RTEMS 6.1-rc4
Filesystem Configuration
#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
 This configuration option is a boolean feature define.
#define CONFIGURE_FILESYSTEM_ALL
#define CONFIGURE_FILESYSTEM_DOSFS
#define CONFIGURE_FILESYSTEM_FTPFS
#define CONFIGURE_FILESYSTEM_IMFS
#define CONFIGURE_FILESYSTEM_JFFS2
#define CONFIGURE_FILESYSTEM_NFS
#define CONFIGURE_FILESYSTEM_RFS
#define CONFIGURE_FILESYSTEM_TFTPFS
#define CONFIGURE_IMFS_DISABLE_CHMOD
#define CONFIGURE_IMFS_DISABLE_CHOWN
#define CONFIGURE_IMFS_DISABLE_LINK
#define CONFIGURE_IMFS_DISABLE_MKNOD
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
#define CONFIGURE_IMFS_DISABLE_MKNOD_FILE
#define CONFIGURE_IMFS_DISABLE_MOUNT
#define CONFIGURE_IMFS_DISABLE_READDIR
#define CONFIGURE_IMFS_DISABLE_READLINK
#define CONFIGURE_IMFS_DISABLE_RENAME
#define CONFIGURE_IMFS_DISABLE_RMNOD
#define CONFIGURE_IMFS_DISABLE_SYMLINK
#define CONFIGURE_IMFS_DISABLE_UNMOUNT
#define CONFIGURE_IMFS_DISABLE_UTIME
#define CONFIGURE_IMFS_ENABLE_MKFIFO
#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
 This configuration option is an integer define.
#define CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY
#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
#define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
This section describes configuration options related to filesytems. By default, the In-Memory Filesystem (IMFS) is used as the base filesystem (also known as root filesystem). In order to save some memory for your application, you can disable the filesystem support with the CONFIGURE_APPLICATION_DISABLE_FILESYSTEM configuration option. Alternatively, you can strip down the features of the base filesystem with the CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM and CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM configuration options. These three configuration options are mutually exclusive. They are intended for an advanced application configuration.
Features of the IMFS can be disabled and enabled with the following configuration options:
◆ CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
In case this configuration option is defined, then no base filesystem is initialized during system initialization and no filesystems are configured.
Default Configuration
If this configuration option is undefined, then a base filesystem and the configured filesystems are initialized during system initialization.
Notes
Filesystems shall be initialized to support file descriptor based device drivers and basic input/output functions such as printf(). Filesystems can be disabled to reduce the memory footprint of an application.
◆ CONFIGURE_FILESYSTEM_ALL
In case this configuration option is defined, then the following configuration options will be defined as well
If this configuration option is undefined, then the described feature is not enabled.
◆ CONFIGURE_FILESYSTEM_DOSFS
In case this configuration option is defined, then the DOS (FAT) filesystem is registered, so that instances of this filesystem can be mounted by the application.
Notes
This filesystem requires a Block Device Cache configuration, see CONFIGURE_APPLICATION_NEEDS_LIBBLOCK.
◆ CONFIGURE_FILESYSTEM_FTPFS
In case this configuration option is defined, then the FTP filesystem (FTP client) is registered, so that instances of this filesystem can be mounted by the application.
◆ CONFIGURE_FILESYSTEM_IMFS
In case this configuration option is defined, then the In-Memory Filesystem (IMFS) is registered, so that instances of this filesystem can be mounted by the application.
Notes
Applications will rarely need this configuration option. This configuration option is intended for test programs. You do not need to define this configuration option for the base filesystem (also known as root filesystem).
◆ CONFIGURE_FILESYSTEM_JFFS2
In case this configuration option is defined, then the JFFS2 filesystem is registered, so that instances of this filesystem can be mounted by the application.
◆ CONFIGURE_FILESYSTEM_NFS
In case this configuration option is defined, then the Network Filesystem (NFS) client is registered, so that instances of this filesystem can be mounted by the application.
◆ CONFIGURE_FILESYSTEM_RFS
In case this configuration option is defined, then the RTEMS Filesystem (RFS) is registered, so that instances of this filesystem can be mounted by the application.
Notes
◆ CONFIGURE_FILESYSTEM_TFTPFS
In case this configuration option is defined, then the TFTP filesystem (TFTP client) is registered, so that instances of this filesystem can be mounted by the application.
◆ CONFIGURE_IMFS_DISABLE_CHMOD
In case this configuration option is defined, then the root IMFS does not support changing the mode of files (no support for chmod()).
If this configuration option is undefined, then the root IMFS supports changing the mode of files.
◆ CONFIGURE_IMFS_DISABLE_CHOWN
In case this configuration option is defined, then the root IMFS does not support changing the ownership of files (no support for chown()).
If this configuration option is undefined, then the root IMFS supports changing the ownership of files.
◆ CONFIGURE_IMFS_DISABLE_LINK
In case this configuration option is defined, then the root IMFS does not support hard links (no support for link()).
If this configuration option is undefined, then the root IMFS supports hard links.
◆ CONFIGURE_IMFS_DISABLE_MKNOD
In case this configuration option is defined, then the root IMFS does not support making files (no support for mknod()).
If this configuration option is undefined, then the root IMFS supports making files.
◆ CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
In case this configuration option is defined, then the root IMFS does not support making device files.
If this configuration option is undefined, then the root IMFS supports making device files.
◆ CONFIGURE_IMFS_DISABLE_MKNOD_FILE
In case this configuration option is defined, then the root IMFS does not support making regular files.
If this configuration option is undefined, then the root IMFS supports making regular files.
◆ CONFIGURE_IMFS_DISABLE_MOUNT
In case this configuration option is defined, then the root IMFS does not support mounting other filesystems (no support for mount()).
If this configuration option is undefined, then the root IMFS supports mounting other filesystems.
◆ CONFIGURE_IMFS_DISABLE_READDIR
In case this configuration option is defined, then the root IMFS does not support reading directories (no support for readdir()). It is still possible to open files in a directory.
If this configuration option is undefined, then the root IMFS supports reading directories.
◆ CONFIGURE_IMFS_DISABLE_READLINK
In case this configuration option is defined, then the root IMFS does not support reading symbolic links (no support for readlink()).
If this configuration option is undefined, then the root IMFS supports reading symbolic links.
◆ CONFIGURE_IMFS_DISABLE_RENAME
In case this configuration option is defined, then the root IMFS does not support renaming files (no support for rename()).
If this configuration option is undefined, then the root IMFS supports renaming files.
◆ CONFIGURE_IMFS_DISABLE_RMNOD
In case this configuration option is defined, then the root IMFS does not support removing files (no support for rmnod()).
If this configuration option is undefined, then the root IMFS supports removing files.
◆ CONFIGURE_IMFS_DISABLE_SYMLINK
In case this configuration option is defined, then the root IMFS does not support creating symbolic links (no support for symlink()).
If this configuration option is undefined, then the root IMFS supports creating symbolic links.
◆ CONFIGURE_IMFS_DISABLE_UNMOUNT
In case this configuration option is defined, then the root IMFS does not support unmounting other filesystems (no support for unmount()).
If this configuration option is undefined, then the root IMFS supports unmounting other filesystems.
◆ CONFIGURE_IMFS_DISABLE_UTIME
In case this configuration option is defined, then the root IMFS does not support changing file times (no support for utime()).
If this configuration option is undefined, then the root IMFS supports changing file times.
◆ CONFIGURE_IMFS_ENABLE_MKFIFO
In case this configuration option is defined, then the root IMFS supports making FIFOs.
If this configuration option is undefined, then the root IMFS does not support making FIFOs (no support for mkfifo()).
◆ CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
The value of this configuration option defines the block size for in-memory files managed by the IMFS.
Default Value
The default value is 128.
Constraints
The value of the configuration option shall be equal to 16, 32, 64, 128, 256, or 512.
Notes
The configured block size has two impacts. The first is the average amount of unused memory in the last block of each file. For example, when the block size is 512, on average one-half of the last block of each file will remain unused and the memory is wasted. In contrast, when the block size is 16, the average unused memory per file is only 8 bytes. However, it requires more allocations for the same size file and thus more overhead per block for the dynamic memory management.
Second, the block size has an impact on the maximum size file that can be stored in the IMFS. With smaller block size, the maximum file size is correspondingly smaller. The following shows the maximum file size possible based on the configured block size:
  • when the block size is 16 bytes, the maximum file size is 1,328 bytes.
  • when the block size is 32 bytes, the maximum file size is 18,656 bytes.
  • when the block size is 64 bytes, the maximum file size is 279,488 bytes.
  • when the block size is 128 bytes, the maximum file size is 4,329,344 bytes.
  • when the block size is 256 bytes, the maximum file size is 68,173,568 bytes.
  • when the block size is 512 bytes, the maximum file size is 1,082,195,456 bytes.
◆ CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY
The value of this configuration option defines the JFFS2 delayed write task priority.
Default Value
The default value is 15.
Constraints
The following constraints apply to this configuration option:
  • The configuration option is not included in the pre-qualified feature set of RTEMS. Applications which are restricted to only use interfaces of the pre-qualified feature set of RTEMS shall not use the configuration option.
  • The value of the configuration option shall be a valid Classic API task priority. The set of valid task priorities depends on the scheduler configuration.
◆ CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
In case this configuration option is defined, then an IMFS with a reduced feature set will be the base filesystem (also known as root filesystem).
Notes
In addition, a simplified path evaluation is enabled. It allows only a look up of absolute paths.
This configuration of the IMFS is basically a device-only filesystem. It is comparable in functionality to the pseudo-filesystem name space provided before RTEMS release 4.5.0.
◆ CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
Notes
