RTEMS 6.1-rc2
wd80x3.h
1
9/*
10 * Information about the DP8390 Ethernet controller.
11 */
12
13#ifndef __BSP_WD80x3_h
14#define __BSP_WD80x3_h
15
16/* Register descriptions */
17/* Controller DP8390. */
18
19#define DATAPORT 0x10 /* Port Window. */
20#define RESET 0x1f /* Issue a read for reset */
21#define W83CREG 0x00 /* I/O port definition */
22#define ADDROM 0x08
23
24/* page 0 read or read/write registers */
25
26#define CMDR 0x00+RO
27#define CLDA0 0x01+RO /* current local dma addr 0 for read */
28#define CLDA1 0x02+RO /* current local dma addr 1 for read */
29#define BNRY 0x03+RO /* boundary reg for rd and wr */
30#define TSR 0x04+RO /* tx status reg for rd */
31#define NCR 0x05+RO /* number of collision reg for rd */
32#define FIFO 0x06+RO /* FIFO for rd */
33#define ISR 0x07+RO /* interrupt status reg for rd and wr */
34#define CRDA0 0x08+RO /* current remote dma address 0 for rd */
35#define CRDA1 0x09+RO /* current remote dma address 1 for rd */
36#define RSR 0x0C+RO /* rx status reg for rd */
37#define CNTR0 0x0D+RO /* tally cnt 0 for frm alg err for rd */
38#define CNTR1 RO+0x0E /* tally cnt 1 for crc err for rd */
39#define CNTR2 0x0F+RO /* tally cnt 2 for missed pkt for rd */
40
41/* page 0 write registers */
42
43#define PSTART 0x01+RO /* page start register */
44#define PSTOP 0x02+RO /* page stop register */
45#define TPSR 0x04+RO /* tx start page start reg */
46#define TBCR0 0x05+RO /* tx byte count 0 reg */
47#define TBCR1 0x06+RO /* tx byte count 1 reg */
48#define RSAR0 0x08+RO /* remote start address reg 0 */
49#define RSAR1 0x09+RO /* remote start address reg 1 */
50#define RBCR0 0x0A+RO /* remote byte count reg 0 */
51#define RBCR1 0x0B+RO /* remote byte count reg 1 */
52#define RCR 0x0C+RO /* rx configuration reg */
53#define TCR 0x0D+RO /* tx configuration reg */
54#define DCR RO+0x0E /* data configuration reg */
55#define IMR 0x0F+RO /* interrupt mask reg */
56
57/* page 1 registers */
58
59#define PAR 0x01+RO /* physical addr reg base for rd and wr */
60#define CURR 0x07+RO /* current page reg for rd and wr */
61#define MAR 0x08+RO /* multicast addr reg base fro rd and WR */
62#define MARsize 8 /* size of multicast addr space */
63
64/*-----W83CREG command bits-----*/
65#define MSK_RESET 0x80 /* W83CREG masks */
66#define MSK_ENASH 0x40
67#define MSK_DECOD 0x3F /* memory decode bits, corresponding */
68 /* to SA 18-13. SA 19 assumed to be 1 */
69
70/*-----CMDR command bits-----*/
71#define MSK_STP 0x01 /* stop the chip */
72#define MSK_STA 0x02 /* start the chip */
73#define MSK_TXP 0x04 /* initial txing of a frm */
74#define MSK_RRE 0x08 /* remote read */
75#define MSK_RWR 0x10 /* remote write */
76#define MSK_RD2 0x20 /* no DMA used */
77#define MSK_PG0 0x00 /* select register page 0 */
78#define MSK_PG1 0x40 /* select register page 1 */
79#define MSK_PG2 0x80 /* select register page 2 */
80
81/*-----ISR and TSR status bits-----*/
82#define MSK_PRX 0x01 /* rx with no error */
83#define MSK_PTX 0x02 /* tx with no error */
84#define MSK_RXE 0x04 /* rx with error */
85#define MSK_TXE 0x08 /* tx with error */
86#define MSK_OVW 0x10 /* overwrite warning */
87#define MSK_CNT 0x20 /* MSB of one of the tally counters is set */
88#define MSK_RDC 0x40 /* remote dma completed */
89#define MSK_RST 0x80 /* reset state indicator */
90
91/*-----DCR command bits-----*/
92#define MSK_WTS 0x01 /* word transfer mode selection */
93#define MSK_BOS 0x02 /* byte order selection */
94#define MSK_LAS 0x04 /* long addr selection */
95#define MSK_BMS 0x08 /* burst mode selection */
96#define MSK_ARM 0x10 /* autoinitialize remote */
97#define MSK_FT00 0x00 /* burst lrngth selection */
98#define MSK_FT01 0x20 /* burst lrngth selection */
99#define MSK_FT10 0x40 /* burst lrngth selection */
100#define MSK_FT11 0x60 /* burst lrngth selection */
101
102/*-----RCR command bits-----*/
103#define MSK_SEP 0x01 /* save error pkts */
104#define MSK_AR 0x02 /* accept runt pkt */
105#define MSK_AB 0x04 /* 8390 RCR */
106#define MSK_AM 0x08 /* accept multicast */
107#define MSK_PRO 0x10 /* accept all pkt with physical adr */
108#define MSK_MON 0x20 /* monitor mode */
109
110/*-----TCR command bits-----*/
111#define MSK_CRC 0x01 /* inhibit CRC, do not append crc */
112#define MSK_LOOP 0x02 /* set loopback mode */
113#define MSK_BCST 0x04 /* Accept broadcasts */
114#define MSK_LB01 0x06 /* encoded loopback control */
115#define MSK_ATD 0x08 /* auto tx disable */
116#define MSK_OFST 0x10 /* collision offset enable */
117
118/*-----receive status bits-----*/
119#define SMK_PRX 0x01 /* rx without error */
120#define SMK_CRC 0x02 /* CRC error */
121#define SMK_FAE 0x04 /* frame alignment error */
122#define SMK_FO 0x08 /* FIFO overrun */
123#define SMK_MPA 0x10 /* missed pkt */
124#define SMK_PHY 0x20 /* physical/multicase address */
125#define SMK_DIS 0x40 /* receiver disable. set in monitor mode */
126#define SMK_DEF 0x80 /* deferring */
127
128/*-----transmit status bits-----*/
129#define SMK_PTX 0x01 /* tx without error */
130#define SMK_DFR 0x02 /* non deferred tx */
131#define SMK_COL 0x04 /* tx collided */
132#define SMK_ABT 0x08 /* tx abort because of excessive collisions */
133#define SMK_CRS 0x10 /* carrier sense lost */
134#define SMK_FU 0x20 /* FIFO underrun */
135#define SMK_CDH 0x40 /* collision detect heartbeat */
136#define SMK_OWC 0x80 /* out of window collision */
137
138#endif
139/* end of include */
