RTEMS 6.1-rc4
Data Structures | Macros | Typedefs | Enumerations | Functions
Generic Flash API to wrap specific device drivers. More...
struct  rtems_flashdev_region
 General definition for on flash device. More...
struct  rtems_flashdev_region_table
 Struct holding region definitions. More...
struct  rtems_flashdev_ioctl_page_info
 Page information returned from IOCTL calls. More...
struct  rtems_flashdev_ioctl_sector_info
 Sector information returned from IOCTL calls. More...
 Flash device. More...
#define RTEMS_FLASHDEV_IOCTL_OBTAIN   0
 Obtains the flash device.
#define RTEMS_FLASHDEV_IOCTL_RELEASE   1
 Releases the flash device.
#define RTEMS_FLASHDEV_IOCTL_JEDEC_ID   2
 Returns the JEDEC ID of the flash device. This IOCTL call is informational only.
#define RTEMS_FLASHDEV_IOCTL_ERASE   3
 Erases flash device.
#define RTEMS_FLASHDEV_IOCTL_REGION_SET   4
 Set a region that limits read, write and erase calls to within it. Regions are file descriptor specific and limited to a single region per file descriptor and 32 regions total per flash device. Regions can be changed or updated by calling this IOCTL again.
#define RTEMS_FLASHDEV_IOCTL_REGION_UNSET   5
 Removes the set region on the file descriptor.
#define RTEMS_FLASHDEV_IOCTL_TYPE   6
 Returns the type of flash device (e.g. NOR or NAND).
#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET   7
 Get the size and address of flash page at given offset.
#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX   8
 Get the size and address of nth flash page where n is index passed in.
#define RTEMS_FLASHDEV_IOCTL_PAGE_COUNT   9
 Get the number of pages in flash device.
#define RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE   10
 Get the minimum write size supported by the driver.
#define RTEMS_FLASHDEV_IOCTL_SECTORINFO_BY_OFFSET   11
 Get the size and address of flash erase sector at given offset.
#define RTEMS_FLASHDEV_IOCTL_SECTOR_COUNT   12
 Get the number of erase sectors in flash device.
#define RTEMS_FLASHDEV_MAX_REGIONS   32
 The maximum number of region limited file descriptors allowed to be open at once.
typedef enum rtems_flashdev_flash_type rtems_flashdev_flash_type
 Enum for flash type returned from IOCTL call.
typedef struct rtems_flashdev_region rtems_flashdev_region
typedef struct rtems_flashdev_region_table rtems_flashdev_region_table
typedef struct rtems_flashdev_ioctl_page_info rtems_flashdev_ioctl_page_info
typedef struct rtems_flashdev_ioctl_sector_info rtems_flashdev_ioctl_sector_info
enum  rtems_flashdev_flash_type { RTEMS_FLASHDEV_NOR , RTEMS_FLASHDEV_NAND }
 Enum for flash type returned from IOCTL call. More...
rtems_flashdevrtems_flashdev_alloc_and_init (size_t size)
 Allocate and initialize the flash device.
int rtems_flashdev_init (rtems_flashdev *flash)
 Initialize the flash device.
int rtems_flashdev_register (rtems_flashdev *flash, const char *flash_path)
 Register the flash device.
void rtems_flashdev_destroy (rtems_flashdev *flash)
 Destroys the flash device.
void rtems_flashdev_destroy_and_free (rtems_flashdev *flash)
 Destroys the flash device and frees its memory.
◆ RTEMS_FLASHDEV_IOCTL_ERASE
Parameters
[in]erase_argsPointer to rtems_flashdev_region struct containing offset and size of erase to be performed.
◆ RTEMS_FLASHDEV_IOCTL_JEDEC_ID
Parameters
[out]jedec_idPointer to uint32_t in which the JEDEC ID is returned in.
◆ RTEMS_FLASHDEV_IOCTL_OBTAIN
This command has no argument.
◆ RTEMS_FLASHDEV_IOCTL_PAGE_COUNT
Parameters
[out]countInteger containing the number of pages.
◆ RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX
The index ignores the region limiting.
Parameters
[in,out]rtems_flashdev_ioctl_page_infoarg Pointer to struct with index and space for return values.
◆ RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET
The offset ignores the region limiting. To find page of region limited offset add the base of the region to the desired offset.
Parameters
[in,out]rtems_flashdev_ioctl_page_infoarg Pointer to struct with offset and space for return values.
◆ RTEMS_FLASHDEV_IOCTL_REGION_SET
Parameters
[in]regionPointer to rtems_flashdev_region struct containing base and length of defined region.
◆ RTEMS_FLASHDEV_IOCTL_REGION_UNSET
◆ RTEMS_FLASHDEV_IOCTL_RELEASE
◆ RTEMS_FLASHDEV_IOCTL_SECTOR_COUNT
Parameters
[out]countInteger containing the number of sectors.
◆ RTEMS_FLASHDEV_IOCTL_SECTORINFO_BY_OFFSET
The offset ignores the region limiting. To find sector of region limited offset add the base of the region to the desired offset.
Parameters
[in,out]rtems_flashdev_ioctl_sector_infoarg Pointer to struct with offset and space for return values.
◆ RTEMS_FLASHDEV_IOCTL_TYPE
Parameters
[out]flash_typePointer to integer which is set to the flash type macro value.
◆ RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE
Parameters
[out]countInteger containing the minimum write size.
◆ rtems_flashdev_flash_type
RTEMS_FLASHDEV_NOR
The flash device is NOR flash.
RTEMS_FLASHDEV_NAND
The flash device is NAND flash.
◆ rtems_flashdev_alloc_and_init()
rtems_flashdev * rtems_flashdev_alloc_and_init ( size_t  size)
After a successful allocation and initialization of the flash device it must be destroyed via rtems_flashdev_destroy_and_free().
Parameters
[in]sizeThe number of bytes to allocate.
Return values
NULLFailed to set up flash device.
non-NULLThe new flash device.
◆ rtems_flashdev_destroy()
void rtems_flashdev_destroy ( rtems_flashdev flash)
Parameters
[in]flashThe flash device.
◆ rtems_flashdev_destroy_and_free()
void rtems_flashdev_destroy_and_free ( rtems_flashdev flash)
Parameters
◆ rtems_flashdev_init()
int rtems_flashdev_init ( rtems_flashdev flash)
After a successful initialization of the flash device it must be destroyed via rtems_flashdev_destory().
After initialization and before registration read, write, erase, jedec_id and flash_type functions need to be set in the flashdev.
Parameters
[in]flashThe flash device to initialize.
Return values
1Failed to set up flash device.
0Successful set up of flash device.
◆ rtems_flashdev_register()
int rtems_flashdev_register ( rtems_flashdev flash,
const char *  flash_path
This function always claims ownership of the flash device.
Parameters
[in]flash_pathThe path to the flash device file.
Return values
0Successful operation.
non-zeroFailed operation.
