RTEMS 6.1-rc4
Object Services
RTEMS provides a collection of services to assist in the management and usage of the objects created and utilized via other managers. These services assist in the manipulation of RTEMS objects independent of the API used to create them. More...
struct  rtems_object_api_class_information
 This structure is used to return information to the application about the objects configured for a specific API/Class combination. More...
#define rtems_object_id_api_minimum(void)   OBJECTS_INTERNAL_API
 Gets the lowest valid value for the API component of an object identifier.
#define rtems_object_id_api_maximum(void)   OBJECTS_APIS_LAST
 Gets the highest valid value for the API component of an object identifier.
#define RTEMS_OBJECT_ID_FINAL   OBJECTS_ID_FINAL
 This constant represents the highest object identifier value.
#define RTEMS_OBJECT_ID_FINAL_INDEX   OBJECTS_ID_FINAL_INDEX
 This constant represents the highest value for the index component of an object identifier.
#define RTEMS_OBJECT_ID_INITIAL(_api, _class, _node)    OBJECTS_ID_INITIAL( _api, _class, _node )
 Builds the object identifier with the lowest index from the API, class, and MPCI node components.
#define RTEMS_OBJECT_ID_INITIAL_INDEX   OBJECTS_ID_INITIAL_INDEX
 This constant represents the lowest value for the index component of an object identifier.
#define RTEMS_SEARCH_ALL_NODES   OBJECTS_SEARCH_ALL_NODES
 This constant indicates that an object name to identifier search should search through all MPCI nodes of the system.
#define RTEMS_SEARCH_LOCAL_NODE   OBJECTS_SEARCH_LOCAL_NODE
 This constant indicates that an object name to identifier search should search only the local MPCI node of the system.
#define RTEMS_SEARCH_OTHER_NODES   OBJECTS_SEARCH_OTHER_NODES
 This constant indicates that an object name to identifier search should search through all MPCI nodes of the system except the local node.
#define RTEMS_WHO_AM_I   OBJECTS_WHO_AM_I
 This constant indicates that an object name to identifier search is being asked for the identifier of the currently executing task.
rtems_id rtems_build_id (uint32_t api, uint32_t the_class, uint32_t node, uint32_t index)
 Builds the object identifier from the API, class, MPCI node, and index components.
rtems_name rtems_build_name (char c1, char c2, char c3, char c4)
 Builds the object name composed of the four characters.
rtems_status_code rtems_object_get_classic_name (rtems_id id, rtems_name *name)
 Gets the object name associated with the object identifier.
char * rtems_object_get_name (rtems_id id, size_t length, char *name)
 Gets the object name associated with the object identifier as a string.
rtems_status_code rtems_object_set_name (rtems_id id, const char *name)
 Sets the object name of the object associated with the object identifier.
int rtems_object_id_get_api (rtems_id id)
 Gets the API component of the object identifier.
int rtems_object_id_get_class (rtems_id id)
 Gets the class component of the object identifier.
int rtems_object_id_get_node (rtems_id id)
 Gets the MPCI node component of the object identifier.
int rtems_object_id_get_index (rtems_id id)
 Gets the index component of the object identifier.
int rtems_object_api_minimum_class (int api)
 Gets the lowest valid class value of the object API.
int rtems_object_api_maximum_class (int api)
 Gets the highest valid class value of the object API.
const char * rtems_object_get_api_name (int api)
 Gets a descriptive name of the object API.
const char * rtems_object_get_api_class_name (int the_api, int the_class)
 Gets a descriptive name of the object class of the object API.
rtems_status_code rtems_object_get_class_information (int the_api, int the_class, rtems_object_api_class_information *info)
 Gets the object class information of the object class of the object API.
◆ rtems_object_id_api_maximum
int rtems_object_id_api_maximum (   void)    OBJECTS_APIS_LAST
Returns
Returns the highest valid value for the API component of an object identifier.
Constraints
The following constraints apply to this directive:
  • The directive is implemented by a macro and may be called from within C/C++ constant expressions. In addition, a function implementation of the directive exists for bindings to other programming languages.
  • The directive will not cause the calling task to be preempted.
◆ rtems_object_id_api_minimum
int rtems_object_id_api_minimum (   void)    OBJECTS_INTERNAL_API
Returns
Returns the lowest valid value for the API component of an object identifier.
Constraints
◆ RTEMS_OBJECT_ID_INITIAL
#define RTEMS_OBJECT_ID_INITIAL (   _api,
  _class,
  _node
Parameters
_apiis the API of the object identifier to build.
_classis the class of the object identifier to build.
_nodeis the MPCI node of the object identifier to build.
Returns
Returns the object identifier with the lowest index built from the API, class, and MPCI node components.
Constraints
  • The directive may be called from within any runtime context.
◆ rtems_build_id()
rtems_id rtems_build_id ( uint32_t  api,
uint32_t  the_class,
uint32_t  node,
uint32_t  index
Parameters
the_classis the class of the object identifier to build.
indexis the index of the object identifier to build.
Returns
Returns the object identifier built from the API, class, MPCI node, and index components.
Constraints
◆ rtems_build_name()
rtems_name rtems_build_name ( char  c1,
char  c2,
char  c3,
char  c4
Parameters
c1is the first character of the name.
c2is the second character of the name.
c3is the third character of the name.
c4is the fourth character of the name.
This directive takes the four characters provided as arguments and composes a 32-bit object name with c1 in the most significant 8-bits and c4 in the least significant 8-bits.
Returns
Returns the object name composed of the four characters.
Constraints
◆ rtems_object_api_maximum_class()
int rtems_object_api_maximum_class ( int  api)
Parameters
apiis the object API to get the highest valid class value.
Return values
0The object API was invalid.
Returns
Returns the highest valid class value of the object API.
Constraints
◆ rtems_object_api_minimum_class()
int rtems_object_api_minimum_class ( int  api)
Parameters
apiis the object API to get the lowest valid class value.
Return values
-1The object API was invalid.
Returns
Returns the lowest valid class value of the object API.
Constraints
◆ rtems_object_get_api_class_name()
const char * rtems_object_get_api_class_name ( int  the_api,
int  the_class
Parameters
the_apiis the object API of the object class.
the_classis the object class of the object API to get the name.
Return values
BAD APIThe API was invalid.
BAD CLASSThe class of the API was invalid.
Returns
Returns a descriptive name of the class of the API, if the class of the API and the API were valid.
Notes
The string returned is from constant space. Do not modify or free it.
Constraints
◆ rtems_object_get_api_name()
const char * rtems_object_get_api_name ( int  api)
Parameters
apiis the object API to get the name.
Return values
Returns
Returns a descriptive name of the API, if the API was valid.
Notes
Constraints
◆ rtems_object_get_class_information()
rtems_status_code rtems_object_get_class_information ( int  the_api,
int  the_class,
rtems_object_api_class_information info
Parameters
the_classis the object class of the object API to get the class information.
[out]infois the pointer to an rtems_object_api_class_information object. When the directive call is successful, the object class information of the class of the API will be stored in this object.
Return values
RTEMS_SUCCESSFULThe requested operation was successful.
RTEMS_INVALID_ADDRESSThe info parameter was NULL.
RTEMS_INVALID_NUMBERThe class of the API or the API was invalid.
Constraints
◆ rtems_object_get_classic_name()
rtems_status_code rtems_object_get_classic_name ( rtems_id  id,
rtems_name name
Parameters
idis the object identifier to get the name.
[out]nameis the pointer to an rtems_name object. When the directive call is successful, the object name associated with the object identifier will be stored in this object.
Return values
RTEMS_INVALID_ADDRESSThe name parameter was NULL.
RTEMS_INVALID_IDThere was no object information available for the object identifier.
RTEMS_INVALID_IDThe object name associated with the object identifier was a string.
RTEMS_INVALID_IDThere was no object associated with the object identifier.
Constraints
◆ rtems_object_get_name()
char * rtems_object_get_name ( rtems_id  id,
size_t  length,
char *  name
Parameters
lengthis the buffer length in bytes.
[out]nameis the pointer to a buffer of the specified length.
The object name is stored in the name buffer. If the name buffer length is greater than zero, then the stored object name will be NUL terminated. The stored object name may be truncated to fit the length. There is no indication if a truncation occurred. Every attempt is made to return name as a printable string even if the object has the Classic API 32-bit integer style name.
Return values
NULLThe length parameter was 0.
NULLThe name parameter was NULL.
NULLThere was no object information available for the object identifier.
NULLThere was no object associated with the object identifier.
Returns
Returns the name parameter value, if there is an object name associated with the object identifier.
Constraints
◆ rtems_object_id_get_api()
int rtems_object_id_get_api ( rtems_id  id)
Parameters
idis the object identifier with the API component to get.
Returns
Returns the API component of the object identifier.
Notes
This directive does not validate the object identifier provided in id.
Constraints
◆ rtems_object_id_get_class()
int rtems_object_id_get_class ( rtems_id  id)
Parameters
idis the object identifier with the class component to get.
Returns
Returns the class component of the object identifier.
Notes
Constraints
◆ rtems_object_id_get_index()
int rtems_object_id_get_index ( rtems_id  id)
Parameters
idis the object identifier with the index component to get.
Returns
Returns the index component of the object identifier.
Notes
Constraints
◆ rtems_object_id_get_node()
int rtems_object_id_get_node ( rtems_id  id)
Parameters
idis the object identifier with the MPCI node component to get.
Returns
Returns the MPCI node component of the object identifier.
Notes
Constraints
◆ rtems_object_set_name()
rtems_status_code rtems_object_set_name ( rtems_id  id,
const char *  name
Parameters
idis the object identifier of the object to set the name.
nameis the object name to set.
This directive will set the object name based upon the user string.
Return values
RTEMS_NO_MEMORYThere was no memory available to duplicate the name.
Notes
This directive can be used to set the name of objects which do not have a naming scheme per their API.
If the object specified by id is of a class that has a string name, this directive will free the existing name to the RTEMS Workspace and allocate enough memory from the RTEMS Workspace to make a copy of the string located at name.
If the object specified by id is of a class that has a 32-bit integer style name, then the first four characters in name will be used to construct the name.
Constraints
  • The directive may be called from within device driver initialization context.
  • The directive may be called from within task context.
  • The directive may obtain and release the object allocator mutex. This may cause the calling task to be preempted.
