Enumerator |
NonMaskableInt_IRQn | 2 Non Maskable Interrupt
HardFault_IRQn | 3 HardFault Interrupt
MemoryManagement_IRQn | 4 Cortex-M7 Memory Management Interrupt
BusFault_IRQn | 5 Cortex-M7 Bus Fault Interrupt
UsageFault_IRQn | 6 Cortex-M7 Usage Fault Interrupt
SVCall_IRQn | 11 Cortex-M7 SV Call Interrupt
DebugMonitor_IRQn | 12 Cortex-M7 Debug Monitor Interrupt
PendSV_IRQn | 14 Cortex-M7 Pend SV Interrupt
SysTick_IRQn | 15 Cortex-M7 System Tick Interrupt
SUPC_IRQn | 0 SAME70J19 Supply Controller (SUPC)
RSTC_IRQn | 1 SAME70J19 Reset Controller (RSTC)
RTC_IRQn | 2 SAME70J19 Real Time Clock (RTC)
RTT_IRQn | 3 SAME70J19 Real Time Timer (RTT)
WDT_IRQn | 4 SAME70J19 Watchdog Timer (WDT)
PMC_IRQn | 5 SAME70J19 Power Management Controller (PMC)
EFC_IRQn | 6 SAME70J19 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAME70J19 UART 0 (UART0)
UART1_IRQn | 8 SAME70J19 UART 1 (UART1)
PIOA_IRQn | 10 SAME70J19 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAME70J19 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAME70J19 USART 0 (USART0)
USART1_IRQn | 14 SAME70J19 USART 1 (USART1)
USART2_IRQn | 15 SAME70J19 USART 2 (USART2)
PIOD_IRQn | 16 SAME70J19 Parallel I/O Controller D (PIOD)
TWIHS0_IRQn | 19 SAME70J19 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAME70J19 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAME70J19 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAME70J19 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAME70J19 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAME70J19 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAME70J19 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAME70J19 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAME70J19 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAME70J19 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAME70J19 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAME70J19 Analog Comparator (ACC)
USBHS_IRQn | 34 SAME70J19 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAME70J19 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAME70J19 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAME70J19 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAME70J19 Analog Front End 1 (AFEC1)
SPI1_IRQn | 42 SAME70J19 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAME70J19 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAME70J19 UART 2 (UART2)
UART3_IRQn | 45 SAME70J19 UART 3 (UART3)
UART4_IRQn | 46 SAME70J19 UART 4 (UART4)
TC9_IRQn | 50 SAME70J19 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAME70J19 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAME70J19 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAME70J19 AES (AES)
TRNG_IRQn | 57 SAME70J19 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAME70J19 DMA (XDMAC)
ISI_IRQn | 59 SAME70J19 Camera Interface (ISI)
PWM1_IRQn | 60 SAME70J19 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAME70J19 Reinforced Secure Watchdog Timer (RSWDT)
PERIPH_COUNT_IRQn | Number of peripheral IDs
SUPC_IRQn | 0 SAME70J20 Supply Controller (SUPC)
RSTC_IRQn | 1 SAME70J20 Reset Controller (RSTC)
RTC_IRQn | 2 SAME70J20 Real Time Clock (RTC)
RTT_IRQn | 3 SAME70J20 Real Time Timer (RTT)
WDT_IRQn | 4 SAME70J20 Watchdog Timer (WDT)
PMC_IRQn | 5 SAME70J20 Power Management Controller (PMC)
EFC_IRQn | 6 SAME70J20 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAME70J20 UART 0 (UART0)
UART1_IRQn | 8 SAME70J20 UART 1 (UART1)
PIOA_IRQn | 10 SAME70J20 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAME70J20 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAME70J20 USART 0 (USART0)
USART1_IRQn | 14 SAME70J20 USART 1 (USART1)
USART2_IRQn | 15 SAME70J20 USART 2 (USART2)
PIOD_IRQn | 16 SAME70J20 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAME70J20 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAME70J20 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAME70J20 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAME70J20 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAME70J20 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAME70J20 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAME70J20 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAME70J20 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAME70J20 Analog Front End 0 (AFEC0)
PWM0_IRQn | 31 SAME70J20 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAME70J20 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAME70J20 Analog Comparator (ACC)
USBHS_IRQn | 34 SAME70J20 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAME70J20 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAME70J20 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAME70J20 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAME70J20 Analog Front End 1 (AFEC1)
SPI1_IRQn | 42 SAME70J20 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAME70J20 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAME70J20 UART 2 (UART2)
UART3_IRQn | 45 SAME70J20 UART 3 (UART3)
UART4_IRQn | 46 SAME70J20 UART 4 (UART4)
TC9_IRQn | 50 SAME70J20 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAME70J20 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAME70J20 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAME70J20 AES (AES)
TRNG_IRQn | 57 SAME70J20 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAME70J20 DMA (XDMAC)
ISI_IRQn | 59 SAME70J20 Camera Interface (ISI)
PWM1_IRQn | 60 SAME70J20 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAME70J20 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAME70J21 Supply Controller (SUPC)
RSTC_IRQn | 1 SAME70J21 Reset Controller (RSTC)
RTC_IRQn | 2 SAME70J21 Real Time Clock (RTC)
RTT_IRQn | 3 SAME70J21 Real Time Timer (RTT)
WDT_IRQn | 4 SAME70J21 Watchdog Timer (WDT)
PMC_IRQn | 5 SAME70J21 Power Management Controller (PMC)
EFC_IRQn | 6 SAME70J21 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAME70J21 UART 0 (UART0)
UART1_IRQn | 8 SAME70J21 UART 1 (UART1)
PIOA_IRQn | 10 SAME70J21 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAME70J21 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAME70J21 USART 0 (USART0)
USART1_IRQn | 14 SAME70J21 USART 1 (USART1)
USART2_IRQn | 15 SAME70J21 USART 2 (USART2)
PIOD_IRQn | 16 SAME70J21 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAME70J21 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAME70J21 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAME70J21 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAME70J21 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAME70J21 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAME70J21 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAME70J21 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAME70J21 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAME70J21 Analog Front End 0 (AFEC0)
PWM0_IRQn | 31 SAME70J21 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAME70J21 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAME70J21 Analog Comparator (ACC)
USBHS_IRQn | 34 SAME70J21 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAME70J21 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAME70J21 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAME70J21 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAME70J21 Analog Front End 1 (AFEC1)
SPI1_IRQn | 42 SAME70J21 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAME70J21 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAME70J21 UART 2 (UART2)
UART3_IRQn | 45 SAME70J21 UART 3 (UART3)
UART4_IRQn | 46 SAME70J21 UART 4 (UART4)
TC9_IRQn | 50 SAME70J21 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAME70J21 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAME70J21 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAME70J21 AES (AES)
TRNG_IRQn | 57 SAME70J21 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAME70J21 DMA (XDMAC)
ISI_IRQn | 59 SAME70J21 Camera Interface (ISI)
PWM1_IRQn | 60 SAME70J21 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAME70J21 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAME70N19 Supply Controller (SUPC)
RSTC_IRQn | 1 SAME70N19 Reset Controller (RSTC)
RTC_IRQn | 2 SAME70N19 Real Time Clock (RTC)
RTT_IRQn | 3 SAME70N19 Real Time Timer (RTT)
WDT_IRQn | 4 SAME70N19 Watchdog Timer (WDT)
PMC_IRQn | 5 SAME70N19 Power Management Controller (PMC)
EFC_IRQn | 6 SAME70N19 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAME70N19 UART 0 (UART0)
UART1_IRQn | 8 SAME70N19 UART 1 (UART1)
PIOA_IRQn | 10 SAME70N19 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAME70N19 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAME70N19 USART 0 (USART0)
USART1_IRQn | 14 SAME70N19 USART 1 (USART1)
USART2_IRQn | 15 SAME70N19 USART 2 (USART2)
PIOD_IRQn | 16 SAME70N19 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAME70N19 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAME70N19 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAME70N19 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAME70N19 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAME70N19 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAME70N19 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAME70N19 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAME70N19 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAME70N19 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAME70N19 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAME70N19 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAME70N19 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAME70N19 Analog Comparator (ACC)
USBHS_IRQn | 34 SAME70N19 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAME70N19 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAME70N19 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAME70N19 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAME70N19 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAME70N19 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAME70N19 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAME70N19 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAME70N19 UART 2 (UART2)
UART3_IRQn | 45 SAME70N19 UART 3 (UART3)
UART4_IRQn | 46 SAME70N19 UART 4 (UART4)
TC9_IRQn | 50 SAME70N19 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAME70N19 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAME70N19 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAME70N19 AES (AES)
TRNG_IRQn | 57 SAME70N19 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAME70N19 DMA (XDMAC)
ISI_IRQn | 59 SAME70N19 Camera Interface (ISI)
PWM1_IRQn | 60 SAME70N19 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAME70N19 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAME70N20 Supply Controller (SUPC)
RSTC_IRQn | 1 SAME70N20 Reset Controller (RSTC)
RTC_IRQn | 2 SAME70N20 Real Time Clock (RTC)
RTT_IRQn | 3 SAME70N20 Real Time Timer (RTT)
WDT_IRQn | 4 SAME70N20 Watchdog Timer (WDT)
PMC_IRQn | 5 SAME70N20 Power Management Controller (PMC)
EFC_IRQn | 6 SAME70N20 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAME70N20 UART 0 (UART0)
UART1_IRQn | 8 SAME70N20 UART 1 (UART1)
PIOA_IRQn | 10 SAME70N20 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAME70N20 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAME70N20 USART 0 (USART0)
USART1_IRQn | 14 SAME70N20 USART 1 (USART1)
USART2_IRQn | 15 SAME70N20 USART 2 (USART2)
PIOD_IRQn | 16 SAME70N20 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAME70N20 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAME70N20 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAME70N20 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAME70N20 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAME70N20 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAME70N20 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAME70N20 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAME70N20 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAME70N20 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAME70N20 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAME70N20 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAME70N20 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAME70N20 Analog Comparator (ACC)
USBHS_IRQn | 34 SAME70N20 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAME70N20 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAME70N20 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAME70N20 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAME70N20 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAME70N20 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAME70N20 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAME70N20 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAME70N20 UART 2 (UART2)
UART3_IRQn | 45 SAME70N20 UART 3 (UART3)
UART4_IRQn | 46 SAME70N20 UART 4 (UART4)
TC9_IRQn | 50 SAME70N20 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAME70N20 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAME70N20 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAME70N20 AES (AES)
TRNG_IRQn | 57 SAME70N20 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAME70N20 DMA (XDMAC)
ISI_IRQn | 59 SAME70N20 Camera Interface (ISI)
PWM1_IRQn | 60 SAME70N20 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAME70N20 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAME70N21 Supply Controller (SUPC)
RSTC_IRQn | 1 SAME70N21 Reset Controller (RSTC)
RTC_IRQn | 2 SAME70N21 Real Time Clock (RTC)
RTT_IRQn | 3 SAME70N21 Real Time Timer (RTT)
WDT_IRQn | 4 SAME70N21 Watchdog Timer (WDT)
PMC_IRQn | 5 SAME70N21 Power Management Controller (PMC)
EFC_IRQn | 6 SAME70N21 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAME70N21 UART 0 (UART0)
UART1_IRQn | 8 SAME70N21 UART 1 (UART1)
PIOA_IRQn | 10 SAME70N21 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAME70N21 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAME70N21 USART 0 (USART0)
USART1_IRQn | 14 SAME70N21 USART 1 (USART1)
USART2_IRQn | 15 SAME70N21 USART 2 (USART2)
PIOD_IRQn | 16 SAME70N21 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAME70N21 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAME70N21 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAME70N21 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAME70N21 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAME70N21 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAME70N21 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAME70N21 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAME70N21 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAME70N21 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAME70N21 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAME70N21 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAME70N21 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAME70N21 Analog Comparator (ACC)
USBHS_IRQn | 34 SAME70N21 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAME70N21 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAME70N21 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAME70N21 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAME70N21 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAME70N21 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAME70N21 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAME70N21 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAME70N21 UART 2 (UART2)
UART3_IRQn | 45 SAME70N21 UART 3 (UART3)
UART4_IRQn | 46 SAME70N21 UART 4 (UART4)
TC9_IRQn | 50 SAME70N21 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAME70N21 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAME70N21 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAME70N21 AES (AES)
TRNG_IRQn | 57 SAME70N21 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAME70N21 DMA (XDMAC)
ISI_IRQn | 59 SAME70N21 Camera Interface (ISI)
PWM1_IRQn | 60 SAME70N21 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAME70N21 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAME70Q19 Supply Controller (SUPC)
RSTC_IRQn | 1 SAME70Q19 Reset Controller (RSTC)
RTC_IRQn | 2 SAME70Q19 Real Time Clock (RTC)
RTT_IRQn | 3 SAME70Q19 Real Time Timer (RTT)
WDT_IRQn | 4 SAME70Q19 Watchdog Timer (WDT)
PMC_IRQn | 5 SAME70Q19 Power Management Controller (PMC)
EFC_IRQn | 6 SAME70Q19 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAME70Q19 UART 0 (UART0)
UART1_IRQn | 8 SAME70Q19 UART 1 (UART1)
PIOA_IRQn | 10 SAME70Q19 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAME70Q19 Parallel I/O Controller B (PIOB)
PIOC_IRQn | 12 SAME70Q19 Parallel I/O Controller C (PIOC)
USART0_IRQn | 13 SAME70Q19 USART 0 (USART0)
USART1_IRQn | 14 SAME70Q19 USART 1 (USART1)
USART2_IRQn | 15 SAME70Q19 USART 2 (USART2)
PIOD_IRQn | 16 SAME70Q19 Parallel I/O Controller D (PIOD)
PIOE_IRQn | 17 SAME70Q19 Parallel I/O Controller E (PIOE)
HSMCI_IRQn | 18 SAME70Q19 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAME70Q19 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAME70Q19 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAME70Q19 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAME70Q19 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAME70Q19 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAME70Q19 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAME70Q19 Timer/Counter 2 (TC2)
TC3_IRQn | 26 SAME70Q19 Timer/Counter 3 (TC3)
TC4_IRQn | 27 SAME70Q19 Timer/Counter 4 (TC4)
TC5_IRQn | 28 SAME70Q19 Timer/Counter 5 (TC5)
AFEC0_IRQn | 29 SAME70Q19 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAME70Q19 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAME70Q19 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAME70Q19 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAME70Q19 Analog Comparator (ACC)
USBHS_IRQn | 34 SAME70Q19 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAME70Q19 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAME70Q19 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAME70Q19 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAME70Q19 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAME70Q19 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAME70Q19 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAME70Q19 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAME70Q19 UART 2 (UART2)
UART3_IRQn | 45 SAME70Q19 UART 3 (UART3)
UART4_IRQn | 46 SAME70Q19 UART 4 (UART4)
TC6_IRQn | 47 SAME70Q19 Timer/Counter 6 (TC6)
TC7_IRQn | 48 SAME70Q19 Timer/Counter 7 (TC7)
TC8_IRQn | 49 SAME70Q19 Timer/Counter 8 (TC8)
TC9_IRQn | 50 SAME70Q19 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAME70Q19 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAME70Q19 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAME70Q19 AES (AES)
TRNG_IRQn | 57 SAME70Q19 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAME70Q19 DMA (XDMAC)
ISI_IRQn | 59 SAME70Q19 Camera Interface (ISI)
PWM1_IRQn | 60 SAME70Q19 Pulse Width Modulation 1 (PWM1)
SDRAMC_IRQn | 62 SAME70Q19 SDRAM Controller (SDRAMC)
RSWDT_IRQn | 63 SAME70Q19 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAME70Q20 Supply Controller (SUPC)
RSTC_IRQn | 1 SAME70Q20 Reset Controller (RSTC)
RTC_IRQn | 2 SAME70Q20 Real Time Clock (RTC)
RTT_IRQn | 3 SAME70Q20 Real Time Timer (RTT)
WDT_IRQn | 4 SAME70Q20 Watchdog Timer (WDT)
PMC_IRQn | 5 SAME70Q20 Power Management Controller (PMC)
EFC_IRQn | 6 SAME70Q20 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAME70Q20 UART 0 (UART0)
UART1_IRQn | 8 SAME70Q20 UART 1 (UART1)
PIOA_IRQn | 10 SAME70Q20 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAME70Q20 Parallel I/O Controller B (PIOB)
PIOC_IRQn | 12 SAME70Q20 Parallel I/O Controller C (PIOC)
USART0_IRQn | 13 SAME70Q20 USART 0 (USART0)
USART1_IRQn | 14 SAME70Q20 USART 1 (USART1)
USART2_IRQn | 15 SAME70Q20 USART 2 (USART2)
PIOD_IRQn | 16 SAME70Q20 Parallel I/O Controller D (PIOD)
PIOE_IRQn | 17 SAME70Q20 Parallel I/O Controller E (PIOE)
HSMCI_IRQn | 18 SAME70Q20 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAME70Q20 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAME70Q20 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAME70Q20 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAME70Q20 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAME70Q20 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAME70Q20 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAME70Q20 Timer/Counter 2 (TC2)
TC3_IRQn | 26 SAME70Q20 Timer/Counter 3 (TC3)
TC4_IRQn | 27 SAME70Q20 Timer/Counter 4 (TC4)
TC5_IRQn | 28 SAME70Q20 Timer/Counter 5 (TC5)
AFEC0_IRQn | 29 SAME70Q20 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAME70Q20 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAME70Q20 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAME70Q20 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAME70Q20 Analog Comparator (ACC)
USBHS_IRQn | 34 SAME70Q20 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAME70Q20 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAME70Q20 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAME70Q20 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAME70Q20 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAME70Q20 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAME70Q20 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAME70Q20 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAME70Q20 UART 2 (UART2)
UART3_IRQn | 45 SAME70Q20 UART 3 (UART3)
UART4_IRQn | 46 SAME70Q20 UART 4 (UART4)
TC6_IRQn | 47 SAME70Q20 Timer/Counter 6 (TC6)
TC7_IRQn | 48 SAME70Q20 Timer/Counter 7 (TC7)
TC8_IRQn | 49 SAME70Q20 Timer/Counter 8 (TC8)
TC9_IRQn | 50 SAME70Q20 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAME70Q20 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAME70Q20 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAME70Q20 AES (AES)
TRNG_IRQn | 57 SAME70Q20 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAME70Q20 DMA (XDMAC)
ISI_IRQn | 59 SAME70Q20 Camera Interface (ISI)
PWM1_IRQn | 60 SAME70Q20 Pulse Width Modulation 1 (PWM1)
SDRAMC_IRQn | 62 SAME70Q20 SDRAM Controller (SDRAMC)
RSWDT_IRQn | 63 SAME70Q20 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAME70Q21 Supply Controller (SUPC)
RSTC_IRQn | 1 SAME70Q21 Reset Controller (RSTC)
RTC_IRQn | 2 SAME70Q21 Real Time Clock (RTC)
RTT_IRQn | 3 SAME70Q21 Real Time Timer (RTT)
WDT_IRQn | 4 SAME70Q21 Watchdog Timer (WDT)
PMC_IRQn | 5 SAME70Q21 Power Management Controller (PMC)
EFC_IRQn | 6 SAME70Q21 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAME70Q21 UART 0 (UART0)
UART1_IRQn | 8 SAME70Q21 UART 1 (UART1)
PIOA_IRQn | 10 SAME70Q21 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAME70Q21 Parallel I/O Controller B (PIOB)
PIOC_IRQn | 12 SAME70Q21 Parallel I/O Controller C (PIOC)
USART0_IRQn | 13 SAME70Q21 USART 0 (USART0)
USART1_IRQn | 14 SAME70Q21 USART 1 (USART1)
USART2_IRQn | 15 SAME70Q21 USART 2 (USART2)
PIOD_IRQn | 16 SAME70Q21 Parallel I/O Controller D (PIOD)
PIOE_IRQn | 17 SAME70Q21 Parallel I/O Controller E (PIOE)
HSMCI_IRQn | 18 SAME70Q21 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAME70Q21 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAME70Q21 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAME70Q21 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAME70Q21 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAME70Q21 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAME70Q21 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAME70Q21 Timer/Counter 2 (TC2)
TC3_IRQn | 26 SAME70Q21 Timer/Counter 3 (TC3)
TC4_IRQn | 27 SAME70Q21 Timer/Counter 4 (TC4)
TC5_IRQn | 28 SAME70Q21 Timer/Counter 5 (TC5)
AFEC0_IRQn | 29 SAME70Q21 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAME70Q21 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAME70Q21 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAME70Q21 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAME70Q21 Analog Comparator (ACC)
USBHS_IRQn | 34 SAME70Q21 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAME70Q21 MCAN Controller 0 (MCAN0)
MCAN0_LINE1_IRQn | 36 SAME70Q21 MCAN Controller 0 LINE1 (MCAN0)
MCAN1_IRQn | 37 SAME70Q21 MCAN Controller 1 (MCAN1)
MCAN1_LINE1_IRQn | 38 SAME70Q21 MCAN Controller 1 LINE1 (MCAN1)
GMAC_IRQn | 39 SAME70Q21 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAME70Q21 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAME70Q21 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAME70Q21 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAME70Q21 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAME70Q21 UART 2 (UART2)
UART3_IRQn | 45 SAME70Q21 UART 3 (UART3)
UART4_IRQn | 46 SAME70Q21 UART 4 (UART4)
TC6_IRQn | 47 SAME70Q21 Timer/Counter 6 (TC6)
TC7_IRQn | 48 SAME70Q21 Timer/Counter 7 (TC7)
TC8_IRQn | 49 SAME70Q21 Timer/Counter 8 (TC8)
TC9_IRQn | 50 SAME70Q21 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAME70Q21 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAME70Q21 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAME70Q21 AES (AES)
TRNG_IRQn | 57 SAME70Q21 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAME70Q21 DMA (XDMAC)
ISI_IRQn | 59 SAME70Q21 Camera Interface (ISI)
PWM1_IRQn | 60 SAME70Q21 Pulse Width Modulation 1 (PWM1)
SDRAMC_IRQn | 62 SAME70Q21 SDRAM Controller (SDRAMC)
RSWDT_IRQn | 63 SAME70Q21 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMS70J19 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMS70J19 Reset Controller (RSTC)
RTC_IRQn | 2 SAMS70J19 Real Time Clock (RTC)
RTT_IRQn | 3 SAMS70J19 Real Time Timer (RTT)
WDT_IRQn | 4 SAMS70J19 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMS70J19 Power Management Controller (PMC)
EFC_IRQn | 6 SAMS70J19 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMS70J19 UART 0 (UART0)
UART1_IRQn | 8 SAMS70J19 UART 1 (UART1)
PIOA_IRQn | 10 SAMS70J19 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMS70J19 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMS70J19 USART 0 (USART0)
USART1_IRQn | 14 SAMS70J19 USART 1 (USART1)
USART2_IRQn | 15 SAMS70J19 USART 2 (USART2)
PIOD_IRQn | 16 SAMS70J19 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMS70J19 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMS70J19 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMS70J19 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMS70J19 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMS70J19 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMS70J19 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMS70J19 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMS70J19 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMS70J19 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMS70J20 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMS70J19 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMS70J19 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMS70J19 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMS70J19 USB Host / Device Controller (USBHS)
AFEC1_IRQn | 40 SAMS70J19 Analog Front End 1 (AFEC1)
SPI1_IRQn | 42 SAMS70J19 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMS70J19 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMS70J19 UART 2 (UART2)
UART3_IRQn | 45 SAMS70J19 UART 3 (UART3)
UART4_IRQn | 46 SAMS70J19 UART 4 (UART4)
TC9_IRQn | 50 SAMS70J19 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMS70J19 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMS70J19 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAMS70J19 AES (AES)
TRNG_IRQn | 57 SAMS70J19 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMS70J19 DMA (XDMAC)
ISI_IRQn | 59 SAMS70J19 Camera Interface (ISI)
PWM1_IRQn | 60 SAMS70J19 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMS70J19 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMS70J20 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMS70J20 Reset Controller (RSTC)
RTC_IRQn | 2 SAMS70J20 Real Time Clock (RTC)
RTT_IRQn | 3 SAMS70J20 Real Time Timer (RTT)
WDT_IRQn | 4 SAMS70J20 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMS70J20 Power Management Controller (PMC)
EFC_IRQn | 6 SAMS70J20 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMS70J20 UART 0 (UART0)
UART1_IRQn | 8 SAMS70J20 UART 1 (UART1)
PIOA_IRQn | 10 SAMS70J20 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMS70J20 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMS70J20 USART 0 (USART0)
USART1_IRQn | 14 SAMS70J20 USART 1 (USART1)
USART2_IRQn | 15 SAMS70J20 USART 2 (USART2)
PIOD_IRQn | 16 SAMS70J20 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMS70J20 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMS70J20 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMS70J20 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMS70J20 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMS70J20 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMS70J20 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMS70J20 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMS70J20 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMS70J20 Analog Front End 0 (AFEC0)
PWM0_IRQn | 31 SAMS70J20 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMS70J20 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMS70J20 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMS70J20 USB Host / Device Controller (USBHS)
AFEC1_IRQn | 40 SAMS70J20 Analog Front End 1 (AFEC1)
SPI1_IRQn | 42 SAMS70J20 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMS70J20 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMS70J20 UART 2 (UART2)
UART3_IRQn | 45 SAMS70J20 UART 3 (UART3)
UART4_IRQn | 46 SAMS70J20 UART 4 (UART4)
TC9_IRQn | 50 SAMS70J20 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMS70J20 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMS70J20 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAMS70J20 AES (AES)
TRNG_IRQn | 57 SAMS70J20 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMS70J20 DMA (XDMAC)
ISI_IRQn | 59 SAMS70J20 Camera Interface (ISI)
PWM1_IRQn | 60 SAMS70J20 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMS70J20 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMS70J21 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMS70J21 Reset Controller (RSTC)
RTC_IRQn | 2 SAMS70J21 Real Time Clock (RTC)
RTT_IRQn | 3 SAMS70J21 Real Time Timer (RTT)
WDT_IRQn | 4 SAMS70J21 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMS70J21 Power Management Controller (PMC)
EFC_IRQn | 6 SAMS70J21 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMS70J21 UART 0 (UART0)
UART1_IRQn | 8 SAMS70J21 UART 1 (UART1)
PIOA_IRQn | 10 SAMS70J21 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMS70J21 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMS70J21 USART 0 (USART0)
USART1_IRQn | 14 SAMS70J21 USART 1 (USART1)
USART2_IRQn | 15 SAMS70J21 USART 2 (USART2)
PIOD_IRQn | 16 SAMS70J21 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMS70J21 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMS70J21 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMS70J21 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMS70J21 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMS70J21 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMS70J21 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMS70J21 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMS70J21 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMS70J21 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMS70J21 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMS70J21 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMS70J21 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMS70J21 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMS70J21 USB Host / Device Controller (USBHS)
AFEC1_IRQn | 40 SAMS70J21 Analog Front End 1 (AFEC1)
SPI1_IRQn | 42 SAMS70J21 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMS70J21 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMS70J21 UART 2 (UART2)
UART3_IRQn | 45 SAMS70J21 UART 3 (UART3)
UART4_IRQn | 46 SAMS70J21 UART 4 (UART4)
TC9_IRQn | 50 SAMS70J21 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMS70J21 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMS70J21 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAMS70J21 AES (AES)
TRNG_IRQn | 57 SAMS70J21 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMS70J21 DMA (XDMAC)
ISI_IRQn | 59 SAMS70J21 Camera Interface (ISI)
PWM1_IRQn | 60 SAMS70J21 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMS70J21 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMS70N19 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMS70N19 Reset Controller (RSTC)
RTC_IRQn | 2 SAMS70N19 Real Time Clock (RTC)
RTT_IRQn | 3 SAMS70N19 Real Time Timer (RTT)
WDT_IRQn | 4 SAMS70N19 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMS70N19 Power Management Controller (PMC)
EFC_IRQn | 6 SAMS70N19 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMS70N19 UART 0 (UART0)
UART1_IRQn | 8 SAMS70N19 UART 1 (UART1)
PIOA_IRQn | 10 SAMS70N19 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMS70N19 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMS70N19 USART 0 (USART0)
USART1_IRQn | 14 SAMS70N19 USART 1 (USART1)
USART2_IRQn | 15 SAMS70N19 USART 2 (USART2)
PIOD_IRQn | 16 SAMS70N19 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMS70N19 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMS70N19 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMS70N19 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMS70N19 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMS70N19 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMS70N19 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMS70N19 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMS70N19 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMS70N19 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMS70N19 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMS70N19 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMS70N19 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMS70N19 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMS70N19 USB Host / Device Controller (USBHS)
AFEC1_IRQn | 40 SAMS70N19 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMS70N19 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMS70N19 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMS70N19 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMS70N19 UART 2 (UART2)
UART3_IRQn | 45 SAMS70N19 UART 3 (UART3)
UART4_IRQn | 46 SAMS70N19 UART 4 (UART4)
TC9_IRQn | 50 SAMS70N19 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMS70N19 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMS70N19 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAMS70N19 AES (AES)
TRNG_IRQn | 57 SAMS70N19 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMS70N19 DMA (XDMAC)
ISI_IRQn | 59 SAMS70N19 Camera Interface (ISI)
PWM1_IRQn | 60 SAMS70N19 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMS70N19 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMS70N20 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMS70N20 Reset Controller (RSTC)
RTC_IRQn | 2 SAMS70N20 Real Time Clock (RTC)
RTT_IRQn | 3 SAMS70N20 Real Time Timer (RTT)
WDT_IRQn | 4 SAMS70N20 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMS70N20 Power Management Controller (PMC)
EFC_IRQn | 6 SAMS70N20 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMS70N20 UART 0 (UART0)
UART1_IRQn | 8 SAMS70N20 UART 1 (UART1)
PIOA_IRQn | 10 SAMS70N20 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMS70N20 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMS70N20 USART 0 (USART0)
USART1_IRQn | 14 SAMS70N20 USART 1 (USART1)
USART2_IRQn | 15 SAMS70N20 USART 2 (USART2)
PIOD_IRQn | 16 SAMS70N20 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMS70N20 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMS70N20 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMS70N20 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMS70N20 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMS70N20 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMS70N20 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMS70N20 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMS70N20 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMS70N20 Analog Front End 0 (AFEC0)
PWM0_IRQn | 31 SAMS70N20 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMS70N20 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMS70N20 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMS70N20 USB Host / Device Controller (USBHS)
AFEC1_IRQn | 40 SAMS70N20 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMS70N20 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMS70N20 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMS70N20 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMS70N20 UART 2 (UART2)
UART3_IRQn | 45 SAMS70N20 UART 3 (UART3)
UART4_IRQn | 46 SAMS70N20 UART 4 (UART4)
TC9_IRQn | 50 SAMS70N20 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMS70N20 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMS70N20 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAMS70N20 AES (AES)
TRNG_IRQn | 57 SAMS70N20 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMS70N20 DMA (XDMAC)
ISI_IRQn | 59 SAMS70N20 Camera Interface (ISI)
PWM1_IRQn | 60 SAMS70N20 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMS70N20 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMS70N21 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMS70N21 Reset Controller (RSTC)
RTC_IRQn | 2 SAMS70N21 Real Time Clock (RTC)
RTT_IRQn | 3 SAMS70N21 Real Time Timer (RTT)
WDT_IRQn | 4 SAMS70N21 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMS70N21 Power Management Controller (PMC)
EFC_IRQn | 6 SAMS70N21 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMS70N21 UART 0 (UART0)
UART1_IRQn | 8 SAMS70N21 UART 1 (UART1)
PIOA_IRQn | 10 SAMS70N21 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMS70N21 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMS70N21 USART 0 (USART0)
USART1_IRQn | 14 SAMS70N21 USART 1 (USART1)
USART2_IRQn | 15 SAMS70N21 USART 2 (USART2)
PIOD_IRQn | 16 SAMS70N21 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMS70N21 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMS70N21 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMS70N21 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMS70N21 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMS70N21 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMS70N21 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMS70N21 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMS70N21 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMS70N21 Analog Front End 0 (AFEC0)
PWM0_IRQn | 31 SAMS70N21 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMS70N21 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMS70N21 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMS70N21 USB Host / Device Controller (USBHS)
AFEC1_IRQn | 40 SAMS70N21 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMS70N21 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMS70N21 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMS70N21 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMS70N21 UART 2 (UART2)
UART3_IRQn | 45 SAMS70N21 UART 3 (UART3)
UART4_IRQn | 46 SAMS70N21 UART 4 (UART4)
TC9_IRQn | 50 SAMS70N21 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMS70N21 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMS70N21 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAMS70N21 AES (AES)
TRNG_IRQn | 57 SAMS70N21 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMS70N21 DMA (XDMAC)
ISI_IRQn | 59 SAMS70N21 Camera Interface (ISI)
PWM1_IRQn | 60 SAMS70N21 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMS70N21 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMS70Q19 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMS70Q19 Reset Controller (RSTC)
RTC_IRQn | 2 SAMS70Q19 Real Time Clock (RTC)
RTT_IRQn | 3 SAMS70Q19 Real Time Timer (RTT)
WDT_IRQn | 4 SAMS70Q19 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMS70Q19 Power Management Controller (PMC)
EFC_IRQn | 6 SAMS70Q19 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMS70Q19 UART 0 (UART0)
UART1_IRQn | 8 SAMS70Q19 UART 1 (UART1)
PIOA_IRQn | 10 SAMS70Q19 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMS70Q19 Parallel I/O Controller B (PIOB)
PIOC_IRQn | 12 SAMS70Q19 Parallel I/O Controller C (PIOC)
USART0_IRQn | 13 SAMS70Q19 USART 0 (USART0)
USART1_IRQn | 14 SAMS70Q19 USART 1 (USART1)
USART2_IRQn | 15 SAMS70Q19 USART 2 (USART2)
PIOD_IRQn | 16 SAMS70Q19 Parallel I/O Controller D (PIOD)
PIOE_IRQn | 17 SAMS70Q19 Parallel I/O Controller E (PIOE)
HSMCI_IRQn | 18 SAMS70Q19 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMS70Q19 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMS70Q19 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMS70Q19 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMS70Q19 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMS70Q19 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMS70Q19 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMS70Q19 Timer/Counter 2 (TC2)
TC3_IRQn | 26 SAMS70Q19 Timer/Counter 3 (TC3)
TC4_IRQn | 27 SAMS70Q19 Timer/Counter 4 (TC4)
TC5_IRQn | 28 SAMS70Q19 Timer/Counter 5 (TC5)
AFEC0_IRQn | 29 SAMS70Q19 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMS70Q19 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMS70Q19 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMS70Q19 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMS70Q19 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMS70Q19 USB Host / Device Controller (USBHS)
AFEC1_IRQn | 40 SAMS70Q19 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMS70Q19 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMS70Q19 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMS70Q19 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMS70Q19 UART 2 (UART2)
UART3_IRQn | 45 SAMS70Q19 UART 3 (UART3)
UART4_IRQn | 46 SAMS70Q19 UART 4 (UART4)
TC6_IRQn | 47 SAMS70Q19 Timer/Counter 6 (TC6)
TC7_IRQn | 48 SAMS70Q19 Timer/Counter 7 (TC7)
TC8_IRQn | 49 SAMS70Q19 Timer/Counter 8 (TC8)
TC9_IRQn | 50 SAMS70Q19 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMS70Q19 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMS70Q19 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAMS70Q19 AES (AES)
TRNG_IRQn | 57 SAMS70Q19 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMS70Q19 DMA (XDMAC)
ISI_IRQn | 59 SAMS70Q19 Camera Interface (ISI)
PWM1_IRQn | 60 SAMS70Q19 Pulse Width Modulation 1 (PWM1)
SDRAMC_IRQn | 62 SAMS70Q19 SDRAM Controller (SDRAMC)
RSWDT_IRQn | 63 SAMS70Q19 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMS70Q20 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMS70Q20 Reset Controller (RSTC)
RTC_IRQn | 2 SAMS70Q20 Real Time Clock (RTC)
RTT_IRQn | 3 SAMS70Q20 Real Time Timer (RTT)
WDT_IRQn | 4 SAMS70Q20 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMS70Q20 Power Management Controller (PMC)
EFC_IRQn | 6 SAMS70Q20 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMS70Q20 UART 0 (UART0)
UART1_IRQn | 8 SAMS70Q20 UART 1 (UART1)
PIOA_IRQn | 10 SAMS70Q20 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMS70Q20 Parallel I/O Controller B (PIOB)
PIOC_IRQn | 12 SAMS70Q20 Parallel I/O Controller C (PIOC)
USART0_IRQn | 13 SAMS70Q20 USART 0 (USART0)
USART1_IRQn | 14 SAMS70Q20 USART 1 (USART1)
USART2_IRQn | 15 SAMS70Q20 USART 2 (USART2)
PIOD_IRQn | 16 SAMS70Q20 Parallel I/O Controller D (PIOD)
PIOE_IRQn | 17 SAMS70Q20 Parallel I/O Controller E (PIOE)
HSMCI_IRQn | 18 SAMS70Q20 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMS70Q20 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMS70Q20 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMS70Q20 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMS70Q20 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMS70Q20 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMS70Q20 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMS70Q20 Timer/Counter 2 (TC2)
TC3_IRQn | 26 SAMS70Q20 Timer/Counter 3 (TC3)
TC4_IRQn | 27 SAMS70Q20 Timer/Counter 4 (TC4)
TC5_IRQn | 28 SAMS70Q20 Timer/Counter 5 (TC5)
AFEC0_IRQn | 29 SAMS70Q20 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMS70Q20 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMS70Q20 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMS70Q20 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMS70Q20 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMS70Q20 USB Host / Device Controller (USBHS)
AFEC1_IRQn | 40 SAMS70Q20 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMS70Q20 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMS70Q20 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMS70Q20 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMS70Q20 UART 2 (UART2)
UART3_IRQn | 45 SAMS70Q20 UART 3 (UART3)
UART4_IRQn | 46 SAMS70Q20 UART 4 (UART4)
TC6_IRQn | 47 SAMS70Q20 Timer/Counter 6 (TC6)
TC7_IRQn | 48 SAMS70Q20 Timer/Counter 7 (TC7)
TC8_IRQn | 49 SAMS70Q20 Timer/Counter 8 (TC8)
TC9_IRQn | 50 SAMS70Q20 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMS70Q20 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMS70Q20 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAMS70Q20 AES (AES)
TRNG_IRQn | 57 SAMS70Q20 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMS70Q20 DMA (XDMAC)
ISI_IRQn | 59 SAMS70Q20 Camera Interface (ISI)
PWM1_IRQn | 60 SAMS70Q20 Pulse Width Modulation 1 (PWM1)
SDRAMC_IRQn | 62 SAMS70Q20 SDRAM Controller (SDRAMC)
RSWDT_IRQn | 63 SAMS70Q20 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMS70Q21 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMS70Q21 Reset Controller (RSTC)
RTC_IRQn | 2 SAMS70Q21 Real Time Clock (RTC)
RTT_IRQn | 3 SAMS70Q21 Real Time Timer (RTT)
WDT_IRQn | 4 SAMS70Q21 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMS70Q21 Power Management Controller (PMC)
EFC_IRQn | 6 SAMS70Q21 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMS70Q21 UART 0 (UART0)
UART1_IRQn | 8 SAMS70Q21 UART 1 (UART1)
PIOA_IRQn | 10 SAMS70Q21 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMS70Q21 Parallel I/O Controller B (PIOB)
PIOC_IRQn | 12 SAMS70Q21 Parallel I/O Controller C (PIOC)
USART0_IRQn | 13 SAMS70Q21 USART 0 (USART0)
USART1_IRQn | 14 SAMS70Q21 USART 1 (USART1)
USART2_IRQn | 15 SAMS70Q21 USART 2 (USART2)
PIOD_IRQn | 16 SAMS70Q21 Parallel I/O Controller D (PIOD)
PIOE_IRQn | 17 SAMS70Q21 Parallel I/O Controller E (PIOE)
HSMCI_IRQn | 18 SAMS70Q21 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMS70Q21 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMS70Q21 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMS70Q21 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMS70Q21 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMS70Q21 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMS70Q21 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMS70Q21 Timer/Counter 2 (TC2)
TC3_IRQn | 26 SAMS70Q21 Timer/Counter 3 (TC3)
TC4_IRQn | 27 SAMS70Q21 Timer/Counter 4 (TC4)
TC5_IRQn | 28 SAMS70Q21 Timer/Counter 5 (TC5)
AFEC0_IRQn | 29 SAMS70Q21 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMS70Q21 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMS70Q21 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMS70Q21 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMS70Q21 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMS70Q21 USB Host / Device Controller (USBHS)
AFEC1_IRQn | 40 SAMS70Q21 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMS70Q21 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMS70Q21 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMS70Q21 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMS70Q21 UART 2 (UART2)
UART3_IRQn | 45 SAMS70Q21 UART 3 (UART3)
UART4_IRQn | 46 SAMS70Q21 UART 4 (UART4)
TC6_IRQn | 47 SAMS70Q21 Timer/Counter 6 (TC6)
TC7_IRQn | 48 SAMS70Q21 Timer/Counter 7 (TC7)
TC8_IRQn | 49 SAMS70Q21 Timer/Counter 8 (TC8)
TC9_IRQn | 50 SAMS70Q21 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMS70Q21 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMS70Q21 Timer/Counter 11 (TC11)
AES_IRQn | 56 SAMS70Q21 AES (AES)
TRNG_IRQn | 57 SAMS70Q21 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMS70Q21 DMA (XDMAC)
ISI_IRQn | 59 SAMS70Q21 Camera Interface (ISI)
PWM1_IRQn | 60 SAMS70Q21 Pulse Width Modulation 1 (PWM1)
SDRAMC_IRQn | 62 SAMS70Q21 SDRAM Controller (SDRAMC)
RSWDT_IRQn | 63 SAMS70Q21 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMV71J19 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMV71J19 Reset Controller (RSTC)
RTC_IRQn | 2 SAMV71J19 Real Time Clock (RTC)
RTT_IRQn | 3 SAMV71J19 Real Time Timer (RTT)
WDT_IRQn | 4 SAMV71J19 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMV71J19 Power Management Controller (PMC)
EFC_IRQn | 6 SAMV71J19 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMV71J19 UART 0 (UART0)
UART1_IRQn | 8 SAMV71J19 UART 1 (UART1)
PIOA_IRQn | 10 SAMV71J19 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMV71J19 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMV71J19 USART 0 (USART0)
USART1_IRQn | 14 SAMV71J19 USART 1 (USART1)
USART2_IRQn | 15 SAMV71J19 USART 2 (USART2)
PIOD_IRQn | 16 SAMV71J19 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMV71J19 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMV71J19 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMV71J19 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMV71J19 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMV71J19 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMV71J19 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMV71J19 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMV71J19 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMV71J19 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMV71N19 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMV71J19 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMV71J19 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMV71J19 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMV71J19 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAMV71J19 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAMV71J19 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAMV71J19 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAMV71J19 Analog Front End 1 (AFEC1)
SPI1_IRQn | 42 SAMV71J19 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMV71J19 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMV71J19 UART 2 (UART2)
UART3_IRQn | 45 SAMV71J19 UART 3 (UART3)
UART4_IRQn | 46 SAMV71J19 UART 4 (UART4)
TC9_IRQn | 50 SAMV71J19 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMV71J19 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMV71J19 Timer/Counter 11 (TC11)
MLB_IRQn | 53 SAMV71J19 MediaLB (MLB)
AES_IRQn | 56 SAMV71J19 AES (AES)
TRNG_IRQn | 57 SAMV71J19 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMV71J19 DMA (XDMAC)
ISI_IRQn | 59 SAMV71J19 Camera Interface (ISI)
PWM1_IRQn | 60 SAMV71J19 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMV71J19 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMV71J20 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMV71J20 Reset Controller (RSTC)
RTC_IRQn | 2 SAMV71J20 Real Time Clock (RTC)
RTT_IRQn | 3 SAMV71J20 Real Time Timer (RTT)
WDT_IRQn | 4 SAMV71J20 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMV71J20 Power Management Controller (PMC)
EFC_IRQn | 6 SAMV71J20 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMV71J20 UART 0 (UART0)
UART1_IRQn | 8 SAMV71J20 UART 1 (UART1)
PIOA_IRQn | 10 SAMV71J20 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMV71J20 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMV71J20 USART 0 (USART0)
USART1_IRQn | 14 SAMV71J20 USART 1 (USART1)
USART2_IRQn | 15 SAMV71J20 USART 2 (USART2)
PIOD_IRQn | 16 SAMV71J20 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMV71J20 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMV71J20 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMV71J20 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMV71J20 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMV71J20 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMV71J20 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMV71J20 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMV71J20 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMV71J20 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMV71J20 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMV71J20 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMV71J20 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMV71J20 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMV71J20 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAMV71J20 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAMV71J20 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAMV71J20 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAMV71J20 Analog Front End 1 (AFEC1)
SPI1_IRQn | 42 SAMV71J20 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMV71J20 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMV71J20 UART 2 (UART2)
UART3_IRQn | 45 SAMV71J20 UART 3 (UART3)
UART4_IRQn | 46 SAMV71J20 UART 4 (UART4)
TC9_IRQn | 50 SAMV71J20 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMV71J20 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMV71J20 Timer/Counter 11 (TC11)
MLB_IRQn | 53 SAMV71J20 MediaLB (MLB)
AES_IRQn | 56 SAMV71J20 AES (AES)
TRNG_IRQn | 57 SAMV71J20 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMV71J20 DMA (XDMAC)
ISI_IRQn | 59 SAMV71J20 Camera Interface (ISI)
PWM1_IRQn | 60 SAMV71J20 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMV71J20 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMV71J21 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMV71J21 Reset Controller (RSTC)
RTC_IRQn | 2 SAMV71J21 Real Time Clock (RTC)
RTT_IRQn | 3 SAMV71J21 Real Time Timer (RTT)
WDT_IRQn | 4 SAMV71J21 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMV71J21 Power Management Controller (PMC)
EFC_IRQn | 6 SAMV71J21 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMV71J21 UART 0 (UART0)
UART1_IRQn | 8 SAMV71J21 UART 1 (UART1)
PIOA_IRQn | 10 SAMV71J21 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMV71J21 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMV71J21 USART 0 (USART0)
USART1_IRQn | 14 SAMV71J21 USART 1 (USART1)
USART2_IRQn | 15 SAMV71J21 USART 2 (USART2)
PIOD_IRQn | 16 SAMV71J21 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMV71J21 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMV71J21 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMV71J21 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMV71J21 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMV71J21 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMV71J21 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMV71J21 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMV71J21 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMV71J21 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMV71J21 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMV71J21 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMV71J21 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMV71J21 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMV71J21 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAMV71J21 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAMV71J21 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAMV71J21 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAMV71J21 Analog Front End 1 (AFEC1)
SPI1_IRQn | 42 SAMV71J21 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMV71J21 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMV71J21 UART 2 (UART2)
UART3_IRQn | 45 SAMV71J21 UART 3 (UART3)
UART4_IRQn | 46 SAMV71J21 UART 4 (UART4)
TC9_IRQn | 50 SAMV71J21 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMV71J21 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMV71J21 Timer/Counter 11 (TC11)
MLB_IRQn | 53 SAMV71J21 MediaLB (MLB)
AES_IRQn | 56 SAMV71J21 AES (AES)
TRNG_IRQn | 57 SAMV71J21 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMV71J21 DMA (XDMAC)
ISI_IRQn | 59 SAMV71J21 Camera Interface (ISI)
PWM1_IRQn | 60 SAMV71J21 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMV71J21 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMV71N19 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMV71N19 Reset Controller (RSTC)
RTC_IRQn | 2 SAMV71N19 Real Time Clock (RTC)
RTT_IRQn | 3 SAMV71N19 Real Time Timer (RTT)
WDT_IRQn | 4 SAMV71N19 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMV71N19 Power Management Controller (PMC)
EFC_IRQn | 6 SAMV71N19 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMV71N19 UART 0 (UART0)
UART1_IRQn | 8 SAMV71N19 UART 1 (UART1)
PIOA_IRQn | 10 SAMV71N19 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMV71N19 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMV71N19 USART 0 (USART0)
USART1_IRQn | 14 SAMV71N19 USART 1 (USART1)
USART2_IRQn | 15 SAMV71N19 USART 2 (USART2)
PIOD_IRQn | 16 SAMV71N19 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMV71N19 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMV71N19 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMV71N19 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMV71N19 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMV71N19 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMV71N19 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMV71N19 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMV71N19 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMV71N19 Analog Front End 0 (AFEC0)
PWM0_IRQn | 31 SAMV71N19 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMV71N19 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMV71N19 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMV71N19 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAMV71N19 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAMV71N19 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAMV71N19 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAMV71N19 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMV71N19 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMV71N19 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMV71N19 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMV71N19 UART 2 (UART2)
UART3_IRQn | 45 SAMV71N19 UART 3 (UART3)
UART4_IRQn | 46 SAMV71N19 UART 4 (UART4)
TC9_IRQn | 50 SAMV71N19 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMV71N19 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMV71N19 Timer/Counter 11 (TC11)
MLB_IRQn | 53 SAMV71N19 MediaLB (MLB)
AES_IRQn | 56 SAMV71N19 AES (AES)
TRNG_IRQn | 57 SAMV71N19 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMV71N19 DMA (XDMAC)
ISI_IRQn | 59 SAMV71N19 Camera Interface (ISI)
PWM1_IRQn | 60 SAMV71N19 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMV71N19 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMV71N20 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMV71N20 Reset Controller (RSTC)
RTC_IRQn | 2 SAMV71N20 Real Time Clock (RTC)
RTT_IRQn | 3 SAMV71N20 Real Time Timer (RTT)
WDT_IRQn | 4 SAMV71N20 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMV71N20 Power Management Controller (PMC)
EFC_IRQn | 6 SAMV71N20 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMV71N20 UART 0 (UART0)
UART1_IRQn | 8 SAMV71N20 UART 1 (UART1)
PIOA_IRQn | 10 SAMV71N20 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMV71N20 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMV71N20 USART 0 (USART0)
USART1_IRQn | 14 SAMV71N20 USART 1 (USART1)
USART2_IRQn | 15 SAMV71N20 USART 2 (USART2)
PIOD_IRQn | 16 SAMV71N20 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMV71N20 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMV71N20 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMV71N20 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMV71N20 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMV71N20 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMV71N20 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMV71N20 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMV71N20 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMV71N20 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMV71Q21 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMV71N20 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMV71N20 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMV71N20 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMV71N20 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAMV71N20 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAMV71N20 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAMV71N20 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAMV71N20 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMV71N20 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMV71N20 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMV71N20 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMV71N20 UART 2 (UART2)
UART3_IRQn | 45 SAMV71N20 UART 3 (UART3)
UART4_IRQn | 46 SAMV71N20 UART 4 (UART4)
TC9_IRQn | 50 SAMV71N20 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMV71N20 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMV71N20 Timer/Counter 11 (TC11)
MLB_IRQn | 53 SAMV71N20 MediaLB (MLB)
AES_IRQn | 56 SAMV71N20 AES (AES)
TRNG_IRQn | 57 SAMV71N20 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMV71N20 DMA (XDMAC)
ISI_IRQn | 59 SAMV71N20 Camera Interface (ISI)
PWM1_IRQn | 60 SAMV71N20 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMV71N20 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMV71N21 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMV71N21 Reset Controller (RSTC)
RTC_IRQn | 2 SAMV71N21 Real Time Clock (RTC)
RTT_IRQn | 3 SAMV71N21 Real Time Timer (RTT)
WDT_IRQn | 4 SAMV71N21 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMV71N21 Power Management Controller (PMC)
EFC_IRQn | 6 SAMV71N21 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMV71N21 UART 0 (UART0)
UART1_IRQn | 8 SAMV71N21 UART 1 (UART1)
PIOA_IRQn | 10 SAMV71N21 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMV71N21 Parallel I/O Controller B (PIOB)
USART0_IRQn | 13 SAMV71N21 USART 0 (USART0)
USART1_IRQn | 14 SAMV71N21 USART 1 (USART1)
USART2_IRQn | 15 SAMV71N21 USART 2 (USART2)
PIOD_IRQn | 16 SAMV71N21 Parallel I/O Controller D (PIOD)
HSMCI_IRQn | 18 SAMV71N21 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMV71N21 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMV71N21 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMV71N21 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMV71N21 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMV71N21 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMV71N21 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMV71N21 Timer/Counter 2 (TC2)
AFEC0_IRQn | 29 SAMV71N21 Analog Front End 0 (AFEC0)
PWM0_IRQn | 31 SAMV71N21 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMV71N21 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMV71N21 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMV71N21 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAMV71N21 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAMV71N21 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAMV71N21 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAMV71N21 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMV71N21 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMV71N21 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMV71N21 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMV71N21 UART 2 (UART2)
UART3_IRQn | 45 SAMV71N21 UART 3 (UART3)
UART4_IRQn | 46 SAMV71N21 UART 4 (UART4)
TC9_IRQn | 50 SAMV71N21 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMV71N21 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMV71N21 Timer/Counter 11 (TC11)
MLB_IRQn | 53 SAMV71N21 MediaLB (MLB)
AES_IRQn | 56 SAMV71N21 AES (AES)
TRNG_IRQn | 57 SAMV71N21 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMV71N21 DMA (XDMAC)
ISI_IRQn | 59 SAMV71N21 Camera Interface (ISI)
PWM1_IRQn | 60 SAMV71N21 Pulse Width Modulation 1 (PWM1)
RSWDT_IRQn | 63 SAMV71N21 Reinforced Secure Watchdog Timer (RSWDT)
NonMaskableInt_IRQn | 2 Non Maskable Interrupt
HardFault_IRQn | 3 HardFault Interrupt
MemoryManagement_IRQn | 4 Cortex-M7 Memory Management Interrupt
BusFault_IRQn | 5 Cortex-M7 Bus Fault Interrupt
UsageFault_IRQn | 6 Cortex-M7 Usage Fault Interrupt
SVCall_IRQn | 11 Cortex-M7 SV Call Interrupt
DebugMonitor_IRQn | 12 Cortex-M7 Debug Monitor Interrupt
PendSV_IRQn | 14 Cortex-M7 Pend SV Interrupt
SysTick_IRQn | 15 Cortex-M7 System Tick Interrupt
SUPC_IRQn | 0 SAMV71Q19 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMV71Q19 Reset Controller (RSTC)
RTC_IRQn | 2 SAMV71Q19 Real Time Clock (RTC)
RTT_IRQn | 3 SAMV71Q19 Real Time Timer (RTT)
WDT_IRQn | 4 SAMV71Q19 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMV71Q19 Power Management Controller (PMC)
EFC_IRQn | 6 SAMV71Q19 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMV71Q19 UART 0 (UART0)
UART1_IRQn | 8 SAMV71Q19 UART 1 (UART1)
PIOA_IRQn | 10 SAMV71Q19 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMV71Q19 Parallel I/O Controller B (PIOB)
PIOC_IRQn | 12 SAMV71Q19 Parallel I/O Controller C (PIOC)
USART0_IRQn | 13 SAMV71Q19 USART 0 (USART0)
USART1_IRQn | 14 SAMV71Q19 USART 1 (USART1)
USART2_IRQn | 15 SAMV71Q19 USART 2 (USART2)
PIOD_IRQn | 16 SAMV71Q19 Parallel I/O Controller D (PIOD)
PIOE_IRQn | 17 SAMV71Q19 Parallel I/O Controller E (PIOE)
HSMCI_IRQn | 18 SAMV71Q19 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMV71Q19 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMV71Q19 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMV71Q19 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMV71Q19 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMV71Q19 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMV71Q19 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMV71Q19 Timer/Counter 2 (TC2)
TC3_IRQn | 26 SAMV71Q19 Timer/Counter 3 (TC3)
TC4_IRQn | 27 SAMV71Q19 Timer/Counter 4 (TC4)
TC5_IRQn | 28 SAMV71Q19 Timer/Counter 5 (TC5)
AFEC0_IRQn | 29 SAMV71Q19 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMV71Q19 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMV71Q19 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMV71Q19 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMV71Q19 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMV71Q19 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAMV71Q19 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAMV71Q19 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAMV71Q19 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAMV71Q19 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMV71Q19 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMV71Q19 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMV71Q19 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMV71Q19 UART 2 (UART2)
UART3_IRQn | 45 SAMV71Q19 UART 3 (UART3)
UART4_IRQn | 46 SAMV71Q19 UART 4 (UART4)
TC6_IRQn | 47 SAMV71Q19 Timer/Counter 6 (TC6)
TC7_IRQn | 48 SAMV71Q19 Timer/Counter 7 (TC7)
TC8_IRQn | 49 SAMV71Q19 Timer/Counter 8 (TC8)
TC9_IRQn | 50 SAMV71Q19 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMV71Q19 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMV71Q19 Timer/Counter 11 (TC11)
MLB_IRQn | 53 SAMV71Q19 MediaLB (MLB)
AES_IRQn | 56 SAMV71Q19 AES (AES)
TRNG_IRQn | 57 SAMV71Q19 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMV71Q19 DMA (XDMAC)
ISI_IRQn | 59 SAMV71Q19 Camera Interface (ISI)
PWM1_IRQn | 60 SAMV71Q19 Pulse Width Modulation 1 (PWM1)
SDRAMC_IRQn | 62 SAMV71Q19 SDRAM Controller (SDRAMC)
RSWDT_IRQn | 63 SAMV71Q19 Reinforced Secure Watchdog Timer (RSWDT)
PERIPH_COUNT_IRQn | Number of peripheral IDs
SUPC_IRQn | 0 SAMV71Q20 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMV71Q20 Reset Controller (RSTC)
RTC_IRQn | 2 SAMV71Q20 Real Time Clock (RTC)
RTT_IRQn | 3 SAMV71Q20 Real Time Timer (RTT)
WDT_IRQn | 4 SAMV71Q20 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMV71Q20 Power Management Controller (PMC)
EFC_IRQn | 6 SAMV71Q20 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMV71Q20 UART 0 (UART0)
UART1_IRQn | 8 SAMV71Q20 UART 1 (UART1)
PIOA_IRQn | 10 SAMV71Q20 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMV71Q20 Parallel I/O Controller B (PIOB)
PIOC_IRQn | 12 SAMV71Q20 Parallel I/O Controller C (PIOC)
USART0_IRQn | 13 SAMV71Q20 USART 0 (USART0)
USART1_IRQn | 14 SAMV71Q20 USART 1 (USART1)
USART2_IRQn | 15 SAMV71Q20 USART 2 (USART2)
PIOD_IRQn | 16 SAMV71Q20 Parallel I/O Controller D (PIOD)
PIOE_IRQn | 17 SAMV71Q20 Parallel I/O Controller E (PIOE)
HSMCI_IRQn | 18 SAMV71Q20 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMV71Q20 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMV71Q20 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMV71Q20 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMV71Q20 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMV71Q20 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMV71Q20 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMV71Q20 Timer/Counter 2 (TC2)
TC3_IRQn | 26 SAMV71Q20 Timer/Counter 3 (TC3)
TC4_IRQn | 27 SAMV71Q20 Timer/Counter 4 (TC4)
TC5_IRQn | 28 SAMV71Q20 Timer/Counter 5 (TC5)
AFEC0_IRQn | 29 SAMV71Q20 Analog Front End 0 (AFEC0)
DACC_IRQn | 30 SAMV71Q20 Digital To Analog Converter (DACC)
PWM0_IRQn | 31 SAMV71Q20 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMV71Q20 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMV71Q20 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMV71Q20 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAMV71Q20 MCAN Controller 0 (MCAN0)
MCAN1_IRQn | 37 SAMV71Q20 MCAN Controller 1 (MCAN1)
GMAC_IRQn | 39 SAMV71Q20 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAMV71Q20 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMV71Q20 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMV71Q20 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMV71Q20 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMV71Q20 UART 2 (UART2)
UART3_IRQn | 45 SAMV71Q20 UART 3 (UART3)
UART4_IRQn | 46 SAMV71Q20 UART 4 (UART4)
TC6_IRQn | 47 SAMV71Q20 Timer/Counter 6 (TC6)
TC7_IRQn | 48 SAMV71Q20 Timer/Counter 7 (TC7)
TC8_IRQn | 49 SAMV71Q20 Timer/Counter 8 (TC8)
TC9_IRQn | 50 SAMV71Q20 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMV71Q20 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMV71Q20 Timer/Counter 11 (TC11)
MLB_IRQn | 53 SAMV71Q20 MediaLB (MLB)
AES_IRQn | 56 SAMV71Q20 AES (AES)
TRNG_IRQn | 57 SAMV71Q20 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMV71Q20 DMA (XDMAC)
ISI_IRQn | 59 SAMV71Q20 Camera Interface (ISI)
PWM1_IRQn | 60 SAMV71Q20 Pulse Width Modulation 1 (PWM1)
SDRAMC_IRQn | 62 SAMV71Q20 SDRAM Controller (SDRAMC)
RSWDT_IRQn | 63 SAMV71Q20 Reinforced Secure Watchdog Timer (RSWDT)
SUPC_IRQn | 0 SAMV71Q21 Supply Controller (SUPC)
RSTC_IRQn | 1 SAMV71Q21 Reset Controller (RSTC)
RTC_IRQn | 2 SAMV71Q21 Real Time Clock (RTC)
RTT_IRQn | 3 SAMV71Q21 Real Time Timer (RTT)
WDT_IRQn | 4 SAMV71Q21 Watchdog Timer (WDT)
PMC_IRQn | 5 SAMV71Q21 Power Management Controller (PMC)
EFC_IRQn | 6 SAMV71Q21 Enhanced Embedded Flash Controller (EFC)
UART0_IRQn | 7 SAMV71Q21 UART 0 (UART0)
UART1_IRQn | 8 SAMV71Q21 UART 1 (UART1)
PIOA_IRQn | 10 SAMV71Q21 Parallel I/O Controller A (PIOA)
PIOB_IRQn | 11 SAMV71Q21 Parallel I/O Controller B (PIOB)
PIOC_IRQn | 12 SAMV71Q21 Parallel I/O Controller C (PIOC)
USART0_IRQn | 13 SAMV71Q21 USART 0 (USART0)
USART1_IRQn | 14 SAMV71Q21 USART 1 (USART1)
USART2_IRQn | 15 SAMV71Q21 USART 2 (USART2)
PIOD_IRQn | 16 SAMV71Q21 Parallel I/O Controller D (PIOD)
PIOE_IRQn | 17 SAMV71Q21 Parallel I/O Controller E (PIOE)
HSMCI_IRQn | 18 SAMV71Q21 Multimedia Card Interface (HSMCI)
TWIHS0_IRQn | 19 SAMV71Q21 Two Wire Interface 0 HS (TWIHS0)
TWIHS1_IRQn | 20 SAMV71Q21 Two Wire Interface 1 HS (TWIHS1)
SPI0_IRQn | 21 SAMV71Q21 Serial Peripheral Interface 0 (SPI0)
SSC_IRQn | 22 SAMV71Q21 Synchronous Serial Controller (SSC)
TC0_IRQn | 23 SAMV71Q21 Timer/Counter 0 (TC0)
TC1_IRQn | 24 SAMV71Q21 Timer/Counter 1 (TC1)
TC2_IRQn | 25 SAMV71Q21 Timer/Counter 2 (TC2)
TC3_IRQn | 26 SAMV71Q21 Timer/Counter 3 (TC3)
TC4_IRQn | 27 SAMV71Q21 Timer/Counter 4 (TC4)
TC5_IRQn | 28 SAMV71Q21 Timer/Counter 5 (TC5)
AFEC0_IRQn | 29 SAMV71Q21 Analog Front End 0 (AFEC0)
PWM0_IRQn | 31 SAMV71Q21 Pulse Width Modulation 0 (PWM0)
ICM_IRQn | 32 SAMV71Q21 Integrity Check Monitor (ICM)
ACC_IRQn | 33 SAMV71Q21 Analog Comparator (ACC)
USBHS_IRQn | 34 SAMV71Q21 USB Host / Device Controller (USBHS)
MCAN0_IRQn | 35 SAMV71Q21 MCAN Controller 0 (MCAN0)
MCAN0_LINE1_IRQn | 36 SAMV71Q21 MCAN Controller 0 LINE1 (MCAN0)
MCAN1_IRQn | 37 SAMV71Q21 MCAN Controller 1 (MCAN1)
MCAN1_LINE1_IRQn | 38 SAMV71Q21 MCAN Controller 1 LINE1 (MCAN1)
GMAC_IRQn | 39 SAMV71Q21 Ethernet MAC (GMAC)
AFEC1_IRQn | 40 SAMV71Q21 Analog Front End 1 (AFEC1)
TWIHS2_IRQn | 41 SAMV71Q21 Two Wire Interface 2 HS (TWIHS2)
SPI1_IRQn | 42 SAMV71Q21 Serial Peripheral Interface 1 (SPI1)
QSPI_IRQn | 43 SAMV71Q21 Quad I/O Serial Peripheral Interface (QSPI)
UART2_IRQn | 44 SAMV71Q21 UART 2 (UART2)
UART3_IRQn | 45 SAMV71Q21 UART 3 (UART3)
UART4_IRQn | 46 SAMV71Q21 UART 4 (UART4)
TC6_IRQn | 47 SAMV71Q21 Timer/Counter 6 (TC6)
TC7_IRQn | 48 SAMV71Q21 Timer/Counter 7 (TC7)
TC8_IRQn | 49 SAMV71Q21 Timer/Counter 8 (TC8)
TC9_IRQn | 50 SAMV71Q21 Timer/Counter 9 (TC9)
TC10_IRQn | 51 SAMV71Q21 Timer/Counter 10 (TC10)
TC11_IRQn | 52 SAMV71Q21 Timer/Counter 11 (TC11)
MLB_IRQn | 53 SAMV71Q21 MediaLB (MLB)
AES_IRQn | 56 SAMV71Q21 AES (AES)
TRNG_IRQn | 57 SAMV71Q21 True Random Generator (TRNG)
XDMAC_IRQn | 58 SAMV71Q21 DMA (XDMAC)
ISI_IRQn | 59 SAMV71Q21 Camera Interface (ISI)
PWM1_IRQn | 60 SAMV71Q21 Pulse Width Modulation 1 (PWM1)
SDRAMC_IRQn | 62 SAMV71Q21 SDRAM Controller (SDRAMC)
RSWDT_IRQn | 63 SAMV71Q21 Reinforced Secure Watchdog Timer (RSWDT)
NotAvail_IRQn | Not available device specific interrupt
NonMaskableInt_IRQn | Non Maskable Interrupt
HardFault_IRQn | Cortex-M7 SV Hard Fault Interrupt
MemoryManagement_IRQn | Cortex-M7 Memory Management Interrupt
BusFault_IRQn | Cortex-M7 Bus Fault Interrupt
UsageFault_IRQn | Cortex-M7 Usage Fault Interrupt
SVCall_IRQn | Cortex-M7 SV Call Interrupt
DebugMonitor_IRQn | Cortex-M7 Debug Monitor Interrupt
PendSV_IRQn | Cortex-M7 Pend SV Interrupt
SysTick_IRQn | Cortex-M7 System Tick Interrupt
DMA0_DMA16_IRQn | DMA channel 0/16 transfer complete
DMA1_DMA17_IRQn | DMA channel 1/17 transfer complete
DMA2_DMA18_IRQn | DMA channel 2/18 transfer complete
DMA3_DMA19_IRQn | DMA channel 3/19 transfer complete
DMA4_DMA20_IRQn | DMA channel 4/20 transfer complete
DMA5_DMA21_IRQn | DMA channel 5/21 transfer complete
DMA6_DMA22_IRQn | DMA channel 6/22 transfer complete
DMA7_DMA23_IRQn | DMA channel 7/23 transfer complete
DMA8_DMA24_IRQn | DMA channel 8/24 transfer complete
DMA9_DMA25_IRQn | DMA channel 9/25 transfer complete
DMA10_DMA26_IRQn | DMA channel 10/26 transfer complete
DMA11_DMA27_IRQn | DMA channel 11/27 transfer complete
DMA12_DMA28_IRQn | DMA channel 12/28 transfer complete
DMA13_DMA29_IRQn | DMA channel 13/29 transfer complete
DMA14_DMA30_IRQn | DMA channel 14/30 transfer complete
DMA15_DMA31_IRQn | DMA channel 15/31 transfer complete
DMA_ERROR_IRQn | DMA error interrupt channels 0-15 / 16-31
CTI0_ERROR_IRQn | CTI0_Error
CTI1_ERROR_IRQn | CTI1_Error
CORE_IRQn | CorePlatform exception IRQ
LPUART1_IRQn | LPUART1 TX interrupt and RX interrupt
LPUART2_IRQn | LPUART2 TX interrupt and RX interrupt
LPUART3_IRQn | LPUART3 TX interrupt and RX interrupt
LPUART4_IRQn | LPUART4 TX interrupt and RX interrupt
LPUART5_IRQn | LPUART5 TX interrupt and RX interrupt
LPUART6_IRQn | LPUART6 TX interrupt and RX interrupt
LPUART7_IRQn | LPUART7 TX interrupt and RX interrupt
LPUART8_IRQn | LPUART8 TX interrupt and RX interrupt
LPI2C1_IRQn | LPI2C1 interrupt
LPI2C2_IRQn | LPI2C2 interrupt
LPI2C3_IRQn | LPI2C3 interrupt
LPI2C4_IRQn | LPI2C4 interrupt
LPSPI1_IRQn | LPSPI1 single interrupt vector for all sources
LPSPI2_IRQn | LPSPI2 single interrupt vector for all sources
LPSPI3_IRQn | LPSPI3 single interrupt vector for all sources
LPSPI4_IRQn | LPSPI4 single interrupt vector for all sources
CAN1_IRQn | CAN1 interrupt
CAN2_IRQn | CAN2 interrupt
FLEXRAM_IRQn | FlexRAM address out of range Or access hit IRQ
KPP_IRQn | Keypad nterrupt
TSC_DIG_IRQn | TSC interrupt
GPR_IRQ_IRQn | GPR interrupt
LCDIF_IRQn | LCDIF interrupt
CSI_IRQn | CSI interrupt
PXP_IRQn | PXP interrupt
WDOG2_IRQn | WDOG2 interrupt
SNVS_HP_WRAPPER_IRQn | SRTC Consolidated Interrupt. Non TZ
SNVS_HP_WRAPPER_TZ_IRQn | SRTC Security Interrupt. TZ
SNVS_LP_WRAPPER_IRQn | ON-OFF button press shorter than 5 secs (pulse event)
CSU_IRQn | CSU interrupt
DCP_IRQn | DCP_IRQ interrupt
DCP_VMI_IRQn | DCP_VMI_IRQ interrupt
Reserved68_IRQn | Reserved interrupt
TRNG_IRQn | TRNG interrupt
SJC_IRQn | SJC interrupt
BEE_IRQn | BEE interrupt
SAI1_IRQn | SAI1 interrupt
SAI2_IRQn | SAI1 interrupt
SAI3_RX_IRQn | SAI3 interrupt
SAI3_TX_IRQn | SAI3 interrupt
SPDIF_IRQn | SPDIF interrupt
PMU_EVENT_IRQn | Brown-out event interrupt
Reserved78_IRQn | Reserved interrupt
TEMP_LOW_HIGH_IRQn | TempSensor low/high interrupt
TEMP_PANIC_IRQn | TempSensor panic interrupt
USB_PHY1_IRQn | USBPHY (UTMI0), Interrupt
USB_PHY2_IRQn | USBPHY (UTMI0), Interrupt
ADC1_IRQn | ADC1 interrupt
ADC2_IRQn | ADC2 interrupt
DCDC_IRQn | DCDC interrupt
Reserved86_IRQn | Reserved interrupt
Reserved87_IRQn | Reserved interrupt
GPIO1_INT0_IRQn | Active HIGH Interrupt from INT0 from GPIO
GPIO1_INT1_IRQn | Active HIGH Interrupt from INT1 from GPIO
GPIO1_INT2_IRQn | Active HIGH Interrupt from INT2 from GPIO
GPIO1_INT3_IRQn | Active HIGH Interrupt from INT3 from GPIO
GPIO1_INT4_IRQn | Active HIGH Interrupt from INT4 from GPIO
GPIO1_INT5_IRQn | Active HIGH Interrupt from INT5 from GPIO
GPIO1_INT6_IRQn | Active HIGH Interrupt from INT6 from GPIO
GPIO1_INT7_IRQn | Active HIGH Interrupt from INT7 from GPIO
GPIO1_Combined_0_15_IRQn | Combined interrupt indication for GPIO1 signal 0 throughout 15
GPIO1_Combined_16_31_IRQn | Combined interrupt indication for GPIO1 signal 16 throughout 31
GPIO2_Combined_0_15_IRQn | Combined interrupt indication for GPIO2 signal 0 throughout 15
GPIO2_Combined_16_31_IRQn | Combined interrupt indication for GPIO2 signal 16 throughout 31
GPIO3_Combined_0_15_IRQn | Combined interrupt indication for GPIO3 signal 0 throughout 15
GPIO3_Combined_16_31_IRQn | Combined interrupt indication for GPIO3 signal 16 throughout 31
GPIO4_Combined_0_15_IRQn | Combined interrupt indication for GPIO4 signal 0 throughout 15
GPIO4_Combined_16_31_IRQn | Combined interrupt indication for GPIO4 signal 16 throughout 31
GPIO5_Combined_0_15_IRQn | Combined interrupt indication for GPIO5 signal 0 throughout 15
GPIO5_Combined_16_31_IRQn | Combined interrupt indication for GPIO5 signal 16 throughout 31
FLEXIO1_IRQn | FLEXIO1 interrupt
FLEXIO2_IRQn | FLEXIO2 interrupt
WDOG1_IRQn | WDOG1 interrupt
RTWDOG_IRQn | RTWDOG interrupt
EWM_IRQn | EWM interrupt
CCM_1_IRQn | CCM IRQ1 interrupt
CCM_2_IRQn | CCM IRQ2 interrupt
GPC_IRQn | GPC interrupt
SRC_IRQn | SRC interrupt
Reserved115_IRQn | Reserved interrupt
GPT1_IRQn | GPT1 interrupt
GPT2_IRQn | GPT2 interrupt
PWM1_0_IRQn | PWM1 capture 0, compare 0, or reload 0 interrupt
PWM1_1_IRQn | PWM1 capture 1, compare 1, or reload 0 interrupt
PWM1_2_IRQn | PWM1 capture 2, compare 2, or reload 0 interrupt
PWM1_3_IRQn | PWM1 capture 3, compare 3, or reload 0 interrupt
PWM1_FAULT_IRQn | PWM1 fault or reload error interrupt
Reserved123_IRQn | Reserved interrupt
FLEXSPI_IRQn | FlexSPI0 interrupt
SEMC_IRQn | SEMC interrupt
USDHC1_IRQn | USDHC1 interrupt
USDHC2_IRQn | USDHC2 interrupt
USB_OTG2_IRQn | USBO2 USB OTG2
USB_OTG1_IRQn | USBO2 USB OTG1
ENET_IRQn | ENET interrupt
ENET_1588_Timer_IRQn | ENET_1588_Timer interrupt
XBAR1_IRQ_0_1_IRQn | XBARA1 output signal 0, 1 interrupt
XBAR1_IRQ_2_3_IRQn | XBARA1 output signal 2, 3 interrupt
ADC_ETC_IRQ0_IRQn | ADCETC IRQ0 interrupt
ADC_ETC_IRQ1_IRQn | ADCETC IRQ1 interrupt
ADC_ETC_IRQ2_IRQn | ADCETC IRQ2 interrupt
ADC_ETC_ERROR_IRQ_IRQn | ADCETC Error IRQ interrupt
PIT_IRQn | PIT interrupt
ACMP1_IRQn | ACMP interrupt
ACMP2_IRQn | ACMP interrupt
ACMP3_IRQn | ACMP interrupt
ACMP4_IRQn | ACMP interrupt
Reserved143_IRQn | Reserved interrupt
Reserved144_IRQn | Reserved interrupt
ENC1_IRQn | ENC1 interrupt
ENC2_IRQn | ENC2 interrupt
ENC3_IRQn | ENC3 interrupt
ENC4_IRQn | ENC4 interrupt
TMR1_IRQn | TMR1 interrupt
TMR2_IRQn | TMR2 interrupt
TMR3_IRQn | TMR3 interrupt
TMR4_IRQn | TMR4 interrupt
PWM2_0_IRQn | PWM2 capture 0, compare 0, or reload 0 interrupt
PWM2_1_IRQn | PWM2 capture 1, compare 1, or reload 0 interrupt
PWM2_2_IRQn | PWM2 capture 2, compare 2, or reload 0 interrupt
PWM2_3_IRQn | PWM2 capture 3, compare 3, or reload 0 interrupt
PWM2_FAULT_IRQn | PWM2 fault or reload error interrupt
PWM3_0_IRQn | PWM3 capture 0, compare 0, or reload 0 interrupt
PWM3_1_IRQn | PWM3 capture 1, compare 1, or reload 0 interrupt
PWM3_2_IRQn | PWM3 capture 2, compare 2, or reload 0 interrupt
PWM3_3_IRQn | PWM3 capture 3, compare 3, or reload 0 interrupt
PWM3_FAULT_IRQn | PWM3 fault or reload error interrupt
PWM4_0_IRQn | PWM4 capture 0, compare 0, or reload 0 interrupt
PWM4_1_IRQn | PWM4 capture 1, compare 1, or reload 0 interrupt
PWM4_2_IRQn | PWM4 capture 2, compare 2, or reload 0 interrupt
PWM4_3_IRQn | PWM4 capture 3, compare 3, or reload 0 interrupt
PWM4_FAULT_IRQn | PWM4 fault or reload error interrupt
HardFault_IRQn | Cortex-M4 SV Hard Fault Interrupt
MemoryManagement_IRQn | Cortex-M4 Memory Management Interrupt
BusFault_IRQn | Cortex-M4 Bus Fault Interrupt
UsageFault_IRQn | Cortex-M4 Usage Fault Interrupt
SVCall_IRQn | Cortex-M4 SV Call Interrupt
DebugMonitor_IRQn | Cortex-M4 Debug Monitor Interrupt
PendSV_IRQn | Cortex-M4 Pend SV Interrupt
SysTick_IRQn | Cortex-M4 System Tick Interrupt
Reserved33_IRQn | Reserved interrupt
Reserved34_IRQn | Reserved interrupt
LPUART9_IRQn | LPUART9 TX interrupt and RX interrupt
LPUART10_IRQn | LPUART10 TX interrupt and RX interrupt
LPUART11_IRQn | LPUART11 TX interrupt and RX interrupt
LPUART12_IRQn | LPUART12 TX interrupt and RX interrupt
LPI2C5_IRQn | LPI2C5 interrupt
LPI2C6_IRQn | LPI2C6 interrupt
LPSPI1_IRQn | LPSPI1 interrupt request line to the core
LPSPI2_IRQn | LPSPI2 interrupt request line to the core
LPSPI3_IRQn | LPSPI3 interrupt request line to the core
LPSPI4_IRQn | LPSPI4 interrupt request line to the core
LPSPI5_IRQn | LPSPI5 interrupt request line to the core
LPSPI6_IRQn | LPSPI6 interrupt request line to the core
CAN1_ERROR_IRQn | CAN1 error interrupt
CAN2_ERROR_IRQn | CAN2 error interrupt
CAN3_IRQn | CAN3 interrupt
CAN3_ERROR_IRQn | CAN3 erro interrupt
Reserved66_IRQn | Reserved interrupt
eLCDIF_IRQn | eLCDIF interrupt
LCDIFv2_IRQn | LCDIFv2 interrupt
MIPI_CSI_IRQn | MIPI_CSI interrupt
MIPI_DSI_IRQn | MIPI_DSI interrupt
GPU2D_IRQn | GPU2D interrupt
GPIO12_Combined_0_15_IRQn | Combined interrupt indication for GPIO12 signal 0 throughout 15
GPIO12_Combined_16_31_IRQn | Combined interrupt indication for GPIO13 signal 16 throughout 31
DAC_IRQn | DAC interrupt
KEY_MANAGER_IRQn | PUF interrupt
SNVS_HP_NON_TZ_IRQn | SRTC Consolidated Interrupt. Non TZ
SNVS_HP_TZ_IRQn | SRTC Security Interrupt. TZ
SNVS_PULSE_EVENT_IRQn | ON-OFF button press shorter than 5 secs (pulse event)
CAAM_IRQ0_IRQn | CAAM interrupt queue for JQ0
CAAM_IRQ1_IRQn | CAAM interrupt queue for JQ1
CAAM_IRQ2_IRQn | CAAM interrupt queue for JQ2
CAAM_IRQ3_IRQn | CAAM interrupt queue for JQ3
CAAM_RECORVE_ERRPR_IRQn | CAAM interrupt for recoverable error
CAAM_RTIC_IRQn | CAAM interrupt for RTIC
CDOG_IRQn | CDOG interrupt
SAI4_RX_IRQn | SAI4 interrupt
SAI4_TX_IRQn | SAI4 interrupt
TMPSNS_INT_IRQn | TMPSNS interrupt
TMPSNS_LOW_HIGH_IRQn | TMPSNS low high interrupt
TMPSNS_PANIC_IRQn | TMPSNS panic interrupt
LPSR_LP8_BROWNOUT_IRQn | LPSR 1p8 brownout interrupt
LPSR_LP0_BROWNOUT_IRQn | LPSR 1p0 brownout interrupt
USBPHY1_IRQn | USBPHY1 interrupt
USBPHY2_IRQn | USBPHY2 interrupt
RDC_IRQn | RDC interrupt
GPIO13_Combined_0_31_IRQn | Combined interrupt indication for GPIO13 signal 0 throughout 31
Reserved110_IRQn | Reserved interrupt
DCIC1_IRQn | DCIC1 interrupt
DCIC2_IRQn | DCIC2 interrupt
ASRC_IRQn | ASRC interrupt
FLEXRAM_ECC_IRQn | FlexRAM ECC fatal interrupt
GPIO7_8_9_10_11_IRQn | GPIO7, GPIO8, GPIO9, GPIO10, GPIO11 interrupt
RTWDOG4_IRQn | RTWDOG4 interrupt
OCOTP_READ_FUSE_ERROR_IRQn | OCOTP read fuse error interrupt
OCOTP_READ_DONE_ERROR_IRQn | OCOTP read fuse done interrupt
MUB_IRQn | MUB interrupt
GPT3_IRQn | GPT3 interrupt
GPT4_IRQn | GPT4 interrupt
GPT5_IRQn | GPT5 interrupt
GPT6_IRQn | GPT6 interrupt
FLEXSPI1_IRQn | FlexSPI1 interrupt
FLEXSPI2_IRQn | FlexSPI2 interrupt
ENET_1G_MAC0_Tx_Rx_1_IRQn | ENET 1G MAC0 transmit/receive 1
ENET_1G_MAC0_Tx_Rx_2_IRQn | ENET 1G MAC0 transmit/receive 2
ENET_1G_IRQn | ENET 1G interrupt
ENET_1G_1588_Timer_IRQn | ENET_1G_1588_Timer interrupt
ADC_ETC_IRQ3_IRQn | ADCETC IRQ3 interrupt
Reserved166_IRQn | Reserved interrupt
Reserved167_IRQn | Reserved interrupt
Reserved168_IRQn | Reserved interrupt
Reserved169_IRQn | Reserved interrupt
Reserved170_IRQn | Reserved interrupt
PIT1_IRQn | PIT1 interrupt
PIT2_IRQn | PIT2 interrupt
Reserved177_IRQn | Reserved interrupt
Reserved178_IRQn | Reserved interrupt
Reserved179_IRQn | Reserved interrupt
Reserved180_IRQn | Reserved interrupt
Reserved185_IRQn | Reserved interrupt
Reserved186_IRQn | Reserved interrupt
SEMA4_CP0_IRQn | SEMA4 CP0 interrupt
SEMA4_CP1_IRQn | SEMA4 CP1 interrupt
Reserved208_IRQn | Reserved interrupt
Reserved209_IRQn | Reserved interrupt
Reserved210_IRQn | Reserved interrupt
Reserved211_IRQn | Reserved interrupt
Reserved212_IRQn | Reserved interrupt
Reserved213_IRQn | Reserved interrupt
Reserved214_IRQn | Reserved interrupt
Reserved215_IRQn | Reserved interrupt
PDM_HWVAD_EVENT_IRQn | HWVAD event interrupt
PDM_HWVAD_ERROR_IRQn | HWVAD error interrupt
PDM_EVENT_IRQn | PDM event interrupt
PDM_ERROR_IRQn | PDM error interrupt
EMVSIM1_IRQn | EMVSIM1 interrupt
EMVSIM2_IRQn | EMVSIM2 interrupt
MECC1_INT_IRQn | MECC1 int
MECC1_FATAL_INT_IRQn | MECC1 fatal int
MECC2_INT_IRQn | MECC2 int
MECC2_FATAL_INT_IRQn | MECC2 fatal int
XECC_FLEXSPI1_INT_IRQn | XECC int
XECC_FLEXSPI1_FATAL_INT_IRQn | XECC fatal int
XECC_FLEXSPI2_INT_IRQn | XECC int
XECC_FLEXSPI2_FATAL_INT_IRQn | XECC fatal int
XECC_SEMC_INT_IRQn | XECC int
XECC_SEMC_FATAL_INT_IRQn | XECC fatal int
Reserved232_IRQn | Reserved interrupt
Reserved233_IRQn | Reserved interrupt
CTI_TRIGGER_OUT0_IRQn | CTI_TRIGGER_OUT0
CTI_TRIGGER_OUT1_IRQn | CTI_TRIGGER_OUT1
GPIO6_Combined_0_15_IRQn | Combined interrupt indication for GPIO6 signal 0 throughout 15
GPIO6_Combined_16_31_IRQn | Combined interrupt indication for GPIO6 signal 16 throughout 31
CM7_GPIO2_3_IRQn | CM7_GPIO2,CM7_GPIO3 interrupt
RTWDOG3_IRQn | RTWDOG3 interrupt
MUA_IRQn | MUA interrupt
