RTEMS 6.1-rc4
aes.c File Reference
#include "chip.h"
#include "aes.h"
void AES_Start (void)
 Starts Manual encryption/decryption process.
void AES_SoftReset (void)
 Resets the AES. A software triggered hardware reset of the AES interface is performed.
void AES_Configure (uint32_t mode)
 Configures an AES peripheral with the specified parameters.
void AES_EnableIt (uint32_t sources)
 Enables the selected interrupts sources on a AES peripheral.
void AES_DisableIt (uint32_t sources)
 Disables the selected interrupts sources on a AES peripheral.
uint32_t AES_GetStatus (void)
 Get the current status register of the given AES peripheral.
void AES_WriteKey (const uint32_t *pKey, uint32_t keyLength)
 Set the 128-bit/192-bit/256-bit cryptographic key used for encryption/decryption.
void AES_SetInput (const uint32_t *data)
 Set the for 32-bit input Data allow to set the 128-bit data block used for encryption/decryption.
void AES_GetOutput (uint32_t *data)
 Get the four 32-bit data contain the 128-bit data block which has been encrypted/decrypted.
void AES_SetVector (const uint32_t *pVector)
 Set four 64-bit initialization vector data block, which is used by some modes of operation as an additional initial input.
void AES_SetAadLen (uint32_t len)
 Set Length in bytes of the AAD data that is to be processed.
void AES_SetDataLen (uint32_t len)
 Set Length in bytes of the Length in bytes of the plaintext/ciphertext (C) data that is to be processed..
void AES_SetGcmHash (uint32_t *hash)
 Set The four 32-bit Hash Word registers expose the intermediate GHASH value. May be read to save the current GHASH value so processing can later be resumed, presumably on a later message fragment. modes of operation as an additional initial input.
void AES_GetGcmTag (uint32_t *tag)
 Get The four 32-bit Tag which contain the final 128-bit GCM Authentication tag Ħ°TĦħ when GCM processing is complete.
void AES_GetGcmCounter (uint32_t *counter)
 Reports the current value of the 32-bit GCM counter.
void AES_GetGcmH (uint32_t *h)
 Get the four 32-bit data contain the 128-bit H value computed from the KEYW value.
Implementation of Advanced Encryption Standard (AES)
◆ AES_Configure()
void AES_Configure ( uint32_t  mode)
Parameters
modeDesired value for the AES mode register (see the datasheet).
◆ AES_DisableIt()
void AES_DisableIt ( uint32_t  sources)
Parameters
sourcesBitwise OR of selected interrupt sources.
◆ AES_EnableIt()
void AES_EnableIt ( uint32_t  sources)
Parameters
◆ AES_GetGcmCounter()
void AES_GetGcmCounter ( uint32_t *  counter)
Parameters
counterPoint to value of GCM counter.
◆ AES_GetGcmH()
void AES_GetGcmH ( uint32_t *  h)
Parameters
datapoint to the word that has been encrypted/decrypted.
◆ AES_GetGcmTag()
void AES_GetGcmTag ( uint32_t *  tag)
Parameters
tagpoint to the word of the tag.
◆ AES_GetOutput()
void AES_GetOutput ( uint32_t *  data)
Parameters
datapointer to the word that has been encrypted/decrypted..
◆ AES_GetStatus()
uint32_t AES_GetStatus ( void  )
Returns
AES status register.
◆ AES_SetAadLen()
void AES_SetAadLen ( uint32_t  len)
Parameters
lenLength.
◆ AES_SetDataLen()
void AES_SetDataLen ( uint32_t  len)
Parameters
lenLength.
◆ AES_SetGcmHash()
void AES_SetGcmHash ( uint32_t *  hash)
Parameters
hashpoint to the word of the hash.
◆ AES_SetInput()
void AES_SetInput ( const uint32_t *  data)
Parameters
dataPointer to the 16-bytes data to cipher/decipher.
◆ AES_SetVector()
void AES_SetVector ( const uint32_t *  pVector)
Parameters
pVectorpoint to the word of the initialization vector.
◆ AES_WriteKey()
void AES_WriteKey ( const uint32_t *  pKey,
uint32_t  keyLength
Parameters
pKeyPointer to a 16/24/32 bytes cipher key.
keyLengthlength of key
