RTEMS 6.1-rc4
The Version API provides functions to return the version or parts of the version of RTEMS you are using. More...
Files | |
file | version.h |
This header file provides the Version API. | |
const char * | rtems_version (void) |
Returns the version string. | |
int | rtems_version_major (void) |
Returns the version's major number. | |
int | rtems_version_minor (void) |
Returns the version's minor number. | |
int | rtems_version_revision (void) |
Returns the version's revision number. | |
const char * | rtems_version_control_key (void) |
Returns the version control key for the current version of code that has been built. | |
const char * | rtems_version_release_label (void) |
Returns the revision label for the current version of code that has been built. | |
bool | rtems_version_release_label_is_valid (void) |
Returns true, if the release label is valid, otherwise false. | |
const char * | rtems_board_support_package (void) |
Returns the board support package name. | |
A branch in the version control system will always fall back to a NOT-RELEASED version number with a minor number of 0. Only the release archives have a VERSION file with a final release number. That means for example that the 5 development branch will still show a version 5.0.0 even after the 5.1 release.
The reason for that are the following:
const char * rtems_board_support_package | ( | void | ) |
const char * rtems_version | ( | void | ) |
text | The version as a string. |
const char * rtems_version_control_key | ( | void | ) |
The key is specific to the version control system being used and allows the built version to be identified.
Use rtems_version_control_key_is_valid() to check if the version control key is valid.
int rtems_version_major | ( | void | ) |
int | The version's major number. |
int rtems_version_minor | ( | void | ) |
int | The version's minor number. |
const char * rtems_version_release_label | ( | void | ) |
The release label is a string of characters. Only the RTEMS project released sources can have an empty release label.
Use rtems_version_release_label_is_valid() to check if the release label is valid.
bool rtems_version_release_label_is_valid | ( | void | ) |
true | The release label is valid. |
false | Otherwise. |
int rtems_version_revision | ( | void | ) |
int | The version's revision number. |
