RTEMS 6.1-rc4
Files | Macros
Directive Attributes
This group contains the implementation to support directive attributes. More...
file  attr.h
 This header file provides Classic API directive attributes.
file  attrimpl.h
 This header file provides the implementation interfaces of the Directive Attributes support.
#define ATTRIBUTES_NOT_SUPPORTED   0
#define ATTRIBUTES_REQUIRED   RTEMS_FLOATING_POINT
◆ ATTRIBUTES_NOT_SUPPORTED
This attribute constant indicates the attributes that are not supportable given the hardware configuration.
◆ ATTRIBUTES_REQUIRED
This attribute constant indicates the attributes that are required given the hardware configuration.
