RTEMS 6.1-rc4
fsl_anatop_ai.h File Reference
#include "fsl_common.h"
CTRL0 - CTRL0 Register
#define AI_PHY_LDO_CTRL0_LINREG_EN(x)    (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_LINREG_EN_SHIFT)) & AI_PHY_LDO_CTRL0_LINREG_EN_MASK)
#define AI_PHY_LDO_CTRL0_LINREG_EN_MASK   (0x1U)
#define AI_PHY_LDO_CTRL0_LINREG_EN_SHIFT   (0U)
#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS(x)    (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_SHIFT)) & AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_MASK)
#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_MASK   (0x2U)
#define AI_PHY_LDO_CTRL0_PWRUPLOAD_DIS_SHIFT   (1U)
#define AI_PHY_LDO_CTRL0_LIMIT_EN(x)    (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_LIMIT_EN_SHIFT)) & AI_PHY_LDO_CTRL0_LIMIT_EN_MASK)
#define AI_PHY_LDO_CTRL0_LIMIT_EN_MASK   (0x4U)
#define AI_PHY_LDO_CTRL0_LIMIT_EN_SHIFT   (2U)
#define AI_PHY_LDO_CTRL0_OUTPUT_TRG(x)    (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_OUTPUT_TRG_SHIFT)) & AI_PHY_LDO_CTRL0_OUTPUT_TRG_MASK)
#define AI_PHY_LDO_CTRL0_OUTPUT_TRG_MASK   (0x1F0U)
#define AI_PHY_LDO_CTRL0_OUTPUT_TRG_SHIFT   (4U)
#define AI_PHY_LDO_CTRL0_PHY_ISO_B(x)    (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_CTRL0_PHY_ISO_B_SHIFT)) & AI_PHY_LDO_CTRL0_PHY_ISO_B_MASK)
#define AI_PHY_LDO_CTRL0_PHY_ISO_B_MASK   (0x8000U)
#define AI_PHY_LDO_CTRL0_PHY_ISO_B_SHIFT   (15U)
#define AI_BANDGAP_CTRL0_REFTOP_PWD(x)    (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_PWD_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_PWD_MASK)
#define AI_BANDGAP_CTRL0_REFTOP_PWD_MASK   (0x1U)
#define AI_BANDGAP_CTRL0_REFTOP_PWD_SHIFT   (0U)
#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD(x)
#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_MASK   (0x2U)
#define AI_BANDGAP_CTRL0_REFTOP_LINREGREF_PWD_SHIFT   (1U)
#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP(x)    (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK)
#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK   (0x4U)
#define AI_BANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT   (2U)
#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER(x)    (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_MASK)
#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_MASK   (0x8U)
#define AI_BANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT   (3U)
#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF(x)
#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_MASK   (0x10U)
#define AI_BANDGAP_CTRL0_REFTOP_SELFBIASOFF_SHIFT   (4U)
#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ(x)    (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_VBGADJ_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_VBGADJ_MASK)
#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ_MASK   (0xE0U)
#define AI_BANDGAP_CTRL0_REFTOP_VBGADJ_SHIFT   (5U)
#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ(x)    (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_SHIFT)) & AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_MASK)
#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_MASK   (0x1C00U)
#define AI_BANDGAP_CTRL0_REFTOP_IBZTCADJ_SHIFT   (10U)
#define AI_RCOSC400M_CTRL0_REF_CLK_DIV(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL0_REF_CLK_DIV_SHIFT)) & AI_RCOSC400M_CTRL0_REF_CLK_DIV_MASK)
#define AI_RCOSC400M_CTRL0_REF_CLK_DIV_MASK   (0x3F000000U)
#define AI_RCOSC400M_CTRL0_REF_CLK_DIV_SHIFT   (24U)
#define AI_PLL1G_CTRL0_HOLD_RING_OFF(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLL1G_CTRL0_HOLD_RING_OFF_MASK)
#define AI_PLL1G_CTRL0_HOLD_RING_OFF_MASK   (0x2000UL)
#define AI_PLL1G_CTRL0_HOLD_RING_OFF_SHIFT   (13U)
#define AI_PLL1G_CTRL0_POWER_UP(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_POWER_UP_SHIFT)) & AI_PLL1G_CTRL0_POWER_UP_MASK)
#define AI_PLL1G_CTRL0_POWER_UP_MASK   (0x4000UL)
#define AI_PLL1G_CTRL0_POWER_UP_SHIFT   (14U)
#define AI_PLL1G_CTRL0_ENABLE(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_ENABLE_SHIFT)) & AI_PLL1G_CTRL0_ENABLE_MASK)
#define AI_PLL1G_CTRL0_ENABLE_MASK   (0x8000UL)
#define AI_PLL1G_CTRL0_ENABLE_SHIFT   (15U)
#define AI_PLL1G_CTRL0_BYPASS(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_BYPASS_SHIFT)) & AI_PLL1G_CTRL0_BYPASS_MASK)
#define AI_PLL1G_CTRL0_BYPASS_MASK   (0x10000UL)
#define AI_PLL1G_CTRL0_BYPASS_SHIFT   (16U)
#define AI_PLL1G_CTRL0_PLL_REG_EN(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLL1G_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLL1G_CTRL0_PLL_REG_EN_MASK)
#define AI_PLL1G_CTRL0_PLL_REG_EN_MASK   (0x400000UL)
#define AI_PLL1G_CTRL0_PLL_REG_EN_SHIFT   (22U)
#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_MASK)
#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_MASK   (0x2000UL)
#define AI_PLLAUDIO_CTRL0_HOLD_RING_OFF_SHIFT   (13U)
#define AI_PLLAUDIO_CTRL0_POWER_UP(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_POWER_UP_SHIFT)) & AI_PLLAUDIO_CTRL0_POWER_UP_MASK)
#define AI_PLLAUDIO_CTRL0_POWER_UP_MASK   (0x4000UL)
#define AI_PLLAUDIO_CTRL0_POWER_UP_SHIFT   (14U)
#define AI_PLLAUDIO_CTRL0_ENABLE(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_ENABLE_SHIFT)) & AI_PLLAUDIO_CTRL0_ENABLE_MASK)
#define AI_PLLAUDIO_CTRL0_ENABLE_MASK   (0x8000UL)
#define AI_PLLAUDIO_CTRL0_ENABLE_SHIFT   (15U)
#define AI_PLLAUDIO_CTRL0_BYPASS(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_BYPASS_SHIFT)) & AI_PLLAUDIO_CTRL0_BYPASS_MASK)
#define AI_PLLAUDIO_CTRL0_BYPASS_MASK   (0x10000UL)
#define AI_PLLAUDIO_CTRL0_BYPASS_SHIFT   (16U)
#define AI_PLLAUDIO_CTRL0_PLL_REG_EN(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLAUDIO_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLLAUDIO_CTRL0_PLL_REG_EN_MASK)
#define AI_PLLAUDIO_CTRL0_PLL_REG_EN_MASK   (0x400000UL)
#define AI_PLLAUDIO_CTRL0_PLL_REG_EN_SHIFT   (22U)
#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_SHIFT)) & AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_MASK)
#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_MASK   (0x2000UL)
#define AI_PLLVIDEO_CTRL0_HOLD_RING_OFF_SHIFT   (13U)
#define AI_PLLVIDEO_CTRL0_POWER_UP(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_POWER_UP_SHIFT)) & AI_PLLVIDEO_CTRL0_POWER_UP_MASK)
#define AI_PLLVIDEO_CTRL0_POWER_UP_MASK   (0x4000UL)
#define AI_PLLVIDEO_CTRL0_POWER_UP_SHIFT   (14U)
#define AI_PLLVIDEO_CTRL0_ENABLE(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_ENABLE_SHIFT)) & AI_PLLVIDEO_CTRL0_ENABLE_MASK)
#define AI_PLLVIDEO_CTRL0_ENABLE_MASK   (0x8000UL)
#define AI_PLLVIDEO_CTRL0_ENABLE_SHIFT   (15U)
#define AI_PLLVIDEO_CTRL0_BYPASS(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_BYPASS_SHIFT)) & AI_PLLVIDEO_CTRL0_BYPASS_MASK)
#define AI_PLLVIDEO_CTRL0_BYPASS_MASK   (0x10000UL)
#define AI_PLLVIDEO_CTRL0_BYPASS_SHIFT   (16U)
#define AI_PLLVIDEO_CTRL0_PLL_REG_EN(x)    (((uint32_t)(((uint32_t)(x)) << AI_PLLVIDEO_CTRL0_PLL_REG_EN_SHIFT)) & AI_PLLVIDEO_CTRL0_PLL_REG_EN_MASK)
#define AI_PLLVIDEO_CTRL0_PLL_REG_EN_MASK   (0x400000UL)
#define AI_PLLVIDEO_CTRL0_PLL_REG_EN_SHIFT   (22U)
STAT0 - STAT0 Register
#define AI_PHY_LDO_STAT0_LINREG_STAT(x)    (((uint32_t)(((uint32_t)(x)) << AI_PHY_LDO_STAT0_LINREG_STAT_SHIFT)) & AI_PHY_LDO_STAT0_LINREG_STAT_MASK)
#define AI_PHY_LDO_STAT0_LINREG_STAT_MASK   (0xFU)
#define AI_PHY_LDO_STAT0_LINREG_STAT_SHIFT   (0U)
#define AI_BANDGAP_STAT0_REFTOP_VBGUP(x)    (((uint32_t)(((uint32_t)(x)) << AI_BANDGAP_STAT0_REFTOP_VBGUP_SHIFT)) & AI_BANDGAP_STAT0_REFTOP_VBGUP_MASK)
#define AI_BANDGAP_STAT0_REFTOP_VBGUP_MASK   (0x1U)
#define AI_BANDGAP_STAT0_REFTOP_VBGUP_SHIFT   (0U)
#define AI_RCOSC400M_STAT0_CLK1M_ERR(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_STAT0_CLK1M_ERR_SHIFT)) & AI_RCOSC400M_STAT0_CLK1M_ERR_MASK)
#define AI_RCOSC400M_STAT0_CLK1M_ERR_MASK   (0x1U)
#define AI_RCOSC400M_STAT0_CLK1M_ERR_SHIFT   (0U)
CTRL1 - CTRL1 Register
#define AI_RCOSC400M_CTRL1_HYST_MINUS(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL1_HYST_MINUS_SHIFT)) & AI_RCOSC400M_CTRL1_HYST_MINUS_MASK)
#define AI_RCOSC400M_CTRL1_HYST_MINUS_MASK   (0xFU)
#define AI_RCOSC400M_CTRL1_HYST_MINUS_SHIFT   (0U)
#define AI_RCOSC400M_CTRL1_HYST_PLUS(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL1_HYST_PLUS_SHIFT)) & AI_RCOSC400M_CTRL1_HYST_PLUS_MASK)
#define AI_RCOSC400M_CTRL1_HYST_PLUS_MASK   (0xF00U)
#define AI_RCOSC400M_CTRL1_HYST_PLUS_SHIFT   (8U)
#define AI_RCOSC400M_CTRL1_TARGET_COUNT(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL1_TARGET_COUNT_SHIFT)) & AI_RCOSC400M_CTRL1_TARGET_COUNT_MASK)
#define AI_RCOSC400M_CTRL1_TARGET_COUNT_MASK   (0xFFFF0000U)
#define AI_RCOSC400M_CTRL1_TARGET_COUNT_SHIFT   (16U)
CTRL2 - CTRL2 Register
#define AI_RCOSC400M_CTRL2_TUNE_BYP(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_TUNE_BYP_SHIFT)) & AI_RCOSC400M_CTRL2_TUNE_BYP_MASK)
#define AI_RCOSC400M_CTRL2_TUNE_BYP_MASK   (0x400U)
#define AI_RCOSC400M_CTRL2_TUNE_BYP_SHIFT   (10U)
#define AI_RCOSC400M_CTRL2_TUNE_EN(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_TUNE_EN_SHIFT)) & AI_RCOSC400M_CTRL2_TUNE_EN_MASK)
#define AI_RCOSC400M_CTRL2_TUNE_EN_MASK   (0x1000U)
#define AI_RCOSC400M_CTRL2_TUNE_EN_SHIFT   (12U)
#define AI_RCOSC400M_CTRL2_TUNE_START(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_TUNE_START_SHIFT)) & AI_RCOSC400M_CTRL2_TUNE_START_MASK)
#define AI_RCOSC400M_CTRL2_TUNE_START_MASK   (0x4000U)
#define AI_RCOSC400M_CTRL2_TUNE_START_SHIFT   (14U)
#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_SHIFT)) & AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_MASK)
#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_MASK   (0xFF000000U)
#define AI_RCOSC400M_CTRL2_OSC_TUNE_VAL_SHIFT   (24U)
CTRL3 - CTRL3 Register
#define AI_RCOSC400M_CTRL3_CLR_ERR(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_CLR_ERR_SHIFT)) & AI_RCOSC400M_CTRL3_CLR_ERR_MASK)
#define AI_RCOSC400M_CTRL3_CLR_ERR_MASK   (0x1U)
#define AI_RCOSC400M_CTRL3_CLR_ERR_SHIFT   (0U)
#define AI_RCOSC400M_CTRL3_EN_1M_CLK(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_EN_1M_CLK_SHIFT)) & AI_RCOSC400M_CTRL3_EN_1M_CLK_MASK)
#define AI_RCOSC400M_CTRL3_EN_1M_CLK_MASK   (0x100U)
#define AI_RCOSC400M_CTRL3_EN_1M_CLK_SHIFT   (8U)
#define AI_RCOSC400M_CTRL3_MUX_1M_CLK(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_MUX_1M_CLK_SHIFT)) & AI_RCOSC400M_CTRL3_MUX_1M_CLK_MASK)
#define AI_RCOSC400M_CTRL3_MUX_1M_CLK_MASK   (0x400U)
#define AI_RCOSC400M_CTRL3_MUX_1M_CLK_SHIFT   (10U)
#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_CTRL3_COUNT_1M_CLK_SHIFT)) & AI_RCOSC400M_CTRL3_COUNT_1M_CLK_MASK)
#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK_MASK   (0xFFFF0000U)
#define AI_RCOSC400M_CTRL3_COUNT_1M_CLK_SHIFT   (16U)
STAT1 - STAT1 Register
#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL(x)    (((uint32_t)(((uint32_t)(x)) << AI_RCOSC400M_STAT1_CURR_COUNT_VAL_SHIFT)) & AI_RCOSC400M_STAT1_CURR_COUNT_VAL_MASK)
#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL_MASK   (0xFFFF0000U)
#define AI_RCOSC400M_STAT1_CURR_COUNT_VAL_SHIFT   (16U)
STAT2 - STAT2 Register
#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL(x)
#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_MASK   (0xFF000000U)
#define AI_RCOSC400M_STAT2_CURR_OSC_TUNE_VAL_SHIFT   (24U)
uint32_t ANATOP_AI_Access (anatop_ai_itf_t itf, bool isWrite, anatop_ai_reg_t addr, uint32_t wdata)
 AI interface access.
void ANATOP_AI_Write (anatop_ai_itf_t itf, anatop_ai_reg_t addr, uint32_t wdata)
 AI interface writing.
uint32_t ANATOP_AI_Read (anatop_ai_itf_t itf, anatop_ai_reg_t addr)
 AI interface reading.
void ANATOP_AI_WriteWithMaskShift (anatop_ai_itf_t itf, anatop_ai_reg_t addr, uint32_t wdata, uint32_t mask, uint32_t shift)
 AI interface write with mask and shift.
Driver version
#define FSL_ANATOP_AI_DRIVER_VERSION   (MAKE_VERSION(1, 0, 0))
 Anatop AI driver version 1.0.0.
enum  _anatop_ai_itf {
  kAI_Itf_Ldo = 0 , kAI_Itf_1g = 1 , kAI_Itf_Audio = 2 , kAI_Itf_Video = 3 ,
  kAI_Itf_400m = 4 , kAI_Itf_Temp = 5 , kAI_Itf_Bandgap = 6
 Anatop AI ITF enumeration. More...
enum  _anatop_ai_reg {
  kAI_PHY_LDO_CTRL0 = 0x0 , kAI_PHY_LDO_CTRL0_SET = 0x4 , kAI_PHY_LDO_CTRL0_CLR = 0x8 , kAI_PHY_LDO_CTRL0_TOG = 0xC ,
  kAI_PHY_LDO_STAT0 = 0x50 , kAI_PHY_LDO_STAT0_SET = 0x54 , kAI_PHY_LDO_STAT0_CLR = 0x58 , kAI_PHY_LDO_STAT0_TOG = 0x5C ,
  kAI_BANDGAP_CTRL0 = 0x0 , kAI_BANDGAP_STAT0 = 0x50 , kAI_RCOSC400M_CTRL0 = 0x0 , kAI_RCOSC400M_CTRL0_SET = 0x4 ,
  kAI_RCOSC400M_CTRL0_CLR = 0x8 , kAI_RCOSC400M_CTRL0_TOG = 0xC , kAI_RCOSC400M_CTRL1 = 0x10 , kAI_RCOSC400M_CTRL1_SET = 0x14 ,
  kAI_RCOSC400M_CTRL1_CLR = 0x18 , kAI_RCOSC400M_CTRL1_TOG = 0x1C , kAI_RCOSC400M_CTRL2 = 0x20 , kAI_RCOSC400M_CTRL2_SET = 0x24 ,
  kAI_RCOSC400M_CTRL2_CLR = 0x28 , kAI_RCOSC400M_CTRL2_TOG = 0x2C , kAI_RCOSC400M_CTRL3 = 0x30 , kAI_RCOSC400M_CTRL3_SET = 0x34 ,
  kAI_RCOSC400M_CTRL3_CLR = 0x38 , kAI_RCOSC400M_CTRL3_TOG = 0x3C , kAI_RCOSC400M_STAT0 = 0x50 , kAI_RCOSC400M_STAT0_SET = 0x54 ,
  kAI_RCOSC400M_STAT0_CLR = 0x58 , kAI_RCOSC400M_STAT0_TOG = 0x5C , kAI_RCOSC400M_STAT1 = 0x60 , kAI_RCOSC400M_STAT1_SET = 0x64 ,
  kAI_RCOSC400M_STAT1_CLR = 0x68 , kAI_RCOSC400M_STAT1_TOG = 0x6C , kAI_RCOSC400M_STAT2 = 0x70 , kAI_RCOSC400M_STAT2_SET = 0x74 ,
  kAI_RCOSC400M_STAT2_CLR = 0x78 , kAI_RCOSC400M_STAT2_TOG = 0x7C , kAI_PLL1G_CTRL0 = 0x0 , kAI_PLL1G_CTRL0_SET = 0x4 ,
  kAI_PLL1G_CTRL0_CLR = 0x8 , kAI_PLL1G_CTRL1 = 0x10 , kAI_PLL1G_CTRL1_SET = 0x14 , kAI_PLL1G_CTRL1_CLR = 0x18 ,
  kAI_PLL1G_CTRL2 = 0x20 , kAI_PLL1G_CTRL2_SET = 0x24 , kAI_PLL1G_CTRL2_CLR = 0x28 , kAI_PLL1G_CTRL3 = 0x30 ,
  kAI_PLL1G_CTRL3_SET = 0x34 , kAI_PLL1G_CTRL3_CLR = 0x38 , kAI_PLLAUDIO_CTRL0 = 0x0 , kAI_PLLAUDIO_CTRL0_SET = 0x4 ,
  kAI_PLLAUDIO_CTRL0_CLR = 0x8 , kAI_PLLAUDIO_CTRL1 = 0x10 , kAI_PLLAUDIO_CTRL1_SET = 0x14 , kAI_PLLAUDIO_CTRL1_CLR = 0x18 ,
  kAI_PLLAUDIO_CTRL2 = 0x20 , kAI_PLLAUDIO_CTRL2_SET = 0x24 , kAI_PLLAUDIO_CTRL2_CLR = 0x28 , kAI_PLLAUDIO_CTRL3 = 0x30 ,
  kAI_PLLAUDIO_CTRL3_SET = 0x34 , kAI_PLLAUDIO_CTRL3_CLR = 0x38 , kAI_PLLVIDEO_CTRL0 = 0x0 , kAI_PLLVIDEO_CTRL0_SET = 0x4 ,
  kAI_PLLVIDEO_CTRL0_CLR = 0x8 , kAI_PLLVIDEO_CTRL1 = 0x10 , kAI_PLLVIDEO_CTRL1_SET = 0x14 , kAI_PLLVIDEO_CTRL1_CLR = 0x18 ,
  kAI_PLLVIDEO_CTRL2 = 0x20 , kAI_PLLVIDEO_CTRL2_SET = 0x24 , kAI_PLLVIDEO_CTRL2_CLR = 0x28 , kAI_PLLVIDEO_CTRL3 = 0x30 ,
  kAI_PLLVIDEO_CTRL3_SET = 0x34 , kAI_PLLVIDEO_CTRL3_CLR = 0x38
 The enumeration of ANATOP AI Register. More...
typedef enum _anatop_ai_itf anatop_ai_itf_t
typedef enum _anatop_ai_reg anatop_ai_reg_t
◆ ANATOP_AI_Access()
uint32_t ANATOP_AI_Access ( anatop_ai_itf_t  itf,
bool  isWrite,
uint32_t  wdata
Parameters
itfAI interface name
isWritewrite enable
addraddress
wdatadata to be set
◆ ANATOP_AI_Read()
uint32_t ANATOP_AI_Read ( anatop_ai_itf_t  itf,
Parameters
addraddress
Returns
data read
◆ ANATOP_AI_Write()
void ANATOP_AI_Write ( anatop_ai_itf_t  itf,
uint32_t  wdata
Parameters
addraddress
wdatadata to be set
◆ ANATOP_AI_WriteWithMaskShift()
void ANATOP_AI_WriteWithMaskShift ( anatop_ai_itf_t  itf,
uint32_t  wdata,
uint32_t  mask,
uint32_t  shift
Parameters
addraddress
wdatadata to be written
maskbit field mask
shiftbit field shift
