RTEMS 6.1-rc4
Files | Macros
General Scheduler Configuration
file  scheduler.h
 This header file contains interfaces to define a scheduler configuration for an application.
#define CONFIGURE_CBS_MAXIMUM_SERVERS
 This configuration option is an integer define.
#define CONFIGURE_MAXIMUM_PRIORITY
#define CONFIGURE_SCHEDULER_ASSIGNMENTS
 This configuration option is an initializer define.
#define CONFIGURE_SCHEDULER_CBS
 This configuration option is a boolean feature define.
#define CONFIGURE_SCHEDULER_EDF
#define CONFIGURE_SCHEDULER_EDF_SMP
#define CONFIGURE_SCHEDULER_NAME
#define CONFIGURE_SCHEDULER_PRIORITY
#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
#define CONFIGURE_SCHEDULER_PRIORITY_SMP
#define CONFIGURE_SCHEDULER_SIMPLE
#define CONFIGURE_SCHEDULER_SIMPLE_SMP
#define CONFIGURE_SCHEDULER_STRONG_APA
#define CONFIGURE_SCHEDULER_TABLE_ENTRIES
#define CONFIGURE_SCHEDULER_USER
#define RTEMS_SCHEDULER_CBS(name)    static Scheduler_EDF_Context SCHEDULER_CBS_CONTEXT_NAME( name )
 Defines a CBS Scheduler instantiation.
#define RTEMS_SCHEDULER_TABLE_CBS(name, obj_name)
 Defines a CBS Scheduler entry for the scheduler table.
#define RTEMS_SCHEDULER_EDF(name)    static Scheduler_EDF_Context SCHEDULER_EDF_CONTEXT_NAME( name )
 Defines an EDF Scheduler instantiation.
#define RTEMS_SCHEDULER_TABLE_EDF(name, obj_name)
 Defines an EDF Scheduler entry for the scheduler table.
#define RTEMS_SCHEDULER_EDF_SMP(name)
 Defines an EDF SMP Scheduler instantiation.
#define RTEMS_SCHEDULER_TABLE_EDF_SMP(name, obj_name)
 Defines an EDF SMP Scheduler entry for the scheduler table.
#define RTEMS_SCHEDULER_PRIORITY(name, prio_count)
 Defines a Deterministic Priority Scheduler instantiation.
#define RTEMS_SCHEDULER_TABLE_PRIORITY(name, obj_name)
 Defines a Deterministic Priority Scheduler entry for the scheduler table.
#define RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP(name, prio_count)
 Defines a Arbitrary Processor Affinity Priority SMP Scheduler instantiation.
#define RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP(name, obj_name)
 Defines a Arbitrary Processor Affinity Priority SMP Scheduler entry for the scheduler table.
#define RTEMS_SCHEDULER_PRIORITY_SMP(name, prio_count)
 Defines a Deterministic Priority SMP Scheduler instantiation.
#define RTEMS_SCHEDULER_TABLE_PRIORITY_SMP(name, obj_name)
 Defines a Deterministic Priority SMP Scheduler entry for the scheduler table.
#define RTEMS_SCHEDULER_STRONG_APA(name, prio_count)
 Defines a Strong APA Scheduler instantiation.
#define RTEMS_SCHEDULER_TABLE_STRONG_APA(name, obj_name)
 Defines a Strong APA Scheduler entry for the scheduler table.
#define RTEMS_SCHEDULER_SIMPLE(name)
 Defines a Simple Scheduler instantiation.
#define RTEMS_SCHEDULER_TABLE_SIMPLE(name, obj_name)
 Defines a Simple Scheduler entry for the scheduler table.
#define RTEMS_SCHEDULER_SIMPLE_SMP(name)
 Defines a Simple SMP Scheduler instantiation.
#define RTEMS_SCHEDULER_TABLE_SIMPLE_SMP(name, obj_name)
 Defines a Simple SMP Scheduler entry for the scheduler table.
This section describes configuration options related to selecting a scheduling algorithm for an application. A scheduler configuration is optional and only necessary in very specific circumstances. A normal application configuration does not need any of the configuration options described in this section.
By default, the Deterministic Priority Scheduler algorithm is used in uniprocessor configurations. In case SMP is enabled and the configured maximum processors (CONFIGURE_MAXIMUM_PROCESSORS) is greater than one, then the Earliest Deadline First SMP Scheduler is selected as the default scheduler algorithm.
For the schedulers provided by RTEMS (see Scheduling Concepts), the configuration is straightforward. All that is required is to define the configuration option which specifies which scheduler you want for in your application.
The pluggable scheduler interface also enables the user to provide their own scheduling algorithm. If you choose to do this, you must define multiple configuration option.
◆ CONFIGURE_CBS_MAXIMUM_SERVERS
The value of this configuration option defines the maximum number Constant Bandwidth Servers that can be concurrently active.
Default Value
The default value is CONFIGURE_MAXIMUM_TASKS.
Constraints
The following constraints apply to this configuration option:
  • The value of the configuration option shall be greater than or equal to zero.
  • The value of the configuration option shall be less than or equal to SIZE_MAX.
  • The value of the configuration option shall be less than or equal to a BSP-specific and application-specific value which depends on the size of the memory available to the application.
Notes
This configuration option is only evaluated if the configuration option CONFIGURE_SCHEDULER_CBS is defined.
◆ CONFIGURE_MAXIMUM_PRIORITY
For the following schedulers
this configuration option specifies the maximum numeric priority of any task for these schedulers and one less that the number of priority levels for these schedulers. For all other schedulers provided by RTEMS, this configuration option has no effect.
Default Value
The default value is 255.
Constraints
The value of the configuration option shall be equal to 3, 7, 31, 63, 127, or 255.
Notes
The numerically greatest priority is the logically lowest priority in the system and will thus be used by the IDLE task.
Priority zero is reserved for internal use by RTEMS and is not available to applications.
Reducing the number of priorities through this configuration option reduces the amount of memory allocated by the schedulers listed above. These schedulers use a chain control structure per priority and this structure consists of three pointers. On a 32-bit architecture, the allocated memory is 12 bytes * (CONFIGURE_MAXIMUM_PRIORITY + 1), e.g. 3072 bytes for 256 priority levels (default), 48 bytes for 4 priority levels (CONFIGURE_MAXIMUM_PRIORITY == 3).
The default value is 255, because RTEMS shall support 256 priority levels to be compliant with various standards. These priorities range from 0 to 255.
◆ CONFIGURE_SCHEDULER_ASSIGNMENTS
The value of this configuration option is used to initialize the initial scheduler to processor assignments.
Default Value
The default value of this configuration option is computed so that the default scheduler is assigned to each configured processor (up to 32).
Constraints
  • The value of the configuration option shall be a list of the following macros:
    • RTEMS_SCHEDULER_ASSIGN( scheduler_index, attributes )
    • RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER
    The scheduler_index macro parameter shall be a valid index of the scheduler table defined by the CONFIGURE_SCHEDULER_TABLE_ENTRIES configuration option.
    The attributes macro parameter shall be set to exactly one of the following constants:
    • RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY
    • RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL
  • The value of the configuration option shall be a list of exactly CONFIGURE_MAXIMUM_PROCESSORS elements.
Notes
Where the system was built with SMP support enabled, this configuration option is evaluated, otherwise it is ignored.
This is an advanced configuration option, see Clustered Scheduler Configuration.
◆ CONFIGURE_SCHEDULER_CBS
In case this configuration option is defined, then the Constant Bandwidth Server Scheduling (CBS) algorithm is made available to the application.
Default Configuration
If this configuration option is undefined, then the described feature is not enabled.
Notes
This scheduler configuration option is an advanced configuration option. Think twice before you use it.
In case no explicit Clustered Scheduler Configuration is present, then it is used as the scheduler for exactly one processor.
◆ CONFIGURE_SCHEDULER_EDF
In case this configuration option is defined, then the Earliest Deadline First Scheduler algorithm is made available to the application.
Notes
◆ CONFIGURE_SCHEDULER_EDF_SMP
In case this configuration option is defined, then the Earliest Deadline First SMP Scheduler algorithm is made available to the application.
Notes
This scheduler algorithm is only available when RTEMS is built with SMP support enabled.
In case no explicit Clustered Scheduler Configuration is present, then it is used as the scheduler for up to 32 processors.
This scheduler algorithm is the default in SMP configurations if CONFIGURE_MAXIMUM_PROCESSORS is greater than one.
◆ CONFIGURE_SCHEDULER_NAME
The value of this configuration option defines the name of the default scheduler.
Default Value
Constraints
The value of the configuration option shall be convertible to an integer of type rtems_name.
Notes
Schedulers can be identified via rtems_scheduler_ident().
Use rtems_build_name() to define the scheduler name.
◆ CONFIGURE_SCHEDULER_PRIORITY
In case this configuration option is defined, then the Deterministic Priority Scheduler algorithm is made available to the application.
Notes
This scheduler algorithm is the default when CONFIGURE_MAXIMUM_PROCESSORS is exactly one.
The memory allocated for this scheduler depends on the CONFIGURE_MAXIMUM_PRIORITY configuration option.
◆ CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
In case this configuration option is defined, then the Arbitrary Processor Affinity Priority SMP Scheduler algorithm is made available to the application.
Notes
◆ CONFIGURE_SCHEDULER_PRIORITY_SMP
In case this configuration option is defined, then the Deterministic Priority SMP Scheduler algorithm is made available to the application.
Notes
◆ CONFIGURE_SCHEDULER_SIMPLE
In case this configuration option is defined, then the Simple Priority Scheduler algorithm is made available to the application.
Notes
◆ CONFIGURE_SCHEDULER_SIMPLE_SMP
In case this configuration option is defined, then the Simple Priority SMP Scheduler algorithm is made available to the application.
Notes
◆ CONFIGURE_SCHEDULER_STRONG_APA
In case this configuration option is defined, then the Strong APA algorithm is made available to the application.
Notes
This scheduler algorithm is not correctly implemented. Do not use it.
◆ CONFIGURE_SCHEDULER_TABLE_ENTRIES
The value of this configuration option is used to initialize the table of configured schedulers.
Default Value
The default value of this configuration option is the definition of exactly one table entry for the configured scheduler.
Constraints
Notes
Schedulers registered in the scheduler table by this configuration option are available to the application. The scheduler table entry index defines the index of the scheduler.
◆ CONFIGURE_SCHEDULER_USER
In case this configuration option is defined, then the user shall provide a scheduler algorithm to the application.
Notes
RTEMS allows the application to provide its own task/thread scheduling algorithm. In order to do this, one shall define CONFIGURE_SCHEDULER_USER to indicate the application provides its own scheduling algorithm. If CONFIGURE_SCHEDULER_USER is defined then the following additional macros shall be defined:
  • CONFIGURE_SCHEDULER shall be defined to a static definition of the scheduler data structures of the user scheduler.
  • CONFIGURE_SCHEDULER_TABLE_ENTRIES shall be defined to a scheduler table entry initializer for the user scheduler.
  • CONFIGURE_SCHEDULER_USER_PER_THREAD shall be defined to the type of the per-thread information of the user scheduler.
At this time, the mechanics and requirements for writing a new scheduler are evolving and not fully documented. It is recommended that you look at the existing Deterministic Priority Scheduler in cpukit/score/src/schedulerpriority*.c for guidance. For guidance on the configuration macros, please examine cpukit/include/rtems/confdefs/scheduler.h for how these are defined for the Deterministic Priority Scheduler.
◆ RTEMS_SCHEDULER_CBS
#define RTEMS_SCHEDULER_CBS (   name)     static Scheduler_EDF_Context SCHEDULER_CBS_CONTEXT_NAME( name )
Parameters
nameis the scheduler instantiation name.
◆ RTEMS_SCHEDULER_EDF
#define RTEMS_SCHEDULER_EDF (   name)     static Scheduler_EDF_Context SCHEDULER_EDF_CONTEXT_NAME( name )
Parameters
◆ RTEMS_SCHEDULER_EDF_SMP
#define RTEMS_SCHEDULER_EDF_SMP (   name)
Value:
static struct { \
#define CONFIGURE_MAXIMUM_PROCESSORS
Definition: appl-config.h:2967
#define SCHEDULER_EDF_SMP_CONTEXT_NAME(name)
Defines an EDF SMP Scheduler context name based on the instantiation name.
Definition: scheduler.h:249
Definition: scheduleredfsmp.h:115
Definition: scheduleredfsmp.h:89
Parameters
◆ RTEMS_SCHEDULER_PRIORITY
#define RTEMS_SCHEDULER_PRIORITY (   name,
  prio_count
Value:
static struct { \
Chain_Control Ready[ ( prio_count ) ]; \
#define SCHEDULER_PRIORITY_CONTEXT_NAME(name)
Defines a Deterministic Priority Scheduler context name based on the instantiation name.
Definition: scheduler.h:312
Definition: schedulerpriority.h:83
This union represents a chain control block.
Definition: chain.h:96
Parameters
prio_countis the count of supported priority levels.
◆ RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP
#define RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP (   name,
  prio_count
Value:
static struct { \
#define SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME(name)
Defines a Arbitrary Processor Affinity Priority SMP Scheduler context name based on the instantiation...
Definition: scheduler.h:372
Scheduler context specialization for Deterministic Priority SMP schedulers.
Definition: schedulerprioritysmp.h:71
Parameters
◆ RTEMS_SCHEDULER_PRIORITY_SMP
#define RTEMS_SCHEDULER_PRIORITY_SMP (   name,
  prio_count
Value:
static struct { \
#define SCHEDULER_PRIORITY_SMP_CONTEXT_NAME(name)
Defines a Deterministic Priority SMP Scheduler context name based on the instantiation name.
Definition: scheduler.h:437
Parameters
◆ RTEMS_SCHEDULER_SIMPLE
#define RTEMS_SCHEDULER_SIMPLE (   name)
Value:
static Scheduler_simple_Context \
SCHEDULER_SIMPLE_CONTEXT_NAME( name )
Parameters
◆ RTEMS_SCHEDULER_SIMPLE_SMP
#define RTEMS_SCHEDULER_SIMPLE_SMP (   name)
Value:
static Scheduler_simple_SMP_Context \
SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name )
Parameters
◆ RTEMS_SCHEDULER_STRONG_APA
#define RTEMS_SCHEDULER_STRONG_APA (   name,
  prio_count
Value:
static struct { \
#define SCHEDULER_STRONG_APA_CONTEXT_NAME(name)
Defines a Strong APA Scheduler context name based on the instantiation name.
Definition: scheduler.h:501
CPU related variables and a CPU_Control to implement BFS.
Definition: schedulerstrongapa.h:102
Scheduler context and node definition for Strong APA scheduler.
Definition: schedulerstrongapa.h:128
Parameters
◆ RTEMS_SCHEDULER_TABLE_CBS
#define RTEMS_SCHEDULER_TABLE_CBS (   name,
  obj_name
Value:
&SCHEDULER_CBS_CONTEXT_NAME( name ).Base, \
SCHEDULER_CBS_MAXIMUM_PRIORITY, \
( obj_name ) \
SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( true ) \
#define SCHEDULER_CBS_ENTRY_POINTS
Definition: schedulercbs.h:74
#define SCHEDULER_CBS_CONTEXT_NAME(name)
Defines a CBS Scheduler context name based on the instantiation name.
Definition: scheduler.h:145
Use this macro to define an entry for the CONFIGURE_SCHEDULER_TABLE_ENTRIES application configuration option.
Parameters
nameis the scheduler object name.
◆ RTEMS_SCHEDULER_TABLE_EDF
#define RTEMS_SCHEDULER_TABLE_EDF (   name,
  obj_name
Value:
&SCHEDULER_EDF_CONTEXT_NAME( name ).Base, \
SCHEDULER_EDF_MAXIMUM_PRIORITY, \
( obj_name ) \
#define SCHEDULER_EDF_ENTRY_POINTS
Definition: scheduleredf.h:73
#define SCHEDULER_EDF_CONTEXT_NAME(name)
Defines an EDF Scheduler context name based on the instantiation name.
Definition: scheduler.h:197
Parameters
◆ RTEMS_SCHEDULER_TABLE_EDF_SMP
#define RTEMS_SCHEDULER_TABLE_EDF_SMP (   name,
  obj_name
Value:
&SCHEDULER_EDF_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
SCHEDULER_EDF_SMP_ENTRY_POINTS, \
( obj_name ) \
SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
Parameters
◆ RTEMS_SCHEDULER_TABLE_PRIORITY
#define RTEMS_SCHEDULER_TABLE_PRIORITY (   name,
  obj_name
Value:
&SCHEDULER_PRIORITY_CONTEXT_NAME( name ).Base.Base, \
RTEMS_ARRAY_SIZE( \
) - 1, \
( obj_name ) \
#define SCHEDULER_PRIORITY_ENTRY_POINTS
Definition: schedulerpriority.h:64
Parameters
◆ RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP
#define RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP (   name,
  obj_name
Value:
RTEMS_ARRAY_SIZE( \
) - 1, \
( obj_name ) \
#define SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS
Entry points for the Deterministic Priority Affinity SMP Scheduler.
Definition: schedulerpriorityaffinitysmp.h:74
Parameters
◆ RTEMS_SCHEDULER_TABLE_PRIORITY_SMP
#define RTEMS_SCHEDULER_TABLE_PRIORITY_SMP (   name,
  obj_name
Value:
&SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
RTEMS_ARRAY_SIZE( \
) - 1, \
( obj_name ) \
#define SCHEDULER_PRIORITY_SMP_ENTRY_POINTS
Entry points for the Priority SMP Scheduler.
Definition: schedulerprioritysmp.h:97
Parameters
◆ RTEMS_SCHEDULER_TABLE_SIMPLE
#define RTEMS_SCHEDULER_TABLE_SIMPLE (   name,
  obj_name
Value:
SCHEDULER_SIMPLE_MAXIMUM_PRIORITY, \
( obj_name ) \
#define SCHEDULER_SIMPLE_ENTRY_POINTS
Definition: schedulersimple.h:63
#define SCHEDULER_SIMPLE_CONTEXT_NAME(name)
Defines a Simple Scheduler context name based on the instantiation name.
Definition: scheduler.h:564
Parameters
◆ RTEMS_SCHEDULER_TABLE_SIMPLE_SMP
#define RTEMS_SCHEDULER_TABLE_SIMPLE_SMP (   name,
  obj_name
Value:
&SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name ).Base.Base, \
SCHEDULER_SIMPLE_SMP_MAXIMUM_PRIORITY, \
( obj_name ) \
#define SCHEDULER_SIMPLE_SMP_ENTRY_POINTS
Entry points for the Simple SMP Scheduler.
Definition: schedulersimplesmp.h:84
#define SCHEDULER_SIMPLE_SMP_CONTEXT_NAME(name)
Defines a Simple SMP Scheduler context name based on the instantiation name.
Definition: scheduler.h:617
Parameters
◆ RTEMS_SCHEDULER_TABLE_STRONG_APA
#define RTEMS_SCHEDULER_TABLE_STRONG_APA (   name,
  obj_name
Value:
&SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
( obj_name ) \
#define SCHEDULER_STRONG_APA_ENTRY_POINTS
Entry points for the Strong APA Scheduler.
Definition: schedulerstrongapa.h:151
Parameters
