RTEMS 6.1-rc4
struct | mscan_context |
MSCAN context that has to be saved throughout the initialization mode. More... | |
Typedefs | |
typedef struct mpc5200_mscan | mscan |
MSCAN registers. | |
bool | mscan_enable (volatile mscan *m, unsigned bit_rate) |
Enables and initializes the MSCAN module m. | |
void | mscan_disable (volatile mscan *m) |
Disables the MSCAN module m. | |
void | mscan_interrupts_disable (volatile mscan *m) |
Disables all interrupts for the MSCAN module m. | |
bool | mscan_set_bit_rate (volatile mscan *m, unsigned bit_rate) |
Sets the bit rate for the MSCAN module m to can_bit_rate in [bits/s]. | |
void | mscan_initialization_mode_enter (volatile mscan *m, mscan_context *context) |
Enter initialization mode for the MSCAN module m. | |
void | mscan_initialization_mode_leave (volatile mscan *m, const mscan_context *context) |
Leave initialization mode for the MSCAN module m. | |
void | mscan_sleep_mode_enter (volatile mscan *m) |
Enter sleep mode for the MSCAN module m. | |
void | mscan_sleep_mode_leave (volatile mscan *m) |
Leave sleep mode for the MSCAN module m. | |
volatile uint8_t * | mscan_id_acceptance_register (volatile mscan *m, unsigned i) |
Returns the address of the CANIDAR register with index i of the MSCAN module m. | |
volatile uint8_t * | mscan_id_mask_register (volatile mscan *m, unsigned i) |
Returns the address of the CANIDMR register with index i of the MSCAN module m. | |
unsigned | mscan_filter_number (volatile mscan *m) |
Returns the number of active filters of the MSCAN module m. | |
bool | mscan_set_filter_number (volatile mscan *m, unsigned number) |
Sets the number of active filters of the MSCAN module m to number and returns true if number is valid. | |
bool | mscan_filter_operation (volatile mscan *m, bool set, unsigned index, uint32_t *id, uint32_t *mask) |
Sets or gets the filter ID and mask in id and mask depending on set of MSCAN module m. The filter is selected by the value of index. | |
void | mscan_filter_clear (volatile mscan *m) |
Sets the filter ID and mask registers of the MSCAN module m to default values. | |
void | mscan_get_error_counters (volatile mscan *m, unsigned *rec, unsigned *tec) |
Returns the receiver and transmitter error counter values in rec and tec of MSCAN module m. | |
MSCAN Transmitter Flag Register (CANTFLG) | |
#define | TFLG_TXE2 (1 << 2) |
#define | TFLG_TXE1 (1 << 1) |
#define | TFLG_TXE0 (1 << 0) |
MSCAN Transmitter Interrupt Enable Register (CANTIER) | |
#define | TIER_TXEI2 (1 << 2) |
#define | TIER_TXEI1 (1 << 1) |
#define | TIER_TXEI0 (1 << 0) |
MSCAN Transmitter Message Abort Request (CANTARQ) | |
#define | TARQ_ABTRQ2 (1 << 2) |
#define | TARQ_ABTRQ1 (1 << 1) |
#define | TARQ_ABTRQ0 (1 << 0) |
MSCAN Transmitter Message Abort Acknoledge (CANTAAK) | |
#define | TAAK_ABTRQ2 (1 << 2) |
#define | TAAK_ABTRQ1 (1 << 1) |
#define | TAAK_ABTRQ0 (1 << 0) |
MSCAN Transmit Buffer Selection (CANBSEL) | |
#define | BSEL_TX2 (1 << 2) |
#define | BSEL_TX1 (1 << 1) |
#define | BSEL_TX0 (1 << 0) |
MSCAN ID Acceptance Control Register (CANIDAC) | |
#define | IDAC_IDAM1 (1 << 5) |
#define | IDAC_IDAM0 (1 << 4) |
#define | IDAC_IDAM (IDAC_IDAM1 | IDAC_IDAM0) |
#define | IDAC_IDHIT(idac) ((idac) & 0x7) |
void mscan_disable | ( | volatile mscan * | m | ) |
The module is set to sleep mode and disabled afterwards.
bool mscan_enable | ( | volatile mscan * | m, |
unsigned | bit_rate | ||
The module is set to listen only mode.
unsigned mscan_filter_number | ( | volatile mscan * | m | ) |
bool mscan_filter_operation | ( | volatile mscan * | m, |
bool | set, | ||
unsigned | index, | ||
uint32_t * | id, | ||
uint32_t * | mask | ||
Returns true if the operation was successful.
volatile uint8_t * mscan_id_acceptance_register | ( | volatile mscan * | m, |
unsigned | i | ||
volatile uint8_t * mscan_id_mask_register | ( | volatile mscan * | m, |
unsigned | i | ||
void mscan_initialization_mode_enter | ( | volatile mscan * | m, |
mscan_context * | context | ||
Saves the current MSCAN context in context.
void mscan_initialization_mode_leave | ( | volatile mscan * | m, |
const mscan_context * | context | ||
Saves the previous MSCAN context saved in context.
bool mscan_set_filter_number | ( | volatile mscan * | m, |
unsigned | number | ||
