RTEMS 6.1-rc4
#define | CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT |
This configuration option is an initializer define. | |
#define | CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE |
This configuration option is an integer define. | |
#define | CONFIGURE_POSIX_INIT_THREAD_TABLE |
This configuration option is a boolean feature define. | |
This section describes configuration options related to the POSIX initialization thread.
#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT |
The value of this configuration option initializes the entry point of the POSIX API initialization thread.
POSIX_Init
.void *( *entry_point )( void * )
.#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE |
The value of this configuration option defines the thread stack size of the POSIX API initialization thread.
The following constraints apply to this configuration option:
<rtems/confdefs.h>
does not overflow an integer of type uintptr_t. #define CONFIGURE_POSIX_INIT_THREAD_TABLE |
In case this configuration option is defined, then exactly one POSIX initialization thread is configured.
The application shall define at least one of the following configuration options
, orotherwise a compile time error in the configuration file will occur.
If no Classic API initialization task is configured, then the POSIX API initialization thread performs the Global Construction.
