RTEMS 6.1-rc4
Files | Data Structures | Typedefs | Functions
FIFO/Pipe File System Support
Interface to the POSIX FIFO/Pipe File System. More...
file  fifo.c
 FIFO/Pipe Support.
file  pipe.c
 Create an Anonymous Pipe.
struct  pipe_control
typedef struct pipe_control pipe_control_t
void pipe_release (pipe_control_t **pipep, rtems_libio_t *iop)
 Release a pipe.
int fifo_open (pipe_control_t **pipep, rtems_libio_t *iop)
 File system open. Interface to file system open.
ssize_t pipe_read (pipe_control_t *pipe, void *buffer, size_t count, rtems_libio_t *iop)
 File system read.
ssize_t pipe_write (pipe_control_t *pipe, const void *buffer, size_t count, rtems_libio_t *iop)
 File system write.
int pipe_ioctl (pipe_control_t *pipe, ioctl_command_t cmd, void *buffer, rtems_libio_t *iop)
 File system Input/Output control.
◆ fifo_open()
int fifo_open ( pipe_control_t **  pipep,
rtems_libio_t iop
*pipep points to pipe control structure. If called with *pipep = NULL, fifo_open will try allocating and initializing a control structure. If the call succeeds, *pipep will be set to address of new control structure.
◆ pipe_ioctl()
int pipe_ioctl ( pipe_control_t pipe,
void *  buffer,
rtems_libio_t iop
Interface to file system ioctl.
◆ pipe_read()
ssize_t pipe_read ( pipe_control_t pipe,
void *  buffer,
size_t  count,
rtems_libio_t iop
File system read.
Interface to file system read.
◆ pipe_release()
void pipe_release ( pipe_control_t **  pipep,
rtems_libio_t iop
Release a pipe.
Interface to file system close.
*pipep points to pipe control structure. When the last user releases pipe, it will be set to NULL.
◆ pipe_write()
ssize_t pipe_write ( pipe_control_t pipe,
const void *  buffer,
size_t  count,
rtems_libio_t iop
File system write.
Interface to file system write.
