RTEMS 6.1-rc4
Data Structures | Macros | Typedefs | Enumerations | Enumerator | Variables
Dcdc
struct  _dcdc_detection_config
 Configuration for DCDC detection. More...
struct  _dcdc_loop_control_config
 Configuration for the loop control. More...
struct  _dcdc_low_power_config
 Configuration for DCDC low power. More...
struct  _dcdc_internal_regulator_config
 Configuration for DCDC internal regulator. More...
struct  _dcdc_min_power_config
 Configuration for min power setting. More...
#define FSL_DCDC_DRIVER_VERSION   (MAKE_VERSION(2, 3, 0))
 DCDC driver version.
typedef enum _dcdc_comparator_current_bias dcdc_comparator_current_bias_t
 The current bias of low power comparator.
typedef enum _dcdc_over_current_threshold dcdc_over_current_threshold_t
 The threshold of over current detection.
typedef enum _dcdc_peak_current_threshold dcdc_peak_current_threshold_t
 The threshold if peak current detection.
typedef enum _dcdc_count_charging_time_period dcdc_count_charging_time_period_t
 The period of counting the charging times in power save mode.
typedef enum _dcdc_count_charging_time_threshold dcdc_count_charging_time_threshold_t
 The threshold of the counting number of charging times.
typedef enum _dcdc_clock_source dcdc_clock_source_t
 Oscillator clock option.
typedef struct _dcdc_detection_config dcdc_detection_config_t
typedef struct _dcdc_loop_control_config dcdc_loop_control_config_t
typedef struct _dcdc_low_power_config dcdc_low_power_config_t
typedef struct _dcdc_internal_regulator_config dcdc_internal_regulator_config_t
typedef struct _dcdc_min_power_config dcdc_min_power_config_t
enum  _dcdc_status_flags_t { kDCDC_LockedOKStatus = (1U << 0U) }
 DCDC status flags. More...
enum  _dcdc_comparator_current_bias {
  kDCDC_ComparatorCurrentBias50nA = 0U , kDCDC_ComparatorCurrentBias100nA = 1U , kDCDC_ComparatorCurrentBias200nA = 2U , kDCDC_ComparatorCurrentBias400nA = 3U ,
 The current bias of low power comparator. More...
enum  _dcdc_over_current_threshold { kDCDC_OverCurrentThresholdAlt0 = 0U , kDCDC_OverCurrentThresholdAlt1 = 1U , kDCDC_OverCurrentThresholdAlt2 = 2U , kDCDC_OverCurrentThresholdAlt3 = 3U }
 The threshold of over current detection. More...
enum  _dcdc_peak_current_threshold {
  kDCDC_PeakCurrentRunMode250mALPMode1P5A = 0U , kDCDC_PeakCurrentRunMode200mALPMode1P5A , kDCDC_PeakCurrentRunMode250mALPMode2A , kDCDC_PeakCurrentRunMode200mALPMode2A ,
  kDCDC_PeakCurrentThresholdAlt0 = 0U , kDCDC_PeakCurrentThresholdAlt1 = 1U , kDCDC_PeakCurrentThresholdAlt2 = 2U , kDCDC_PeakCurrentThresholdAlt3 = 3U ,
  kDCDC_PeakCurrentThresholdAlt4 = 4U , kDCDC_PeakCurrentThresholdAlt5 = 5U
 The threshold if peak current detection. More...
enum  _dcdc_count_charging_time_period { kDCDC_CountChargingTimePeriod8Cycle = 0U , kDCDC_CountChargingTimePeriod16Cycle = 1U }
 The period of counting the charging times in power save mode. More...
enum  _dcdc_count_charging_time_threshold { kDCDC_CountChargingTimeThreshold32 = 0U , kDCDC_CountChargingTimeThreshold64 = 1U , kDCDC_CountChargingTimeThreshold16 = 2U , kDCDC_CountChargingTimeThreshold8 = 3U }
 The threshold of the counting number of charging times. More...
enum  _dcdc_clock_source {
  kDCDC_ClockAutoSwitch = 0U , kDCDC_ClockInternalOsc = 1U , kDCDC_ClockExternalOsc = 2U , kDCDC_ClockAutoSwitch = 0U ,
 Oscillator clock option. More...
bool _dcdc_detection_config::enableXtalokDetection
bool _dcdc_detection_config::powerDownOverVoltageDetection
bool _dcdc_detection_config::powerDownLowVlotageDetection
bool _dcdc_detection_config::powerDownOverCurrentDetection
bool _dcdc_detection_config::powerDownPeakCurrentDetection
bool _dcdc_detection_config::powerDownZeroCrossDetection
dcdc_over_current_threshold_t _dcdc_detection_config::OverCurrentThreshold
dcdc_peak_current_threshold_t _dcdc_detection_config::PeakCurrentThreshold
bool _dcdc_loop_control_config::enableCommonHysteresis
bool _dcdc_loop_control_config::enableCommonThresholdDetection
bool _dcdc_loop_control_config::enableInvertHysteresisSign
bool _dcdc_loop_control_config::enableRCThresholdDetection
uint32_t _dcdc_loop_control_config::enableRCScaleCircuit
uint32_t _dcdc_loop_control_config::complementFeedForwardStep
bool _dcdc_low_power_config::enableOverloadDetection
bool _dcdc_low_power_config::enableAdjustHystereticValue
dcdc_count_charging_time_period_t _dcdc_low_power_config::countChargingTimePeriod
dcdc_count_charging_time_threshold_t _dcdc_low_power_config::countChargingTimeThreshold
bool _dcdc_internal_regulator_config::enableLoadResistor
uint32_t _dcdc_internal_regulator_config::feedbackPoint
bool _dcdc_min_power_config::enableUseHalfFreqForContinuous
Initialization and deinitialization
void DCDC_Init (DCDC_Type *base)
 Enable the access to DCDC registers.
void DCDC_Deinit (DCDC_Type *base)
 Disable the access to DCDC registers.
Status
uint32_t DCDC_GetstatusFlags (DCDC_Type *base)
 Get DCDC status flags.
Misc control
void DCDC_SetClockSource (DCDC_Type *base, dcdc_clock_source_t clockSource)
 Configure the DCDC clock source.
void DCDC_GetDefaultDetectionConfig (dcdc_detection_config_t *config)
 Get the default setting for detection configuration.
void DCDC_SetDetectionConfig (DCDC_Type *base, const dcdc_detection_config_t *config)
 Configure the DCDC detection.
void DCDC_GetDefaultLowPowerConfig (dcdc_low_power_config_t *config)
 Get the default setting for low power configuration.
void DCDC_SetLowPowerConfig (DCDC_Type *base, const dcdc_low_power_config_t *config)
 Configure the DCDC low power.
void DCDC_ResetCurrentAlertSignal (DCDC_Type *base, bool enable)
 Reset current alert signal. Alert signal is generate by peak current detection.
void DCDC_GetDefaultLoopControlConfig (dcdc_loop_control_config_t *config)
 Get the default setting for loop control configuration.
void DCDC_SetLoopControlConfig (DCDC_Type *base, const dcdc_loop_control_config_t *config)
 Configure the DCDC loop control.
void DCDC_SetMinPowerConfig (DCDC_Type *base, const dcdc_min_power_config_t *config)
 Configure for the min power.
void DCDC_AdjustTargetVoltage (DCDC_Type *base, uint32_t VDDRun, uint32_t VDDStandby)
 Adjust the target voltage of VDD_SOC in run mode and low power mode.
void DCDC_AdjustRunTargetVoltage (DCDC_Type *base, uint32_t VDDRun)
 Adjust the target voltage of VDD_SOC in run mode.
void DCDC_AdjustLowPowerTargetVoltage (DCDC_Type *base, uint32_t VDDStandby)
 Adjust the target voltage of VDD_SOC in low power mode.
void DCDC_SetInternalRegulatorConfig (DCDC_Type *base, const dcdc_internal_regulator_config_t *config)
 Configure the DCDC internal regulator.
Application guideline
void DCDC_BootIntoDCM (DCDC_Type *base)
 Boot DCDC into DCM(discontinous conduction mode).
void DCDC_BootIntoCCM (DCDC_Type *base)
 Boot DCDC into CCM(continous conduction mode).
◆ FSL_DCDC_DRIVER_VERSION
Version 2.3.0.
◆ _dcdc_clock_source
Automatic clock switch from internal oscillator to external clock.
Use internal oscillator.
Use external 24M crystal oscillator.
◆ _dcdc_comparator_current_bias
The current bias of low power comparator is 50nA.
The current bias of low power comparator is 100nA.
The current bias of low power comparator is 200nA.
The current bias of low power comparator is 400nA.
◆ _dcdc_count_charging_time_period
Eight 32k cycle.
Sixteen 32k cycle.
◆ _dcdc_count_charging_time_threshold
0x0: 32.
0x1: 64.
0x2: 16.
0x3: 8.
◆ _dcdc_over_current_threshold
1A in the run mode, 0.25A in the power save mode.
2A in the run mode, 0.25A in the power save mode.
1A in the run mode, 0.2A in the power save mode.
2A in the run mode, 0.2A in the power save mode.
◆ _dcdc_peak_current_threshold
Over peak current threshold in low power mode is 250mA, in run mode is 1.5A
Over peak current threshold in low power mode is 200mA, in run mode is 1.5A
Over peak current threshold in low power mode is 250mA, in run mode is 2A
Over peak current threshold in low power mode is 200mA, in run mode is 2A
150mA peak current threshold.
250mA peak current threshold.
350mA peak current threshold.
450mA peak current threshold.
550mA peak current threshold.
650mA peak current threshold.
◆ _dcdc_status_flags_t
DCDC status flags.
Indicate DCDC status. 1'b1: DCDC already settled 1'b0: DCDC is settling.
◆ DCDC_AdjustLowPowerTargetVoltage()
void DCDC_AdjustLowPowerTargetVoltage ( DCDC_Type base,
uint32_t  VDDStandby
This function is to adjust the target voltage of DCDC output. Change them and finally wait until the output is stabled. Set the target value of run mode the same as low power mode before entering power save mode, because DCDC will switch back to run mode if it detects the current loading is larger than about 50 mA(typical value).
Parameters
baseDCDC peripheral base address.
VDDStandbyTarget value in low power mode. 25 mV each step from 0x00 to 0x4. 00 is for 0.9V, 0x4 is for 1.0V.
brief Adjust the target voltage of VDD_SOC in low power mode.
param base DCDC peripheral base address. param VDDStandby Target value in low power mode. 25 mV each step from 0x00 to 0x4. 00 is for 0.9V, 0x4 is for 1.0V.
◆ DCDC_AdjustRunTargetVoltage()
void DCDC_AdjustRunTargetVoltage ( DCDC_Type base,
uint32_t  VDDRun
Parameters
VDDRunTarget value in run mode. 25 mV each step from 0x00 to 0x1F. 00 is for 0.8V, 0x1F is for 1.575V.
brief Adjust the target voltage of VDD_SOC in run mode.
param base DCDC peripheral base address. param VDDRun Target value in run mode. 25 mV each step from 0x00 to 0x1F. 00 is for 0.8V, 0x1F is for 1.575V.
◆ DCDC_AdjustTargetVoltage()
void DCDC_AdjustTargetVoltage ( DCDC_Type base,
uint32_t  VDDRun,
uint32_t  VDDStandby
Deprecated:
Do not use this function. It has been superceded by DCDC_AdjustRunTargetVoltage and DCDC_AdjustLowPowerTargetVoltage
Parameters
brief Adjust the target voltage of VDD_SOC in run mode and low power mode. Do not use this function. It has been superceded by DCDC_AdjustRunTargetVoltage and DCDC_AdjustLowPowerTargetVoltage
param base DCDC peripheral base address. param VDDRun Target value in run mode. 25 mV each step from 0x00 to 0x1F. 00 is for 0.8V, 0x1F is for 1.575V. param VDDStandby Target value in low power mode. 25 mV each step from 0x00 to 0x4. 00 is for 0.9V, 0x4 is for 1.0V.
◆ DCDC_BootIntoCCM()
void DCDC_BootIntoCCM ( DCDC_Type base)
pwd_zcd=0x1; pwd_cmp_offset=0x0; dcdc_loopctrl_en_rcscale=0x3;
Parameters
brief Boots DCDC into CCM(continous conduction mode).
brief Boot DCDC into CCM(continous conduction mode).
◆ DCDC_BootIntoDCM()
void DCDC_BootIntoDCM ( DCDC_Type base)
pwd_zcd=0x0; pwd_cmp_offset=0x0; dcdc_loopctrl_en_rcscale= 0x5; DCM_set_ctrl=1'b1;
Parameters
brief Boots DCDC into DCM(discontinous conduction mode).
pwd_zcd=0x0; DM_CTRL = 1'b1; pwd_cmp_offset=0x0; dcdc_loopctrl_en_rcscale=0x3 or 0x5; DCM_set_ctrl=1'b1;
brief Boot DCDC into DCM(discontinous conduction mode).
◆ DCDC_Deinit()
void DCDC_Deinit ( DCDC_Type base)
Parameters
brief De-initializes the DCDC module.
brief Disable the access to DCDC registers.
◆ DCDC_GetDefaultDetectionConfig()
void DCDC_GetDefaultDetectionConfig ( dcdc_detection_config_t config)
The default configuration are set according to responding registers' setting when powered on. They are:
config->enableXtalokDetection = false;
config->powerDownOverVoltageDetection = true;
config->powerDownLowVlotageDetection = false;
config->powerDownOverCurrentDetection = true;
config->powerDownPeakCurrentDetection = true;
config->powerDownZeroCrossDetection = true;
config->OverCurrentThreshold = kDCDC_OverCurrentThresholdAlt0;
config->PeakCurrentThreshold = kDCDC_PeakCurrentThresholdAlt0;
@ kDCDC_PeakCurrentThresholdAlt0
Definition: fsl_dcdc.h:60
@ kDCDC_OverCurrentThresholdAlt0
Definition: fsl_dcdc.h:49
Definition: deflate.c:114
Parameters
configPointer to configuration structure. See to "dcdc_detection_config_t"
brief Gets the default setting for detection configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableXtalokDetection = false; config->powerDownOverVoltageVdd1P8Detection = true; config->powerDownOverVoltageVdd1P0Detection = true; config->powerDownLowVoltageDetection = false; config->powerDownOverCurrentDetection = true; config->powerDownPeakCurrentDetection = true; config->powerDownZeroCrossDetection = true; config->PeakCurrentThreshold = kDCDC_PeakCurrentRunMode250mALPMode1P5A; endcode
param config Pointer to configuration structure. See to "dcdc_detection_config_t"
brief Get the default setting for detection configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableXtalokDetection = false; config->powerDownOverVoltageDetection = true; config->powerDownLowVlotageDetection = false; config->powerDownOverCurrentDetection = true; config->powerDownPeakCurrentDetection = true; config->powerDownZeroCrossDetection = true; config->OverCurrentThreshold = kDCDC_OverCurrentThresholdAlt0; config->PeakCurrentThreshold = kDCDC_PeakCurrentThresholdAlt0; endcode
◆ DCDC_GetDefaultLoopControlConfig()
void DCDC_GetDefaultLoopControlConfig ( dcdc_loop_control_config_t config)
config->enableCommonHysteresis = false;
config->enableCommonThresholdDetection = false;
config->enableInvertHysteresisSign = false;
config->enableRCThresholdDetection = false;
config->enableRCScaleCircuit = 0U;
config->complementFeedForwardStep = 0U;
Parameters
configPointer to configuration structure. See to "dcdc_loop_control_config_t"
brief Gets the default setting for loop control configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableCommonHysteresis = false; config->enableCommonThresholdDetection = false; config->enableInvertHysteresisSign = false; config->enableRCThresholdDetection = false; config->enableRCScaleCircuit = 0U; config->complementFeedForwardStep = 0U; config->controlParameterMagnitude = 2U; config->integralProportionalRatio = 2U; endcode
param config Pointer to configuration structure. See to "dcdc_loop_control_config_t"
brief Get the default setting for loop control configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableCommonHysteresis = false; config->enableCommonThresholdDetection = false; config->enableInvertHysteresisSign = false; config->enableRCThresholdDetection = false; config->enableRCScaleCircuit = 0U; config->complementFeedForwardStep = 0U; endcode
◆ DCDC_GetDefaultLowPowerConfig()
void DCDC_GetDefaultLowPowerConfig ( dcdc_low_power_config_t config)
config->enableOverloadDetection = true;
config->enableAdjustHystereticValue = false;
config->countChargingTimePeriod = kDCDC_CountChargingTimePeriod8Cycle;
config->countChargingTimeThreshold = kDCDC_CountChargingTimeThreshold32;
@ kDCDC_CountChargingTimePeriod8Cycle
Definition: fsl_dcdc.h:73
@ kDCDC_CountChargingTimeThreshold32
Definition: fsl_dcdc.h:82
Parameters
configPointer to configuration structure. See to "dcdc_low_power_config_t"
brief Gets the default setting for low power configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableAdjustHystereticValue = false; endcode
param config Pointer to configuration structure. See to "dcdc_low_power_config_t"
brief Get the default setting for low power configuration.
The default configuration are set according to responding registers' setting when powered on. They are: code config->enableOverloadDetection = true; config->enableAdjustHystereticValue = false; config->countChargingTimePeriod = kDCDC_CountChargingTimePeriod8Cycle; config->countChargingTimeThreshold = kDCDC_CountChargingTimeThreshold32; endcode
◆ DCDC_GetstatusFlags()
uint32_t DCDC_GetstatusFlags ( DCDC_Type base)
Parameters
baseperipheral base address.
Returns
Mask of asserted status flags. See to "_dcdc_status_flags_t".
brief Get DCDC status flags.
param base peripheral base address. return Mask of asserted status flags. See to "_dcdc_status_flags_t".
◆ DCDC_Init()
void DCDC_Init ( DCDC_Type base)
Parameters
brief Enable the access to DCDC registers.
◆ DCDC_ResetCurrentAlertSignal()
void DCDC_ResetCurrentAlertSignal ( DCDC_Type base,
bool  enable
Parameters
enableSwitcher to reset signal. True means reset signal. False means don't reset signal.
brief Reset current alert signal. Alert signal is generate by peak current detection.
param base DCDC peripheral base address. param enable Switcher to reset signal. True means reset signal. False means don't reset signal.
◆ DCDC_SetClockSource()
void DCDC_SetClockSource ( DCDC_Type base,
Parameters
clockSourceClock source for DCDC. See to "dcdc_clock_source_t".
brief Configures the DCDC clock source.
param base DCDC peripheral base address. param clockSource Clock source for DCDC. See to "dcdc_clock_source_t".
brief Configure the DCDC clock source.
◆ DCDC_SetDetectionConfig()
void DCDC_SetDetectionConfig ( DCDC_Type base,
const dcdc_detection_config_t config
Parameters
breif Configures the DCDC detection.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_detection_config_t"
breif Configure the DCDC detection.
◆ DCDC_SetInternalRegulatorConfig()
void DCDC_SetInternalRegulatorConfig ( DCDC_Type base,
const dcdc_internal_regulator_config_t config
Parameters
configPointer to configuration structure. See to "dcdc_internal_regulator_config_t".
brief Configures the DCDC internal regulator.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_internal_regulator_config_t".
brief Configure the DCDC internal regulator.
◆ DCDC_SetLoopControlConfig()
void DCDC_SetLoopControlConfig ( DCDC_Type base,
const dcdc_loop_control_config_t config
Parameters
configPointer to configuration structure. See to "dcdc_loop_control_config_t".
brief Configures the DCDC loop control.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_loop_control_config_t".
brief Configure the DCDC loop control.
◆ DCDC_SetLowPowerConfig()
void DCDC_SetLowPowerConfig ( DCDC_Type base,
const dcdc_low_power_config_t config
Parameters
configPointer to configuration structure. See to "dcdc_low_power_config_t".
brief Configures the DCDC low power.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_low_power_config_t".
brief Configure the DCDC low power.
◆ DCDC_SetMinPowerConfig()
void DCDC_SetMinPowerConfig ( DCDC_Type base,
const dcdc_min_power_config_t config
Parameters
configPointer to configuration structure. See to "dcdc_min_power_config_t".
brief Configures for the min power.
param base DCDC peripheral base address. param config Pointer to configuration structure. See to "dcdc_min_power_config_t".
brief Configure for the min power.
Variable Documentation
◆ complementFeedForwardStep
Available range is 0~7. Two's complement feed forward step in duty cycle in the switching DC-DC converter. Each time this field makes a transition from 0x0, the loop filter of the DC-DC converter is stepped once by a value proportional to the change. This can be used to force a certain control loop behavior, such as improving response under known heavy load transients.
◆ countChargingTimePeriod
◆ countChargingTimeThreshold
the threshold of the counting number of charging times during the period that lp_overload_freq_sel sets in power save mode.
◆ enableAdjustHystereticValue
Adjust hysteretic value in low power from 12.5mV to 25mV.
◆ enableCommonHysteresis
Enable hysteresis in switching converter common mode analog comparators. This feature will improve transient supply ripple and efficiency.
◆ enableCommonThresholdDetection
Increase the threshold detection for common mode analog comparator.
◆ enableInvertHysteresisSign
Invert the sign of the hysteresis in DC-DC analog comparators.
◆ enableLoadResistor
control the load resistor of the internal regulator of DCDC, the load resistor is connected as default "true", and need set to "false" to disconnect the load resistor.
◆ enableOverloadDetection
Enable the overload detection in power save mode, if current is larger than the overloading threshold (typical value is 50 mA), DCDC will switch to the run mode automatically.
◆ enableRCScaleCircuit
Available range is 0~7. Enable analog circuit of DC-DC converter to respond faster under transient load conditions.
◆ enableRCThresholdDetection
Increase the threshold detection for RC scale circuit.
◆ enableUseHalfFreqForContinuous
Set DCDC clock to half frequency for the continuous mode.
◆ enableXtalokDetection
Enable xtalok detection circuit.
◆ feedbackPoint
Available range is 0~3. Select the feedback point of the internal regulator.
◆ OverCurrentThreshold
◆ PeakCurrentThreshold
The threshold of peak current detection.
◆ powerDownLowVlotageDetection
Power down low-voltage detection comparator.
◆ powerDownOverCurrentDetection
Power down over-current detection.
◆ powerDownOverVoltageDetection
Power down over-voltage detection comparator.
◆ powerDownPeakCurrentDetection
Power down peak-current detection.
◆ powerDownZeroCrossDetection
Power down the zero cross detection function for discontinuous conductor mode.
