RTEMS 6.1-rc4
Data Structures | Enumerator | Variables
Ewm
struct  _ewm_config
 Describes EWM clock source. More...
bool _ewm_config::enableEwm
bool _ewm_config::enableEwmInput
bool _ewm_config::setInputAssertLogic
bool _ewm_config::enableInterrupt
uint8_t _ewm_config::compareLowValue
uint8_t _ewm_config::compareHighValue
Driver version
enum  _ewm_interrupt_enable_t { kEWM_InterruptEnable = EWM_CTRL_INTEN_MASK }
 EWM interrupt configuration structure with default settings all disabled. More...
enum  _ewm_status_flags_t { kEWM_RunningFlag = EWM_CTRL_EWMEN_MASK }
 EWM status flags. More...
typedef struct _ewm_config ewm_config_t
#define FSL_EWM_DRIVER_VERSION   (MAKE_VERSION(2, 0, 3))
 EWM driver version 2.0.3.
EWM initialization and de-initialization
void EWM_Init (EWM_Type *base, const ewm_config_t *config)
 Initializes the EWM peripheral.
void EWM_Deinit (EWM_Type *base)
 Deinitializes the EWM peripheral.
void EWM_GetDefaultConfig (ewm_config_t *config)
 Initializes the EWM configuration structure.
EWM functional Operation
void EWM_Refresh (EWM_Type *base)
 Services the EWM.
Typedef Documentation
◆ ewm_config_t
Data structure for EWM configuration.
This structure is used to configure the EWM.
◆ _ewm_interrupt_enable_t
This structure contains the settings for all of EWM interrupt configurations.
Enable the EWM to generate an interrupt
◆ _ewm_status_flags_t
EWM status flags.
This structure contains the constants for the EWM status flags for use in the EWM functions.
kEWM_RunningFlag
Running flag, set when EWM is enabled
◆ EWM_Deinit()
void EWM_Deinit ( EWM_Type base)
This function is used to shut down the EWM.
Parameters
baseEWM peripheral base address
brief Deinitializes the EWM peripheral.
param base EWM peripheral base address
◆ EWM_GetDefaultConfig()
void EWM_GetDefaultConfig ( ewm_config_t config)
This function initializes the EWM configuration structure to default values. The default values are as follows.
ewmConfig->enableEwm = true;
ewmConfig->enableEwmInput = false;
ewmConfig->setInputAssertLogic = false;
ewmConfig->enableInterrupt = false;
ewmConfig->ewm_lpo_clock_source_t = kEWM_LpoClockSource0;
ewmConfig->prescaler = 0;
ewmConfig->compareLowValue = 0;
ewmConfig->compareHighValue = 0xFEU;
Parameters
configPointer to the EWM configuration structure.
See also
ewm_config_t
brief Initializes the EWM configuration structure.
This function initializes the EWM configuration structure to default values. The default values are as follows. code ewmConfig->enableEwm = true; ewmConfig->enableEwmInput = false; ewmConfig->setInputAssertLogic = false; ewmConfig->enableInterrupt = false; ewmConfig->ewm_lpo_clock_source_t = kEWM_LpoClockSource0; ewmConfig->prescaler = 0; ewmConfig->compareLowValue = 0; ewmConfig->compareHighValue = 0xFEU; endcode
param config Pointer to the EWM configuration structure. see ewm_config_t
◆ EWM_Init()
void EWM_Init ( EWM_Type base,
const ewm_config_t config
This function is used to initialize the EWM. After calling, the EWM runs immediately according to the configuration. Note that, except for the interrupt enable control bit, other control bits and registers are write once after a CPU reset. Modifying them more than once generates a bus transfer error.
This is an example.
config.compareHighValue = 0xAAU;
EWM_Init(ewm_base,&config);
void EWM_GetDefaultConfig(ewm_config_t *config)
Definition: fsl_ewm.c:103
void EWM_Init(EWM_Type *base, const ewm_config_t *config)
Definition: fsl_ewm.c:39
Definition: fsl_ewm.h:45
Definition: deflate.c:114
Parameters
configThe configuration of the EWM
brief Initializes the EWM peripheral.
This is an example. code ewm_config_t config; EWM_GetDefaultConfig(&config); config.compareHighValue = 0xAAU; EWM_Init(ewm_base,&config); endcode
param base EWM peripheral base address param config The configuration of the EWM
◆ EWM_Refresh()
void EWM_Refresh ( EWM_Type base)
Services the EWM.
This function resets the EWM counter to zero.
Parameters
brief Services the EWM.
Variable Documentation
◆ compareHighValue
Compare high-register value
◆ compareLowValue
Compare low-register value
◆ enableEwm
Enable EWM module
◆ enableEwmInput
Enable EWM_in input
◆ enableInterrupt
Enable EWM interrupt
◆ setInputAssertLogic
EWM_in signal assertion state
