RTEMS 6.1-rc4
drvmgr_list.h File Reference
Linked list help functions used by driver manager. More...
struct  drvmgr_list
#define LIST_INITIALIZER(type, field)   {NULL, NULL, offsetof(type, field)}
#define LIST_HEAD(list, type)   ((type *)(list)->head)
#define LIST_TAIL(list, type)   ((type *)(list)->tail)
#define LIST_FIELD(list, entry)   (*(void **)((char *)(entry) + (list)->ofs))
#define LIST_NEXT(list, entry, type)   ((type *)(LIST_FIELD(list, entry)))
#define LIST_FOR_EACH(list, entry, type)
void drvmgr_list_init (struct drvmgr_list *list, int offset)
void drvmgr_list_empty (struct drvmgr_list *list)
void drvmgr_list_add_head (struct drvmgr_list *list, void *entry)
void drvmgr_list_add_tail (struct drvmgr_list *list, void *entry)
void drvmgr_list_remove_head (struct drvmgr_list *list)
void drvmgr_list_remove (struct drvmgr_list *list, void *entry)
◆ LIST_FOR_EACH
#define LIST_FOR_EACH (   list,
  entry,
  type
Value:
for (entry = LIST_HEAD(list, type); \
entry; \
entry = LIST_NEXT(list, entry, type))
Definition: mmu-config.c:53
◆ drvmgr_list_add_head()
void drvmgr_list_add_head ( struct drvmgr_list list,
void *  entry
Add entry to front of list
◆ drvmgr_list_add_tail()
void drvmgr_list_add_tail ( struct drvmgr_list list,
void *  entry
Add entry to end of list
◆ drvmgr_list_empty()
void drvmgr_list_empty ( struct drvmgr_list list)
Clear list
◆ drvmgr_list_init()
void drvmgr_list_init ( struct drvmgr_list list,
int  offset
Initialize a list during runtime
Parameters
listThe list to initialize
offsetThe number of bytes into the entry structure the next pointer is found
◆ drvmgr_list_remove()
void drvmgr_list_remove ( struct drvmgr_list list,
void *  entry
Remove entry from anywhere in list
◆ drvmgr_list_remove_head()
void drvmgr_list_remove_head ( struct drvmgr_list list)
Remove entry from front of list
