RTEMS 6.1-rc2
wd80x3.h File Reference
DP8390 Ethernet controller definitions. More...
#define DATAPORT   0x10 /* Port Window. */
#define RESET   0x1f /* Issue a read for reset */
#define W83CREG   0x00 /* I/O port definition */
#define ADDROM   0x08
#define CMDR   0x00+RO
#define CLDA0   0x01+RO /* current local dma addr 0 for read */
#define CLDA1   0x02+RO /* current local dma addr 1 for read */
#define BNRY   0x03+RO /* boundary reg for rd and wr */
#define TSR   0x04+RO /* tx status reg for rd */
#define NCR   0x05+RO /* number of collision reg for rd */
#define FIFO   0x06+RO /* FIFO for rd */
#define ISR   0x07+RO /* interrupt status reg for rd and wr */
#define CRDA0   0x08+RO /* current remote dma address 0 for rd */
#define CRDA1   0x09+RO /* current remote dma address 1 for rd */
#define RSR   0x0C+RO /* rx status reg for rd */
#define CNTR0   0x0D+RO /* tally cnt 0 for frm alg err for rd */
#define CNTR1   RO+0x0E /* tally cnt 1 for crc err for rd */
#define CNTR2   0x0F+RO /* tally cnt 2 for missed pkt for rd */
#define PSTART   0x01+RO /* page start register */
#define PSTOP   0x02+RO /* page stop register */
#define TPSR   0x04+RO /* tx start page start reg */
#define TBCR0   0x05+RO /* tx byte count 0 reg */
#define TBCR1   0x06+RO /* tx byte count 1 reg */
#define RSAR0   0x08+RO /* remote start address reg 0 */
#define RSAR1   0x09+RO /* remote start address reg 1 */
#define RBCR0   0x0A+RO /* remote byte count reg 0 */
#define RBCR1   0x0B+RO /* remote byte count reg 1 */
#define RCR   0x0C+RO /* rx configuration reg */
#define TCR   0x0D+RO /* tx configuration reg */
#define DCR   RO+0x0E /* data configuration reg */
#define IMR   0x0F+RO /* interrupt mask reg */
#define PAR   0x01+RO /* physical addr reg base for rd and wr */
#define CURR   0x07+RO /* current page reg for rd and wr */
#define MAR   0x08+RO /* multicast addr reg base fro rd and WR */
#define MARsize   8 /* size of multicast addr space */
#define MSK_RESET   0x80 /* W83CREG masks */
#define MSK_ENASH   0x40
#define MSK_DECOD   0x3F /* memory decode bits, corresponding */
#define MSK_STP   0x01 /* stop the chip */
#define MSK_STA   0x02 /* start the chip */
#define MSK_TXP   0x04 /* initial txing of a frm */
#define MSK_RRE   0x08 /* remote read */
#define MSK_RWR   0x10 /* remote write */
#define MSK_RD2   0x20 /* no DMA used */
#define MSK_PG0   0x00 /* select register page 0 */
#define MSK_PG1   0x40 /* select register page 1 */
#define MSK_PG2   0x80 /* select register page 2 */
#define MSK_PRX   0x01 /* rx with no error */
#define MSK_PTX   0x02 /* tx with no error */
#define MSK_RXE   0x04 /* rx with error */
#define MSK_TXE   0x08 /* tx with error */
#define MSK_OVW   0x10 /* overwrite warning */
#define MSK_CNT   0x20 /* MSB of one of the tally counters is set */
#define MSK_RDC   0x40 /* remote dma completed */
#define MSK_RST   0x80 /* reset state indicator */
#define MSK_WTS   0x01 /* word transfer mode selection */
#define MSK_BOS   0x02 /* byte order selection */
#define MSK_LAS   0x04 /* long addr selection */
#define MSK_BMS   0x08 /* burst mode selection */
#define MSK_ARM   0x10 /* autoinitialize remote */
#define MSK_FT00   0x00 /* burst lrngth selection */
#define MSK_FT01   0x20 /* burst lrngth selection */
#define MSK_FT10   0x40 /* burst lrngth selection */
#define MSK_FT11   0x60 /* burst lrngth selection */
#define MSK_SEP   0x01 /* save error pkts */
#define MSK_AR   0x02 /* accept runt pkt */
#define MSK_AB   0x04 /* 8390 RCR */
#define MSK_AM   0x08 /* accept multicast */
#define MSK_PRO   0x10 /* accept all pkt with physical adr */
#define MSK_MON   0x20 /* monitor mode */
#define MSK_CRC   0x01 /* inhibit CRC, do not append crc */
#define MSK_LOOP   0x02 /* set loopback mode */
#define MSK_BCST   0x04 /* Accept broadcasts */
#define MSK_LB01   0x06 /* encoded loopback control */
#define MSK_ATD   0x08 /* auto tx disable */
#define MSK_OFST   0x10 /* collision offset enable */
#define SMK_PRX   0x01 /* rx without error */
#define SMK_CRC   0x02 /* CRC error */
#define SMK_FAE   0x04 /* frame alignment error */
#define SMK_FO   0x08 /* FIFO overrun */
#define SMK_MPA   0x10 /* missed pkt */
#define SMK_PHY   0x20 /* physical/multicase address */
#define SMK_DIS   0x40 /* receiver disable. set in monitor mode */
#define SMK_DEF   0x80 /* deferring */
#define SMK_PTX   0x01 /* tx without error */
#define SMK_DFR   0x02 /* non deferred tx */
#define SMK_COL   0x04 /* tx collided */
#define SMK_ABT   0x08 /* tx abort because of excessive collisions */
#define SMK_CRS   0x10 /* carrier sense lost */
#define SMK_FU   0x20 /* FIFO underrun */
#define SMK_CDH   0x40 /* collision detect heartbeat */
#define SMK_OWC   0x80 /* out of window collision */
