RTEMS 6.1-rc4
#define | CONSOLE_BAUDRATE 115200 |
#define | CONSOLE_EDBG |
#define | CONSOLE_ON_USART |
#define | PIN_USART1_RXD_DBG {PIO_PA21A_RXD1, PIOA, ID_PIOA, PIO_PERIPH_A, PIO_DEFAULT} |
#define | PIN_USART1_TXD_DBG {PIO_PB4D_TXD1, PIOB, ID_PIOB, PIO_PERIPH_D, PIO_DEFAULT} |
#define | PINS_USART1 PIN_USART1_TXD_DBG, PIN_USART1_RXD_DBG |
#define | CONSOLE_Usart USART1 |
#define | CONSOLE_PINS {PINS_USART1} |
#define | CONSOLE_ID ID_USART1 |
void | DBG_Configure (uint32_t baudrate, uint32_t masterClock) |
Configures an USART peripheral with the specified parameters. | |
void | DBG_PutChar (uint8_t c) |
Outputs a character on the UART line. | |
uint32_t | DBG_GetChar (void) |
Input a character from the UART line. | |
uint32_t | DBG_IsRxReady (void) |
Check if there is Input from UART line. | |
void | DBG_DumpFrame (uint8_t *pucFrame, uint32_t dwSize) |
void | DBG_DumpMemory (uint8_t *pucBuffer, uint32_t dwSize, uint32_t dwAddress) |
uint32_t | DBG_GetInteger (int32_t *pdwValue) |
uint32_t | DBG_GetIntegerMinMax (int32_t *pdwValue, int32_t dwMin, int32_t dwMax) |
uint32_t | DBG_GetHexa32 (uint32_t *pdwValue) |
WEAK int | puts (const char *ptr) |
WEAK char * | gets (char *ptr) |
Implements UART console.
#define CONSOLE_BAUDRATE 115200 |
Console baud rate always using 115200.
#define CONSOLE_EDBG |
EDBG used USART1 as the console, but LON support on USART1 only
#define CONSOLE_PINS {PINS_USART1} |
Pins description corresponding to Rxd,Txd, (Usart pins)
#define CONSOLE_Usart USART1 |
Usart Hw interface used by the console (Usart0).
#define PIN_USART1_RXD_DBG {PIO_PA21A_RXD1, PIOA, ID_PIOA, PIO_PERIPH_A, PIO_DEFAULT} |
USART1 pin RX
#define PIN_USART1_TXD_DBG {PIO_PB4D_TXD1, PIOB, ID_PIOB, PIO_PERIPH_D, PIO_DEFAULT} |
USART1 pin TX
void DBG_Configure | ( | uint32_t | baudrate, |
uint32_t | masterClock | ||
baudrate | Baudrate at which the USART should operate (in Hz). |
masterClock | Frequency of the system master clock (in Hz). |
void DBG_DumpFrame | ( | uint8_t * | pucFrame, |
uint32_t | dwSize | ||
Displays the content of the given frame on the UART0.
pucFrame | Pointer to the frame to dump. |
dwSize | Buffer size in bytes. |
void DBG_DumpMemory | ( | uint8_t * | pucBuffer, |
uint32_t | dwSize, | ||
uint32_t | dwAddress | ||
Displays the content of the given buffer on the UART0.
pucBuffer | Pointer to the buffer to dump. |
dwAddress | Start address to display |
uint32_t DBG_GetChar | ( | void | ) |
uint32_t DBG_GetHexa32 | ( | uint32_t * | pdwValue | ) |
Reads an hexadecimal number
pdwValue | Pointer to the uint32_t variable to contain the input value. |
uint32_t DBG_GetInteger | ( | int32_t * | pdwValue | ) |
Reads an integer
pdwValue | Pointer to a integer variable to contain the input value. |
uint32_t DBG_GetIntegerMinMax | ( | int32_t * | pdwValue, |
int32_t | dwMin, | ||
int32_t | dwMax | ||
Reads an integer and check the value
dwMin | Minimum value |
dwMax | Maximum value |
uint32_t DBG_IsRxReady | ( | void | ) |
void DBG_PutChar | ( | uint8_t | c | ) |
c | Character to send. |
