RTEMS 6.1-rc4
Modules | Files | Data Structures | Typedefs
This group contains the L2CACHE interfaces. More...
 L2C Access control register (L2CACCC)
 This group contains register bit definitions.
 L2C Control register (L2CC)
 L2C Data-Check-Bits register (L2CCB)
 L2C Error address register (L2CERRA)
 L2C Error injection register (L2CEINJ)
 L2C Flush (Memory address) register (L2CFMA)
 L2C Flush (Set, Index) register (L2CFSI)
 L2C Memory type range register (L2CMTRR)
 L2C Scrub control/status register (L2CSCRUB)
 L2C Scrub delay register (L2CSDEL)
 L2C Status register (L2CS)
 L2C TAG-Check-Bits register (L2CTCB)
 L2C injection configuration register (L2CEINJCFG)
 L2CError status/control register (L2CERR)
file  l2cache-regs.h
 This header file defines the L2CACHE register block interface.
struct  l2cache
 This structure defines the L2CACHE register block memory map. More...
typedef struct l2cache l2cache
