RTEMS 6.1-rc4
Modules | Files | Macros | Enumerations | Functions
QorIQ - Interrupt Support
Interrupt support. More...
 QorIQ - External Interrupt Sources
 External interrupt sources.
 QorIQ - Internal Interrupt Sources
 Internal interrupt sources.
 QorIQ - Interprocessor Interrupts
 Interprocessor interrupts.
 QorIQ - P1020 Internal Interrupt Sources
 P1020 internal interrupt sources.
 QorIQ - P2020 Internal Interrupt Sources
 P2020 internal interrupt sources.
file  irq.h
 Interrupt API.
#define QORIQ_PIC_PRIORITY_LOWEST   14
#define QORIQ_PIC_PRIORITY_HIGHEST   0
#define QORIQ_PIC_PRIORITY_DISABLED   15
#define QORIQ_PIC_PRIORITY_INVALID   16
#define QORIQ_PIC_PRIORITY_DEFAULT   13
#define QORIQ_PIC_PRIORITY_IS_VALID(p)    (((uint32_t) (p)) <= QORIQ_PIC_PRIORITY_DISABLED)
enum  qoriq_eirq_sense_and_polarity { QORIQ_EIRQ_TRIGGER_EDGE_FALLING , QORIQ_EIRQ_TRIGGER_EDGE_RISING , QORIQ_EIRQ_TRIGGER_LEVEL_LOW , QORIQ_EIRQ_TRIGGER_LEVEL_HIGH }
rtems_status_code qoriq_pic_msi_allocate (rtems_vector_number *vector)
rtems_status_code qoriq_pic_msi_free (rtems_vector_number vector)
rtems_status_code qoriq_pic_msi_map (rtems_vector_number vector, uint64_t *addr, uint32_t *data)
rtems_status_code qoriq_pic_set_sense_and_polarity (rtems_vector_number vector, qoriq_eirq_sense_and_polarity new_sense_and_polarity, qoriq_eirq_sense_and_polarity *old_sense_and_polarity)
 Change polarity and sense settings of external interrupts.
Interrupt support.
◆ qoriq_pic_set_sense_and_polarity()
rtems_status_code qoriq_pic_set_sense_and_polarity ( rtems_vector_number  vector,
qoriq_eirq_sense_and_polarity *  old_sense_and_polarity
NOTE: There are only very rare edge cases where you need this function.
vector must be the vector number of an external interrupt.
Use new_sense_and_polarity to select the new setting. If old_sense_and_polarity is not NULL, the old value is returned.
Returns
RTEMS_SUCCSSSFUL on sucess or other values for invalid settings.
