RTEMS 6.1-rc4
Modules | Functions | Variables
Lpi2c
 Lpi2c_master_driver
 Lpi2c_slave_driver
uint32_t LPI2C_GetInstance (LPI2C_Type *base)
 Returns an instance number given a base address.
IRQn_Type const kLpi2cIrqs []
 Array to map LPI2C instance number to IRQ number, used internally for LPI2C master interrupt and EDMA transactional APIs.
lpi2c_master_isr_t s_lpi2cMasterIsr
 Pointer to master IRQ handler for each instance, used internally for LPI2C master interrupt and EDMA transactional APIs.
void * s_lpi2cMasterHandle []
 Pointers to master handles for each instance, used internally for LPI2C master interrupt and EDMA transactional APIs.
Driver version
enum  {
  kStatus_LPI2C_Busy = MAKE_STATUS(kStatusGroup_LPI2C, 0) , kStatus_LPI2C_Idle = MAKE_STATUS(kStatusGroup_LPI2C, 1) , kStatus_LPI2C_Nak = MAKE_STATUS(kStatusGroup_LPI2C, 2) , kStatus_LPI2C_FifoError = MAKE_STATUS(kStatusGroup_LPI2C, 3) ,
  kStatus_LPI2C_BitError = MAKE_STATUS(kStatusGroup_LPI2C, 4) , kStatus_LPI2C_ArbitrationLost = MAKE_STATUS(kStatusGroup_LPI2C, 5) , kStatus_LPI2C_PinLowTimeout , kStatus_LPI2C_NoTransferInProgress ,
  kStatus_LPI2C_DmaRequestFail = MAKE_STATUS(kStatusGroup_LPI2C, 8) , kStatus_LPI2C_Timeout = MAKE_STATUS(kStatusGroup_LPI2C, 9)
 LPI2C status return codes. More...
#define FSL_LPI2C_DRIVER_VERSION   (MAKE_VERSION(2, 4, 1))
 LPI2C driver version.
#define I2C_RETRY_TIMES   0U /* Define to zero means keep waiting until the flag is assert/deassert. */
 Retry times for waiting flag.
◆ anonymous enum
anonymous enum
kStatus_LPI2C_Busy
The master is already performing a transfer.
kStatus_LPI2C_Idle
The slave driver is idle.
kStatus_LPI2C_Nak
The slave device sent a NAK in response to a byte.
FIFO under run or overrun.
Transferred bit was not seen on the bus.
Arbitration lost error.
SCL or SDA were held low longer than the timeout.
Attempt to abort a transfer when one is not in progress.
DMA request failed.
Timeout polling status flags.
◆ LPI2C_GetInstance()
uint32_t LPI2C_GetInstance ( LPI2C_Type base)
If an invalid base address is passed, debug builds will assert. Release builds will just return instance number 0.
Parameters
baseThe LPI2C peripheral base address.
Returns
LPI2C instance number starting from 0.
brief Returns an instance number given a base address.
param base The LPI2C peripheral base address. return LPI2C instance number starting from 0.
Variable Documentation
◆ kLpi2cIrqs
IRQn_Type const kLpi2cIrqs[]
extern
◆ s_lpi2cMasterHandle
void* s_lpi2cMasterHandle[]
extern
◆ s_lpi2cMasterIsr
extern
