#define | XNANDPSU_H /* by using protection macros */ |
#define | XNANDPSU_DEBUG |
#define | XNANDPSU_MAX_TARGETS 1U |
#define | XNANDPSU_MAX_PKT_SIZE 0x7FFU |
#define | XNANDPSU_MAX_PKT_COUNT 0xFFFU |
#define | XNANDPSU_PAGE_SIZE_512 512U |
#define | XNANDPSU_PAGE_SIZE_2K 2048U |
#define | XNANDPSU_PAGE_SIZE_4K 4096U |
#define | XNANDPSU_PAGE_SIZE_8K 8192U |
#define | XNANDPSU_PAGE_SIZE_16K 16384U |
#define | XNANDPSU_PAGE_SIZE_1K_16BIT 1024U |
#define | XNANDPSU_MAX_PAGE_SIZE 16384U |
#define | XNANDPSU_HAMMING 0x1U |
#define | XNANDPSU_BCH 0x2U |
#define | XNANDPSU_MAX_BLOCKS 16384U |
#define | XNANDPSU_MAX_SPARE_SIZE 0x800U |
#define | XNANDPSU_MAX_LUNS 8U |
#define | XNANDPSU_MAX_PAGES_PER_BLOCK 512U |
#define | XNANDPSU_INTR_POLL_TIMEOUT 0xF000000U |
#define | XNANDPSU_SDR_CLK ((u16)100U * (u16)1000U * (u16)1000U) |
#define | XNANDPSU_NVDDR_CLK_0 ((u16)20U * (u16)1000U * (u16)1000U) |
#define | XNANDPSU_NVDDR_CLK_1 ((u16)33U * (u16)1000U * (u16)1000U) |
#define | XNANDPSU_NVDDR_CLK_2 ((u16)50U * (u16)1000U * (u16)1000U) |
#define | XNANDPSU_NVDDR_CLK_3 ((u16)66U * (u16)1000U * (u16)1000U) |
#define | XNANDPSU_NVDDR_CLK_4 ((u16)83U * (u16)1000U * (u16)1000U) |
#define | XNANDPSU_NVDDR_CLK_5 ((u16)100U * (u16)1000U * (u16)1000U) |
#define | XNANDPSU_MAX_TIMING_MODE 5 |
#define | XNandPsu_SetBits(InstancePtr, RegOffset, BitMask) |
#define | XNandPsu_ClrBits(InstancePtr, RegOffset, BitMask) |
#define | XNandPsu_ReadModifyWrite(InstancePtr, RegOffset, Mask, Value) |
#define | XNandPsu_IntrSigEnable(InstancePtr, Mask) |
#define | XNandPsu_IntrSigClear(InstancePtr, Mask) |
#define | XNandPsu_IntrStsEnable(InstancePtr, Mask) |
#define | IS_ONFI(Buff) |
#define | XNANDPSU_BBM_H /* by using protection macros */ |
#define | XNANDPSU_BLOCK_GOOD 0x0U |
#define | XNANDPSU_BLOCK_BAD 0x1U |
#define | XNANDPSU_BLOCK_RESERVED 0x2U |
#define | XNANDPSU_BLOCK_FACTORY_BAD 0x3U |
#define | XNANDPSU_FLASH_BLOCK_GOOD 0x3U |
#define | XNANDPSU_FLASH_BLOCK_BAD 0x2U |
#define | XNANDPSU_FLASH_BLOCK_RESERVED 0x1U |
#define | XNANDPSU_FLASH_BLOCK_FAC_BAD 0x0U |
#define | XNANDPSU_BBT_SCAN_2ND_PAGE 0x00000001U |
#define | XNANDPSU_BBT_DESC_PAGE_OFFSET 0U |
#define | XNANDPSU_BBT_DESC_SIG_OFFSET 8U |
#define | XNANDPSU_BBT_DESC_VER_OFFSET 12U |
#define | XNANDPSU_NO_OOB_BBT_DESC_SIG_OFFSET 0U |
#define | XNANDPSU_NO_OOB_BBT_DESC_VER_OFFSET 4U |
#define | XNANDPSU_BBT_DESC_SIG_LEN 4U |
#define | XNANDPSU_BBT_DESC_MAX_BLOCKS 64U |
#define | XNANDPSU_BBT_BLOCK_SHIFT 2U |
#define | XNANDPSU_BBT_ENTRY_NUM_BLOCKS 4U |
#define | XNANDPSU_BB_PTRN_OFF_SML_PAGE 5U |
#define | XNANDPSU_BB_PTRN_LEN_SML_PAGE 1U |
#define | XNANDPSU_BB_PTRN_OFF_LARGE_PAGE 0U |
#define | XNANDPSU_BB_PTRN_LEN_LARGE_PAGE 2U |
#define | XNANDPSU_BB_PATTERN 0xFFU |
#define | XNANDPSU_BLOCK_TYPE_MASK 0x03U |
#define | XNANDPSU_BLOCK_SHIFT_MASK 0x06U |
#define | XNANDPSU_ONDIE_SIG_OFFSET 0x4U |
#define | XNANDPSU_ONDIE_VER_OFFSET 0x14U |
#define | XNANDPSU_BBT_VERSION_LENGTH 1U |
#define | XNANDPSU_BBT_SIG_LENGTH 4U |
#define | XNANDPSU_BBT_BUF_LENGTH |
#define | XNandPsu_BbtBlockShift(Block) (u8)(((Block) * 2U) & XNANDPSU_BLOCK_SHIFT_MASK) |
#define | XNANDPSU_HW_H /* by using protection macros */ |
#define | XNANDPSU_PKT_OFFSET 0x00U |
#define | XNANDPSU_MEM_ADDR1_OFFSET 0x04U |
#define | XNANDPSU_MEM_ADDR2_OFFSET 0x08U |
#define | XNANDPSU_CMD_OFFSET 0x0CU |
#define | XNANDPSU_PROG_OFFSET 0x10U |
#define | XNANDPSU_INTR_STS_EN_OFFSET 0x14U |
#define | XNANDPSU_INTR_SIG_EN_OFFSET 0x18U |
#define | XNANDPSU_INTR_STS_OFFSET 0x1CU |
#define | XNANDPSU_READY_BUSY_OFFSET 0x20U |
#define | XNANDPSU_FLASH_STS_OFFSET 0x28U |
#define | XNANDPSU_TIMING_OFFSET 0x2CU |
#define | XNANDPSU_BUF_DATA_PORT_OFFSET 0x30U |
#define | XNANDPSU_ECC_OFFSET 0x34U |
#define | XNANDPSU_ECC_ERR_CNT_OFFSET 0x38U |
#define | XNANDPSU_ECC_SPR_CMD_OFFSET 0x3CU |
#define | XNANDPSU_ECC_CNT_1BIT_OFFSET 0x40U |
#define | XNANDPSU_ECC_CNT_2BIT_OFFSET 0x44U |
#define | XNANDPSU_ECC_CNT_3BIT_OFFSET 0x48U |
#define | XNANDPSU_ECC_CNT_4BIT_OFFSET 0x4CU |
#define | XNANDPSU_CPU_REL_OFFSET 0x58U |
#define | XNANDPSU_ECC_CNT_5BIT_OFFSET 0x5CU |
#define | XNANDPSU_ECC_CNT_6BIT_OFFSET 0x60U |
#define | XNANDPSU_ECC_CNT_7BIT_OFFSET 0x64U |
#define | XNANDPSU_ECC_CNT_8BIT_OFFSET 0x68U |
#define | XNANDPSU_DATA_INTF_OFFSET 0x6CU |
#define | XNANDPSU_DMA_SYS_ADDR0_OFFSET 0x50U |
#define | XNANDPSU_DMA_SYS_ADDR1_OFFSET 0x24U |
#define | XNANDPSU_DMA_BUF_BND_OFFSET 0x54U |
#define | XNANDPSU_SLV_DMA_CONF_OFFSET 0x80U |
#define | XNANDPSU_ONFI_H /* by using protection macros */ |
#define | ONFI_CMD_RD1 0x00U |
#define | ONFI_CMD_RD2 0x30U |
#define | ONFI_CMD_CHNG_RD_COL1 0x05U |
#define | ONFI_CMD_CHNG_RD_COL2 0xE0U |
#define | ONFI_CMD_BLK_ERASE1 0x60U |
#define | ONFI_CMD_BLK_ERASE2 0xD0U |
#define | ONFI_CMD_RD_STS 0x70U |
#define | ONFI_CMD_PG_PROG1 0x80U |
#define | ONFI_CMD_PG_PROG2 0x10U |
#define | ONFI_CMD_CHNG_WR_COL 0x85U |
#define | ONFI_CMD_RD_ID 0x90U |
#define | ONFI_CMD_RD_PRM_PG 0xECU |
#define | ONFI_CMD_RST 0xFFU |
#define | ONFI_CMD_MUL_RD1 0x00U |
#define | ONFI_CMD_MUL_RD2 0x32U |
#define | ONFI_CMD_CPBK_RD1 0x00U |
#define | ONFI_CMD_CPBK_RD2 0x35U |
#define | ONFI_CMD_CHNG_RD_COL_ENHCD1 0x06U |
#define | ONFI_CMD_CHNG_RD_COL_ENHCD2 0xE0U |
#define | ONFI_CMD_RD_CACHE_RND1 0x00U |
#define | ONFI_CMD_RD_CACHE_RND2 0x31U |
#define | ONFI_CMD_RD_CACHE_SEQ 0x31U |
#define | ONFI_CMD_RD_CACHE_END 0x3FU |
#define | ONFI_CMD_MUL_BLK_ERASE1 0x60U |
#define | ONFI_CMD_MUL_BLK_ERASE2 0xD1U |
#define | ONFI_CMD_RD_STS_ENHCD 0x78U |
#define | ONFI_CMD_BLK_ERASE_INTRLVD2 0xD1U |
#define | ONFI_CMD_MUL_PG_PROG1 0x80U |
#define | ONFI_CMD_MUL_PG_PROG2 0x11U |
#define | ONFI_CMD_PG_CACHE_PROG1 0x80U |
#define | ONFI_CMD_PG_CACHE_PROG2 0x15U |
#define | ONFI_CMD_CPBK_PROG1 0x85U |
#define | ONFI_CMD_CPBK_PROG2 0x10U |
#define | ONFI_CMD_MUL_CPBK_PROG1 0x85U |
#define | ONFI_CMD_MUL_CPBK_PROG2 0x10U |
#define | ONFI_CMD_SMALL_DATA_MV1 0x85U |
#define | ONFI_CMD_SMALL_DATA_MV2 0x10U |
#define | ONFI_CMD_CHNG_ROW_ADDR 0x85U |
#define | ONFI_CMD_VOL_SEL 0xE1U |
#define | ONFI_CMD_ODT_CONF 0xE2U |
#define | ONFI_CMD_RD_UNIQID 0xEDU |
#define | ONFI_CMD_GET_FEATURES 0xEEU |
#define | ONFI_CMD_SET_FEATURES 0xEFU |
#define | ONFI_CMD_LUN_GET_FEATURES 0xD4U |
#define | ONFI_CMD_LUN_SET_FEATURES 0xD5U |
#define | ONFI_CMD_RST_LUN 0xFAU |
#define | ONFI_CMD_SYN_RST 0xFCU |
#define | ONFI_STS_FAIL 0x01U |
#define | ONFI_STS_FAILC 0x02U |
#define | ONFI_STS_CSP 0x08U |
#define | ONFI_STS_VSP 0x10U |
#define | ONFI_STS_ARDY 0x20U |
#define | ONFI_STS_RDY 0x40U |
#define | ONFI_STS_WP 0x80U |
#define | ONFI_CRC_LEN 254U |
#define | ONFI_PRM_PG_LEN 256U |
#define | ONFI_MND_PRM_PGS 3U |
#define | ONFI_SIG_LEN 4U |
#define | ONFI_CMD_INVALID 0x00U |
#define | ONFI_READ_ID_LEN 4U |
#define | ONFI_READ_ID_ADDR 0x20U |
#define | ONFI_READ_ID_ADDR_CYCLES 1U |
#define | ONFI_PRM_PG_ADDR_CYCLES 1U |
#define | XQSPIPSU_H_ |
#define | BYTES256_PER_PAGE 256U |
#define | BYTES512_PER_PAGE 512U |
#define | BYTES1024_PER_PAGE 1024U |
#define | PAGES16_PER_SECTOR 16U |
#define | PAGES128_PER_SECTOR 128U |
#define | PAGES256_PER_SECTOR 256U |
#define | PAGES512_PER_SECTOR 512U |
#define | PAGES1024_PER_SECTOR 1024U |
#define | NUM_OF_SECTORS2 2U |
#define | NUM_OF_SECTORS4 4U |
#define | NUM_OF_SECTORS8 8U |
#define | NUM_OF_SECTORS16 16U |
#define | NUM_OF_SECTORS32 32U |
#define | NUM_OF_SECTORS64 64U |
#define | NUM_OF_SECTORS128 128U |
#define | NUM_OF_SECTORS256 256U |
#define | NUM_OF_SECTORS512 512U |
#define | NUM_OF_SECTORS1024 1024U |
#define | NUM_OF_SECTORS2048 2048U |
#define | NUM_OF_SECTORS4096 4096U |
#define | NUM_OF_SECTORS8192 8192U |
#define | SECTOR_SIZE_64K 0X10000U |
#define | SECTOR_SIZE_128K 0X20000U |
#define | SECTOR_SIZE_256K 0X40000U |
#define | SECTOR_SIZE_512K 0X80000U |
#define | XQSPIPSU_READMODE_DMA 0x0U |
#define | XQSPIPSU_READMODE_IO 0x1U |
#define | XQSPIPSU_SELECT_FLASH_CS_LOWER 0x1U |
#define | XQSPIPSU_SELECT_FLASH_CS_UPPER 0x2U |
#define | XQSPIPSU_SELECT_FLASH_CS_BOTH 0x3U |
#define | XQSPIPSU_SELECT_FLASH_BUS_LOWER 0x1U |
#define | XQSPIPSU_SELECT_FLASH_BUS_UPPER 0x2U |
#define | XQSPIPSU_SELECT_FLASH_BUS_BOTH 0x3U |
#define | XQSPIPSU_SELECT_MODE_SPI 0x1U |
#define | XQSPIPSU_SELECT_MODE_DUALSPI 0x2U |
#define | XQSPIPSU_SELECT_MODE_QUADSPI 0x4U |
#define | XQSPIPSU_GENFIFO_CS_SETUP 0x05U |
#define | XQSPIPSU_GENFIFO_CS_HOLD 0x04U |
#define | XQSPIPSU_CLK_ACTIVE_LOW_OPTION 0x2U |
#define | XQSPIPSU_CLK_PHASE_1_OPTION 0x4U |
#define | XQSPIPSU_MANUAL_START_OPTION 0x8U |
#define | XQSPIPSU_LQSPI_MODE_OPTION 0x20U |
#define | XQSPIPSU_LQSPI_LESS_THEN_SIXTEENMB 1U |
#define | XQSPIPSU_GENFIFO_EXP_START 0x100U |
#define | XQSPIPSU_DMA_BYTES_MAX 0x10000000U |
#define | XQSPIPSU_CLK_PRESCALE_2 0x00U |
#define | XQSPIPSU_CLK_PRESCALE_4 0x01U |
#define | XQSPIPSU_CLK_PRESCALE_8 0x02U |
#define | XQSPIPSU_CLK_PRESCALE_16 0x03U |
#define | XQSPIPSU_CLK_PRESCALE_32 0x04U |
#define | XQSPIPSU_CLK_PRESCALE_64 0x05U |
#define | XQSPIPSU_CLK_PRESCALE_128 0x06U |
#define | XQSPIPSU_CLK_PRESCALE_256 0x07U |
#define | XQSPIPSU_CR_PRESC_MAXIMUM 7U |
#define | XQSPIPSU_CONNECTION_MODE_SINGLE 0U |
#define | XQSPIPSU_CONNECTION_MODE_STACKED 1U |
#define | XQSPIPSU_CONNECTION_MODE_PARALLEL 2U |
#define | XQSPIPSU_FREQ_37_5MHZ 37500000U |
#define | XQSPIPSU_FREQ_40MHZ 40000000U |
#define | XQSPIPSU_FREQ_100MHZ 100000000U |
#define | XQSPIPSU_FREQ_150MHZ 150000000U |
#define | XQSPIPSU_MSG_FLAG_STRIPE 0x1U |
#define | XQSPIPSU_MSG_FLAG_RX 0x2U |
#define | XQSPIPSU_MSG_FLAG_TX 0x4U |
#define | XQSPIPSU_MSG_FLAG_POLL 0x8U |
#define | XQSPIPSU_RXADDR_OVER_32BIT 0x100000000U |
#define | XQSPIPSU_SET_WP 1 |
#define | XQspiPsu_Select(InstancePtr, Mask) |
#define | XQspiPsu_Enable(InstancePtr) |
#define | XQspiPsu_Disable(InstancePtr) |
#define | XQspiPsu_GetLqspiConfigReg(InstancePtr) |
#define | XQSPIPSU_HW_H |
#define | XQspiPsu_In32 Xil_In32 |
#define | XQspiPsu_Out32 Xil_Out32 |
#define | XQspiPsu_ReadReg(BaseAddress, RegOffset) XQspiPsu_In32((BaseAddress) + (RegOffset)) |
#define | XQspiPsu_WriteReg(BaseAddress, RegOffset, RegisterValue) XQspiPsu_Out32((BaseAddress) + (RegOffset), (RegisterValue)) |
#define | MAX_DELAY_CNT 10000000U |
#define | XQSPIPSU_NUM_OPTIONS (sizeof(OptionsTable) / sizeof(OptionsMap)) |
enum | XNandPsu_DataInterface { XNANDPSU_SDR = 0U
, XNANDPSU_NVDDR
enum | XNandPsu_TimingMode {
XNANDPSU_SDR0 = 0U
, XNANDPSU_SDR1
, XNANDPSU_SDR2
, XNANDPSU_SDR3
XNANDPSU_SDR4
, XNANDPSU_SDR5
, XNANDPSU_NVDDR0
, XNANDPSU_NVDDR1
XNANDPSU_NVDDR2
, XNANDPSU_NVDDR3
, XNANDPSU_NVDDR4
, XNANDPSU_NVDDR5
enum | XNandPsu_SWMode { XNANDPSU_POLLING = 0
, XNANDPSU_INTERRUPT
enum | XNandPsu_DmaMode { XNANDPSU_PIO = 0
, XNANDPSU_SDMA
, XNANDPSU_MDMA
enum | XNandPsu_EccMode { XNANDPSU_NONE = 0
, XNANDPSU_HWECC
, XNANDPSU_EZNAND
, XNANDPSU_ONDIE
enum | OnfiCommandList {
READ =0
, MULTIPLANE_READ
, COPYBACK_READ
, CHANGE_READ_COLUMN
CHANGE_READ_COLUMN_ENHANCED
, READ_CACHE_RANDOM
, READ_CACHE_SEQUENTIAL
, READ_CACHE_END
BLOCK_ERASE
, MULTIPLANE_BLOCK_ERASE
, READ_STATUS
, READ_STATUS_ENHANCED
PAGE_PROGRAM
, MULTIPLANE_PAGE_PROGRAM
, PAGE_CACHE_PROGRAM
, COPYBACK_PROGRAM
MULTIPLANE_COPYBACK_PROGRAM
, SMALL_DATA_MOVE
, CHANGE_WRITE_COLUMN
, CHANGE_ROW_ADDR
READ_ID
, VOLUME_SELECT
, ODT_CONFIGURE
, READ_PARAM_PAGE
READ_UNIQUE_ID
, GET_FEATURES
, SET_FEATURES
, LUN_GET_FEATURES
LUN_SET_FEATURES
, RESET_LUN
, SYN_RESET
, RESET
MAX_CMDS
s32 | XNandPsu_CfgInitialize (XNandPsu *InstancePtr, XNandPsu_Config *ConfigPtr, u32 EffectiveAddr) |
s32 | XNandPsu_Erase (XNandPsu *InstancePtr, u64 Offset, u64 Length) |
s32 | XNandPsu_Write (XNandPsu *InstancePtr, u64 Offset, u64 Length, u8 *SrcBuf) |
s32 | XNandPsu_Read (XNandPsu *InstancePtr, u64 Offset, u64 Length, u8 *DestBuf) |
s32 | XNandPsu_EraseBlock (XNandPsu *InstancePtr, u32 Target, u32 Block) |
s32 | XNandPsu_WriteSpareBytes (XNandPsu *InstancePtr, u32 Page, u8 *Buf) |
s32 | XNandPsu_ReadSpareBytes (XNandPsu *InstancePtr, u32 Page, u8 *Buf) |
s32 | XNandPsu_ChangeTimingMode (XNandPsu *InstancePtr, XNandPsu_DataInterface NewIntf, XNandPsu_TimingMode NewMode) |
s32 | XNandPsu_GetFeature (XNandPsu *InstancePtr, u32 Target, u8 Feature, u8 *Buf) |
s32 | XNandPsu_SetFeature (XNandPsu *InstancePtr, u32 Target, u8 Feature, u8 *Buf) |
s32 | XNandPsu_ScanBbt (XNandPsu *InstancePtr) |
s32 | XNandPsu_MarkBlockBad (XNandPsu *InstancePtr, u32 Block) |
void | XNandPsu_EnableDmaMode (XNandPsu *InstancePtr) |
void | XNandPsu_DisableDmaMode (XNandPsu *InstancePtr) |
void | XNandPsu_EnableEccMode (XNandPsu *InstancePtr) |
void | XNandPsu_DisableEccMode (XNandPsu *InstancePtr) |
void | XNandPsu_Prepare_Cmd (XNandPsu *InstancePtr, u8 Cmd1, u8 Cmd2, u8 EccState, u8 DmaMode, u8 AddrCycles) |
XNandPsu_Config * | XNandPsu_LookupConfig (u16 DevID) |
void | XNandPsu_InitBbtDesc (XNandPsu *InstancePtr) |
s32 | XNandPsu_IsBlockBad (XNandPsu *InstancePtr, u32 Block) |
u32 | XNandPsu_OnfiParamPageCrc (u8 *ParamBuf, u32 StartOff, u32 Length) |
XQspiPsu_Config * | XQspiPsu_LookupConfig (u16 DeviceId) |
s32 | XQspiPsu_CfgInitialize (XQspiPsu *InstancePtr, const XQspiPsu_Config *ConfigPtr, UINTPTR EffectiveAddr) |
void | XQspiPsu_Reset (XQspiPsu *InstancePtr) |
void | XQspiPsu_Abort (XQspiPsu *InstancePtr) |
s32 | XQspiPsu_PolledTransfer (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 NumMsg) |
s32 | XQspiPsu_InterruptTransfer (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 NumMsg) |
s32 | XQspiPsu_InterruptHandler (XQspiPsu *InstancePtr) |
void | XQspiPsu_SetStatusHandler (XQspiPsu *InstancePtr, void *CallBackRef, XQspiPsu_StatusHandler FuncPointer) |
s32 | XQspiPsu_StartDmaTransfer (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 NumMsg) |
s32 | XQspiPsu_CheckDmaDone (XQspiPsu *InstancePtr) |
s32 | XQspiPsu_SetClkPrescaler (const XQspiPsu *InstancePtr, u8 Prescaler) |
void | XQspiPsu_SelectFlash (XQspiPsu *InstancePtr, u8 FlashCS, u8 FlashBus) |
s32 | XQspiPsu_SetOptions (XQspiPsu *InstancePtr, u32 Options) |
s32 | XQspiPsu_ClearOptions (XQspiPsu *InstancePtr, u32 Options) |
u32 | XQspiPsu_GetOptions (const XQspiPsu *InstancePtr) |
s32 | XQspiPsu_SetReadMode (XQspiPsu *InstancePtr, u32 Mode) |
void | XQspiPsu_SetWP (const XQspiPsu *InstancePtr, u8 Value) |
void | XQspiPsu_WriteProtectToggle (const XQspiPsu *InstancePtr, u32 Toggle) |
| This API enables/ disables Write Protect pin on the flash parts.
void | XQspiPsu_Idle (const XQspiPsu *InstancePtr) |
void | XQspiPsu_PollDataHandler (XQspiPsu *InstancePtr, u32 StatusReg) |
void | XQspiPsu_GenFifoEntryData (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg) |
void | XQspiPsu_PollDataConfig (XQspiPsu *InstancePtr, XQspiPsu_Msg *FlashMsg) |
void | XQspiPsu_FillTxFifo (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 Size) |
void | XQspiPsu_TXSetup (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg) |
void | XQspiPsu_SetupRxDma (const XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg) |
void | XQspiPsu_Setup64BRxDma (const XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg) |
u32 | XQspiPsu_SetIOMode (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg) |
void | XQspiPsu_RXSetup (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg) |
void | XQspiPsu_TXRXSetup (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 *GenFifoEntry) |
void | XQspiPsu_GenFifoEntryDataLen (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 *GenFifoEntry) |
u32 | XQspiPsu_CreatePollDataConfig (const XQspiPsu *InstancePtr, const XQspiPsu_Msg *FlashMsg) |
u32 | XQspiPsu_SelectSpiMode (u8 SpiMode) |
void | XQspiPsu_SetDefaultConfig (XQspiPsu *InstancePtr) |
void | XQspiPsu_ReadRxFifo (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, s32 Size) |
void | XQspiPsu_IORead (XQspiPsu *InstancePtr, XQspiPsu_Msg *Msg, u32 StatusReg) |
#define | XNANDPSU_DMA_BUF_BND_BND_MASK 0x00000007U |
#define | XNANDPSU_DMA_BUF_BND_4K 0x0U |
#define | XNANDPSU_DMA_BUF_BND_8K 0x1U |
#define | XNANDPSU_DMA_BUF_BND_16K 0x2U |
#define | XNANDPSU_DMA_BUF_BND_32K 0x3U |
#define | XNANDPSU_DMA_BUF_BND_64K 0x4U |
#define | XNANDPSU_DMA_BUF_BND_128K 0x5U |
#define | XNANDPSU_DMA_BUF_BND_256K 0x6U |
#define | XNANDPSU_DMA_BUF_BND_512K 0x7U |
Below macros gives QSPI, QSPIPSU base address.
#define | XQSPIPS_BASEADDR 0XFF0F0000U |
#define | XQSPIPSU_BASEADDR 0xFF0F0100U |
#define | XQSPIPSU_OFFSET 0x100U |
QSPIPSU Enable Register
#define | XQSPIPS_EN_REG ( ( XQSPIPS_BASEADDR ) + 0X00000014U ) |
#define | XQSPIPS_EN_SHIFT 0U |
#define | XQSPIPS_EN_WIDTH 1U |
#define | XQSPIPS_EN_MASK 0X00000001U |
This register contains bits for configuring GQSPI controller
#define | XQSPIPSU_CFG_OFFSET 0X00000000U |
#define | XQSPIPSU_CFG_MODE_EN_SHIFT 30U |
#define | XQSPIPSU_CFG_MODE_EN_WIDTH 2U |
#define | XQSPIPSU_CFG_MODE_EN_MASK 0XC0000000U |
#define | XQSPIPSU_CFG_MODE_EN_DMA_MASK 0X80000000U |
#define | XQSPIPSU_CFG_GEN_FIFO_START_MODE_SHIFT 29U |
#define | XQSPIPSU_CFG_GEN_FIFO_START_MODE_WIDTH 1U |
#define | XQSPIPSU_CFG_GEN_FIFO_START_MODE_MASK 0X20000000U |
#define | XQSPIPSU_CFG_START_GEN_FIFO_SHIFT 28U |
#define | XQSPIPSU_CFG_START_GEN_FIFO_WIDTH 1U |
#define | XQSPIPSU_CFG_START_GEN_FIFO_MASK 0X10000000U |
#define | XQSPIPSU_CFG_ENDIAN_SHIFT 26U |
#define | XQSPIPSU_CFG_ENDIAN_WIDTH 1U |
#define | XQSPIPSU_CFG_ENDIAN_MASK 0X04000000U |
#define | XQSPIPSU_CFG_EN_POLL_TO_SHIFT 20U |
#define | XQSPIPSU_CFG_EN_POLL_TO_WIDTH 1U |
#define | XQSPIPSU_CFG_EN_POLL_TO_MASK 0X00100000U |
#define | XQSPIPSU_CFG_WP_HOLD_SHIFT 19U |
#define | XQSPIPSU_CFG_WP_HOLD_WIDTH 1U |
#define | XQSPIPSU_CFG_WP_HOLD_MASK 0X00080000U |
#define | XQSPIPSU_CFG_BAUD_RATE_DIV_SHIFT 3U |
#define | XQSPIPSU_CFG_BAUD_RATE_DIV_WIDTH 3U |
#define | XQSPIPSU_CFG_BAUD_RATE_DIV_MASK 0X00000038U |
#define | XQSPIPSU_CFG_CLK_PHA_SHIFT 2U |
#define | XQSPIPSU_CFG_CLK_PHA_WIDTH 1U |
#define | XQSPIPSU_CFG_CLK_PHA_MASK 0X00000004U |
#define | XQSPIPSU_CFG_CLK_POL_SHIFT 1U |
#define | XQSPIPSU_CFG_CLK_POL_WIDTH 1U |
#define | XQSPIPSU_CFG_CLK_POL_MASK 0X00000002U |
QSPIPSU Interrupt Status Register
#define | XQSPIPSU_ISR_OFFSET 0X00000004U |
#define | XQSPIPSU_ISR_RXEMPTY_SHIFT 11U |
#define | XQSPIPSU_ISR_RXEMPTY_WIDTH 1U |
#define | XQSPIPSU_ISR_RXEMPTY_MASK 0X00000800U |
#define | XQSPIPSU_ISR_GENFIFOFULL_SHIFT 10U |
#define | XQSPIPSU_ISR_GENFIFOFULL_WIDTH 1U |
#define | XQSPIPSU_ISR_GENFIFOFULL_MASK 0X00000400U |
#define | XQSPIPSU_ISR_GENFIFONOT_FULL_SHIFT 9U |
#define | XQSPIPSU_ISR_GENFIFONOT_FULL_WIDTH 1U |
#define | XQSPIPSU_ISR_GENFIFONOT_FULL_MASK 0X00000200U |
#define | XQSPIPSU_ISR_TXEMPTY_SHIFT 8U |
#define | XQSPIPSU_ISR_TXEMPTY_WIDTH 1U |
#define | XQSPIPSU_ISR_TXEMPTY_MASK 0X00000100U |
#define | XQSPIPSU_ISR_GENFIFOEMPTY_SHIFT 7U |
#define | XQSPIPSU_ISR_GENFIFOEMPTY_WIDTH 1U |
#define | XQSPIPSU_ISR_GENFIFOEMPTY_MASK 0X00000080U |
#define | XQSPIPSU_ISR_RXFULL_SHIFT 5U |
#define | XQSPIPSU_ISR_RXFULL_WIDTH 1U |
#define | XQSPIPSU_ISR_RXFULL_MASK 0X00000020U |
#define | XQSPIPSU_ISR_RXNEMPTY_SHIFT 4U |
#define | XQSPIPSU_ISR_RXNEMPTY_WIDTH 1U |
#define | XQSPIPSU_ISR_RXNEMPTY_MASK 0X00000010U |
#define | XQSPIPSU_ISR_TXFULL_SHIFT 3U |
#define | XQSPIPSU_ISR_TXFULL_WIDTH 1U |
#define | XQSPIPSU_ISR_TXFULL_MASK 0X00000008U |
#define | XQSPIPSU_ISR_TXNOT_FULL_SHIFT 2U |
#define | XQSPIPSU_ISR_TXNOT_FULL_WIDTH 1U |
#define | XQSPIPSU_ISR_TXNOT_FULL_MASK 0X00000004U |
#define | XQSPIPSU_ISR_POLL_TIME_EXPIRE_SHIFT 1U |
#define | XQSPIPSU_ISR_POLL_TIME_EXPIRE_WIDTH 1U |
#define | XQSPIPSU_ISR_POLL_TIME_EXPIRE_MASK 0X00000002U |
#define | XQSPIPSU_ISR_WR_TO_CLR_MASK 0X00000002U |
This register bits for enabling interrupts
#define | XQSPIPSU_IER_OFFSET 0X00000008U |
#define | XQSPIPSU_IER_RXEMPTY_SHIFT 11U |
#define | XQSPIPSU_IER_RXEMPTY_WIDTH 1U |
#define | XQSPIPSU_IER_RXEMPTY_MASK 0X00000800U |
#define | XQSPIPSU_IER_GENFIFOFULL_SHIFT 10U |
#define | XQSPIPSU_IER_GENFIFOFULL_WIDTH 1U |
#define | XQSPIPSU_IER_GENFIFOFULL_MASK 0X00000400U |
#define | XQSPIPSU_IER_GENFIFONOT_FULL_SHIFT 9U |
#define | XQSPIPSU_IER_GENFIFONOT_FULL_WIDTH 1U |
#define | XQSPIPSU_IER_GENFIFONOT_FULL_MASK 0X00000200U |
#define | XQSPIPSU_IER_TXEMPTY_SHIFT 8U |
#define | XQSPIPSU_IER_TXEMPTY_WIDTH 1U |
#define | XQSPIPSU_IER_TXEMPTY_MASK 0X00000100U |
#define | XQSPIPSU_IER_GENFIFOEMPTY_SHIFT 7U |
#define | XQSPIPSU_IER_GENFIFOEMPTY_WIDTH 1U |
#define | XQSPIPSU_IER_GENFIFOEMPTY_MASK 0X00000080U |
#define | XQSPIPSU_IER_RXFULL_SHIFT 5U |
#define | XQSPIPSU_IER_RXFULL_WIDTH 1U |
#define | XQSPIPSU_IER_RXFULL_MASK 0X00000020U |
#define | XQSPIPSU_IER_RXNEMPTY_SHIFT 4U |
#define | XQSPIPSU_IER_RXNEMPTY_WIDTH 1U |
#define | XQSPIPSU_IER_RXNEMPTY_MASK 0X00000010U |
#define | XQSPIPSU_IER_TXFULL_SHIFT 3U |
#define | XQSPIPSU_IER_TXFULL_WIDTH 1U |
#define | XQSPIPSU_IER_TXFULL_MASK 0X00000008U |
#define | XQSPIPSU_IER_TXNOT_FULL_SHIFT 2U |
#define | XQSPIPSU_IER_TXNOT_FULL_WIDTH 1U |
#define | XQSPIPSU_IER_TXNOT_FULL_MASK 0X00000004U |
#define | XQSPIPSU_IER_POLL_TIME_EXPIRE_SHIFT 1U |
#define | XQSPIPSU_IER_POLL_TIME_EXPIRE_WIDTH 1U |
#define | XQSPIPSU_IER_POLL_TIME_EXPIRE_MASK 0X00000002U |
This register bits for disabling interrupts
#define | XQSPIPSU_IDR_OFFSET 0X0000000CU |
#define | XQSPIPSU_IDR_RXEMPTY_SHIFT 11U |
#define | XQSPIPSU_IDR_RXEMPTY_WIDTH 1U |
#define | XQSPIPSU_IDR_RXEMPTY_MASK 0X00000800U |
#define | XQSPIPSU_IDR_GENFIFOFULL_SHIFT 10U |
#define | XQSPIPSU_IDR_GENFIFOFULL_WIDTH 1U |
#define | XQSPIPSU_IDR_GENFIFOFULL_MASK 0X00000400U |
#define | XQSPIPSU_IDR_GENFIFONOT_FULL_SHIFT 9U |
#define | XQSPIPSU_IDR_GENFIFONOT_FULL_WIDTH 1U |
#define | XQSPIPSU_IDR_GENFIFONOT_FULL_MASK 0X00000200U |
#define | XQSPIPSU_IDR_TXEMPTY_SHIFT 8U |
#define | XQSPIPSU_IDR_TXEMPTY_WIDTH 1U |
#define | XQSPIPSU_IDR_TXEMPTY_MASK 0X00000100U |
#define | XQSPIPSU_IDR_GENFIFOEMPTY_SHIFT 7U |
#define | XQSPIPSU_IDR_GENFIFOEMPTY_WIDTH 1U |
#define | XQSPIPSU_IDR_GENFIFOEMPTY_MASK 0X00000080U |
#define | XQSPIPSU_IDR_RXFULL_SHIFT 5U |
#define | XQSPIPSU_IDR_RXFULL_WIDTH 1U |
#define | XQSPIPSU_IDR_RXFULL_MASK 0X00000020U |
#define | XQSPIPSU_IDR_RXNEMPTY_SHIFT 4U |
#define | XQSPIPSU_IDR_RXNEMPTY_WIDTH 1U |
#define | XQSPIPSU_IDR_RXNEMPTY_MASK 0X00000010U |
#define | XQSPIPSU_IDR_TXFULL_SHIFT 3U |
#define | XQSPIPSU_IDR_TXFULL_WIDTH 1U |
#define | XQSPIPSU_IDR_TXFULL_MASK 0X00000008U |
#define | XQSPIPSU_IDR_TXNOT_FULL_SHIFT 2U |
#define | XQSPIPSU_IDR_TXNOT_FULL_WIDTH 1U |
#define | XQSPIPSU_IDR_TXNOT_FULL_MASK 0X00000004U |
#define | XQSPIPSU_IDR_POLL_TIME_EXPIRE_SHIFT 1U |
#define | XQSPIPSU_IDR_POLL_TIME_EXPIRE_WIDTH 1U |
#define | XQSPIPSU_IDR_POLL_TIME_EXPIRE_MASK 0X00000002U |
#define | XQSPIPSU_IDR_ALL_MASK 0X0FBEU |
This register bits for masking interrupts
#define | XQSPIPSU_IMR_OFFSET 0X00000010U |
#define | XQSPIPSU_IMR_RXEMPTY_SHIFT 11U |
#define | XQSPIPSU_IMR_RXEMPTY_WIDTH 1U |
#define | XQSPIPSU_IMR_RXEMPTY_MASK 0X00000800U |
#define | XQSPIPSU_IMR_GENFIFOFULL_SHIFT 10U |
#define | XQSPIPSU_IMR_GENFIFOFULL_WIDTH 1U |
#define | XQSPIPSU_IMR_GENFIFOFULL_MASK 0X00000400U |
#define | XQSPIPSU_IMR_GENFIFONOT_FULL_SHIFT 9U |
#define | XQSPIPSU_IMR_GENFIFONOT_FULL_WIDTH 1U |
#define | XQSPIPSU_IMR_GENFIFONOT_FULL_MASK 0X00000200U |
#define | XQSPIPSU_IMR_TXEMPTY_SHIFT 8U |
#define | XQSPIPSU_IMR_TXEMPTY_WIDTH 1U |
#define | XQSPIPSU_IMR_TXEMPTY_MASK 0X00000100U |
#define | XQSPIPSU_IMR_GENFIFOEMPTY_SHIFT 7U |
#define | XQSPIPSU_IMR_GENFIFOEMPTY_WIDTH 1U |
#define | XQSPIPSU_IMR_GENFIFOEMPTY_MASK 0X00000080U |
#define | XQSPIPSU_IMR_RXFULL_SHIFT 5U |
#define | XQSPIPSU_IMR_RXFULL_WIDTH 1U |
#define | XQSPIPSU_IMR_RXFULL_MASK 0X00000020U |
#define | XQSPIPSU_IMR_RXNEMPTY_SHIFT 4U |
#define | XQSPIPSU_IMR_RXNEMPTY_WIDTH 1U |
#define | XQSPIPSU_IMR_RXNEMPTY_MASK 0X00000010U |
#define | XQSPIPSU_IMR_TXFULL_SHIFT 3U |
#define | XQSPIPSU_IMR_TXFULL_WIDTH 1U |
#define | XQSPIPSU_IMR_TXFULL_MASK 0X00000008U |
#define | XQSPIPSU_IMR_TXNOT_FULL_SHIFT 2U |
#define | XQSPIPSU_IMR_TXNOT_FULL_WIDTH 1U |
#define | XQSPIPSU_IMR_TXNOT_FULL_MASK 0X00000004U |
#define | XQSPIPSU_IMR_POLL_TIME_EXPIRE_SHIFT 1U |
#define | XQSPIPSU_IMR_POLL_TIME_EXPIRE_WIDTH 1U |
#define | XQSPIPSU_IMR_POLL_TIME_EXPIRE_MASK 0X00000002U |
This register bits for enabling QSPI controller
#define | XQSPIPSU_EN_OFFSET 0X00000014U |
#define | XQSPIPSU_EN_SHIFT 0U |
#define | XQSPIPSU_EN_WIDTH 1U |
#define | XQSPIPSU_EN_MASK 0X00000001U |
This register bits for configuring TXFIFO
#define | XQSPIPSU_TXD_OFFSET 0X0000001CU |
#define | XQSPIPSU_TXD_SHIFT 0U |
#define | XQSPIPSU_TXD_WIDTH 32U |
#define | XQSPIPSU_TXD_MASK 0XFFFFFFFFU |
#define | XQSPIPSU_TXD_DEPTH 64 |
This register bits for configuring RXFIFO
#define | XQSPIPSU_RXD_OFFSET 0X00000020U |
#define | XQSPIPSU_RXD_SHIFT 0U |
#define | XQSPIPSU_RXD_WIDTH 32U |
#define | XQSPIPSU_RXD_MASK 0XFFFFFFFFU |
This register bits for configuring TX/RX Threshold
#define | XQSPIPSU_TX_THRESHOLD_OFFSET 0X00000028U |
#define | XQSPIPSU_TX_FIFO_THRESHOLD_SHIFT 0U |
#define | XQSPIPSU_TX_FIFO_THRESHOLD_WIDTH 6U |
#define | XQSPIPSU_TX_FIFO_THRESHOLD_MASK 0X0000003FU |
#define | XQSPIPSU_TX_FIFO_THRESHOLD_RESET_VAL 0X01U |
#define | XQSPIPSU_RX_THRESHOLD_OFFSET 0X0000002CU |
#define | XQSPIPSU_RX_FIFO_THRESHOLD_SHIFT 0U |
#define | XQSPIPSU_RX_FIFO_THRESHOLD_WIDTH 6U |
#define | XQSPIPSU_RX_FIFO_THRESHOLD_MASK 0X0000003FU |
#define | XQSPIPSU_RX_FIFO_THRESHOLD_RESET_VAL 0X01U |
#define | XQSPIPSU_RXFIFO_THRESHOLD_OPT 32U |
#define | XQSPIPSU_GPIO_OFFSET 0X00000030U |
#define | XQSPIPSU_GPIO_WP_N_SHIFT 0U |
#define | XQSPIPSU_GPIO_WP_N_WIDTH 1U |
#define | XQSPIPSU_GPIO_WP_N_MASK 0X00000001U |
This register contains bits for configuring loopback
#define | XQSPIPSU_LPBK_DLY_ADJ_OFFSET 0X00000038U |
#define | XQSPIPSU_LPBK_DLY_ADJ_USE_LPBK_SHIFT 5U |
#define | XQSPIPSU_LPBK_DLY_ADJ_USE_LPBK_WIDTH 1U |
#define | XQSPIPSU_LPBK_DLY_ADJ_USE_LPBK_MASK 0X00000020U |
#define | XQSPIPSU_LPBK_DLY_ADJ_DLY1_SHIFT 3U |
#define | XQSPIPSU_LPBK_DLY_ADJ_DLY1_WIDTH 2U |
#define | XQSPIPSU_LPBK_DLY_ADJ_DLY1_MASK 0X00000018U |
#define | XQSPIPSU_LPBK_DLY_ADJ_DLY0_SHIFT 0U |
#define | XQSPIPSU_LPBK_DLY_ADJ_DLY0_WIDTH 3U |
#define | XQSPIPSU_LPBK_DLY_ADJ_DLY0_MASK 0X00000007U |
This register contains bits for configuring GENFIFO
#define | XQSPIPSU_GEN_FIFO_OFFSET 0X00000040U |
#define | XQSPIPSU_GEN_FIFO_DATA_SHIFT 0U |
#define | XQSPIPSU_GEN_FIFO_DATA_WIDTH 20U |
#define | XQSPIPSU_GEN_FIFO_DATA_MASK 0X000FFFFFU |
This register contains bits for selection GQSPI/LQSPI controller
#define | XQSPIPSU_SEL_OFFSET 0X00000044U |
#define | XQSPIPSU_SEL_SHIFT 0U |
#define | XQSPIPSU_SEL_WIDTH 1U |
#define | XQSPIPSU_SEL_LQSPI_MASK 0X0U |
#define | XQSPIPSU_SEL_GQSPI_MASK 0X00000001U |
This register contains bits for controlling TXFIFO and RXFIFO
#define | XQSPIPSU_FIFO_CTRL_OFFSET 0X0000004CU |
#define | XQSPIPSU_FIFO_CTRL_RST_RX_FIFO_SHIFT 2U |
#define | XQSPIPSU_FIFO_CTRL_RST_RX_FIFO_WIDTH 1U |
#define | XQSPIPSU_FIFO_CTRL_RST_RX_FIFO_MASK 0X00000004U |
#define | XQSPIPSU_FIFO_CTRL_RST_TX_FIFO_SHIFT 1U |
#define | XQSPIPSU_FIFO_CTRL_RST_TX_FIFO_WIDTH 1U |
#define | XQSPIPSU_FIFO_CTRL_RST_TX_FIFO_MASK 0X00000002U |
#define | XQSPIPSU_FIFO_CTRL_RST_GEN_FIFO_SHIFT 0U |
#define | XQSPIPSU_FIFO_CTRL_RST_GEN_FIFO_WIDTH 1U |
#define | XQSPIPSU_FIFO_CTRL_RST_GEN_FIFO_MASK 0X00000001U |
This register contains bits for configuring GENFIFO threshold
#define | XQSPIPSU_GF_THRESHOLD_OFFSET 0X00000050U |
#define | XQSPIPSU_GEN_FIFO_THRESHOLD_SHIFT 0U |
#define | XQSPIPSU_GEN_FIFO_THRESHOLD_WIDTH 5U |
#define | XQSPIPSU_GEN_FIFO_THRESHOLD_MASK 0X0000001FU |
#define | XQSPIPSU_GEN_FIFO_THRESHOLD_RESET_VAL 0X10U |
This register contains bits for configuring Poll feature
#define | XQSPIPSU_POLL_CFG_OFFSET 0X00000054U |
#define | XQSPIPSU_POLL_CFG_EN_MASK_UPPER_SHIFT 31U |
#define | XQSPIPSU_POLL_CFG_EN_MASK_UPPER_WIDTH 1U |
#define | XQSPIPSU_POLL_CFG_EN_MASK_UPPER_MASK 0X80000000U |
#define | XQSPIPSU_POLL_CFG_EN_MASK_LOWER_SHIFT 30U |
#define | XQSPIPSU_POLL_CFG_EN_MASK_LOWER_WIDTH 1U |
#define | XQSPIPSU_POLL_CFG_EN_MASK_LOWER_MASK 0X40000000U |
#define | XQSPIPSU_POLL_CFG_MASK_EN_SHIFT 8U |
#define | XQSPIPSU_POLL_CFG_MASK_EN_WIDTH 8U |
#define | XQSPIPSU_POLL_CFG_MASK_EN_MASK 0X0000FF00U |
#define | XQSPIPSU_POLL_CFG_DATA_VALUE_SHIFT 0U |
#define | XQSPIPSU_POLL_CFG_DATA_VALUE_WIDTH 8U |
#define | XQSPIPSU_POLL_CFG_DATA_VALUE_MASK 0X000000FFU |
#define | XQSPIPSU_P_TO_OFFSET 0X00000058U |
#define | XQSPIPSU_P_TO_VALUE_SHIFT 0U |
#define | XQSPIPSU_P_TO_VALUE_WIDTH 32U |
#define | XQSPIPSU_P_TO_VALUE_MASK 0XFFFFFFFFU |
This register contains bits for transfer status
#define | XQSPIPSU_XFER_STS_OFFSET 0X0000005CU |
#define | XQSPIPSU_XFER_STS_PEND_BYTES_SHIFT 0U |
#define | XQSPIPSU_XFER_STS_PEND_BYTES_WIDTH 32U |
#define | XQSPIPSU_XFER_STS_PEND_BYTES_MASK 0XFFFFFFFFU |
#define | XQSPIPSU_GF_SNAPSHOT_OFFSET 0X00000060U |
#define | XQSPIPSU_GF_SNAPSHOT_SHIFT 0U |
#define | XQSPIPSU_GF_SNAPSHOT_WIDTH 20U |
#define | XQSPIPSU_GF_SNAPSHOT_MASK 0X000FFFFFU |
#define | XQSPIPSU_RX_COPY_OFFSET 0X00000064U |
#define | XQSPIPSU_RX_COPY_UPPER_SHIFT 8U |
#define | XQSPIPSU_RX_COPY_UPPER_WIDTH 8U |
#define | XQSPIPSU_RX_COPY_UPPER_MASK 0X0000FF00U |
#define | XQSPIPSU_RX_COPY_LOWER_SHIFT 0U |
#define | XQSPIPSU_RX_COPY_LOWER_WIDTH 8U |
#define | XQSPIPSU_RX_COPY_LOWER_MASK 0X000000FFU |
#define | XQSPIPSU_MOD_ID_OFFSET 0X000000FCU |
#define | XQSPIPSU_MOD_ID_SHIFT 0U |
#define | XQSPIPSU_MOD_ID_WIDTH 32U |
#define | XQSPIPSU_MOD_ID_MASK 0XFFFFFFFFU |
This register contains bits for configuring DMA
#define | XQSPIPSU_QSPIDMA_DST_ADDR_OFFSET 0X00000700U |
#define | XQSPIPSU_QSPIDMA_DST_ADDR_SHIFT 2U |
#define | XQSPIPSU_QSPIDMA_DST_ADDR_WIDTH 30U |
#define | XQSPIPSU_QSPIDMA_DST_ADDR_MASK 0XFFFFFFFCU |
#define | XQSPIPSU_QSPIDMA_DST_SIZE_OFFSET 0X00000704U |
#define | XQSPIPSU_QSPIDMA_DST_SIZE_SHIFT 2U |
#define | XQSPIPSU_QSPIDMA_DST_SIZE_WIDTH 27U |
#define | XQSPIPSU_QSPIDMA_DST_SIZE_MASK 0X1FFFFFFCU |
#define | XQSPIPSU_QSPIDMA_DST_STS_OFFSET 0X00000708U |
#define | XQSPIPSU_QSPIDMA_DST_STS_DONE_CNT_SHIFT 13U |
#define | XQSPIPSU_QSPIDMA_DST_STS_DONE_CNT_WIDTH 3U |
#define | XQSPIPSU_QSPIDMA_DST_STS_DONE_CNT_MASK 0X0000E000U |
#define | XQSPIPSU_QSPIDMA_DST_STS_DST_FIFO_LEVEL_SHIFT 5U |
#define | XQSPIPSU_QSPIDMA_DST_STS_DST_FIFO_LEVEL_WIDTH 8U |
#define | XQSPIPSU_QSPIDMA_DST_STS_DST_FIFO_LEVEL_MASK 0X00001FE0U |
#define | XQSPIPSU_QSPIDMA_DST_STS_WR_OUTSTANDING_SHIFT 1U |
#define | XQSPIPSU_QSPIDMA_DST_STS_WR_OUTSTANDING_WIDTH 4U |
#define | XQSPIPSU_QSPIDMA_DST_STS_WR_OUTSTANDING_MASK 0X0000001EU |
#define | XQSPIPSU_QSPIDMA_DST_STS_BUSY_SHIFT 0U |
#define | XQSPIPSU_QSPIDMA_DST_STS_BUSY_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_STS_BUSY_MASK 0X00000001U |
#define | XQSPIPSU_QSPIDMA_DST_STS_WTC 0xE000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_OFFSET 0X0000070CU |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_LVL_HIT_THRESHOLD_SHIFT 25U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_LVL_HIT_THRESHOLD_WIDTH 7U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_LVL_HIT_THRESHOLD_MASK 0XFE000000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_APB_ERR_RESP_SHIFT 24U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_APB_ERR_RESP_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_APB_ERR_RESP_MASK 0X01000000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_ENDIAN_SHIFT 23U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_ENDIAN_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_ENDIAN_MASK 0X00800000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_AXI_BRST_TYPE_SHIFT 22U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_AXI_BRST_TYPE_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_AXI_BRST_TYPE_MASK 0X00400000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_TO_VAL_SHIFT 10U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_TO_VAL_WIDTH 12U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_TO_VAL_MASK 0X003FFC00U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_THRESHOLD_SHIFT 2U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_THRESHOLD_WIDTH 8U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_FIFO_THRESHOLD_MASK 0X000003FCU |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_STRM_SHIFT 1U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_STRM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_STRM_MASK 0X00000002U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_MEM_SHIFT 0U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_MEM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_PAUSE_MEM_MASK 0X00000001U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL_RESET_VAL 0x403FFA00U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_OFFSET 0X00000714U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_FIFO_OF_SHIFT 7U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_FIFO_OF_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_FIFO_OF_MASK 0X00000080U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_INVALID_APB_SHIFT 6U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_INVALID_APB_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_INVALID_APB_MASK 0X00000040U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_THRESHOLD_HIT_SHIFT 5U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_THRESHOLD_HIT_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_THRESHOLD_HIT_MASK 0X00000020U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_TO_MEM_SHIFT 4U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_TO_MEM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_TO_MEM_MASK 0X00000010U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_TO_STRM_SHIFT 3U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_TO_STRM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_TO_STRM_MASK 0X00000008U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_AXI_BRESP_ERR_SHIFT 2U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_AXI_BRESP_ERR_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_AXI_BRESP_ERR_MASK 0X00000004U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_DONE_SHIFT 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_DONE_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_STS_DONE_MASK 0X00000002U |
#define | XQSPIPSU_QSPIDMA_DST_INTR_ERR_MASK 0X000000FCU |
#define | XQSPIPSU_QSPIDMA_DST_INTR_ALL_MASK 0X000000FEU |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_OFFSET 0X00000718U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_FIFO_OF_SHIFT 7U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_FIFO_OF_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_FIFO_OF_MASK 0X00000080U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_INVALID_APB_SHIFT 6U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_INVALID_APB_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_INVALID_APB_MASK 0X00000040U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_THRESHOLD_HIT_SHIFT 5U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_THRESHOLD_HIT_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_THRESHOLD_HIT_MASK 0X00000020U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_TO_MEM_SHIFT 4U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_TO_MEM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_TO_MEM_MASK 0X00000010U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_TO_STRM_SHIFT 3U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_TO_STRM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_TO_STRM_MASK 0X00000008U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_AXI_BRESP_ERR_SHIFT 2U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_AXI_BRESP_ERR_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_AXI_BRESP_ERR_MASK 0X00000004U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_DONE_SHIFT 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_DONE_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_EN_DONE_MASK 0X00000002U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_OFFSET 0X0000071CU |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_FIFO_OF_SHIFT 7U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_FIFO_OF_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_FIFO_OF_MASK 0X00000080U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_INVALID_APB_SHIFT 6U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_INVALID_APB_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_INVALID_APB_MASK 0X00000040U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_THRESHOLD_HIT_SHIFT 5U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_THRESHOLD_HIT_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_THRESHOLD_HIT_MASK 0X00000020U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_TO_MEM_SHIFT 4U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_TO_MEM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_TO_MEM_MASK 0X00000010U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_TO_STRM_SHIFT 3U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_TO_STRM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_TO_STRM_MASK 0X00000008U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_AXI_BRESP_ERR_SHIFT 2U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_AXI_BRESP_ERR_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_AXI_BRESP_ERR_MASK 0X00000004U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_DONE_SHIFT 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_DONE_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_I_DIS_DONE_MASK 0X00000002U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_OFFSET 0X00000720U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_FIFO_OF_SHIFT 7U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_FIFO_OF_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_FIFO_OF_MASK 0X00000080U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_INVALID_APB_SHIFT 6U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_INVALID_APB_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_INVALID_APB_MASK 0X00000040U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_THRESHOLD_HIT_SHIFT 5U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_THRESHOLD_HIT_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_THRESHOLD_HIT_MASK 0X00000020U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_TO_MEM_SHIFT 4U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_TO_MEM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_TO_MEM_MASK 0X00000010U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_TO_STRM_SHIFT 3U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_TO_STRM_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_TO_STRM_MASK 0X00000008U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_AXI_BRESP_ERR_SHIFT 2U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_AXI_BRESP_ERR_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_AXI_BRESP_ERR_MASK 0X00000004U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_DONE_SHIFT 1U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_DONE_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_IMR_DONE_MASK 0X00000002U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_OFFSET 0X00000724U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMASA_SHIFT 27U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMASA_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMASA_MASK 0X08000000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_AWCACHE_SHIFT 24U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_AWCACHE_WIDTH 3U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_AWCACHE_MASK 0X07000000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_TO_EN_SHIFT 22U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_TO_EN_WIDTH 1U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_TO_EN_MASK 0X00400000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAB_SHIFT 19U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAB_WIDTH 3U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAB_MASK 0X00380000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAA_SHIFT 16U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAA_WIDTH 3U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_RAM_EMAA_MASK 0X00070000U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_TO_PRE_SHIFT 4U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_TO_PRE_WIDTH 12U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_TO_PRE_MASK 0X0000FFF0U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_MAX_OUTS_CMDS_SHIFT 0U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_MAX_OUTS_CMDS_WIDTH 4U |
#define | XQSPIPSU_QSPIDMA_DST_CTRL2_MAX_OUTS_CMDS_MASK 0X0000000FU |
#define | XQSPIPSU_QSPIDMA_DST_ADDR_MSB_OFFSET 0X00000728U |
#define | XQSPIPSU_QSPIDMA_DST_ADDR_MSB_SHIFT 0U |
#define | XQSPIPSU_QSPIDMA_DST_ADDR_MSB_WIDTH 12U |
#define | XQSPIPSU_QSPIDMA_DST_ADDR_MSB_MASK 0X00000FFFU |
#define | XQSPIPSU_QSPIDMA_FUTURE_ECO_OFFSET 0X00000EFCU |
#define | XQSPIPSU_QSPIDMA_FUTURE_ECO_VAL_SHIFT 0U |
#define | XQSPIPSU_QSPIDMA_FUTURE_ECO_VAL_WIDTH 32U |
#define | XQSPIPSU_QSPIDMA_FUTURE_ECO_VAL_MASK 0XFFFFFFFFU |
Generic FIFO masks information
#define | XQSPIPSU_GENFIFO_IMM_DATA_MASK 0xFFU |
#define | XQSPIPSU_GENFIFO_DATA_XFER 0x100U |
#define | XQSPIPSU_GENFIFO_EXP 0x200U |
#define | XQSPIPSU_GENFIFO_MODE_SPI 0x400U |
#define | XQSPIPSU_GENFIFO_MODE_DUALSPI 0x800U |
#define | XQSPIPSU_GENFIFO_MODE_QUADSPI 0xC00U |
#define | XQSPIPSU_GENFIFO_MODE_MASK 0xC00U /* And with ~MASK first */ |
#define | XQSPIPSU_GENFIFO_CS_LOWER 0x1000U |
#define | XQSPIPSU_GENFIFO_CS_UPPER 0x2000U |
#define | XQSPIPSU_GENFIFO_BUS_LOWER 0x4000U |
#define | XQSPIPSU_GENFIFO_BUS_UPPER 0x8000U |
#define | XQSPIPSU_GENFIFO_BUS_BOTH 0xC000U /* inverse is no bus */ |
#define | XQSPIPSU_GENFIFO_BUS_MASK 0xC000U /* And with ~MASK first */ |
#define | XQSPIPSU_GENFIFO_TX 0x10000U /* inverse is zero pump */ |
#define | XQSPIPSU_GENFIFO_RX 0x20000U /* inverse is RX discard */ |
#define | XQSPIPSU_GENFIFO_STRIPE 0x40000U |
#define | XQSPIPSU_GENFIFO_POLL 0x80000U |
#define | XQSPIPSU_DATA_DLY_ADJ_OFFSET 0X000000F8U |
#define | XQSPIPSU_DATA_DLY_ADJ_USE_DATA_DLY_SHIFT 31U |
#define | XQSPIPSU_DATA_DLY_ADJ_USE_DATA_DLY_WIDTH 1U |
#define | XQSPIPSU_DATA_DLY_ADJ_USE_DATA_DLY_MASK 0X80000000U |
#define | XQSPIPSU_DATA_DLY_ADJ_DLY_SHIFT 28U |
#define | XQSPIPSU_DATA_DLY_ADJ_DLY_WIDTH 3U |
#define | XQSPIPSU_DATA_DLY_ADJ_DLY_MASK 0X70000000U |
#define | IOU_TAPDLY_BYPASS_OFFSET 0X00000390U |
#define | IOU_TAPDLY_BYPASS_LQSPI_RX_SHIFT 0X02U |
#define | IOU_TAPDLY_BYPASS_LQSPI_RX_WIDTH 0X01U |
#define | IOU_TAPDLY_BYPASS_LQSPI_RX_MASK 0x00000004U |
#define | IOU_TAPDLY_RESET_STATE 0x7U |
This file implements a driver to support Arasan NAND controller present in Zynq Ultrascale Mp.
Driver Initialization
The function call XNandPsu_CfgInitialize() should be called by the application before any other function in the driver. The initialization function takes device specific data (like device id, instance id, and base address) and initializes the XNandPsu instance with the device specific data.
Device Geometry
NAND flash device is memory device and it is segmented into areas called Logical Unit(s) (LUN) and further in to blocks and pages. A NAND flash device can have multiple LUN. LUN is sequential raw of multiple blocks of the same size. A block is the smallest erasable unit of data within the Flash array of a LUN. The size of each block is based on a power of 2. There is no restriction on the number of blocks within the LUN. A block contains a number of pages. A page is the smallest addressable unit for read and program operations. The arrangement of LUN, blocks, and pages is referred to by this module as the part's geometry.
The cells within the part can be programmed from a logic 1 to a logic 0 and not the other way around. To change a cell back to a logic 1, the entire block containing that cell must be erased. When a block is erased all bytes contain the value 0xFF. The number of times a block can be erased is finite. Eventually the block will wear out and will no longer be capable of erasure. As of this writing, the typical flash block can be erased 100,000 or more times.
The jobs done by this driver typically are:
- 8-bit operational mode
- Read, Write, and Erase operation
Write Operation
The write call can be used to write a minimum of one byte and a maximum entire flash. If the address offset specified to write is out of flash or if the number of bytes specified from the offset exceed flash boundaries an error is reported back to the user. The write is blocking in nature in that the control is returned back to user only after the write operation is completed successfully or an error is reported.
Read Operation
The read call can be used to read a minimum of one byte and maximum of entire flash. If the address offset specified to read is out of flash or if the number of bytes specified from the offset exceed flash boundaries an error is reported back to the user. The read is blocking in nature in that the control is returned back to user only after the read operation is completed successfully or an error is reported.
Erase Operation
The erase operations are provided to erase a Block in the Flash memory. The erase call is blocking in nature in that the control is returned back to user only after the erase operation is completed successfully or an error is reported.
- Note
- Driver has been renamed to nandpsu after change in naming convention.
This driver is intended to be RTOS and processor independent. It works with physical addresses only. Any needs for dynamic memory management, threads, mutual exclusion, virtual memory, cache control, or HW write protection management must be satisfied by the layer above this driver.
MODIFICATION HISTORY:
Ver Who Date Changes
1.0 nm 05/06/2014 First release
2.0 sb 01/12/2015 Removed Null checks for Buffer passed
as parameter to Read API's
- XNandPsu_Read()
- XNandPsu_ReadPage
Modified
- XNandPsu_SetFeature()
- XNandPsu_GetFeature()
and made them public.
Removed Failure Return for BCF Error check in
XNandPsu_ReadPage() and added BCH_Error counter
in the instance pointer structure.
Added XNandPsu_Prepare_Cmd API
Replaced
- XNandPsu_IntrStsEnable
- XNandPsu_IntrStsClear
- XNandPsu_IntrClear
- XNandPsu_SetProgramReg
with XNandPsu_WriteReg call
Modified xnandpsu.c file API's with above changes.
Corrected the program command for Set Feature API.
Modified
- XNandPsu_OnfiReadStatus
to add support for DDR mode.
Changed Convention for SLC/MLC
SLC --> HAMMING
MLC --> BCH
SlcMlc --> IsBCH
Added support for writing BBT signature and version
in page section by enabling XNANDPSU_BBT_NO_OOB.
Removed extra DMA mode initialization from
the XNandPsu_CfgInitialize API.
Modified
- XNandPsu_SetEccAddrSize
ECC address now is calculated based upon the
size of spare area
Modified Block Erase API, removed clearing of
packet register before erase.
Clearing Data Interface Register before
XNandPsu_OnfiReset call.
Modified XNandPsu_ChangeTimingMode API supporting
SDR and NVDDR interface for timing modes 0 to 5.
Modified Bbt Signature and Version Offset value for
Oob and No-Oob region.
1.0 kpc 17/06/2015 Increased the timeout for complete event to avoid
timeout errors for erase operation on slower devices.
1.1 mi 09/16/16 Removed compilation warnings with extra compiler flags.
1.1 nsk 11/07/16 Change memcpy to Xil_MemCpy, CR#960462
1.2 nsk 01/19/17 Fix for the failure of reading nand first redundant
parameter page. CR#966603
ms 02/12/17 Fix for the compilation warning in _g.c file.
ms 03/17/17 Added readme.txt file in examples folder for doxygen
generation.
ms 04/10/17 Modified Comment lines in nandpsu_example.c to
follow doxygen rules.
1.2 nsk 08/08/17 Added support to import example in SDK
1.4 nsk 04/10/18 Added ICCARM compiler support. CR#997552.
1.5 mus 11/08/18 Updated BBT signature array size in
XNandPsu_BbtDesc structure to fix the compilation
warnings.
# 1.6 sd 06/02/20 Added Clock support
1.6 sd 20/03/20 Added compilation flag
1.8 sg 03/18/21 Added validation check for parameter page.
1.9 akm 07/15/21 Initialize NandInstPtr with Data Interface & Timing mode info.
1.10 akm 10/20/21 Fix gcc warnings.
1.10 akm 12/21/21 Validate input parameters before use.
1.10 akm 01/05/22 Remove assert checks form static and internal APIs.
1.11 akm 03/31/22 Fix unused parameter warning.
1.11 akm 03/31/22 Fix misleading-indentation warning.
This file implements the Bad Block Management(BBM) functionality. This is
similar to the Bad Block Management which is a part of the MTD subsystem in
Linux. The factory marked bad blocks are scanned initially and a Bad Block
Table(BBT) is created in the memory. This table is also written to the flash
so that upon reboot, the BBT is read back from the flash and loaded into the
memory instead of scanning every time. The Bad Block Table(BBT) is written
into one of the the last four blocks in the flash memory. The last four
blocks are marked as Reserved so that user can't erase/program those blocks.
There are two bad block tables, a primary table and a mirror table. The
tables are versioned and incrementing version number is used to detect and
recover from interrupted updates. Each table is stored in a separate block,
beginning in the first page of that block. Only two blocks would be necessary
in the absence of bad blocks within the last four; the range of four provides
a little slack in case one or two of those blocks is bad. These blocks are
marked as reserved and cannot be programmed by the user. A NAND Flash device
with 3 or more factory bad blocks in the last 4 cannot be used. The bad block
table signature is written into the spare data area of the pages containing
bad block table so that upon rebooting the bad block table signature is
searched and the bad block table is loaded into RAM. The signature is "Bbt0"
for primary Bad Block Table and "1tbB" for Mirror Bad Block Table. The
version offset follows the signature offset in the spare data area. The
version number increments on every update to the bad block table and the
version wraps at 0xff.
Each block in the Bad Block Table(BBT) is represented by 2 bits.
The two bits are encoded as follows in RAM BBT.
0'b00 -> Good Block
0'b01 -> Block is bad due to wear
0'b10 -> Reserved block
0'b11 -> Factory marked bad block
While writing to the flash the two bits are encoded as follows.
0'b00 -> Factory marked bad block
0'b01 -> Reserved block
0'b10 -> Block is bad due to wear
0'b11 -> Good Block
The user can check for the validity of the block using the API
XNandPsu_IsBlockBad and take the action based on the return value. Also user
can update the bad block table using XNandPsu_MarkBlockBad API.
- Note
- None
2.0 sb 01/12/2015 Added support for writing BBT signature and version
This file contains identifiers and low-level macros/functions for the Arasan
NAND flash controller driver.
See xnandpsu.h for more information.
- Note
- None
1.0 nm 05/06/2014 First Release
2.0 sb 11/04/2014 Changed XNANDPSU_ECC_SLC_MLC_MASK to
XNANDPSU_ECC_HAMMING_BCH_MASK.
1.7 akm 09/03/20 Updated the Makefile to support parallel make
execution.
This file defines all the ONFI 3.1 specific commands and values.
- Note
- None
1.4 nsk 04/10/2018 Added ICCARM compiler support.
This section explains the implementation the functions required to use the
QSPIPSU hardware to perform a transfer. These are accessible to the user
via xqspipsu.h.
Generic QSPI interface allows for communication to any QSPI slave device.
GQSPI contains a GENFIFO into which the bus transfers required are to be
pushed with appropriate configuration. The controller provides TX and RX
FIFO's and a DMA to be used for RX transfers. The controller executes each
GENFIFO entry noting the configuration and places data on the bus as required
The different options in GENFIFO are as follows:
- IMM_DATA : Can be one byte of data to be transmitted, number of clocks or
number of bytes in transfer.
- DATA_XFER : Indicates that data/clocks need to be transmitted or received.
- EXPONENT : e when 2^e bytes are involved in transfer.
- SPI_MODE : SPI/Dual SPI/Quad SPI
- CS : Lower or Upper CS or Both
- Bus : Lower or Upper Bus or Both
- TX : When selected, controller transmits data in IMM or fetches number of
bytes mentioned form TX FIFO. If not selected, dummies are pumped.
- RX : When selected, controller receives and fills the RX FIFO/allows RX DMA
of requested number of bytes. If not selected, RX data is discarded.
- Stripe : Byte stripe over lower and upper bus or not.
- Poll : Polls response to match for to a set value (used along with POLL_CFG
registers) and then proceeds to next GENFIFO entry.
This feature is not currently used in the driver.
GENFIFO has manual and auto start options.
All DMA requests need a 4-byte aligned destination address buffer and
size of transfer should also be a multiple of 4.
This driver supports DMA RX and IO RX.
Initialization & Configuration
This driver uses the GQSPI controller with RX DMA. It supports both
interrupt and polled transfers. Manual start of GENFIFO is used.
XQspiPsu_CfgInitialize() initializes the instance variables.
Additional setting can be done using SetOptions/ClearOptions functions
and SelectSlave function.
Transfer
Polled or Interrupt transfers can be done. The transfer function needs the
message(s) to be transmitted in the form of an array of type XQspiPsu_Msg.
This is supposed to contain the byte count and any TX/RX buffers as required.
Flags can be used indicate further information such as whether the message
should be striped. The transfer functions form and write GENFIFO entries,
check the status of the transfer and report back to the application
when done.
1.0 hk 08/21/14 First release
sk 03/13/15 Added IO mode support.
hk 03/18/15 Switch to I/O mode before clearing RX FIFO.
Clear and disable DMA interrupts/status in abort.
Use DMA DONE bit instead of BUSY as recommended.
sk 04/24/15 Modified the code according to MISRAC-2012.
sk 06/17/15 Removed NULL checks for Rx/Tx buffers. As
writing/reading from 0x0 location is permitted.
1.1 sk 04/12/16 Added debug message prints.
1.2 nsk 07/01/16 Added LQSPI support
Modified XQspiPsu_Select() macro in xqspipsu.h
Added XQspiPsu_GetLqspiConfigReg() in xqspipsu.h
Added required macros in xqspipsu_hw.h
Modified XQspiPsu_SetOptions() to support
LQSPI options and updated OptionsTable in
xqspipsu_options.c
rk 07/15/16 Added support for TapDelays at different frequencies.
nsk 08/05/16 Added example support PollData and PollTimeout
Added XQSPIPSU_MSG_FLAG_POLL macro in xqspipsu.h
Added XQspiPsu_Create_PollConfigData and
XQspiPsu_PollData() functions in xqspipsu.c
1.3 nsk 09/16/16 Update PollData and Polltimeout support for dual parallel
configuration. Updated XQspiPsu_PollData() and
XQspiPsu_Create_PollConfigData() functions in xqspipsu.c
and also modified the polldata example
generation.
ms 04/05/17 Modified Comment lines in functions of qspipsu
examples to recognize it as documentation block
and modified filename tag to include them in
doxygen examples.
1.4 tjs 05/26/17 Added support for accessing upper DDR (0x800000000)
while booting images from QSPI
1.5 tjs 08/08/17 Added index.html file for importing examples
from system.mss
1.5 nsk 08/14/17 Added CCI support
1.5 tjs 09/14/17 Modified the checks for 4 byte addressing and commands.
1.6 tjs 10/16/17 Flow for accessing flash is made similar to u-boot
and linux For CR-984966
1.6 tjs 11/02/17 Resolved the compilation errors for ICCARM. CR-988625
1.7 tjs 11/16/17 Removed the unsupported 4 Byte write and sector erase
commands.
1.7 tjs 12/01/17 Added support for MT25QL02G Flash from Micron. CR-990642
1.7 tjs 12/19/17 Added support for S25FL064L from Spansion. CR-990724
1.7 tjs 01/11/18 Added support for MX66L1G45G flash from Macronix CR-992367
1.7 tjs 01/16/18 Removed the check for DMA MSB to be written. (CR#992560)
1.7 tjs 01/17/18 Added support to toggle the WP pin of flash. (PR#2448)
Added XQspiPsu_SetWP() in xqspipsu_options.c
Added XQspiPsu_WriteProtectToggle() in xqspipsu.c and
also added write protect example.
1.7 tjs 03/14/18 Added support in EL1 NS mode (CR#974882)
1.7 tjs 26/03/18 In dual parallel mode enable both CS when issuing Write
enable command. CR-998478
1.8 tjs 05/02/18 Added support for IS25LP064 and IS25WP064.
1.8 tjs 06/26/18 Added an example for accessing 64bit dma within
32 bit application. CR#1004701
1.8 tjs 06/26/18 Removed checkpatch warnings
1.8 tjs 07/09/19 Fixed cppcheck, doxygen and gcc warnings.
1.8 tjs 07/18/18 Setup64BRxDma() should be called only if the RxAddress is
greater than 32 bit address space. (CR#1006862)
1.8 tjs 07/18/18 Added support for the low density ISSI flash parts.
1.8 tjs 09/06/18 Fixed the code in XQspiPsu_GenFifoEntryData() for data
transfer length up to 255 for reducing the extra loop.
1.9 tjs 11/22/17 Added the check for A72 and R5 processors (CR-987075)
1.9 tjs 04/17/18 Updated register addresses as per the latest revision
of versal (CR#999610)
1.9 aru 01/17/19 Fixed the violations for MISRAC-2012
in safety mode .Done changes such as added U suffix,
Declared pointer param as const.
1.9 nsk 02/01/19 Clear DMA_DST_ADDR_MSB register on 32bit machine, if the
address is of only 32bit (CR#1020031)
1.9 nsk 02/01/19 Added QSPI idling support
1.9 akm 03/08/19 Set recommended clock and data tap delay values for 40MHZ,
100MHZ and 150MHZ frequencies(CR#1023187)
1.9 nsk 03/27/19 Update 64bit dma support
(CR#1018102).
1.9 akm 04/03/19 Fixed data alignment warnings on IAR compiler.
1.9 akm 04/03/19 Fixed compilation error in XQspiPsu_LqspiRead()
function on IAR compiler.
1.10 sk 08/20/19 Fixed issues in poll timeout feature.
1.10 akm 08/22/19 Set recommended tap delay values for 37.5MHZ, 100MHZ and
150MHZ frequencies in Versal.
1.10 akm 09/05/19 Added Multi Die Erase and Muti Die Read support.
1.11 akm 11/07/19 Removed LQSPI register access in Versal.
1.11 akm 11/15/19 Fixed Coverity deadcode warning in
XQspipsu_Calculate_Tapdelay().
1.11 akm 02/19/20 Added XQspiPsu_StartDmaTransfer() and XQspiPsu_CheckDmaDone()
APIs for non-blocking transfer.
1.11 sd 01/02/20 Added clocking support
1.11 akm 03/09/20 Reorganize the source code, enable qspi controller and
interrupts in XQspiPsu_CfgInitialize() API.
1.11 akm 03/26/20 Fixed issue by updating XQspiPsu_CfgInitialize to return
XST_DEVICE_IS_STARTED instead of asserting, when the
instance is already configured(CR#1058525).
1.12 akm 09/02/20 Updated the Makefile to support parallel make execution.
1.13 akm 01/04/21 Fix MISRA-C violations.
1.13 sne 04/23/21 Fixed doxygen warnings.
1.14 akm 06/24/21 Allow enough time for the controller to reset the FIFOs.
1.14 akm 08/12/21 Perform Dcache invalidate at the end of the DMA transfer.
This is the header file for the implementation of QSPIPSU driver.
1.11 akm 03/09/20 First release
1.15 akm 03/03/22 Enable tapdelay settings for applications on
Microblaze platform.
This file contains low level access functions using the base address
directly without an instance.
hk 03/18/15 Add DMA status register masks required.
1.2 nsk 07/01/16 Added LQSPI supported Masks
1.7 tjs 03/14/18 Added support in EL1 NS mode.
1.15 akm 12/02/21 Fix Doxygen warnings.
This file contains the implementation of the interface functions for
XNandPsu driver. Refer to the header file xnandpsu.h for more detailed
information.
This module supports for NAND flash memory devices that conform to the
"Open NAND Flash Interface" (ONFI) 3.0 Specification. This modules
implements basic flash operations like read, write and erase.
- Note
naming convention.
- XNandPsu_Read()
- XNandPsu_ReadPage
Modified
Replaced
Modified
SLC --> HAMMING
MLC --> BCH
SlcMlc --> IsBCH
Modified
size of spare area
1.0 kpc 17/6/2015 Added timer based timeout intsead of sw counter.
1.1 nsk 11/07/16 Change memcpy to Xil_MemCpy to handle word aligned
data access.
1.3 nsk 08/14/17 Added CCI support
1.5 mus 11/05/18 Support 64 bit DMA addresses for Microblaze-X platform.
1.5 mus 11/05/18 Updated XNandPsu_ChangeClockFreq to fix compilation
warnings.
This file implements the Bad Block Management (BBM) functionality.
See xnandpsu_bbm.h for more details.
- Note
- None
data access.
This file contains the implementation of ONFI specific functions.
- Note
- None
This file implements the functions required to use the QSPIPSU hardware to
perform a transfer. These are accessible to the user via xqspipsu.h.
1.2 nsk 07/01/16 Changed XQspiPsu_Select to support GQSPI and LQSPI
selection.
1.3 nsk 09/16/16 Update PollData and PollTimeout support for dual
parallel configurations, modified XQspiPsu_PollData()
and XQspiPsu_Create_PollConfigData()
1,5 nsk 08/14/17 Added CCI support
1.7 tjs 01/17/18 Added a support to toggle WP pin of the flash.
1.8 tjs 06/26/18 Removed checkpatch warnings.
1.8 tjs 07/09/18 Fixed cppcheck and doxygen warnings. (CR#1006336)
1.8 mus 11/05/18 Support 64 bit DMA addresses for Microblaze-X platform.
1.9 aru 01/17/19 Fixes violations according to MISRAC-2012
in safety mode and modified the code such as
Added UNITPTR inplace of INTPTR,Declared the pointer param
as Pointer to const .
1.9 nsk 02/01/19 Added QSPI idling support.
1.9 rama 03/13/19 Fixed MISRA violations related to UR data anamoly,
expression is not a boolean
instance is already configured.
1.15 akm 10/21/21 Fix MISRA-C violations.
This file contains intermediate control functions used by functions
in xqspipsu.c and xqspipsu_options.c files.
This file contains functions to reads RXFifo, writes TXFifo and setup
RX DMA operation, used by xqspipsu_control.c and xqspipsu_lowlevel.c files.
mn 03/30/20 Add xil_smc.h include for Xil_Smc calls
1.15 akm 11/16/21 Typecast function parameter with appropriate
data type.
1.15 akm 11/30/21 Fix compilation warnings reported with -Wundef flag
This file implements functions to configure the QSPIPSU component,
specifically some optional settings, clock and flash related information.
1.2 nsk 07/01/16 Modified XQspiPsu_SetOptions() to support
1.7 tjs 03/14/18 Added support in EL1 NS mode. (CR#974882)
1.8 tjs 07/26/18 Resolved cppcheck errors. (CR#1006336)
Added Xil_MemCpy inplace of memcpy,Declared the pointer param
as Pointer to const, declared XQspi_Set_TapDelay() as static.
1.15 akm 03/03/22 Enable tapdelay settings for applications on Microblaze
platform.
◆ BYTES1024_PER_PAGE
#define BYTES1024_PER_PAGE 1024U |
◆ BYTES256_PER_PAGE
#define BYTES256_PER_PAGE 256U |
Definitions for Intel, STM, Winbond and Spansion Serial Flash Device geometry. 256 Bytes per Page
◆ BYTES512_PER_PAGE
#define BYTES512_PER_PAGE 512U |
◆ IOU_TAPDLY_BYPASS_OFFSET
#define IOU_TAPDLY_BYPASS_OFFSET 0X00000390U |
◆ IS_ONFI
Value: ((Buff)[0] == (u8)'O') && ((Buff)[1] == (u8)'N') && \
((Buff)[2] == (u8)'F') && ((Buff)[3] == (u8)'I')
This macro checks for the ONFI ID.
- Parameters
Buff | is the buffer holding ONFI ID |
- Note
- none.
◆ MAX_DELAY_CNT
#define MAX_DELAY_CNT 10000000U |
◆ NUM_OF_SECTORS1024
#define NUM_OF_SECTORS1024 1024U |
◆ NUM_OF_SECTORS128
#define NUM_OF_SECTORS128 128U |
◆ NUM_OF_SECTORS16
#define NUM_OF_SECTORS16 16U |
◆ NUM_OF_SECTORS2
#define NUM_OF_SECTORS2 2U |
◆ NUM_OF_SECTORS2048
#define NUM_OF_SECTORS2048 2048U |
◆ NUM_OF_SECTORS256
#define NUM_OF_SECTORS256 256U |
◆ NUM_OF_SECTORS32
#define NUM_OF_SECTORS32 32U |
◆ NUM_OF_SECTORS4
#define NUM_OF_SECTORS4 4U |
◆ NUM_OF_SECTORS4096
#define NUM_OF_SECTORS4096 4096U |
◆ NUM_OF_SECTORS512
#define NUM_OF_SECTORS512 512U |
◆ NUM_OF_SECTORS64
#define NUM_OF_SECTORS64 64U |
◆ NUM_OF_SECTORS8
#define NUM_OF_SECTORS8 8U |
◆ NUM_OF_SECTORS8192
#define NUM_OF_SECTORS8192 8192U |
◆ ONFI_CMD_BLK_ERASE1
#define ONFI_CMD_BLK_ERASE1 0x60U |
◆ ONFI_CMD_BLK_ERASE2
#define ONFI_CMD_BLK_ERASE2 0xD0U |
◆ ONFI_CMD_BLK_ERASE_INTRLVD2
#define ONFI_CMD_BLK_ERASE_INTRLVD2 0xD1U |
Block Erase Interleaved (2nd cycle)
◆ ONFI_CMD_CHNG_RD_COL1
#define ONFI_CMD_CHNG_RD_COL1 0x05U |
Change Read Column (1st cycle)
◆ ONFI_CMD_CHNG_RD_COL2
#define ONFI_CMD_CHNG_RD_COL2 0xE0U |
Change Read Column (2nd cycle)
◆ ONFI_CMD_CHNG_RD_COL_ENHCD1
#define ONFI_CMD_CHNG_RD_COL_ENHCD1 0x06U |
Change Read Column Enhanced (1st cycle)
◆ ONFI_CMD_CHNG_RD_COL_ENHCD2
#define ONFI_CMD_CHNG_RD_COL_ENHCD2 0xE0U |
Change Read Column Enhanced (2nd cycle)
◆ ONFI_CMD_CHNG_ROW_ADDR
#define ONFI_CMD_CHNG_ROW_ADDR 0x85U |
◆ ONFI_CMD_CHNG_WR_COL
#define ONFI_CMD_CHNG_WR_COL 0x85U |
◆ ONFI_CMD_CPBK_PROG1
#define ONFI_CMD_CPBK_PROG1 0x85U |
Copyback Program (1st cycle)
◆ ONFI_CMD_CPBK_PROG2
#define ONFI_CMD_CPBK_PROG2 0x10U |
Copyback Program (2nd cycle)
◆ ONFI_CMD_CPBK_RD1
#define ONFI_CMD_CPBK_RD1 0x00U |
Copyback Read (1st cycle)
◆ ONFI_CMD_CPBK_RD2
#define ONFI_CMD_CPBK_RD2 0x35U |
Copyback Read (2nd cycle)
◆ ONFI_CMD_GET_FEATURES
#define ONFI_CMD_GET_FEATURES 0xEEU |
◆ ONFI_CMD_INVALID
#define ONFI_CMD_INVALID 0x00U |
◆ ONFI_CMD_LUN_GET_FEATURES
#define ONFI_CMD_LUN_GET_FEATURES 0xD4U |
◆ ONFI_CMD_LUN_SET_FEATURES
#define ONFI_CMD_LUN_SET_FEATURES 0xD5U |
◆ ONFI_CMD_MUL_BLK_ERASE1
#define ONFI_CMD_MUL_BLK_ERASE1 0x60U |
Multiplane Block Erase (1st cycle)
◆ ONFI_CMD_MUL_BLK_ERASE2
#define ONFI_CMD_MUL_BLK_ERASE2 0xD1U |
Multiplane Block Erase (2nd cycle)
◆ ONFI_CMD_MUL_CPBK_PROG1
#define ONFI_CMD_MUL_CPBK_PROG1 0x85U |
Multiplane Copyback Program (1st cycle)
◆ ONFI_CMD_MUL_CPBK_PROG2
#define ONFI_CMD_MUL_CPBK_PROG2 0x10U |
Multiplane Copyback Program (2nd cycle)
◆ ONFI_CMD_MUL_PG_PROG1
#define ONFI_CMD_MUL_PG_PROG1 0x80U |
Multiplane Page Program (1st cycle)
◆ ONFI_CMD_MUL_PG_PROG2
#define ONFI_CMD_MUL_PG_PROG2 0x11U |
Multiplane Page Program (2nd cycle)
◆ ONFI_CMD_MUL_RD1
#define ONFI_CMD_MUL_RD1 0x00U |
Multiplane Read (1st cycle)
◆ ONFI_CMD_MUL_RD2
#define ONFI_CMD_MUL_RD2 0x32U |
Multiplane Read (2nd cycle)
◆ ONFI_CMD_ODT_CONF
#define ONFI_CMD_ODT_CONF 0xE2U |
◆ ONFI_CMD_PG_CACHE_PROG1
#define ONFI_CMD_PG_CACHE_PROG1 0x80U |
Page Cache Program (1st cycle)
◆ ONFI_CMD_PG_CACHE_PROG2
#define ONFI_CMD_PG_CACHE_PROG2 0x15U |
Page Cache Program (2nd cycle)
◆ ONFI_CMD_PG_PROG1
#define ONFI_CMD_PG_PROG1 0x80U |
◆ ONFI_CMD_PG_PROG2
#define ONFI_CMD_PG_PROG2 0x10U |
◆ ONFI_CMD_RD1
#define ONFI_CMD_RD1 0x00U |
◆ ONFI_CMD_RD2
#define ONFI_CMD_RD2 0x30U |
◆ ONFI_CMD_RD_CACHE_END
#define ONFI_CMD_RD_CACHE_END 0x3FU |
◆ ONFI_CMD_RD_CACHE_RND1
#define ONFI_CMD_RD_CACHE_RND1 0x00U |
Read Cache Random (1st cycle)
◆ ONFI_CMD_RD_CACHE_RND2
#define ONFI_CMD_RD_CACHE_RND2 0x31U |
Read Cache Random (2nd cycle)
◆ ONFI_CMD_RD_CACHE_SEQ
#define ONFI_CMD_RD_CACHE_SEQ 0x31U |
◆ ONFI_CMD_RD_ID
#define ONFI_CMD_RD_ID 0x90U |
◆ ONFI_CMD_RD_PRM_PG
#define ONFI_CMD_RD_PRM_PG 0xECU |
◆ ONFI_CMD_RD_STS
#define ONFI_CMD_RD_STS 0x70U |
◆ ONFI_CMD_RD_STS_ENHCD
#define ONFI_CMD_RD_STS_ENHCD 0x78U |
◆ ONFI_CMD_RD_UNIQID
#define ONFI_CMD_RD_UNIQID 0xEDU |
◆ ONFI_CMD_RST
#define ONFI_CMD_RST 0xFFU |
◆ ONFI_CMD_RST_LUN
#define ONFI_CMD_RST_LUN 0xFAU |
◆ ONFI_CMD_SET_FEATURES
#define ONFI_CMD_SET_FEATURES 0xEFU |
◆ ONFI_CMD_SMALL_DATA_MV1
#define ONFI_CMD_SMALL_DATA_MV1 0x85U |
Small Data Move (1st cycle)
◆ ONFI_CMD_SMALL_DATA_MV2
#define ONFI_CMD_SMALL_DATA_MV2 0x10U |
Small Data Move (2nd cycle)
◆ ONFI_CMD_SYN_RST
#define ONFI_CMD_SYN_RST 0xFCU |
◆ ONFI_CMD_VOL_SEL
#define ONFI_CMD_VOL_SEL 0xE1U |
◆ ONFI_CRC_LEN
#define ONFI_CRC_LEN 254U |
◆ ONFI_MND_PRM_PGS
#define ONFI_MND_PRM_PGS 3U |
Number of mandatory parameter pages
◆ ONFI_PRM_PG_ADDR_CYCLES
#define ONFI_PRM_PG_ADDR_CYCLES 1U |
ONFI Read Parameter page address cycles
◆ ONFI_PRM_PG_LEN
#define ONFI_PRM_PG_LEN 256U |
◆ ONFI_READ_ID_ADDR
#define ONFI_READ_ID_ADDR 0x20U |
◆ ONFI_READ_ID_ADDR_CYCLES
#define ONFI_READ_ID_ADDR_CYCLES 1U |
ONFI Read ID Address cycles
◆ ONFI_READ_ID_LEN
#define ONFI_READ_ID_LEN 4U |
◆ ONFI_SIG_LEN
◆ ONFI_STS_ARDY
#define ONFI_STS_ARDY 0x20U |
◆ ONFI_STS_CSP
#define ONFI_STS_CSP 0x08U |
◆ ONFI_STS_FAIL
#define ONFI_STS_FAIL 0x01U |
◆ ONFI_STS_FAILC
#define ONFI_STS_FAILC 0x02U |
◆ ONFI_STS_RDY
#define ONFI_STS_RDY 0x40U |
◆ ONFI_STS_VSP
#define ONFI_STS_VSP 0x10U |
◆ ONFI_STS_WP
#define ONFI_STS_WP 0x80U |
◆ PAGES1024_PER_SECTOR
#define PAGES1024_PER_SECTOR 1024U |
◆ PAGES128_PER_SECTOR
#define PAGES128_PER_SECTOR 128U |
◆ PAGES16_PER_SECTOR
#define PAGES16_PER_SECTOR 16U |
◆ PAGES256_PER_SECTOR
#define PAGES256_PER_SECTOR 256U |
◆ PAGES512_PER_SECTOR
#define PAGES512_PER_SECTOR 512U |
◆ SECTOR_SIZE_128K
#define SECTOR_SIZE_128K 0X20000U |
◆ SECTOR_SIZE_256K
#define SECTOR_SIZE_256K 0X40000U |
◆ SECTOR_SIZE_512K
#define SECTOR_SIZE_512K 0X80000U |
◆ SECTOR_SIZE_64K
#define SECTOR_SIZE_64K 0X10000U |
◆ XNANDPSU_BB_PATTERN
#define XNANDPSU_BB_PATTERN 0xFFU |
Bad block pattern to search in a page
◆ XNANDPSU_BB_PTRN_LEN_LARGE_PAGE
#define XNANDPSU_BB_PTRN_LEN_LARGE_PAGE 2U |
◆ XNANDPSU_BB_PTRN_LEN_SML_PAGE
#define XNANDPSU_BB_PTRN_LEN_SML_PAGE 1U |
◆ XNANDPSU_BB_PTRN_OFF_LARGE_PAGE
#define XNANDPSU_BB_PTRN_OFF_LARGE_PAGE 0U |
Bad block pattern offset in a large page
◆ XNANDPSU_BB_PTRN_OFF_SML_PAGE
#define XNANDPSU_BB_PTRN_OFF_SML_PAGE 5U |
Bad block pattern offset in a page
◆ XNANDPSU_BBT_BLOCK_SHIFT
#define XNANDPSU_BBT_BLOCK_SHIFT 2U |
Block shift value for a block in BBT
◆ XNANDPSU_BBT_BUF_LENGTH
#define XNANDPSU_BBT_BUF_LENGTH |
Value:
XNANDPSU_BBT_SIG_LENGTH + \
XNANDPSU_BBT_VERSION_LENGTH))
#define XNANDPSU_BBT_DESC_SIG_OFFSET
Definition: xnandpsu_bbm.h:101
#define XNANDPSU_MAX_BLOCKS
Definition: xnandpsu.h:210
Definition: xnandpsu_bbm.h:116
◆ XNANDPSU_BBT_DESC_MAX_BLOCKS
#define XNANDPSU_BBT_DESC_MAX_BLOCKS 64U |
Bad block Table max blocks
◆ XNANDPSU_BBT_DESC_PAGE_OFFSET
#define XNANDPSU_BBT_DESC_PAGE_OFFSET 0U |
Page offset of Bad Block Table Desc
◆ XNANDPSU_BBT_DESC_SIG_LEN
#define XNANDPSU_BBT_DESC_SIG_LEN 4U |
Bad block Table signature length
◆ XNANDPSU_BBT_DESC_SIG_OFFSET
#define XNANDPSU_BBT_DESC_SIG_OFFSET 8U |
Bad Block Table signature offset
◆ XNANDPSU_BBT_DESC_VER_OFFSET
#define XNANDPSU_BBT_DESC_VER_OFFSET 12U |
Bad block Table version offset
◆ XNANDPSU_BBT_ENTRY_NUM_BLOCKS
#define XNANDPSU_BBT_ENTRY_NUM_BLOCKS 4U |
Num of blocks in one BBT entry
◆ XNANDPSU_BBT_SCAN_2ND_PAGE
#define XNANDPSU_BBT_SCAN_2ND_PAGE 0x00000001U |
Scan the second page for bad block information
◆ XNandPsu_BbtBlockShift
This macro returns the Block shift value corresponding to a Block.
- Parameters
Block | is the block number. |
- Returns
- Block shift value
- Note
- None.
◆ XNANDPSU_BCH
#define XNANDPSU_BCH 0x2U |
◆ XNANDPSU_BLOCK_BAD
#define XNANDPSU_BLOCK_BAD 0x1U |
◆ XNANDPSU_BLOCK_FACTORY_BAD
#define XNANDPSU_BLOCK_FACTORY_BAD 0x3U |
◆ XNANDPSU_BLOCK_GOOD
#define XNANDPSU_BLOCK_GOOD 0x0U |
◆ XNANDPSU_BLOCK_RESERVED
#define XNANDPSU_BLOCK_RESERVED 0x2U |
◆ XNANDPSU_BLOCK_SHIFT_MASK
#define XNANDPSU_BLOCK_SHIFT_MASK 0x06U |
Block shift mask for a Bad Block Table entry byte
◆ XNANDPSU_BLOCK_TYPE_MASK
#define XNANDPSU_BLOCK_TYPE_MASK 0x03U |
◆ XNANDPSU_BUF_DATA_PORT_OFFSET
#define XNANDPSU_BUF_DATA_PORT_OFFSET 0x30U |
Buffer Data Port Register
◆ XNandPsu_ClrBits
#define XNandPsu_ClrBits |
InstancePtr, |
RegOffset, |
BitMask |
Value:
(RegOffset), \
(RegOffset)) & ~(BitMask))))
#define XNandPsu_WriteReg(BaseAddress, RegOffset, Data)
Definition: xnandpsu_hw.h:475
#define XNandPsu_ReadReg(BaseAddress, RegOffset)
Definition: xnandpsu_hw.h:457
This macro clears the bitmask in the register.
- Parameters
InstancePtr | is a pointer to the XNandPsu instance of the controller. |
RegOffset | is the register offset. |
BitMask | is the bitmask. |
- Note
- C-style signature: void XNandPsu_ClrBits(XNandPsu *InstancePtr, u32 RegOffset,
u32 BitMask)
◆ XNANDPSU_CMD_ADDR_CYCLES_MASK
#define XNANDPSU_CMD_ADDR_CYCLES_MASK 0x70000000U |
◆ XNANDPSU_CMD_ADDR_CYCLES_SHIFT
#define XNANDPSU_CMD_ADDR_CYCLES_SHIFT 28U |
Number of Address Cycles Shift
◆ XNANDPSU_CMD_CMD1_MASK
#define XNANDPSU_CMD_CMD1_MASK 0x000000FFU |
◆ XNANDPSU_CMD_CMD2_MASK
#define XNANDPSU_CMD_CMD2_MASK 0x0000FF00U |
◆ XNANDPSU_CMD_CMD2_SHIFT
#define XNANDPSU_CMD_CMD2_SHIFT 8U |
◆ XNANDPSU_CMD_DMA_EN_MASK
#define XNANDPSU_CMD_DMA_EN_MASK 0x0C000000U |
◆ XNANDPSU_CMD_DMA_EN_SHIFT
#define XNANDPSU_CMD_DMA_EN_SHIFT 26U |
◆ XNANDPSU_CMD_ECC_ON_MASK
#define XNANDPSU_CMD_ECC_ON_MASK 0x80000000U |
◆ XNANDPSU_CMD_ECC_ON_SHIFT
#define XNANDPSU_CMD_ECC_ON_SHIFT 31U |
◆ XNANDPSU_CMD_OFFSET
#define XNANDPSU_CMD_OFFSET 0x0CU |
◆ XNANDPSU_CMD_PG_SIZE_MASK
#define XNANDPSU_CMD_PG_SIZE_MASK 0x03800000U |
◆ XNANDPSU_CMD_PG_SIZE_SHIFT
#define XNANDPSU_CMD_PG_SIZE_SHIFT 23U |
◆ XNANDPSU_CPU_REL_OFFSET
#define XNANDPSU_CPU_REL_OFFSET 0x58U |
◆ XNANDPSU_DATA_INTF_DATA_INTF_MASK
#define XNANDPSU_DATA_INTF_DATA_INTF_MASK 0x00000600U |
◆ XNANDPSU_DATA_INTF_DATA_INTF_SHIFT
#define XNANDPSU_DATA_INTF_DATA_INTF_SHIFT 9U |
◆ XNANDPSU_DATA_INTF_NVDDR2_MASK
#define XNANDPSU_DATA_INTF_NVDDR2_MASK 0x000001C0U |
◆ XNANDPSU_DATA_INTF_NVDDR_MASK
#define XNANDPSU_DATA_INTF_NVDDR_MASK 0x00000038U |
◆ XNANDPSU_DATA_INTF_NVDDR_SHIFT
#define XNANDPSU_DATA_INTF_NVDDR_SHIFT 3U |
◆ XNANDPSU_DATA_INTF_OFFSET
#define XNANDPSU_DATA_INTF_OFFSET 0x6CU |
◆ XNANDPSU_DATA_INTF_SDR_MASK
#define XNANDPSU_DATA_INTF_SDR_MASK 0x00000007U |
◆ XNANDPSU_DMA_BUF_BND_BND_MASK
#define XNANDPSU_DMA_BUF_BND_BND_MASK 0x00000007U |
◆ XNANDPSU_DMA_BUF_BND_OFFSET
#define XNANDPSU_DMA_BUF_BND_OFFSET 0x54U |
DMA Buffer Boundary Register
◆ XNANDPSU_DMA_SYS_ADDR0_OFFSET
#define XNANDPSU_DMA_SYS_ADDR0_OFFSET 0x50U |
DMA System Address 0 Register
◆ XNANDPSU_DMA_SYS_ADDR1_OFFSET
#define XNANDPSU_DMA_SYS_ADDR1_OFFSET 0x24U |
DMA System Address 1 Register
◆ XNANDPSU_ECC_ADDR_MASK
#define XNANDPSU_ECC_ADDR_MASK 0x0000FFFFU |
◆ XNANDPSU_ECC_CNT_1BIT_OFFSET
#define XNANDPSU_ECC_CNT_1BIT_OFFSET 0x40U |
Error Count 1bit Register
◆ XNANDPSU_ECC_CNT_2BIT_OFFSET
#define XNANDPSU_ECC_CNT_2BIT_OFFSET 0x44U |
Error Count 2bit Register
◆ XNANDPSU_ECC_CNT_3BIT_OFFSET
#define XNANDPSU_ECC_CNT_3BIT_OFFSET 0x48U |
Error Count 3bit Register
◆ XNANDPSU_ECC_CNT_4BIT_OFFSET
#define XNANDPSU_ECC_CNT_4BIT_OFFSET 0x4CU |
Error Count 4bit Register
◆ XNANDPSU_ECC_CNT_5BIT_OFFSET
#define XNANDPSU_ECC_CNT_5BIT_OFFSET 0x5CU |
Error Count 5bit Register
◆ XNANDPSU_ECC_CNT_6BIT_OFFSET
#define XNANDPSU_ECC_CNT_6BIT_OFFSET 0x60U |
Error Count 6bit Register
◆ XNANDPSU_ECC_CNT_7BIT_OFFSET
#define XNANDPSU_ECC_CNT_7BIT_OFFSET 0x64U |
Error Count 7bit Register
◆ XNANDPSU_ECC_CNT_8BIT_OFFSET
#define XNANDPSU_ECC_CNT_8BIT_OFFSET 0x68U |
Error Count 8bit Register
◆ XNANDPSU_ECC_ERR_CNT_OFFSET
#define XNANDPSU_ECC_ERR_CNT_OFFSET 0x38U |
◆ XNANDPSU_ECC_ERR_CNT_PG_BND_ERR_CNT_MASK
#define XNANDPSU_ECC_ERR_CNT_PG_BND_ERR_CNT_MASK 0x0000FF00U |
◆ XNANDPSU_ECC_ERR_CNT_PKT_BND_ERR_CNT_MASK
#define XNANDPSU_ECC_ERR_CNT_PKT_BND_ERR_CNT_MASK 0x000000FFU |
◆ XNANDPSU_ECC_HAMMING_BCH_MASK
#define XNANDPSU_ECC_HAMMING_BCH_MASK 0x02000000U |
◆ XNANDPSU_ECC_OFFSET
#define XNANDPSU_ECC_OFFSET 0x34U |
◆ XNANDPSU_ECC_SIZE_MASK
#define XNANDPSU_ECC_SIZE_MASK 0x01FF0000U |
◆ XNANDPSU_ECC_SPR_CMD_ECC_ADDR_CYCLES_MASK
#define XNANDPSU_ECC_SPR_CMD_ECC_ADDR_CYCLES_MASK 0x70000000U |
Number of ECC/ spare address cycles
◆ XNANDPSU_ECC_SPR_CMD_OFFSET
#define XNANDPSU_ECC_SPR_CMD_OFFSET 0x3CU |
ECC Spare Command Register
◆ XNANDPSU_ECC_SPR_CMD_SPR_CMD_MASK
#define XNANDPSU_ECC_SPR_CMD_SPR_CMD_MASK 0x000000FFU |
◆ XNANDPSU_FLASH_BLOCK_BAD
#define XNANDPSU_FLASH_BLOCK_BAD 0x2U |
◆ XNANDPSU_FLASH_BLOCK_FAC_BAD
#define XNANDPSU_FLASH_BLOCK_FAC_BAD 0x0U |
◆ XNANDPSU_FLASH_BLOCK_GOOD
#define XNANDPSU_FLASH_BLOCK_GOOD 0x3U |
◆ XNANDPSU_FLASH_BLOCK_RESERVED
#define XNANDPSU_FLASH_BLOCK_RESERVED 0x1U |
◆ XNANDPSU_FLASH_STS_FLASH_STS_MASK
#define XNANDPSU_FLASH_STS_FLASH_STS_MASK 0x0000FFFFU |
◆ XNANDPSU_FLASH_STS_OFFSET
#define XNANDPSU_FLASH_STS_OFFSET 0x28U |
◆ XNANDPSU_HAMMING
#define XNANDPSU_HAMMING 0x1U |
◆ XNANDPSU_ID2_DEVICE_ID2_MASK
#define XNANDPSU_ID2_DEVICE_ID2_MASK 0x000000FFU |
◆ XNANDPSU_INTR_BUFF_RD_RDY_STS_EN_MASK
#define XNANDPSU_INTR_BUFF_RD_RDY_STS_EN_MASK 0x00000002U |
Buffer Read Ready Status Enable
◆ XNANDPSU_INTR_BUFF_WR_RDY_STS_EN_MASK
#define XNANDPSU_INTR_BUFF_WR_RDY_STS_EN_MASK 0x00000001U |
Buffer Write Ready Status Enable
◆ XNANDPSU_INTR_DMA_INT_STS_EN_MASK
#define XNANDPSU_INTR_DMA_INT_STS_EN_MASK 0x00000040U |
◆ XNANDPSU_INTR_ERR_AHB_STS_EN_MASK
#define XNANDPSU_INTR_ERR_AHB_STS_EN_MASK 0x00000080U |
◆ XNANDPSU_INTR_ERR_INTR_STS_EN_MASK
#define XNANDPSU_INTR_ERR_INTR_STS_EN_MASK 0x00000010U |
Single Bit Error Status Enable, BCH Detect Error Status Enable
◆ XNANDPSU_INTR_MUL_BIT_ERR_STS_EN_MASK
#define XNANDPSU_INTR_MUL_BIT_ERR_STS_EN_MASK 0x00000008U |
Multi Bit Error Status Enable
◆ XNANDPSU_INTR_SIG_EN_BUFF_RD_RDY_STS_EN_MASK
#define XNANDPSU_INTR_SIG_EN_BUFF_RD_RDY_STS_EN_MASK 0x00000002U |
Buffer Read Ready Signal Enable
◆ XNANDPSU_INTR_SIG_EN_BUFF_WR_RDY_STS_EN_MASK
#define XNANDPSU_INTR_SIG_EN_BUFF_WR_RDY_STS_EN_MASK 0x00000001U |
Buffer Write Ready Signal Enable
◆ XNANDPSU_INTR_SIG_EN_DMA_INT_STS_EN_MASK
#define XNANDPSU_INTR_SIG_EN_DMA_INT_STS_EN_MASK 0x00000040U |
◆ XNANDPSU_INTR_SIG_EN_ERR_AHB_STS_EN_MASK
#define XNANDPSU_INTR_SIG_EN_ERR_AHB_STS_EN_MASK 0x00000080U |
◆ XNANDPSU_INTR_SIG_EN_ERR_INTR_STS_EN_MASK
#define XNANDPSU_INTR_SIG_EN_ERR_INTR_STS_EN_MASK 0x00000010U |
Single Bit Error Signal Enable, BCH Detect Error Signal Enable
◆ XNANDPSU_INTR_SIG_EN_MUL_BIT_ERR_STS_EN_MASK
#define XNANDPSU_INTR_SIG_EN_MUL_BIT_ERR_STS_EN_MASK 0x00000008U |
Multi Bit Error Signal Enable
◆ XNANDPSU_INTR_SIG_EN_OFFSET
#define XNANDPSU_INTR_SIG_EN_OFFSET 0x18U |
Interrupt Signal Enable Register
◆ XNANDPSU_INTR_SIG_EN_TRANS_COMP_STS_EN_MASK
#define XNANDPSU_INTR_SIG_EN_TRANS_COMP_STS_EN_MASK 0x00000004U |
Transfer Complete Signal Enable
◆ XNANDPSU_INTR_STS_BUFF_RD_RDY_STS_EN_MASK
#define XNANDPSU_INTR_STS_BUFF_RD_RDY_STS_EN_MASK 0x00000002U |
◆ XNANDPSU_INTR_STS_BUFF_WR_RDY_STS_EN_MASK
#define XNANDPSU_INTR_STS_BUFF_WR_RDY_STS_EN_MASK 0x00000001U |
◆ XNANDPSU_INTR_STS_DMA_INT_STS_EN_MASK
#define XNANDPSU_INTR_STS_DMA_INT_STS_EN_MASK 0x00000040U |
◆ XNANDPSU_INTR_STS_EN_BUFF_RD_RDY_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_BUFF_RD_RDY_STS_EN_MASK 0x00000002U |
◆ XNANDPSU_INTR_STS_EN_BUFF_WR_RDY_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_BUFF_WR_RDY_STS_EN_MASK 0x00000001U |
◆ XNANDPSU_INTR_STS_EN_DMA_INT_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_DMA_INT_STS_EN_MASK 0x00000040U |
◆ XNANDPSU_INTR_STS_EN_ERR_AHB_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_ERR_AHB_STS_EN_MASK 0x00000080U |
◆ XNANDPSU_INTR_STS_EN_ERR_INTR_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_ERR_INTR_STS_EN_MASK 0x00000010U |
◆ XNANDPSU_INTR_STS_EN_MUL_BIT_ERR_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_MUL_BIT_ERR_STS_EN_MASK 0x00000008U |
◆ XNANDPSU_INTR_STS_EN_OFFSET
#define XNANDPSU_INTR_STS_EN_OFFSET 0x14U |
Interrupt Status Enable Register
◆ XNANDPSU_INTR_STS_EN_TRANS_COMP_STS_EN_MASK
#define XNANDPSU_INTR_STS_EN_TRANS_COMP_STS_EN_MASK 0x00000004U |
Transfer Complete Status Enable
◆ XNANDPSU_INTR_STS_ERR_AHB_STS_EN_MASK
#define XNANDPSU_INTR_STS_ERR_AHB_STS_EN_MASK 0x00000080U |
◆ XNANDPSU_INTR_STS_ERR_INTR_STS_EN_MASK
#define XNANDPSU_INTR_STS_ERR_INTR_STS_EN_MASK 0x00000010U |
Single Bit Error, BCH Detect Error
◆ XNANDPSU_INTR_STS_MUL_BIT_ERR_STS_EN_MASK
#define XNANDPSU_INTR_STS_MUL_BIT_ERR_STS_EN_MASK 0x00000008U |
◆ XNANDPSU_INTR_STS_OFFSET
#define XNANDPSU_INTR_STS_OFFSET 0x1CU |
◆ XNANDPSU_INTR_STS_TRANS_COMP_STS_EN_MASK
#define XNANDPSU_INTR_STS_TRANS_COMP_STS_EN_MASK 0x00000004U |
◆ XNANDPSU_INTR_TRANS_COMP_STS_EN_MASK
#define XNANDPSU_INTR_TRANS_COMP_STS_EN_MASK 0x00000004U |
◆ XNandPsu_IntrSigClear
#define XNandPsu_IntrSigClear |
InstancePtr, |
Mask |
Value:
(Mask))
Definition: xnandpsu_hw.h:61
#define XNandPsu_ClrBits(InstancePtr, RegOffset, BitMask)
Definition: xnandpsu.h:459
This macro clears bitmask in Interrupt Signal Enable register.
- Parameters
- Note
- C-style signature: void XNandPsu_IntrSigClear(XNandPsu *InstancePtr, u32 Mask)
◆ XNandPsu_IntrSigEnable
#define XNandPsu_IntrSigEnable |
InstancePtr, |
Mask |
Value:
(Mask))
#define XNandPsu_SetBits(InstancePtr, RegOffset, BitMask)
Definition: xnandpsu.h:439
This macro enables bitmask in Interrupt Signal Enable register.
- Parameters
- Note
- C-style signature: void XNandPsu_IntrSigEnable(XNandPsu *InstancePtr, u32 Mask)
◆ XNandPsu_IntrStsEnable
#define XNandPsu_IntrStsEnable |
InstancePtr, |
Mask |
Value:
(Mask))
Definition: xnandpsu_hw.h:59
This macro enables bitmask in Interrupt Status Enable register.
- Parameters
- Note
- C-style signature: void XNandPsu_IntrStsEnable(XNandPsu *InstancePtr, u32 Mask)
◆ XNANDPSU_MAX_BLOCKS
#define XNANDPSU_MAX_BLOCKS 16384U |
◆ XNANDPSU_MAX_LUNS
#define XNANDPSU_MAX_LUNS 8U |
◆ XNANDPSU_MAX_PAGE_SIZE
#define XNANDPSU_MAX_PAGE_SIZE 16384U |
◆ XNANDPSU_MAX_PAGES_PER_BLOCK
#define XNANDPSU_MAX_PAGES_PER_BLOCK 512U |
Max number pages per block
◆ XNANDPSU_MAX_PKT_COUNT
#define XNANDPSU_MAX_PKT_COUNT 0xFFFU |
◆ XNANDPSU_MAX_PKT_SIZE
#define XNANDPSU_MAX_PKT_SIZE 0x7FFU |
◆ XNANDPSU_MAX_SPARE_SIZE
#define XNANDPSU_MAX_SPARE_SIZE 0x800U |
Max spare bytes of a NAND flash page of 16K
◆ XNANDPSU_MAX_TARGETS
#define XNANDPSU_MAX_TARGETS 1U |
◆ XNANDPSU_MEM_ADDR1_COL_ADDR_MASK
#define XNANDPSU_MEM_ADDR1_COL_ADDR_MASK 0x0000FFFFU |
◆ XNANDPSU_MEM_ADDR1_OFFSET
#define XNANDPSU_MEM_ADDR1_OFFSET 0x04U |
Memory Address Register 1
◆ XNANDPSU_MEM_ADDR1_PG_ADDR_MASK
#define XNANDPSU_MEM_ADDR1_PG_ADDR_MASK 0xFFFF0000U |
◆ XNANDPSU_MEM_ADDR1_PG_ADDR_SHIFT
#define XNANDPSU_MEM_ADDR1_PG_ADDR_SHIFT 16U |
◆ XNANDPSU_MEM_ADDR2_BUS_WIDTH_MASK
#define XNANDPSU_MEM_ADDR2_BUS_WIDTH_MASK 0x01000000U |
◆ XNANDPSU_MEM_ADDR2_BUS_WIDTH_SHIFT
#define XNANDPSU_MEM_ADDR2_BUS_WIDTH_SHIFT 24U |
◆ XNANDPSU_MEM_ADDR2_CHIP_SEL_MASK
#define XNANDPSU_MEM_ADDR2_CHIP_SEL_MASK 0xC0000000U |
◆ XNANDPSU_MEM_ADDR2_CHIP_SEL_SHIFT
#define XNANDPSU_MEM_ADDR2_CHIP_SEL_SHIFT 30U |
◆ XNANDPSU_MEM_ADDR2_MEM_ADDR_MASK
#define XNANDPSU_MEM_ADDR2_MEM_ADDR_MASK 0x000000FFU |
◆ XNANDPSU_MEM_ADDR2_MODE_MASK
#define XNANDPSU_MEM_ADDR2_MODE_MASK 0x30000000U |
◆ XNANDPSU_MEM_ADDR2_NFC_BCH_MODE_MASK
#define XNANDPSU_MEM_ADDR2_NFC_BCH_MODE_MASK 0x0E000000U |
◆ XNANDPSU_MEM_ADDR2_OFFSET
#define XNANDPSU_MEM_ADDR2_OFFSET 0x08U |
Memory Address Register 2
◆ XNANDPSU_NO_OOB_BBT_DESC_SIG_OFFSET
#define XNANDPSU_NO_OOB_BBT_DESC_SIG_OFFSET 0U |
Bad Block Table signature offset in page memory
◆ XNANDPSU_NO_OOB_BBT_DESC_VER_OFFSET
#define XNANDPSU_NO_OOB_BBT_DESC_VER_OFFSET 4U |
Bad block Table version offset in page memory
◆ XNANDPSU_PAGE_SIZE_16K
#define XNANDPSU_PAGE_SIZE_16K 16384U |
◆ XNANDPSU_PAGE_SIZE_1K_16BIT
#define XNANDPSU_PAGE_SIZE_1K_16BIT 1024U |
◆ XNANDPSU_PAGE_SIZE_2K
#define XNANDPSU_PAGE_SIZE_2K 2048U |
◆ XNANDPSU_PAGE_SIZE_4K
#define XNANDPSU_PAGE_SIZE_4K 4096U |
◆ XNANDPSU_PAGE_SIZE_512
#define XNANDPSU_PAGE_SIZE_512 512U |
◆ XNANDPSU_PAGE_SIZE_8K
#define XNANDPSU_PAGE_SIZE_8K 8192U |
◆ XNANDPSU_PKT_OFFSET
#define XNANDPSU_PKT_OFFSET 0x00U |
◆ XNANDPSU_PKT_PKT_CNT_MASK
#define XNANDPSU_PKT_PKT_CNT_MASK 0x00FFF000U |
◆ XNANDPSU_PKT_PKT_CNT_SHIFT
#define XNANDPSU_PKT_PKT_CNT_SHIFT 12U |
◆ XNANDPSU_PKT_PKT_SIZE_MASK
#define XNANDPSU_PKT_PKT_SIZE_MASK 0x000007FFU |
◆ XNANDPSU_PROG_BLK_ERASE_MASK
#define XNANDPSU_PROG_BLK_ERASE_MASK 0x00000004U |
◆ XNANDPSU_PROG_CHNG_RD_COL_ENH_MASK
#define XNANDPSU_PROG_CHNG_RD_COL_ENH_MASK 0x00004000U |
◆ XNANDPSU_PROG_CHNG_ROW_ADDR_END_MASK
#define XNANDPSU_PROG_CHNG_ROW_ADDR_END_MASK 0x00400000U |
◆ XNANDPSU_PROG_CHNG_ROW_ADDR_MASK
#define XNANDPSU_PROG_CHNG_ROW_ADDR_MASK 0x00200000U |
◆ XNANDPSU_PROG_COPY_BACK_INTRLVD_MASK
#define XNANDPSU_PROG_COPY_BACK_INTRLVD_MASK 0x00008000U |
◆ XNANDPSU_PROG_GET_FEATURES_MASK
#define XNANDPSU_PROG_GET_FEATURES_MASK 0x00000200U |
◆ XNANDPSU_PROG_MUL_DIE_MASK
#define XNANDPSU_PROG_MUL_DIE_MASK 0x00000002U |
◆ XNANDPSU_PROG_MUL_DIE_RD_MASK
#define XNANDPSU_PROG_MUL_DIE_RD_MASK 0x00000020U |
◆ XNANDPSU_PROG_ODT_CONF_MASK
#define XNANDPSU_PROG_ODT_CONF_MASK 0x04000000U |
◆ XNANDPSU_PROG_OFFSET
#define XNANDPSU_PROG_OFFSET 0x10U |
◆ XNANDPSU_PROG_PG_PROG_MASK
#define XNANDPSU_PROG_PG_PROG_MASK 0x00000010U |
◆ XNANDPSU_PROG_PGM_PG_CLR_MASK
#define XNANDPSU_PROG_PGM_PG_CLR_MASK 0x01000000U |
Enhanced Program Page Register Clear
◆ XNANDPSU_PROG_RD_CACHE_END_MASK
#define XNANDPSU_PROG_RD_CACHE_END_MASK 0x00080000U |
◆ XNANDPSU_PROG_RD_CACHE_RAND_MASK
#define XNANDPSU_PROG_RD_CACHE_RAND_MASK 0x00040000U |
◆ XNANDPSU_PROG_RD_CACHE_SEQ_MASK
#define XNANDPSU_PROG_RD_CACHE_SEQ_MASK 0x00020000U |
◆ XNANDPSU_PROG_RD_CACHE_START_MASK
#define XNANDPSU_PROG_RD_CACHE_START_MASK 0x00010000U |
◆ XNANDPSU_PROG_RD_ID_MASK
#define XNANDPSU_PROG_RD_ID_MASK 0x00000040U |
◆ XNANDPSU_PROG_RD_INTRLVD_MASK
#define XNANDPSU_PROG_RD_INTRLVD_MASK 0x00002000U |
◆ XNANDPSU_PROG_RD_MASK
#define XNANDPSU_PROG_RD_MASK 0x00000001U |
◆ XNANDPSU_PROG_RD_PRM_PG_MASK
#define XNANDPSU_PROG_RD_PRM_PG_MASK 0x00000080U |
◆ XNANDPSU_PROG_RD_STS_ENH_MASK
#define XNANDPSU_PROG_RD_STS_ENH_MASK 0x00001000U |
◆ XNANDPSU_PROG_RD_STS_MASK
#define XNANDPSU_PROG_RD_STS_MASK 0x00000008U |
◆ XNANDPSU_PROG_RD_UNQ_ID_MASK
#define XNANDPSU_PROG_RD_UNQ_ID_MASK 0x00000800U |
◆ XNANDPSU_PROG_RST_LUN_MASK
#define XNANDPSU_PROG_RST_LUN_MASK 0x00800000U |
◆ XNANDPSU_PROG_RST_MASK
#define XNANDPSU_PROG_RST_MASK 0x00000100U |
◆ XNANDPSU_PROG_SET_FEATURES_MASK
#define XNANDPSU_PROG_SET_FEATURES_MASK 0x00000400U |
◆ XNANDPSU_PROG_SMALL_DATA_MOVE_MASK
#define XNANDPSU_PROG_SMALL_DATA_MOVE_MASK 0x00100000U |
◆ XNANDPSU_PROG_VOL_SEL_MASK
#define XNANDPSU_PROG_VOL_SEL_MASK 0x02000000U |
◆ XNandPsu_ReadModifyWrite
#define XNandPsu_ReadModifyWrite |
InstancePtr, |
RegOffset, |
Mask, |
Value |
◆ XNandPsu_ReadReg
#define XNandPsu_ReadReg |
BaseAddress, |
RegOffset |
| Xil_In32((BaseAddress) + (RegOffset)) |
This macro reads the given register.
- Parameters
BaseAddress | is the base address of controller registers. |
RegOffset | is the register offset to be read. |
- Returns
- The 32-bit value of the register.
- Note
- C-style signature: u32 XNandPsu_ReadReg(u32 BaseAddress, u32 RegOffset)
◆ XNANDPSU_READY_BUSY_OFFSET
#define XNANDPSU_READY_BUSY_OFFSET 0x20U |
Ready/Busy status Register
◆ XNandPsu_SetBits
#define XNandPsu_SetBits |
InstancePtr, |
RegOffset, |
BitMask |
◆ XNANDPSU_SLV_DMA_CONF_DMA_BURST_SIZE_MASK
#define XNANDPSU_SLV_DMA_CONF_DMA_BURST_SIZE_MASK 0x00E00000U |
◆ XNANDPSU_SLV_DMA_CONF_DMA_TMOUT_CNT_VAL_MASK
#define XNANDPSU_SLV_DMA_CONF_DMA_TMOUT_CNT_VAL_MASK 0x0F000000U |
DMA Timeout Counter Value
◆ XNANDPSU_SLV_DMA_CONF_DMA_TRANS_CNT_MASK
#define XNANDPSU_SLV_DMA_CONF_DMA_TRANS_CNT_MASK 0x001FFFFEU |
◆ XNANDPSU_SLV_DMA_CONF_OFFSET
#define XNANDPSU_SLV_DMA_CONF_OFFSET 0x80U |
Slave DMA Configuration Register
◆ XNANDPSU_SLV_DMA_CONF_SDMA_EN_MASK
#define XNANDPSU_SLV_DMA_CONF_SDMA_EN_MASK 0x10000000U |
◆ XNANDPSU_SLV_DMA_CONF_SDMA_TX_RX_MASK
#define XNANDPSU_SLV_DMA_CONF_SDMA_TX_RX_MASK 0x00000001U |
Slave DMA Transfer Direction
◆ XNANDPSU_TIMING_DQS_BUFF_SEL_MASK
#define XNANDPSU_TIMING_DQS_BUFF_SEL_MASK 0x00000078U |
Write/Read data transaction value
◆ XNANDPSU_TIMING_OFFSET
#define XNANDPSU_TIMING_OFFSET 0x2CU |
◆ XNANDPSU_TIMING_SLOW_FAST_TCAD_MASK
#define XNANDPSU_TIMING_SLOW_FAST_TCAD_MASK 0x00000004U |
◆ XNANDPSU_TIMING_TADL_TIME_MASK
#define XNANDPSU_TIMING_TADL_TIME_MASK 0x00007F80U |
Address latch enable to Data loading time
◆ XNANDPSU_TIMING_TCCS_TIME_MASK
#define XNANDPSU_TIMING_TCCS_TIME_MASK 0x00000003U |
◆ XNandPsu_WriteReg
#define XNandPsu_WriteReg |
BaseAddress, |
RegOffset, |
Data |
| Xil_Out32(((BaseAddress) + (RegOffset)), (Data)) |
This macro writes the given register.
- Parameters
BaseAddress | is the the base address of controller registers. |
RegOffset | is the register offset to be written. |
Data | is the the 32-bit value to write to the register. |
- Returns
- None.
- Note
- C-style signature: void XNandPsu_WriteReg(u32 BaseAddress, u32 RegOffset, u32 Data)
◆ XQSPIPS_BASEADDR
#define XQSPIPS_BASEADDR 0XFF0F0000U |
◆ XQSPIPS_EN_REG
◆ XQSPIPS_LQSPI_CFG_RST_STATE
#define XQSPIPS_LQSPI_CFG_RST_STATE 0x800238C1U |
◆ XQSPIPS_LQSPI_CR_4_BYTE_STATE
#define XQSPIPS_LQSPI_CR_4_BYTE_STATE 0x88000013U |
Default 4 Byte LQSPI CR value
◆ XQSPIPS_LQSPI_CR_INST_MASK
#define XQSPIPS_LQSPI_CR_INST_MASK 0x000000FFU |
◆ XQSPIPS_LQSPI_CR_RST_STATE
#define XQSPIPS_LQSPI_CR_RST_STATE 0x80000003U |
◆ XQSPIPSU_CFG_OFFSET
#define XQSPIPSU_CFG_OFFSET 0X00000000U |
◆ XQSPIPSU_CLK_ACTIVE_LOW_OPTION
#define XQSPIPSU_CLK_ACTIVE_LOW_OPTION 0x2U |
◆ XQSPIPSU_CLK_PHASE_1_OPTION
#define XQSPIPSU_CLK_PHASE_1_OPTION 0x4U |
◆ XQSPIPSU_CLK_PRESCALE_128
#define XQSPIPSU_CLK_PRESCALE_128 0x06U |
◆ XQSPIPSU_CLK_PRESCALE_16
#define XQSPIPSU_CLK_PRESCALE_16 0x03U |
◆ XQSPIPSU_CLK_PRESCALE_2
#define XQSPIPSU_CLK_PRESCALE_2 0x00U |
◆ XQSPIPSU_CLK_PRESCALE_256
#define XQSPIPSU_CLK_PRESCALE_256 0x07U |
◆ XQSPIPSU_CLK_PRESCALE_32
#define XQSPIPSU_CLK_PRESCALE_32 0x04U |
◆ XQSPIPSU_CLK_PRESCALE_4
#define XQSPIPSU_CLK_PRESCALE_4 0x01U |
◆ XQSPIPSU_CLK_PRESCALE_64
#define XQSPIPSU_CLK_PRESCALE_64 0x05U |
◆ XQSPIPSU_CLK_PRESCALE_8
#define XQSPIPSU_CLK_PRESCALE_8 0x02U |
◆ XQSPIPSU_CONNECTION_MODE_PARALLEL
#define XQSPIPSU_CONNECTION_MODE_PARALLEL 2U |
◆ XQSPIPSU_CONNECTION_MODE_SINGLE
#define XQSPIPSU_CONNECTION_MODE_SINGLE 0U |
◆ XQSPIPSU_CONNECTION_MODE_STACKED
#define XQSPIPSU_CONNECTION_MODE_STACKED 1U |
◆ XQSPIPSU_CR_PRESC_MAXIMUM
#define XQSPIPSU_CR_PRESC_MAXIMUM 7U |
◆ XQSPIPSU_DATA_DLY_ADJ_OFFSET
#define XQSPIPSU_DATA_DLY_ADJ_OFFSET 0X000000F8U |
◆ XQspiPsu_Disable
#define XQspiPsu_Disable |
InstancePtr | ) |
Value:
#define XQSPIPSU_EN_OFFSET
Definition: xqspipsu_hw.h:382
#define XQspiPsu_Out32
Definition: xqspipsu_hw.h:967
Disable QSPI controller
◆ XQSPIPSU_DMA_BYTES_MAX
#define XQSPIPSU_DMA_BYTES_MAX 0x10000000U |
◆ XQSPIPSU_EN_OFFSET
#define XQSPIPSU_EN_OFFSET 0X00000014U |
Register: XQSPIPSU_EN_REG
◆ XQspiPsu_Enable
#define XQspiPsu_Enable |
InstancePtr | ) |
Value:Enable QSPI Controller
◆ XQSPIPSU_FIFO_CTRL_OFFSET
#define XQSPIPSU_FIFO_CTRL_OFFSET 0X0000004CU |
Register: XQSPIPSU_FIFO_CTRL
◆ XQSPIPSU_FREQ_100MHZ
#define XQSPIPSU_FREQ_100MHZ 100000000U |
◆ XQSPIPSU_FREQ_150MHZ
#define XQSPIPSU_FREQ_150MHZ 150000000U |
◆ XQSPIPSU_FREQ_37_5MHZ
#define XQSPIPSU_FREQ_37_5MHZ 37500000U |
◆ XQSPIPSU_FREQ_40MHZ
#define XQSPIPSU_FREQ_40MHZ 40000000U |
◆ XQSPIPSU_GEN_FIFO_OFFSET
#define XQSPIPSU_GEN_FIFO_OFFSET 0X00000040U |
Register: XQSPIPSU_GEN_FIFO
◆ XQSPIPSU_GENFIFO_CS_HOLD
#define XQSPIPSU_GENFIFO_CS_HOLD 0x04U |
Chip select hold in GENFIFO
◆ XQSPIPSU_GENFIFO_CS_SETUP
#define XQSPIPSU_GENFIFO_CS_SETUP 0x05U |
Chip select setup in GENFIO
◆ XQSPIPSU_GENFIFO_EXP_START
#define XQSPIPSU_GENFIFO_EXP_START 0x100U |
◆ XQSPIPSU_GENFIFO_IMM_DATA_MASK
#define XQSPIPSU_GENFIFO_IMM_DATA_MASK 0xFFU |
◆ XQspiPsu_GetLqspiConfigReg
#define XQspiPsu_GetLqspiConfigReg |
InstancePtr | ) |
Value:
#define XQSPIPSU_LQSPI_CR_OFFSET
Definition: xqspipsu_hw.h:149
Definition: xqspipsu_hw.h:67
#define XQspiPsu_In32
Definition: xqspipsu_hw.h:966
Read Configuration register of LQSPI Controller
◆ XQSPIPSU_GF_SNAPSHOT_OFFSET
#define XQSPIPSU_GF_SNAPSHOT_OFFSET 0X00000060U |
Register: XQSPIPSU_GF_SNAPSHOT
◆ XQSPIPSU_GF_THRESHOLD_OFFSET
#define XQSPIPSU_GF_THRESHOLD_OFFSET 0X00000050U |
Register: XQSPIPSU_GF_THRESHOLD
◆ XQSPIPSU_GPIO_OFFSET
#define XQSPIPSU_GPIO_OFFSET 0X00000030U |
◆ XQSPIPSU_H_
< prevent circular inclusions by using protection macros
◆ XQSPIPSU_HW_H
◆ XQSPIPSU_IDR_OFFSET
#define XQSPIPSU_IDR_OFFSET 0X0000000CU |
◆ XQSPIPSU_IER_OFFSET
#define XQSPIPSU_IER_OFFSET 0X00000008U |
◆ XQSPIPSU_IMR_OFFSET
#define XQSPIPSU_IMR_OFFSET 0X00000010U |
◆ XQspiPsu_In32
#define XQspiPsu_In32 Xil_In32 |
Read the 32 bit register value
◆ XQSPIPSU_ISR_OFFSET
#define XQSPIPSU_ISR_OFFSET 0X00000004U |
◆ XQSPIPSU_LPBK_DLY_ADJ_OFFSET
#define XQSPIPSU_LPBK_DLY_ADJ_OFFSET 0X00000038U |
Register: XQSPIPSU_LPBK_DLY_ADJ
◆ XQSPIPSU_LQSPI_CR_ADDR_32BIT_MASK
#define XQSPIPSU_LQSPI_CR_ADDR_32BIT_MASK 0x01000000U |
◆ XQSPIPSU_LQSPI_CR_LINEAR_MASK
#define XQSPIPSU_LQSPI_CR_LINEAR_MASK 0x80000000U |
◆ XQSPIPSU_LQSPI_CR_MODE_BITS_MASK
#define XQSPIPSU_LQSPI_CR_MODE_BITS_MASK 0x00FF0000U |
Mode value for dual I/O or quad I/O
◆ XQSPIPSU_LQSPI_CR_MODE_EN_MASK
#define XQSPIPSU_LQSPI_CR_MODE_EN_MASK 0x02000000U |
◆ XQSPIPSU_LQSPI_CR_MODE_ON_MASK
#define XQSPIPSU_LQSPI_CR_MODE_ON_MASK 0x01000000U |
◆ XQSPIPSU_LQSPI_CR_OFFSET
#define XQSPIPSU_LQSPI_CR_OFFSET 0X000000A0U |
◆ XQSPIPSU_LQSPI_CR_SEP_BUS_MASK
#define XQSPIPSU_LQSPI_CR_SEP_BUS_MASK 0x20000000U |
◆ XQSPIPSU_LQSPI_CR_TWO_MEM_MASK
#define XQSPIPSU_LQSPI_CR_TWO_MEM_MASK 0x40000000U |
◆ XQSPIPSU_LQSPI_CR_U_PAGE_MASK
#define XQSPIPSU_LQSPI_CR_U_PAGE_MASK 0x10000000U |
◆ XQSPIPSU_LQSPI_LESS_THEN_SIXTEENMB
#define XQSPIPSU_LQSPI_LESS_THEN_SIXTEENMB 1U |
◆ XQSPIPSU_LQSPI_MODE_OPTION
#define XQSPIPSU_LQSPI_MODE_OPTION 0x20U |
◆ XQSPIPSU_MANUAL_START_OPTION
#define XQSPIPSU_MANUAL_START_OPTION 0x8U |
◆ XQSPIPSU_MOD_ID_OFFSET
#define XQSPIPSU_MOD_ID_OFFSET 0X000000FCU |
Register: XQSPIPSU_MOD_ID
◆ XQSPIPSU_MSG_FLAG_POLL
#define XQSPIPSU_MSG_FLAG_POLL 0x8U |
◆ XQSPIPSU_MSG_FLAG_RX
#define XQSPIPSU_MSG_FLAG_RX 0x2U |
◆ XQSPIPSU_MSG_FLAG_STRIPE
#define XQSPIPSU_MSG_FLAG_STRIPE 0x1U |
◆ XQSPIPSU_MSG_FLAG_TX
#define XQSPIPSU_MSG_FLAG_TX 0x4U |
◆ XQSPIPSU_NUM_OPTIONS
#define XQSPIPSU_NUM_OPTIONS (sizeof(OptionsTable) / sizeof(OptionsMap)) |
Number of options in option table
◆ XQspiPsu_Out32
#define XQspiPsu_Out32 Xil_Out32 |
Write the 32 bit register value
◆ XQSPIPSU_POLL_CFG_OFFSET
#define XQSPIPSU_POLL_CFG_OFFSET 0X00000054U |
Register: XQSPIPSU_POLL_CFG
◆ XQSPIPSU_QSPIDMA_DST_ADDR_OFFSET
#define XQSPIPSU_QSPIDMA_DST_ADDR_OFFSET 0X00000700U |
Register: XQSPIPSU_QSPIDMA_DST_ADDR
◆ XQSPIPSU_READMODE_DMA
#define XQSPIPSU_READMODE_DMA 0x0U |
◆ XQSPIPSU_READMODE_IO
#define XQSPIPSU_READMODE_IO 0x1U |
◆ XQspiPsu_ReadReg
#define XQspiPsu_ReadReg |
BaseAddress, |
RegOffset |
| XQspiPsu_In32((BaseAddress) + (RegOffset)) |
Read a register.
- Parameters
BaseAddress | contains the base address of the device. |
RegOffset | contains the offset from the 1st register of the device to the target register. |
- Returns
- The value read from the register.
- Note
- C-Style signature: u32 XQspiPsu_ReadReg(u32 BaseAddress. s32 RegOffset)
◆ XQSPIPSU_RX_COPY_OFFSET
#define XQSPIPSU_RX_COPY_OFFSET 0X00000064U |
Register: XQSPIPSU_RX_COPY
◆ XQSPIPSU_RXADDR_OVER_32BIT
#define XQSPIPSU_RXADDR_OVER_32BIT 0x100000000U |
◆ XQSPIPSU_RXD_OFFSET
#define XQSPIPSU_RXD_OFFSET 0X00000020U |
◆ XQSPIPSU_SEL_OFFSET
#define XQSPIPSU_SEL_OFFSET 0X00000044U |
◆ XQspiPsu_Select
#define XQspiPsu_Select |
InstancePtr, |
Mask |
Value:
Definition: xqspipsu_hw.h:506
select QSPI controller
◆ XQSPIPSU_SELECT_FLASH_BUS_BOTH
#define XQSPIPSU_SELECT_FLASH_BUS_BOTH 0x3U |
◆ XQSPIPSU_SELECT_FLASH_BUS_LOWER
#define XQSPIPSU_SELECT_FLASH_BUS_LOWER 0x1U |
◆ XQSPIPSU_SELECT_FLASH_BUS_UPPER
#define XQSPIPSU_SELECT_FLASH_BUS_UPPER 0x2U |
◆ XQSPIPSU_SELECT_FLASH_CS_BOTH
#define XQSPIPSU_SELECT_FLASH_CS_BOTH 0x3U |
◆ XQSPIPSU_SELECT_FLASH_CS_LOWER
#define XQSPIPSU_SELECT_FLASH_CS_LOWER 0x1U |
◆ XQSPIPSU_SELECT_FLASH_CS_UPPER
#define XQSPIPSU_SELECT_FLASH_CS_UPPER 0x2U |
◆ XQSPIPSU_SELECT_MODE_DUALSPI
#define XQSPIPSU_SELECT_MODE_DUALSPI 0x2U |
◆ XQSPIPSU_SELECT_MODE_QUADSPI
#define XQSPIPSU_SELECT_MODE_QUADSPI 0x4U |
◆ XQSPIPSU_SELECT_MODE_SPI
#define XQSPIPSU_SELECT_MODE_SPI 0x1U |
◆ XQSPIPSU_SET_WP
#define XQSPIPSU_SET_WP 1 |
GQSPI configuration to toggle WP of flash
◆ XQSPIPSU_TX_THRESHOLD_OFFSET
#define XQSPIPSU_TX_THRESHOLD_OFFSET 0X00000028U |
Register: XQSPIPSU_TX_THRESHOLD
◆ XQSPIPSU_TXD_OFFSET
#define XQSPIPSU_TXD_OFFSET 0X0000001CU |
◆ XQspiPsu_WriteReg
#define XQspiPsu_WriteReg |
BaseAddress, |
RegOffset, |
RegisterValue |
| XQspiPsu_Out32((BaseAddress) + (RegOffset), (RegisterValue)) |
Write to a register.
- Parameters
RegOffset | contains the offset from the 1st register of the device to target register. |
RegisterValue | is the value to be written to the register. |
- Returns
- None.
- Note
- C-Style signature: void XQspiPsu_WriteReg(u32 BaseAddress, s32 RegOffset,
u32 RegisterValue) XQSPIPSU_H
◆ XQSPIPSU_XFER_STS_OFFSET
#define XQSPIPSU_XFER_STS_OFFSET 0X0000005CU |
Register: XQSPIPSU_XFER_STS
◆ XQspiPsu_StatusHandler
typedef void(* XQspiPsu_StatusHandler) (const void *CallBackRef, u32 StatusEvent, u32 ByteCount) |
The handler data type allows the user to define a callback function to handle the asynchronous processing for the QSPIPSU device. The application using this driver is expected to define a handler of this type to support interrupt driven mode. The handler executes in an interrupt context, so only minimal processing should be performed.
- Parameters
CallBackRef | is the callback reference passed in by the upper layer when setting the callback functions, and passed back to the upper layer when the callback is invoked. Its type is not important to the driver, so it is a void pointer. |
StatusEvent | holds one or more status events that have occurred. See the XQspiPsu_SetStatusHandler() for details on the status events that can be passed in the callback. |
ByteCount | indicates how many bytes of data were successfully transferred. This may be less than the number of bytes requested if the status event indicates an error. |
◆ OnfiCommandList
This enum defines the ONFI 3.1 commands.
Enumerator |
READ | Read
MULTIPLANE_READ | Multiplane Read
COPYBACK_READ | Copyback Read
CHANGE_READ_COLUMN | Change Read Column
CHANGE_READ_COLUMN_ENHANCED | Change Read Column Enhanced
READ_CACHE_RANDOM | Read Cache Random
READ_CACHE_SEQUENTIAL | Read Cache Sequential
READ_CACHE_END | Read Cache End
BLOCK_ERASE | Block Erase
MULTIPLANE_BLOCK_ERASE | Multiplane Block Erase
READ_STATUS | Read Status
READ_STATUS_ENHANCED | Read Status Enhanced
PAGE_PROGRAM | Page Program
MULTIPLANE_PAGE_PROGRAM | Multiplane Page Program
PAGE_CACHE_PROGRAM | Page Cache Program
COPYBACK_PROGRAM | Copyback Program
MULTIPLANE_COPYBACK_PROGRAM | Multiplance Copyback Program
SMALL_DATA_MOVE | Small Data Move
CHANGE_WRITE_COLUMN | Change Write Column
CHANGE_ROW_ADDR | Change Row Address
READ_ID | Read ID
VOLUME_SELECT | Volume Select
ODT_CONFIGURE | ODT Configure
READ_PARAM_PAGE | Read Parameter Page
READ_UNIQUE_ID | Read Unique ID
GET_FEATURES | Get Features
SET_FEATURES | Set Features
LUN_GET_FEATURES | LUN Get Features
LUN_SET_FEATURES | LUN Set Features
RESET_LUN | Reset LUN
SYN_RESET | Synchronous Reset
RESET | Reset
MAX_CMDS | Dummy Command
◆ XNandPsu_DataInterface
The XNandPsu_DataInterface enum contains flash operating mode.
Enumerator |
XNANDPSU_SDR | Single Data Rate
XNANDPSU_NVDDR | Double Data Rate
◆ XNandPsu_DmaMode
The XNandPsu_DmaMode enum contains the controller MDMA mode.
Enumerator |
XNANDPSU_PIO | PIO Mode
XNANDPSU_SDMA | SDMA Mode
XNANDPSU_MDMA | MDMA Mode
◆ XNandPsu_EccMode
The XNandPsu_EccMode enum contains ECC functionality.
◆ XNandPsu_SWMode
The XNandPsu_SWMode enum contains the driver operating mode.
Enumerator |
XNANDPSU_POLLING | Polling
XNANDPSU_INTERRUPT | Interrupt
◆ XNandPsu_TimingMode
XNandPsu_TimingMode enum contains timing modes.
◆ XNandPsu_CfgInitialize()
This function initializes a specific XNandPsu instance. This function must be called prior to using the NAND flash device to read or write any data.
- Parameters
InstancePtr | is a pointer to the XNandPsu instance. |
ConfigPtr | points to XNandPsu device configuration structure. |
EffectiveAddr | is the base address of NAND flash controller. |
- Returns
- XST_SUCCESS if successful.
- XST_FAILURE if fail.
- Note
- The user needs to first call the XNandPsu_LookupConfig() API which returns the Configuration structure pointer which is passed as a parameter to the XNandPsu_CfgInitialize() API.
◆ XNandPsu_ChangeTimingMode()
This function changes the data interface and timing mode.
- Parameters
NewIntf | is the new data interface. |
NewMode | is the new timing mode. |
- Returns
- XST_FAILURE if failed.
- Note
- None
◆ XNandPsu_DisableDmaMode()
void XNandPsu_DisableDmaMode |
XNandPsu * |
InstancePtr | ) |
This function disables DMA mode of driver/controller operation.
- Parameters
- Returns
- None
- Note
- None
◆ XNandPsu_DisableEccMode()
void XNandPsu_DisableEccMode |
XNandPsu * |
InstancePtr | ) |
This function disables ECC mode of driver/controller operation.
- Parameters
- Returns
- None
- Note
- None
◆ XNandPsu_EnableDmaMode()
void XNandPsu_EnableDmaMode |
XNandPsu * |
InstancePtr | ) |
This function enables DMA mode of controller operation.
- Parameters
- Returns
- None
- Note
- None
◆ XNandPsu_EnableEccMode()
void XNandPsu_EnableEccMode |
XNandPsu * |
InstancePtr | ) |
This function enables ECC mode of driver/controller operation.
- Parameters
- Returns
- None
- Note
- None
◆ XNandPsu_Erase()
s32 XNandPsu_Erase |
XNandPsu * |
InstancePtr, |
u64 |
Offset, |
u64 |
Length |
This function erases the flash.
- Parameters
Offset | is the starting offset of flash to erase. |
Length | is the number of bytes to erase. |
- Returns
- Note
- The Offset and Length should be aligned to block size boundary to get better results.
◆ XNandPsu_EraseBlock()
s32 XNandPsu_EraseBlock |
XNandPsu * |
InstancePtr, |
u32 |
Target, |
u32 |
Block |
This function sends ONFI block erase command to the flash.
- Parameters
Target | is the chip select value. |
Block | is the block to erase. |
- Returns
- Note
- None
◆ XNandPsu_GetFeature()
s32 XNandPsu_GetFeature |
XNandPsu * |
InstancePtr, |
u32 |
Target, |
u8 |
Feature, |
u8 * |
Buf |
This function sends ONFI Get Feature command to flash.
- Parameters
Feature | is the feature selector. |
Buf | is the buffer to fill feature value. |
- Returns
- Note
- None
◆ XNandPsu_InitBbtDesc()
void XNandPsu_InitBbtDesc |
XNandPsu * |
InstancePtr | ) |
This function initializes the Bad Block Table(BBT) descriptors with a predefined pattern for searching Bad Block Table(BBT) in flash.
- Parameters
- Returns
◆ XNandPsu_IsBlockBad()
s32 XNandPsu_IsBlockBad |
XNandPsu * |
InstancePtr, |
u32 |
Block |
This function checks whether a block is bad or not.
- Parameters
InstancePtr | is the pointer to the XNandPsu instance. |
- Returns
◆ XNandPsu_MarkBlockBad()
s32 XNandPsu_MarkBlockBad |
XNandPsu * |
InstancePtr, |
u32 |
Block |
This function marks a block as bad in the RAM based Bad Block Table(BBT). It also updates the Bad Block Table(BBT) in the flash.
- Parameters
- Returns
◆ XNandPsu_OnfiParamPageCrc()
u32 XNandPsu_OnfiParamPageCrc |
u8 * |
ParamBuf, |
u32 |
StartOff, |
u32 |
Length |
This function calculates ONFI parameter page CRC.
- Parameters
ParamBuf | is a pointer to the ONFI parameter page buffer. |
StartOff | is the starting offset in buffer to calculate CRC. |
Length | is the number of bytes for which CRC is calculated. |
- Returns
- CRC value.
- Note
- None.
◆ XNandPsu_Prepare_Cmd()
void XNandPsu_Prepare_Cmd |
XNandPsu * |
InstancePtr, |
u8 |
Cmd1, |
u8 |
Cmd2, |
u8 |
EccState, |
u8 |
DmaMode, |
u8 |
AddrCycles |
This function prepares command to be written into command register.
- Parameters
Cmd1 | is the first Onfi Command. |
Cmd2 | is the second Onfi Command. |
EccState | is the flag to set Ecc State. |
DmaMode | is the flag to set DMA mode. |
AddrCycles | is the number of Address Cycles. |
- Returns
- None
- Note
- None
◆ XNandPsu_Read()
s32 XNandPsu_Read |
XNandPsu * |
InstancePtr, |
u64 |
Offset, |
u64 |
Length, |
u8 * |
DestBuf |
This function reads from the flash.
- Parameters
Offset | is the starting offset of flash to read. |
Length | is the number of bytes to read. |
DestBuf | is the destination data buffer to fill in. |
- Returns
- Note
- None
◆ XNandPsu_ReadSpareBytes()
s32 XNandPsu_ReadSpareBytes |
XNandPsu * |
InstancePtr, |
u32 |
Page, |
u8 * |
Buf |
This function reads spare bytes from flash.
- Parameters
Page | is the page address value to read. |
Buf | is the data buffer to fill in. |
- Returns
- Note
- None
◆ XNandPsu_ScanBbt()
s32 XNandPsu_ScanBbt |
XNandPsu * |
InstancePtr | ) |
This function reads the Bad Block Table(BBT) if present in flash. If not it scans the flash for detecting factory marked bad blocks and creates a bad block table and write the Bad Block Table(BBT) into the flash.
- Parameters
- Returns
◆ XNandPsu_SetFeature()
s32 XNandPsu_SetFeature |
XNandPsu * |
InstancePtr, |
u32 |
Target, |
u8 |
Feature, |
u8 * |
Buf |
This function sends ONFI Set Feature command to flash.
- Parameters
Buf | is the feature value to send. |
- Returns
- Note
- None
◆ XNandPsu_Write()
s32 XNandPsu_Write |
XNandPsu * |
InstancePtr, |
u64 |
Offset, |
u64 |
Length, |
u8 * |
SrcBuf |
This function writes to the flash.
- Parameters
Offset | is the starting offset of flash to write. |
Length | is the number of bytes to write. |
SrcBuf | is the source data buffer to write. |
- Returns
- Note
- None
◆ XNandPsu_WriteSpareBytes()
s32 XNandPsu_WriteSpareBytes |
XNandPsu * |
InstancePtr, |
u32 |
Page, |
u8 * |
Buf |
This function sends ONFI Program Page command to flash.
- Parameters
Page | is the page address value to program. |
Buf | is the data buffer to program. |
- Returns
- Note
- None
◆ XQspiPsu_Abort()
void XQspiPsu_Abort |
XQspiPsu * |
InstancePtr | ) |
Aborts a transfer in progress.
- Parameters
InstancePtr | is a pointer to the XQspiPsu instance. |
- Returns
- None.
- Note
- None.
◆ XQspiPsu_CfgInitialize()
Initializes a specific XQspiPsu instance as such the driver is ready to use.
- Parameters
ConfigPtr | is a reference to a structure containing information about a specific QSPIPSU device. This function initializes an InstancePtr object for a specific device specified by the contents of Config. |
EffectiveAddr | is the device base address in the virtual memory address space. The caller is responsible for keeping the address mapping from EffectiveAddr to the device physical base address unchanged once this function is invoked. Unexpected errors may occur if the address mapping changes after this function is called. If address translation is not used, use ConfigPtr->Config.BaseAddress for this device. |
- Returns
- XST_DEVICE_IS_STARTED if the device is already started. It must be stopped to re-initialize.
- Note
- None.
◆ XQspiPsu_CheckDmaDone()
s32 XQspiPsu_CheckDmaDone |
XQspiPsu * |
InstancePtr | ) |
This function check for DMA transfer complete.
- Parameters
- Returns
- XST_SUCCESS if DMA transfer complete.
- XST_FAILURE if DMA transfer is not completed.
- Note
- None.
◆ XQspiPsu_ClearOptions()
s32 XQspiPsu_ClearOptions |
XQspiPsu * |
InstancePtr, |
u32 |
Options |
This function resets the options for the QSPIPSU device driver.The options control how the device behaves relative to the QSPIPSU bus. The device must be idle rather than busy transferring data before setting these device options.
- Parameters
Options | contains the specified options to be set. This is a bit mask where a 1 indicates the option should be turned OFF and a 0 indicates no action. One or more bit values may be contained in the mask. See the bit definitions named XQSPIPSU_*_OPTIONS in the file xqspipsu.h. |
- Returns
- XST_SUCCESS if options are successfully set.
- XST_DEVICE_BUSY if the device is currently transferring data. The transfer must complete or be aborted before setting options.
- Note
- This function is not thread-safe.
◆ XQspiPsu_CreatePollDataConfig()
This function creates Poll config register data to write
- Parameters
FlashMsg | is a pointer to the structure containing transfer data. |
- Returns
- None
- Note
- None.
◆ XQspiPsu_FillTxFifo()
Fills the TX FIFO as long as there is room in the FIFO or the bytes required to be transmitted.
- Parameters
Size | is the number of bytes to be transmitted. |
- Returns
- None
- Note
- None.
◆ XQspiPsu_GenFifoEntryData()
This function writes the GENFIFO entries to transmit the messages requested.
- Parameters
- Returns
- XST_FAILURE if transfer fails.
- XST_DEVICE_BUSY if a transfer is already in progress.
- Note
- None.
◆ XQspiPsu_GenFifoEntryDataLen()
void XQspiPsu_GenFifoEntryDataLen |
XQspiPsu * |
InstancePtr, |
XQspiPsu_Msg * |
Msg, |
u32 * |
GenFifoEntry |
This function writes the Data length to GENFIFO entries that need to be transmitted or received.
- Parameters
GenFifoEntry | is index of the current message to be handled. |
- Returns
- Note
- None.
◆ XQspiPsu_GetOptions()
u32 XQspiPsu_GetOptions |
const XQspiPsu * |
InstancePtr | ) |
This function gets the options for the QSPIPSU device. The options control how the device behaves relative to the QSPIPSU bus.
- Parameters
- Returns
Options contains the specified options currently set. This is a bit value where a 1 means the option is on, and a 0 means the option is off. See the bit definitions named XQSPIPSU_*_OPTIONS in file xqspipsu.h.
- Note
- None.
◆ XQspiPsu_Idle()
void XQspiPsu_Idle |
const XQspiPsu * |
InstancePtr | ) |
Stops the transfer of data to internal DST FIFO from stream interface and also stops the issuing of new write commands to memory.
By calling this API, any ongoing Dma transfers will be paused and DMA will not issue AXI write commands to memory
- Parameters
- Returns
- None.
- Note
- None.
◆ XQspiPsu_InterruptHandler()
s32 XQspiPsu_InterruptHandler |
XQspiPsu * |
InstancePtr | ) |
Handles interrupt based transfers by acting on GENFIFO and DMA interurpts.
- Parameters
- Returns
- Note
- None.
◆ XQspiPsu_InterruptTransfer()
This function initiates a transfer on the bus and enables interrupts. The transfer is completed by the interrupt handler. The messages passed are all transferred on the bus between one CS assert and de-assert.
- Parameters
NumMsg | is the number of messages to be transferred. |
- Returns
- Note
- None.
◆ XQspiPsu_IORead()
This function reads data from RXFifo in IO mode.
- Parameters
StatusReg | is the Interrupt status Register value. |
- Returns
- None.
- Note
- None.
◆ XQspiPsu_PollDataConfig()
This function enables the polling functionality of controller
- Parameters
FlashMsg | is a pointer to the structure containing transfer data |
- Returns
- None
- Note
- None.
◆ XQspiPsu_PollDataHandler()
void XQspiPsu_PollDataHandler |
XQspiPsu * |
InstancePtr, |
u32 |
StatusReg |
This is the handler for polling functionality of controller. It reads data from RXFIFO, since when data from the flash device (status data) matched with configured value in poll_cfg, then controller writes the matched data into RXFIFO.
- Parameters
- Returns
- None.
- Note
- None.
◆ XQspiPsu_PolledTransfer()
This function performs a transfer on the bus in polled mode. The messages passed are all transferred on the bus between one CS assert and de-assert.
- Parameters
- Returns
- Note
- None.
◆ XQspiPsu_ReadRxFifo()
Read the specified number of bytes from RX FIFO
- Parameters
Size | is the number of bytes to be read. |
- Returns
- None
- Note
- None.
◆ XQspiPsu_Reset()
void XQspiPsu_Reset |
XQspiPsu * |
InstancePtr | ) |
Resets the QSPIPSU device. Reset must only be called after the driver has been initialized. Any data transfer that is in progress is aborted.
The upper layer software is responsible for re-configuring (if necessary) and restarting the QSPIPSU device after the reset.
- Parameters
- Returns
- None.
- Note
- None.
◆ XQspiPsu_RXSetup()
This function checks the RX buffers in the message and setup the RX DMA as required.
- Parameters
- Returns
- None
- Note
- None.
◆ XQspiPsu_SelectFlash()
void XQspiPsu_SelectFlash |
XQspiPsu * |
InstancePtr, |
u8 |
FlashCS, |
u8 |
FlashBus |
This function should be used to tell the QSPIPSU driver the HW flash configuration being used. This API should be called at least once in the application. If desired, it can be called multiple times when switching between communicating to different flahs devices/using different configs.
- Parameters
FlashCS | - Flash Chip Select. |
FlashBus | - Flash Bus (Upper, Lower or Both). |
- Returns
- Note
- If this function is not called at least once in the application, the driver assumes there is a single flash connected to the lower bus and CS line.
◆ XQspiPsu_SelectSpiMode()
u32 XQspiPsu_SelectSpiMode |
u8 |
SpiMode | ) |
Selects SPI mode - x1 or x2 or x4.
- Parameters
SpiMode | - spi or dual or quad. |
- Returns
- Mask to set desired SPI mode in GENFIFO entry.
- Note
- None.
◆ XQspiPsu_SetClkPrescaler()
s32 XQspiPsu_SetClkPrescaler |
const XQspiPsu * |
InstancePtr, |
u8 |
Prescaler |
Configures the clock according to the prescaler passed.
- Parameters
Prescaler | - clock prescaler to be set. |
- Returns
- XST_DEVICE_BUSY if the device is currently transferring data. It must be stopped to re-initialize.
- Note
- None.
◆ XQspiPsu_SetDefaultConfig()
void XQspiPsu_SetDefaultConfig |
XQspiPsu * |
InstancePtr | ) |
Enable and initialize DMA Mode, set little endain, disable poll timeout, clear prescalar bits and reset thresholds
- Parameters
- Returns
- None.
- Note
- None.
◆ XQspiPsu_SetIOMode()
This function reads remaining bytes, after the completion of a DMA transfer, using IO mode
- Parameters
- Returns
- Note
- None.
◆ XQspiPsu_SetOptions()
s32 XQspiPsu_SetOptions |
XQspiPsu * |
InstancePtr, |
u32 |
Options |
This function sets the options for the QSPIPSU device driver.The options control how the device behaves relative to the QSPIPSU bus. The device must be idle rather than busy transferring data before setting these device options.
- Parameters
Options | contains the specified options to be set. This is a bit mask where a 1 indicates the option should be turned ON and a 0 indicates no action. One or more bit values may be contained in the mask. See the bit definitions named XQSPIPSU_*_OPTIONS in the file xqspipsu.h. |
- Returns
- Note
◆ XQspiPsu_SetReadMode()
s32 XQspiPsu_SetReadMode |
XQspiPsu * |
InstancePtr, |
u32 |
Mode |
This function sets the Read mode for the QSPIPSU device driver.The device must be idle rather than busy transferring data before setting Read mode options.
- Parameters
Mode | contains the specified Mode to be set. See the bit definitions named XQSPIPSU_READMODE_* in the file xqspipsu.h. |
- Returns
- XST_DEVICE_BUSY if the device is currently transferring data. The transfer must complete or be aborted before setting Mode.
- Note
◆ XQspiPsu_SetStatusHandler()
Sets the status callback function, the status handler, which the driver calls when it encounters conditions that should be reported to upper layer software. The handler executes in an interrupt context, so it must minimize the amount of processing performed. One of the following status events is passed to the status handler.
XST_SPI_TRANSFER_DONE The requested data transfer is done
XST_SPI_TRANSMIT_UNDERRUN As a slave device, the master clocked data
but there were none available in the transmit
register/FIFO. This typically means the slave
application did not issue a transfer request
fast enough, or the processor/driver could not
fill the transmit register/FIFO fast enough.
XST_SPI_RECEIVE_OVERRUN The QSPIPSU device lost data. Data was received
but the receive data register/FIFO was full.
- Parameters
CallBackRef | is the upper layer callback reference passed back when the callback function is invoked. |
FuncPointer | is the pointer to the callback function. |
- Returns
- None.
- Note
The handler is called within interrupt context, so it should do its work quickly and queue potentially time-consuming work to a task-level thread.
◆ XQspiPsu_Setup64BRxDma()
This function sets up the RX DMA operation on a 32bit Machine For 64bit Dma transfers.
- Parameters
- Returns
- None
- Note
- None.
◆ XQspiPsu_SetupRxDma()
This function sets up the RX DMA operation.
- Parameters
- Returns
- None
- Note
- None.
◆ XQspiPsu_SetWP()
void XQspiPsu_SetWP |
const XQspiPsu * |
InstancePtr, |
u8 |
Value |
This function sets the Write Protect and Hold options for the QSPIPSU device driver.The device must be idle rather than busy transferring data before setting Write Protect and Hold options.
- Parameters
Value | of the WP_HOLD bit in configuration register |
- Returns
- None
- Note
- This function is not thread-safe. This function can only be used with single flash configuration and x1/x2 data mode. This function cannot be used with x4 data mode and dual parallel and stacked flash configuration.
◆ XQspiPsu_StartDmaTransfer()
This function start a DMA transfer.
- Parameters
- Returns
- XST_FAILURE if ByteCount is greater than XQSPIPSU_DMA_BYTES_MAX.
- Note
- None.
◆ XQspiPsu_TXRXSetup()
This function checks the TX/RX buffers in the message and setups up the GENFIFO entries, TX FIFO or RX DMA as required.
- Parameters
GenFifoEntry | is pointer to the variable in which GENFIFO mask is returned to calling function |
- Returns
- None
- Note
- None.
◆ XQspiPsu_TXSetup()
This function checks the TX buffer in the message and setup the TX FIFO as required.
- Parameters
- Returns
- None
- Note
- None.
◆ XQspiPsu_WriteProtectToggle()
void XQspiPsu_WriteProtectToggle |
const XQspiPsu * |
InstancePtr, |
u32 |
Toggle |
This API enables/ disables Write Protect pin on the flash parts.
- Parameters
InstancePtr | is a pointer to the QSPIPSU driver component to use. |
Toggle | is a value of the GPIO pin |
- Returns
- None
- Note
- By default WP pin as per the QSPI controller is driven High which means no write protection. Calling this function once will enable the protection.
◆ XQspiPsu_ConfigTable
This table contains configuration information for each QSPIPSU device in the system.
