 0xFFFF
 MECC interrupt status configuration structure, default settings all disabled. More...
enum  {
  kMECC_SingleError0InterruptFlag , kMECC_SingleError1InterruptFlag , kMECC_SingleError2InterruptFlag , kMECC_SingleError3InterruptFlag ,
  kMECC_MultiError0InterruptFlag , kMECC_MultiError1InterruptFlag , kMECC_MultiError2InterruptFlag , kMECC_MultiError3InterruptFlag ,
  kMECC_StrobeError0InterruptFlag , kMECC_StrobeError1InterruptFlag , kMECC_StrobeError2InterruptFlag , kMECC_StrobeError3InterruptFlag ,
  kMECC_AccessError0InterruptFlag = MECC_ERR_STATUS_ADDR_ERR0_MASK , kMECC_AccessError1InterruptFlag = MECC_ERR_STATUS_ADDR_ERR1_MASK , kMECC_AccessError2InterruptFlag = MECC_ERR_STATUS_ADDR_ERR2_MASK , kMECC_AccessError3InterruptFlag = MECC_ERR_STATUS_ADDR_ERR3_MASK ,
  kMECC_AllInterruptsFlag = 0xFFFF
 MECC status flags. More...
enum  { kMECC_OcramBank0 = 0U , kMECC_OcramBank1 = 1U , kMECC_OcramBank2 = 2U , kMECC_OcramBank3 = 3U }
 MECC ocram bank number. More...
enum  { kMECC_Instance0 = 0U , kMECC_Instance1 = 1U }
 MECC instance. More...
typedef struct _mecc_config mecc_config_t
typedef struct _mecc_single_error_info mecc_single_error_info_t
typedef struct _mecc_multi_error_info mecc_multi_error_info_t
#define FSL_MECC_DRIVER_VERSION   (MAKE_VERSION(2U, 0U, 2U))
 Driver version 2.0.2.
Initialization and deinitialization
void MECC_Init (MECC_Type *base, mecc_config_t *config)
 MECC module initialization function.
void MECC_Deinit (MECC_Type *base)
 Deinitializes the MECC.
void MECC_GetDefaultConfig (mecc_config_t *config)
 Sets the MECC configuration structure to default values.
functional
status_t MECC_ErrorInjection (MECC_Type *base, uint32_t lowerrordata, uint32_t higherrordata, uint8_t eccdata, uint8_t banknumber)
 MECC module error injection.
status_t MECC_GetSingleErrorInfo (MECC_Type *base, mecc_single_error_info_t *info, uint8_t banknumber)
 MECC module get single error information.
status_t MECC_GetMultiErrorInfo (MECC_Type *base, mecc_multi_error_info_t *info, uint8_t banknumber)
 MECC module get multiple error information.
◆ anonymous enum
anonymous enum
Ocram bank miss
◆ anonymous enum
anonymous enum
This structure contains the settings for all of the MECC interrupt configurations.
Single Bit Error On Ocram Bank0 interrupt enable.
Single Bit Error On Ocram Bank1 interrupt enable
Single Bit Error On Ocram Bank2 interrupt enable
Single Bit Error On Ocram Bank3 interrupt enable
Multiple Bits Error On Ocram Bank0 interrupt enable
Multiple Bits Error On Ocram Bank1 interrupt enable
Multiple Bits Error On Ocram Bank2 interrupt enable
Multiple Bits Error On Ocram Bank3 interrupt enable
AXI Strobe Error On Ocram Bank0 interrupt enable
AXI Strobe Error On Ocram Bank1 interrupt enable
AXI Strobe Error On Ocram Bank2 interrupt enable
AXI Strobe Error On Ocram Bank3 interrupt enable
Ocram Access Error On Bank0 interrupt enable
Ocram Access Error On Bank1 interrupt enable
Ocram Access Error On Bank2 interrupt enable
Ocram Access Error On Bank3 interrupt enable
all interrupts enable
◆ anonymous enum
anonymous enum
This structure contains the settings for all of the MECC interrupt status configurations.
Single Bit Error On Ocram Bank0 interrupt status enable.
Single Bit Error On Ocram Bank1 interrupt status enable
Single Bit Error On Ocram Bank2 interrupt status enable
Single Bit Error On Ocram Bank3 interrupt status enable
Multiple Bits Error On Ocram Bank0 interrupt status enable
Multiple Bits Error On Ocram Bank1 interrupt status enable
Multiple Bits Error On Ocram Bank2 interrupt status enable
Multiple Bits Error On Ocram Bank3 interrupt status enable
AXI Strobe Error On Ocram Bank0 interrupt status enable
AXI Strobe Error On Ocram Bank1 interrupt status enable
AXI Strobe Error On Ocram Bank2 interrupt status enable
AXI Strobe Error On Ocram Bank3 interrupt status enable
Ocram Access Error On Bank0 interrupt status enable
Ocram Access Error On Bank1 interrupt status enable
Ocram Access Error On Bank2 interrupt status enable
Ocram Access Error On Bank3 interrupt status enable
◆ anonymous enum
anonymous enum
MECC status flags.
This provides constants for the MECC status flags for use in the MECC functions.
Single Bit Error On Ocram Bank0 interrupt flag
Single Bit Error On Ocram Bank1 interrupt flag
Single Bit Error On Ocram Bank2 interrupt flag
Single Bit Error On Ocram Bank3 interrupt flag
Multiple Bits Error On Ocram Bank0 interrupt flag
Multiple Bits Error On Ocram Bank1 interrupt flag
Multiple Bits Error On Ocram Bank2 interrupt flag
Multiple Bits Error On Ocram Bank3 interrupt flag
AXI Strobe Error On Ocram Bank0 interrupt flag
AXI Strobe Error On Ocram Bank1 interrupt flag
AXI Strobe Error On Ocram Bank2 interrupt flag
AXI Strobe Error On Ocram Bank3 interrupt flag
Ocram Access Error On Bank0 interrupt flag
Ocram Access Error On Bank1 interrupt flag
Ocram Access Error On Bank2 interrupt flag
Ocram Access Error On Bank3 interrupt flag
all interrupts interrupt flag
◆ anonymous enum
anonymous enum
kMECC_OcramBank0
ocram bank number 0: ocram_base_address+0x20*i
kMECC_OcramBank1
ocram bank number 1: ocram_base_address+0x20*i+0x8
kMECC_OcramBank2
ocram bank number 2: ocram_base_address+0x20*i+0x10
kMECC_OcramBank3
ocram bank number 3: ocram_base_address+0x20*i+0x18
◆ anonymous enum
anonymous enum
MECC instance.
kMECC_Instance0
Peripheral MECC1 base
kMECC_Instance1
Peripheral MECC2 base
◆ MECC_Deinit()
void MECC_Deinit ( MECC_Type base)
Parameters
baseMECC base address.
brief Deinitializes the MECC.
◆ MECC_ErrorInjection()
status_t MECC_ErrorInjection ( MECC_Type base,
uint8_t  eccdata,
uint8_t  banknumber
Parameters
lowerrordatalow 32 bits data.
higherrordatahigh 32 bits data.
eccdataecc code.
banknumberocram bank number.
Return values
kStatus_Success.
Bank0: ocram_base_address+0x20*i Bank1: ocram_base_address+0x20*i+0x8 Bank2: ocram_base_address+0x20*i+0x10 Bank3: ocram_base_address+0x20*i+0x18 i = 0,1,2,3,4.....
◆ MECC_GetDefaultConfig()
void MECC_GetDefaultConfig ( mecc_config_t config)
Parameters
configpointer to the MECC configuration structure.
◆ MECC_GetMultiErrorInfo()
status_t MECC_GetMultiErrorInfo ( MECC_Type base,
mecc_multi_error_info_t info,
uint8_t  banknumber
Parameters
infomultiple error information.
Return values
kStatus_Success.
kStatus_MECC_BankMiss.
◆ MECC_GetSingleErrorInfo()
status_t MECC_GetSingleErrorInfo ( MECC_Type base,
mecc_single_error_info_t info,
uint8_t  banknumber
Parameters
infosingle error information.
Return values
kStatus_Success.
◆ MECC_Init()
void MECC_Init ( MECC_Type base,
Parameters
brief MECC module initialization function.
param base MECC base address.
