RTEMS 6.1-rc4
abeoz9-rtc.h
2
11/*
12 * Copyright (C) 2024 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBCHIP_ABEOZ9_RTC_H
37#define LIBCHIP_ABEOZ9_RTC_H
38
39#include <libchip/i2c-rtc.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
66struct abeoz9_rtc {
67 struct i2c_rtc_base base;
68};
69
71int abeoz9_rtc_hw_init(struct i2c_rtc_base *base);
72
73#define ABEOZ9_RTC_INITIALIZER(i2c_path, i2c_address) { \
74 .base = I2C_RTC_INITIALIZER( \
75 i2c_path, \
76 i2c_address, \
77 8, \
78 I2C_RTC_ORDER_sec_min_hour_day_wkday_month_year, \
79 "abeoz9", \
80 abeoz9_rtc_hw_init), \
81 }
82
83#define ABEOZ9_RTC_TBL_ENTRY(dev_name, abeoz9_rtc_ctx) \
84 I2C_RTC_TBL_ENTRY(dev_name, abeoz9_rtc_ctx)
85
88#ifdef __cplusplus
89}
90#endif /* __cplusplus */
91
92#endif /* LIBCHIP_ABEOZ9_RTC_H */
Definition: abeoz9.c:98
This file provides the interfaces of Shared_tod_i2c_rtc.
Definition: abeoz9-rtc.h:66
Definition: i2c-rtc.h:98
