RTEMS 6.1-rc4
uint32_t | Afe_ConfigureDma (AfeDma *pAfed, Afec *pAfeHw, uint8_t AfeId, sXdmad *pXdmad) |
Initializes the AfeDma structure and the corresponding AFE & DMA . hardware select value. The driver will uses DMA channel 0 for RX . The DMA channels are freed automatically when no DMA command processing. | |
uint32_t | Afe_SendData (AfeDma *pAfed, AfeCmd *pCommand) |
Starts a AFE transfer. This is a non blocking function. It will return as soon as the transfer is started. | |
pAfed | Pointer to a AfeDma instance. |
pAfeHw | Associated Afe peripheral. |
AfeId | Afe peripheral identifier. |
pDmad | Pointer to a Dmad instance. |
pCommand | Pointer to the Afe command to execute. |
