file | gr740-bootstrap-regs.h [code] |
| This header file defines the GR740 Boostrap Signals register block interface.
file | gr740-iopll-regs.h [code] |
| This header file defines the GR740 I/O and PLL configuration register block interface.
file | gr740-thsens-regs.h [code] |
| This header file defines the GR740 Temperatur Sensor Controller register block interface.
file | irq.h [code] |
| LEON3 generic shared IRQ setup.
file | irqimpl.h [code] |
| This header file provides interfaces used by the interrupt support implementation.
file | leon3.h [code] |
| This header file provides interfaces used by the BSP implementation.
file | watchdog.h [code] |
