RTEMS 6.1-rc4
Data Structures | Enumerator | Variables
Flexio_driver
struct  _flexio_config_
 Define FlexIO user configuration structure. More...
struct  _flexio_timer_config
 Define FlexIO timer configuration structure. More...
struct  _flexio_shifter_config
 Define FlexIO shifter configuration structure. More...
bool _flexio_config_::enableFlexio
bool _flexio_config_::enableInDoze
bool _flexio_config_::enableInDebug
bool _flexio_config_::enableFastAccess
uint32_t _flexio_timer_config::triggerSelect
flexio_timer_trigger_polarity_t _flexio_timer_config::triggerPolarity
flexio_timer_trigger_source_t _flexio_timer_config::triggerSource
flexio_pin_config_t _flexio_timer_config::pinConfig
uint32_t _flexio_timer_config::pinSelect
flexio_pin_polarity_t _flexio_timer_config::pinPolarity
flexio_timer_mode_t _flexio_timer_config::timerMode
flexio_timer_output_t _flexio_timer_config::timerOutput
flexio_timer_decrement_source_t _flexio_timer_config::timerDecrement
flexio_timer_reset_condition_t _flexio_timer_config::timerReset
flexio_timer_disable_condition_t _flexio_timer_config::timerDisable
flexio_timer_enable_condition_t _flexio_timer_config::timerEnable
flexio_timer_stop_bit_condition_t _flexio_timer_config::timerStop
flexio_timer_start_bit_condition_t _flexio_timer_config::timerStart
uint32_t _flexio_timer_config::timerCompare
uint32_t _flexio_shifter_config::timerSelect
flexio_shifter_timer_polarity_t _flexio_shifter_config::timerPolarity
flexio_pin_config_t _flexio_shifter_config::pinConfig
uint32_t _flexio_shifter_config::pinSelect
flexio_pin_polarity_t _flexio_shifter_config::pinPolarity
flexio_shifter_mode_t _flexio_shifter_config::shifterMode
flexio_shifter_input_source_t _flexio_shifter_config::inputSource
flexio_shifter_stop_bit_t _flexio_shifter_config::shifterStop
flexio_shifter_start_bit_t _flexio_shifter_config::shifterStart
Driver version
enum  _flexio_timer_trigger_polarity { kFLEXIO_TimerTriggerPolarityActiveHigh = 0x0U , kFLEXIO_TimerTriggerPolarityActiveLow = 0x1U }
 Define time of timer trigger polarity. More...
enum  _flexio_timer_trigger_source { kFLEXIO_TimerTriggerSourceExternal = 0x0U , kFLEXIO_TimerTriggerSourceInternal = 0x1U }
 Define type of timer trigger source. More...
enum  _flexio_pin_config { kFLEXIO_PinConfigOutputDisabled = 0x0U , kFLEXIO_PinConfigOpenDrainOrBidirection = 0x1U , kFLEXIO_PinConfigBidirectionOutputData = 0x2U , kFLEXIO_PinConfigOutput = 0x3U }
 Define type of timer/shifter pin configuration. More...
enum  _flexio_pin_polarity { kFLEXIO_PinActiveHigh = 0x0U , kFLEXIO_PinActiveLow = 0x1U }
 Definition of pin polarity. More...
enum  _flexio_timer_mode { kFLEXIO_TimerModeDisabled = 0x0U , kFLEXIO_TimerModeDual8BitBaudBit = 0x1U , kFLEXIO_TimerModeDual8BitPWM = 0x2U , kFLEXIO_TimerModeSingle16Bit = 0x3U }
 Define type of timer work mode. More...
enum  _flexio_timer_output { kFLEXIO_TimerOutputOneNotAffectedByReset = 0x0U , kFLEXIO_TimerOutputZeroNotAffectedByReset = 0x1U , kFLEXIO_TimerOutputOneAffectedByReset = 0x2U , kFLEXIO_TimerOutputZeroAffectedByReset = 0x3U }
 Define type of timer initial output or timer reset condition. More...
enum  _flexio_timer_decrement_source { kFLEXIO_TimerDecSrcOnFlexIOClockShiftTimerOutput = 0x0U , kFLEXIO_TimerDecSrcOnTriggerInputShiftTimerOutput , kFLEXIO_TimerDecSrcOnPinInputShiftPinInput , kFLEXIO_TimerDecSrcOnTriggerInputShiftTriggerInput }
 Define type of timer decrement. More...
enum  _flexio_timer_reset_condition {
  kFLEXIO_TimerResetNever = 0x0U , kFLEXIO_TimerResetOnTimerPinEqualToTimerOutput = 0x2U , kFLEXIO_TimerResetOnTimerTriggerEqualToTimerOutput = 0x3U , kFLEXIO_TimerResetOnTimerPinRisingEdge = 0x4U ,
  kFLEXIO_TimerResetOnTimerTriggerRisingEdge = 0x6U , kFLEXIO_TimerResetOnTimerTriggerBothEdge = 0x7U
 Define type of timer reset condition. More...
enum  _flexio_timer_disable_condition {
  kFLEXIO_TimerDisableNever = 0x0U , kFLEXIO_TimerDisableOnPreTimerDisable = 0x1U , kFLEXIO_TimerDisableOnTimerCompare = 0x2U , kFLEXIO_TimerDisableOnTimerCompareTriggerLow = 0x3U ,
  kFLEXIO_TimerDisableOnPinBothEdge = 0x4U , kFLEXIO_TimerDisableOnPinBothEdgeTriggerHigh = 0x5U , kFLEXIO_TimerDisableOnTriggerFallingEdge = 0x6U
 Define type of timer disable condition. More...
enum  _flexio_timer_enable_condition {
  kFLEXIO_TimerEnabledAlways = 0x0U , kFLEXIO_TimerEnableOnPrevTimerEnable = 0x1U , kFLEXIO_TimerEnableOnTriggerHigh = 0x2U , kFLEXIO_TimerEnableOnTriggerHighPinHigh = 0x3U ,
  kFLEXIO_TimerEnableOnPinRisingEdge = 0x4U , kFLEXIO_TimerEnableOnPinRisingEdgeTriggerHigh = 0x5U , kFLEXIO_TimerEnableOnTriggerRisingEdge = 0x6U , kFLEXIO_TimerEnableOnTriggerBothEdge = 0x7U
 Define type of timer enable condition. More...
enum  _flexio_timer_stop_bit_condition { kFLEXIO_TimerStopBitDisabled = 0x0U , kFLEXIO_TimerStopBitEnableOnTimerCompare = 0x1U , kFLEXIO_TimerStopBitEnableOnTimerDisable = 0x2U , kFLEXIO_TimerStopBitEnableOnTimerCompareDisable = 0x3U }
 Define type of timer stop bit generate condition. More...
enum  _flexio_timer_start_bit_condition { kFLEXIO_TimerStartBitDisabled = 0x0U , kFLEXIO_TimerStartBitEnabled = 0x1U }
 Define type of timer start bit generate condition. More...
enum  _flexio_timer_output_state { kFLEXIO_PwmLow = 0 , kFLEXIO_PwmHigh }
 FlexIO as PWM channel output state. More...
enum  _flexio_shifter_timer_polarity { kFLEXIO_ShifterTimerPolarityOnPositive = 0x0U , kFLEXIO_ShifterTimerPolarityOnNegitive = 0x1U }
 Define type of timer polarity for shifter control. More...
enum  _flexio_shifter_mode {
  kFLEXIO_ShifterDisabled = 0x0U , kFLEXIO_ShifterModeReceive = 0x1U , kFLEXIO_ShifterModeTransmit = 0x2U , kFLEXIO_ShifterModeMatchStore = 0x4U ,
  kFLEXIO_ShifterModeMatchContinuous = 0x5U
 Define type of shifter working mode. More...
enum  _flexio_shifter_input_source { kFLEXIO_ShifterInputFromPin = 0x0U , kFLEXIO_ShifterInputFromNextShifterOutput = 0x1U }
 Define type of shifter input source. More...
enum  _flexio_shifter_stop_bit { kFLEXIO_ShifterStopBitDisable = 0x0U , kFLEXIO_ShifterStopBitLow = 0x2U , kFLEXIO_ShifterStopBitHigh = 0x3U }
 Define of STOP bit configuration. More...
enum  _flexio_shifter_start_bit { kFLEXIO_ShifterStartBitDisabledLoadDataOnEnable = 0x0U , kFLEXIO_ShifterStartBitDisabledLoadDataOnShift = 0x1U , kFLEXIO_ShifterStartBitLow = 0x2U , kFLEXIO_ShifterStartBitHigh = 0x3U }
 Define type of START bit configuration. More...
enum  _flexio_shifter_buffer_type { kFLEXIO_ShifterBuffer = 0x0U , kFLEXIO_ShifterBufferBitSwapped = 0x1U , kFLEXIO_ShifterBufferByteSwapped = 0x2U , kFLEXIO_ShifterBufferBitByteSwapped = 0x3U }
 Define FlexIO shifter buffer type. More...
typedef enum _flexio_timer_trigger_polarity flexio_timer_trigger_polarity_t
typedef enum _flexio_timer_trigger_source flexio_timer_trigger_source_t
typedef enum _flexio_pin_config flexio_pin_config_t
typedef enum _flexio_pin_polarity flexio_pin_polarity_t
typedef enum _flexio_timer_mode flexio_timer_mode_t
typedef enum _flexio_timer_output flexio_timer_output_t
typedef enum _flexio_timer_decrement_source flexio_timer_decrement_source_t
typedef enum _flexio_timer_reset_condition flexio_timer_reset_condition_t
typedef enum _flexio_timer_disable_condition flexio_timer_disable_condition_t
typedef enum _flexio_timer_enable_condition flexio_timer_enable_condition_t
typedef enum _flexio_timer_stop_bit_condition flexio_timer_stop_bit_condition_t
typedef enum _flexio_timer_start_bit_condition flexio_timer_start_bit_condition_t
typedef enum _flexio_timer_output_state flexio_timer_output_state_t
typedef enum _flexio_shifter_timer_polarity flexio_shifter_timer_polarity_t
typedef enum _flexio_shifter_mode flexio_shifter_mode_t
typedef enum _flexio_shifter_input_source flexio_shifter_input_source_t
typedef enum _flexio_shifter_stop_bit flexio_shifter_stop_bit_t
typedef enum _flexio_shifter_start_bit flexio_shifter_start_bit_t
typedef enum _flexio_shifter_buffer_type flexio_shifter_buffer_type_t
typedef struct _flexio_config_ flexio_config_t
typedef struct _flexio_timer_config flexio_timer_config_t
typedef struct _flexio_shifter_config flexio_shifter_config_t
typedef void(* flexio_isr_t) (void *base, void *handle)
 typedef for FlexIO simulated driver interrupt handler.
FLEXIO_Type *const s_flexioBases []
 Pointers to flexio bases for each instance.
const clock_ip_name_t s_flexioClocks []
 Pointers to flexio clocks for each instance.
#define FSL_FLEXIO_DRIVER_VERSION   (MAKE_VERSION(2, 1, 0))
 FlexIO driver version.
#define FLEXIO_TIMER_TRIGGER_SEL_PININPUT(x)   ((uint32_t)(x) << 1U)
 Calculate FlexIO timer trigger.
#define FLEXIO_TIMER_TRIGGER_SEL_SHIFTnSTAT(x)   (((uint32_t)(x) << 2U) | 0x1U)
#define FLEXIO_TIMER_TRIGGER_SEL_TIMn(x)   (((uint32_t)(x) << 2U) | 0x3U)
FlexIO Initialization and De-initialization
void FLEXIO_GetDefaultConfig (flexio_config_t *userConfig)
 Gets the default configuration to configure the FlexIO module. The configuration can used directly to call the FLEXIO_Configure().
void FLEXIO_Init (FLEXIO_Type *base, const flexio_config_t *userConfig)
 Configures the FlexIO with a FlexIO configuration. The configuration structure can be filled by the user or be set with default values by FLEXIO_GetDefaultConfig().
void FLEXIO_Deinit (FLEXIO_Type *base)
 Gates the FlexIO clock. Call this API to stop the FlexIO clock.
uint32_t FLEXIO_GetInstance (FLEXIO_Type *base)
 Get instance number for FLEXIO module.
FlexIO Basic Operation
void FLEXIO_Reset (FLEXIO_Type *base)
 Resets the FlexIO module.
void FLEXIO_SetShifterConfig (FLEXIO_Type *base, uint8_t index, const flexio_shifter_config_t *shifterConfig)
 Configures the shifter with the shifter configuration. The configuration structure covers both the SHIFTCTL and SHIFTCFG registers. To configure the shifter to the proper mode, select which timer controls the shifter to shift, whether to generate start bit/stop bit, and the polarity of start bit and stop bit.
void FLEXIO_SetTimerConfig (FLEXIO_Type *base, uint8_t index, const flexio_timer_config_t *timerConfig)
 Configures the timer with the timer configuration. The configuration structure covers both the TIMCTL and TIMCFG registers. To configure the timer to the proper mode, select trigger source for timer and the timer pin output and the timing for timer.
FlexIO DMA Operation
uint32_t FLEXIO_GetShifterBufferAddress (FLEXIO_Type *base, flexio_shifter_buffer_type_t type, uint8_t index)
 Gets the shifter buffer address for the DMA transfer usage.
status_t FLEXIO_RegisterHandleIRQ (void *base, void *handle, flexio_isr_t isr)
 Registers the handle and the interrupt handler for the FlexIO-simulated peripheral.
status_t FLEXIO_UnregisterHandleIRQ (void *base)
 Unregisters the handle and the interrupt handler for the FlexIO-simulated peripheral.
◆ _flexio_pin_config
Pin output disabled.
Pin open drain or bidirectional output enable.
Pin bidirectional output data.
Pin output.
◆ _flexio_pin_polarity
Active high.
Active low.
◆ _flexio_shifter_buffer_type
Shifter Buffer N Register.
Shifter Buffer N Bit Byte Swapped Register.
Shifter Buffer N Byte Swapped Register.
Shifter Buffer N Bit Swapped Register.
◆ _flexio_shifter_input_source
Shifter input from pin.
Shifter input from Shifter N+1.
◆ _flexio_shifter_mode
Shifter is disabled.
Receive mode.
Transmit mode.
Match store mode.
Match continuous mode.
◆ _flexio_shifter_start_bit
Disable shifter start bit, transmitter loads data on enable.
Disable shifter start bit, transmitter loads data on first shift.
Set shifter start bit to logic low level.
Set shifter start bit to logic high level.
◆ _flexio_shifter_stop_bit
Disable shifter stop bit.
Set shifter stop bit to logic low level.
Set shifter stop bit to logic high level.
◆ _flexio_shifter_timer_polarity
Shift on positive edge of shift clock.
Shift on negative edge of shift clock.
◆ _flexio_timer_decrement_source
Decrement counter on FlexIO clock, Shift clock equals Timer output.
Decrement counter on Trigger input (both edges), Shift clock equals Timer output.
Decrement counter on Pin input (both edges), Shift clock equals Pin input.
Decrement counter on Trigger input (both edges), Shift clock equals Trigger input.
◆ _flexio_timer_disable_condition
Timer never disabled.
Timer disabled on Timer N-1 disable.
Timer disabled on Timer compare.
Timer disabled on Timer compare and Trigger Low.
Timer disabled on Pin rising or falling edge.
Timer disabled on Pin rising or falling edge provided Trigger is high.
Timer disabled on Trigger falling edge.
◆ _flexio_timer_enable_condition
Timer always enabled.
Timer enabled on Timer N-1 enable.
Timer enabled on Trigger high.
Timer enabled on Trigger high and Pin high.
Timer enabled on Pin rising edge.
Timer enabled on Pin rising edge and Trigger high.
Timer enabled on Trigger rising edge.
Timer enabled on Trigger rising or falling edge.
◆ _flexio_timer_mode
Timer Disabled.
Dual 8-bit counters baud/bit mode.
Dual 8-bit counters PWM mode.
Single 16-bit counter mode.
◆ _flexio_timer_output
Logic one when enabled and is not affected by timer reset.
Logic zero when enabled and is not affected by timer reset.
Logic one when enabled and on timer reset.
Logic zero when enabled and on timer reset.
◆ _flexio_timer_output_state
kFLEXIO_PwmLow
The output state of PWM channel is low
kFLEXIO_PwmHigh
The output state of PWM channel is high
◆ _flexio_timer_reset_condition
Timer never reset.
Timer reset on Timer Pin equal to Timer Output.
Timer reset on Timer Trigger equal to Timer Output.
Timer reset on Timer Pin rising edge.
Timer reset on Trigger rising edge.
Timer reset on Trigger rising or falling edge.
◆ _flexio_timer_start_bit_condition
Start bit disabled.
Start bit enabled.
◆ _flexio_timer_stop_bit_condition
Stop bit disabled.
Stop bit is enabled on timer compare.
Stop bit is enabled on timer disable.
Stop bit is enabled on timer compare and timer disable.
◆ _flexio_timer_trigger_polarity
Active high.
Active low.
◆ _flexio_timer_trigger_source
External trigger selected.
Internal trigger selected.
◆ FLEXIO_Deinit()
void FLEXIO_Deinit ( FLEXIO_Type base)
Note
After calling this API, call the FLEXO_Init to use the FlexIO module.
Parameters
baseFlexIO peripheral base address
brief Gates the FlexIO clock. Call this API to stop the FlexIO clock.
note After calling this API, call the FLEXO_Init to use the FlexIO module.
param base FlexIO peripheral base address
◆ FLEXIO_GetDefaultConfig()
void FLEXIO_GetDefaultConfig ( flexio_config_t userConfig)
Example:
void FLEXIO_GetDefaultConfig(flexio_config_t *userConfig)
Gets the default configuration to configure the FlexIO module. The configuration can used directly to...
Definition: fsl_flexio.c:140
Definition: fsl_flexio.h:240
Definition: deflate.c:114
Parameters
userConfigpointer to flexio_config_t structure
brief Gets the default configuration to configure the FlexIO module. The configuration can used directly to call the FLEXIO_Configure().
Example: code flexio_config_t config; FLEXIO_GetDefaultConfig(&config); endcode
param userConfig pointer to flexio_config_t structure
◆ FLEXIO_GetInstance()
uint32_t FLEXIO_GetInstance ( FLEXIO_Type base)
Parameters
baseFLEXIO peripheral base address.
brief Get instance number for FLEXIO module.
param base FLEXIO peripheral base address.
◆ FLEXIO_GetShifterBufferAddress()
uint32_t FLEXIO_GetShifterBufferAddress ( FLEXIO_Type base,
uint8_t  index
Parameters
typeShifter type of flexio_shifter_buffer_type_t
indexShifter index
Returns
Corresponding shifter buffer index
brief Gets the shifter buffer address for the DMA transfer usage.
param base FlexIO peripheral base address param type Shifter type of flexio_shifter_buffer_type_t param index Shifter index return Corresponding shifter buffer index
◆ FLEXIO_Init()
void FLEXIO_Init ( FLEXIO_Type base,
const flexio_config_t userConfig
Example
.enableFlexio = true,
.enableInDoze = false,
.enableInDebug = true,
.enableFastAccess = false
FLEXIO_Configure(base, &config);
Parameters
brief Configures the FlexIO with a FlexIO configuration. The configuration structure can be filled by the user or be set with default values by FLEXIO_GetDefaultConfig().
Example code flexio_config_t config = { .enableFlexio = true, .enableInDoze = false, .enableInDebug = true, .enableFastAccess = false }; FLEXIO_Configure(base, &config); endcode
param base FlexIO peripheral base address param userConfig pointer to flexio_config_t structure
◆ FLEXIO_RegisterHandleIRQ()
status_t FLEXIO_RegisterHandleIRQ ( void *  base,
void *  handle,
flexio_isr_t  isr
Parameters
basePointer to the FlexIO simulated peripheral type.
handlePointer to the handler for FlexIO simulated peripheral.
isrFlexIO simulated peripheral interrupt handler.
Return values
kStatus_SuccessSuccessfully create the handle.
kStatus_OutOfRangeThe FlexIO type/handle/ISR table out of range.
brief Registers the handle and the interrupt handler for the FlexIO-simulated peripheral.
param base Pointer to the FlexIO simulated peripheral type. param handle Pointer to the handler for FlexIO simulated peripheral. param isr FlexIO simulated peripheral interrupt handler. retval kStatus_Success Successfully create the handle. retval kStatus_OutOfRange The FlexIO type/handle/ISR table out of range.
◆ FLEXIO_Reset()
void FLEXIO_Reset ( FLEXIO_Type base)
Parameters
brief Resets the FlexIO module.
◆ FLEXIO_SetShifterConfig()
void FLEXIO_SetShifterConfig ( FLEXIO_Type base,
uint8_t  index,
const flexio_shifter_config_t shifterConfig
Example
.timerSelect = 0,
.pinPolarity = kFLEXIO_PinActiveLow,
void FLEXIO_SetShifterConfig(FLEXIO_Type *base, uint8_t index, const flexio_shifter_config_t *shifterConfig)
Configures the shifter with the shifter configuration. The configuration structure covers both the SH...
Definition: fsl_flexio.c:247
@ kFLEXIO_PinActiveLow
Definition: fsl_flexio.h:60
@ kFLEXIO_ShifterTimerPolarityOnPositive
Definition: fsl_flexio.h:172
@ kFLEXIO_ShifterStartBitLow
Definition: fsl_flexio.h:216
@ kFLEXIO_ShifterModeTransmit
Definition: fsl_flexio.h:181
@ kFLEXIO_ShifterInputFromPin
Definition: fsl_flexio.h:197
@ kFLEXIO_PinConfigOpenDrainOrBidirection
Definition: fsl_flexio.h:51
@ kFLEXIO_ShifterStopBitHigh
Definition: fsl_flexio.h:206
Definition: fsl_flexio.h:278
Parameters
indexShifter index
shifterConfigPointer to flexio_shifter_config_t structure
brief Configures the shifter with the shifter configuration. The configuration structure covers both the SHIFTCTL and SHIFTCFG registers. To configure the shifter to the proper mode, select which timer controls the shifter to shift, whether to generate start bit/stop bit, and the polarity of start bit and stop bit.
Example code flexio_shifter_config_t config = { .timerSelect = 0, .timerPolarity = kFLEXIO_ShifterTimerPolarityOnPositive, .pinConfig = kFLEXIO_PinConfigOpenDrainOrBidirection, .pinPolarity = kFLEXIO_PinActiveLow, .shifterMode = kFLEXIO_ShifterModeTransmit, .inputSource = kFLEXIO_ShifterInputFromPin, .shifterStop = kFLEXIO_ShifterStopBitHigh, .shifterStart = kFLEXIO_ShifterStartBitLow }; FLEXIO_SetShifterConfig(base, &config); endcode
param base FlexIO peripheral base address param index Shifter index param shifterConfig Pointer to flexio_shifter_config_t structure
◆ FLEXIO_SetTimerConfig()
void FLEXIO_SetTimerConfig ( FLEXIO_Type base,
uint8_t  index,
const flexio_timer_config_t timerConfig
Example
.triggerSelect = FLEXIO_TIMER_TRIGGER_SEL_SHIFTnSTAT(0),
.pinSelect = 0,
.pinPolarity = kFLEXIO_PinActiveHigh,
void FLEXIO_SetTimerConfig(FLEXIO_Type *base, uint8_t index, const flexio_timer_config_t *timerConfig)
Configures the timer with the timer configuration. The configuration structure covers both the TIMCTL...
Definition: fsl_flexio.c:292
@ kFLEXIO_TimerOutputZeroNotAffectedByReset
Definition: fsl_flexio.h:77
@ kFLEXIO_PinActiveHigh
Definition: fsl_flexio.h:59
@ kFLEXIO_TimerDisableOnTimerCompare
Definition: fsl_flexio.h:124
@ kFLEXIO_TimerTriggerPolarityActiveLow
Definition: fsl_flexio.h:37
@ kFLEXIO_TimerEnableOnTriggerHigh
Definition: fsl_flexio.h:137
@ kFLEXIO_TimerModeDual8BitBaudBit
Definition: fsl_flexio.h:67
@ kFLEXIO_TimerStartBitEnabled
Definition: fsl_flexio.h:159
@ kFLEXIO_TimerDecSrcOnFlexIOClockShiftTimerOutput
Definition: fsl_flexio.h:86
@ kFLEXIO_TimerTriggerSourceInternal
Definition: fsl_flexio.h:44
@ kFLEXIO_TimerResetOnTimerPinEqualToTimerOutput
Definition: fsl_flexio.h:111
@ kFLEXIO_TimerStopBitEnableOnTimerDisable
Definition: fsl_flexio.h:150
Definition: fsl_flexio.h:250
Parameters
indexTimer index
timerConfigPointer to the flexio_timer_config_t structure
brief Configures the timer with the timer configuration. The configuration structure covers both the TIMCTL and TIMCFG registers. To configure the timer to the proper mode, select trigger source for timer and the timer pin output and the timing for timer.
Example code flexio_timer_config_t config = { .triggerSelect = FLEXIO_TIMER_TRIGGER_SEL_SHIFTnSTAT(0), .triggerPolarity = kFLEXIO_TimerTriggerPolarityActiveLow, .triggerSource = kFLEXIO_TimerTriggerSourceInternal, .pinConfig = kFLEXIO_PinConfigOpenDrainOrBidirection, .pinSelect = 0, .pinPolarity = kFLEXIO_PinActiveHigh, .timerMode = kFLEXIO_TimerModeDual8BitBaudBit, .timerOutput = kFLEXIO_TimerOutputZeroNotAffectedByReset, .timerDecrement = kFLEXIO_TimerDecSrcOnFlexIOClockShiftTimerOutput, .timerReset = kFLEXIO_TimerResetOnTimerPinEqualToTimerOutput, .timerDisable = kFLEXIO_TimerDisableOnTimerCompare, .timerEnable = kFLEXIO_TimerEnableOnTriggerHigh, .timerStop = kFLEXIO_TimerStopBitEnableOnTimerDisable, .timerStart = kFLEXIO_TimerStartBitEnabled }; FLEXIO_SetTimerConfig(base, &config); endcode
param base FlexIO peripheral base address param index Timer index param timerConfig Pointer to the flexio_timer_config_t structure
◆ FLEXIO_UnregisterHandleIRQ()
status_t FLEXIO_UnregisterHandleIRQ ( void *  base)
Parameters
Return values
brief Unregisters the handle and the interrupt handler for the FlexIO-simulated peripheral.
param base Pointer to the FlexIO simulated peripheral type. retval kStatus_Success Successfully create the handle. retval kStatus_OutOfRange The FlexIO type/handle/ISR table out of range.
Variable Documentation
◆ enableFastAccess
Enable/disable fast access to FlexIO registers, fast access requires the FlexIO clock to be at least twice the frequency of the bus clock.
◆ enableFlexio
Enable/disable FlexIO module
◆ enableInDebug
Enable/disable FlexIO operation in debug mode
◆ enableInDoze
Enable/disable FlexIO operation in doze mode
◆ inputSource
Selects the input source for the shifter.
◆ pinConfig [1/2]
Timer Pin Configuration.
◆ pinConfig [2/2]
Shifter Pin Configuration.
◆ pinPolarity [1/2]
Timer Pin Polarity.
◆ pinPolarity [2/2]
Shifter Pin Polarity.
◆ pinSelect [1/2]
Timer Pin number Select.
◆ pinSelect [2/2]
Shifter Pin number Select.
◆ shifterMode
Configures the mode of the Shifter.
◆ shifterStart
Shifter START bit.
◆ shifterStop
Shifter STOP bit.
◆ timerCompare
Value for Timer Compare N Register.
◆ timerDecrement
Configures the source of the Timer decrement and the source of the Shift clock.
◆ timerDisable
Configures the condition that causes the Timer to be disabled and stop decrementing.
◆ timerEnable
Configures the condition that causes the Timer to be enabled and start decrementing.
◆ timerMode
Timer work Mode.
◆ timerOutput
Configures the initial state of the Timer Output and whether it is affected by the Timer reset.
◆ timerPolarity
Timer Polarity.
◆ timerReset
Configures the condition that causes the timer counter (and optionally the timer output) to be reset.
◆ timerSelect
Selects which Timer is used for controlling the logic/shift register and generating the Shift clock.
◆ timerStart
Timer STRAT Bit generation.
◆ timerStop
Timer STOP Bit generation.
◆ triggerPolarity
Trigger Polarity.
◆ triggerSelect
The internal trigger selection number using MACROs.
◆ triggerSource
Trigger Source, internal (see 'trgsel') or external.
