RTEMS 6.1-rc2
Data Structures | Macros
vbe3.h File Reference
VESA Bios Extension definitions. More...
#include <stdint.h>
struct  RTEMS_PACKED
 Used for passing and retrieving registers content to/from real mode interrupt call. More...
#define VBE_functionSupported   0x4F
#define VBE_callSuccessful   0x00
#define VBE_callFailed   0x01
#define VBE_notSupportedInCurHWConf   0x02
#define VBE_callInvalid   0x03
#define VBE_modeNumberMask   0x01FF
#define VBE_modeNumberShift   0x00
#define VBE_VESAmodeMask   0x0100
#define VBE_VESAmodeShift   0x08
#define VBE_refreshRateCtrlMask   0x0800
#define VBE_refreshRateCtrlShift   0x0B
#define VBE_linearFlatFrameBufMask   0x4000
#define VBE_linearFlatFrameBufShift   0x0E
#define VBE_preserveDispMemMask   0x8000
#define VBE_preserveDispMemShift   0x0F
#define VBE_R640x400C256   0x100
#define VBE_R640x480C256   0x101
#define VBE_R800x600C16   0x102
#define VBE_b7R800x600C16   0x6A
#define VBE_R800x600C256   0x103
#define VBE_R1024x768C16   0x104
#define VBE_R1024x768C256   0x105
#define VBE_R1280x1024C16   0x106
#define VBE_R1280x1024C256   0x107
#define VBE_R320x200C32K   0x10D
#define VBE_R320x200C64K   0x10E
#define VBE_R320x200C17M   0x10F
#define VBE_R640x480C32K   0x110
#define VBE_R640x480C64K   0x111
#define VBE_R640x480C17M   0x112
#define VBE_R800x600C32K   0x113
#define VBE_R800x600C64K   0x114
#define VBE_R800x600C17M   0x115
#define VBE_R1024x768C32K   0x116
#define VBE_R1024x768C64K   0x117
#define VBE_R1024x768C17M   0x118
#define VBE_R1280x1024C32K   0x119
#define VBE_R1280x1024C64K   0x11A
#define VBE_R1280x1024C17M   0x11B
#define VBE_SpecialMode   0x81FF
#define VBE_C80R60   0x108
#define VBE_C132R25   0x109
#define VBE_C132R43   0x10A
#define VBE_C132R50   0x10B
#define VBE_C132R60   0x10C
#define VBE_RetVBEConInf   0x4F00
#define VBE_RetVBEModInf   0x4F01
#define VBE_SetVBEMod   0x4F02
#define VBE_RetCurVBEMod   0x4F03
#define VBE_SavResSta   0x4F04
#define VBE_DisWinCon   0x4F05
#define VBE_SetGetLogScaLinLen   0x4F06
#define VBE_SetGetDisSta   0x4F07
#define VBE_SetGetDACPalFor   0x4F08
#define VBE_SetGetPalDat   0x4F09
#define VBE_RetVBEProModInt   0x4F0A
#define VBE_GetSetpixclo   0x4F0B
#define VBE_PowManExt   0x4F10
#define VBE_FlaPanIntExt   0x4F11
#define VBE_AudIntExt   0x4F13
#define VBE_OEMExt   0x4F14
#define VBE_DisDatCha   0x4F15
#define VBE_RetVBESupSpeInf   0x00
#define VBE_SIGNATURE   "VESA"
#define VBE20plus_SIGNATURE   "VBE2"
#define VBE_STUB_VideoModeList   0xFFFF
#define VBE_END_OF_VideoModeList   0xFFFF
#define VBE_DACswitchableMask   0x0001
#define VBE_notVGAcompatibleMask   0x0002
#define VBE_specialRAMDACopMask   0x0004
#define VBE_hwStereoscopicMask   0x0008
#define VBE_supportEVCconnMask   0x0010
#define VBE_modSupInHWMask   0x0001
#define VBE_TTYOutSupByBIOSMask   0x0004
#define VBE_ColorModeMask   0x0008
#define VBE_GraphicsModeMask   0x0010
#define VBE_VGACompModeMask   0x0020
#define VBE_VGACompWinMemModeMask   0x0040
#define VBE_LinFraBufModeAvaiMask   0x0080
#define VBE_DblScnModeAvaiMask   0x0100
#define VBE_InterlModeAvaiMask   0x0200
#define VBE_HWTripBufSupMask   0x0400
#define VBE_HWSterDispSupMask   0x0800
#define VBE_DualDispStAdrSupMask   0x1000
#define VBE_RelocWinSupMask   0x01
#define VBE_WinReadableMask   0x02
#define VBE_WinWritableMask   0x04
#define VBE_TextMode   0x00
#define VBE_CGAGraphics   0x01
#define VBE_HerculesGraphics   0x02
#define VBE_Planar   0x03
#define VBE_PackedPixel   0x04
#define VBE_NonChain4Color256   0x05
#define VBE_DirectColor   0x06
#define VBE_YUV   0x07
#define VBE_ColRampProgMask   0x01
#define VBE_RsvdBitsUsableMask   0x02
#define VBE_GrModeDblScanMask   0x01
#define VBE_GrModeInterlMask   0x02
#define VBE_HorSncPolNegMask   0x04
#define VBE_VerSncPolNegMask   0x08
#define VBEDDC_Capabilities   0x0
#define VBEDDC_ReadEDID   0x1
#define VBEDDC_1SupportedMask   0x1
#define VBEDDC_2SupportedMask   0x2
#define VBEDDC_scrBlnkDatTrMs   0x4
#define VBESCI_ReportCapabil   0x10
#define VBESCI_BegSCLSDACtrl   0x11
#define VBESCI_EndSCLSDACtrl   0x12
#define VBESCI_WrtSCLClkLine   0x13
#define VBESCI_WrtSDADatLine   0x14
#define VBESCI_RdySCLClkLine   0x15
#define VBESCI_RdySDADatLine   0x16
#define VBESCI_capSCLwrtMask   0x1
#define VBESCI_capSDAwrtMask   0x2
#define VBESCI_capSCLrdyMask   0x4
#define VBESCI_capSDArdyMask   0x8
This file contains definitions for constants related to VBE. More information can be found at http://www.vesa.org/vesa-standards/free-standards/. VESA public standards may be found at http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm.
◆ VBE20plus_SIGNATURE
Signature for VBE 2.0 and higher
◆ VBE_AudIntExt
VBE function - Audio Interface Extensions (AI)
◆ VBE_b7R800x600C16
7-bit mode, Resolution: 800x600, Colors: 16
◆ VBE_C132R25
15-bit mode, Columns: 132, Rows: 25
◆ VBE_C132R43
15-bit mode, Columns: 132, Rows: 43
◆ VBE_C132R50
15-bit mode, Columns: 132, Rows: 50
◆ VBE_C132R60
15-bit mode, Columns: 132, Rows: 60
◆ VBE_C80R60
15-bit mode, Columns: 80, Rows: 60
◆ VBE_callFailed
AH == 01h: Function call failed
◆ VBE_callInvalid
AH == 03h: Function call invalid in current video mode
◆ VBE_callSuccessful
AH == 00h: Function call successful
◆ VBE_ColorModeMask
Mode Info Block - Mode Attributes
D3 = Monochrome/color mode (see note below). 0 = Monochrome mode
1 = Color mode
◆ VBE_ColRampProgMask
D0 = Color ramp is fixed/programmable. 0 = Color ramp is fixed
1 = Color ramp is programmable
◆ VBE_DACswitchableMask
VBE Info Block - Capabilities
D0 = 0 DAC is fixed width, with 6 bits per primary color
D0 = 1 DAC width is switchable to 8 bits per primary color
◆ VBE_DblScnModeAvaiMask
D8 = Double scan mode is available. 0 = No
1 = Yes
◆ VBE_DisDatCha
VBE function - Display Data Channel (DDC), Serial Control Interface (SCI)
◆ VBE_DisWinCon
VBE function - Display Window Control
◆ VBE_DualDispStAdrSupMask
D12 = Dual display start address support. 0 = No
1 = Yes
◆ VBE_FlaPanIntExt
VBE function - Flat Panel Interface Extensions (FP)
◆ VBE_functionSupported
AL == 4Fh: Function is supported
AL != 4Fh: Function is not supported
◆ VBE_GetSetpixclo
VBE function - Get/Set pixel clock
◆ VBE_GraphicsModeMask
D4 = Mode type. 0 = Text mode
1 = Graphics mode
◆ VBE_GrModeDblScanMask
CRTC Info Block - Flags
D0 = Double Scan Mode Enable. 0 = Graphics mode is not double scanned
1 = Graphics mode is double scanned
◆ VBE_GrModeInterlMask
D1 = Interlaced Mode Enable. 0 = Graphics mode is non-interlaced
1 = Graphics mode is interlaced
◆ VBE_HorSncPolNegMask
D2 = Horizontal sync polarity. 0 = Horizontal sync polarity is positive (+)
1 = Horizontal sync polarity is negative (-)
◆ VBE_HWSterDispSupMask
D11 = Hardware stereoscopic display support. 0 = No
1 = Yes
◆ VBE_hwStereoscopicMask
D3 = 0 No hardware stereoscopic signaling support
D3 = 1 Hardware stereoscopic signaling supported by controller
◆ VBE_HWTripBufSupMask
D10 = Hardware triple buffering support. 0 = No
1 = Yes
◆ VBE_InterlModeAvaiMask
D9 = Interlaced mode is available. 0 = No
1 = Yes
◆ VBE_linearFlatFrameBufMask
If D14 == 0, Use Banked/Windowed Frame Buffer
If D14 == 1, Use Linear/Flat Frame Buffer
◆ VBE_LinFraBufModeAvaiMask
D7 = Linear frame buffer mode is available. 0 = No
1 = Yes
◆ VBE_modeNumberMask
D0-D8 = Mode number
◆ VBE_modSupInHWMask
D0 = Mode supported by hardware configuration. 0 = Mode not supported in hardware
1 = Mode supported in hardware
◆ VBE_notSupportedInCurHWConf
AH == 02h: Function is not supported in the current hardware configuration
◆ VBE_notVGAcompatibleMask
D1 = 0 Controller is VGA compatible
D1 = 1 Controller is not VGA compatible
◆ VBE_OEMExt
VBE function - OEM Extensions
◆ VBE_PowManExt
VBE function - Power Management Extensions (PM)
◆ VBE_preserveDispMemMask
If D15 == 0, Clear display memory
If D15 == 1, Preserve display memory
◆ VBE_R1024x768C16
15-bit mode, Resolution: 1024x768, Colors: 16
◆ VBE_R1024x768C17M
15-bit mode, Resolution: 1024x768, Colors: 16.8M (8:8:8)
◆ VBE_R1024x768C256
15-bit mode, Resolution: 1024x768, Colors: 256
◆ VBE_R1024x768C32K
15-bit mode, Resolution: 1024x768, Colors: 32K (1:5:5:5)
◆ VBE_R1024x768C64K
15-bit mode, Resolution: 1024x768, Colors: 64K (5:6:5)
◆ VBE_R1280x1024C16
15-bit mode, Resolution: 1280x1024, Colors: 16
◆ VBE_R1280x1024C17M
15-bit mode, Resolution: 1280x1024, Colors: 16.8M (8:8:8)
◆ VBE_R1280x1024C256
15-bit mode, Resolution: 1280x1024, Colors: 256
◆ VBE_R1280x1024C32K
15-bit mode, Resolution: 1280x1024, Colors: 32K (1:5:5:5)
◆ VBE_R1280x1024C64K
15-bit mode, Resolution: 1280x1024, Colors: 64K (5:6:5)
◆ VBE_R320x200C17M
15-bit mode, Resolution: 320x200, Colors: 16.8M (8:8:8)
◆ VBE_R320x200C32K
15-bit mode, Resolution: 320x200, Colors: 32K (1:5:5:5)
◆ VBE_R320x200C64K
15-bit mode, Resolution: 320x200, Colors: 64K (5:6:5)
◆ VBE_R640x400C256
15-bit mode, Resolution: 640x400, Colors: 256
◆ VBE_R640x480C17M
15-bit mode, Resolution: 640x480, Colors: 16.8M (8:8:8)
◆ VBE_R640x480C256
15-bit mode, Resolution: 640x480, Colors: 256
◆ VBE_R640x480C32K
15-bit mode, Resolution: 640x480, Colors: 32K (1:5:5:5)
◆ VBE_R640x480C64K
15-bit mode, Resolution: 640x480, Colors: 64K (5:6:5)
◆ VBE_R800x600C16
15-bit mode, Resolution: 800x600, Colors: 16
◆ VBE_R800x600C17M
15-bit mode, Resolution: 800x600, Colors: 16.8M (8:8:8)
◆ VBE_R800x600C256
15-bit mode, Resolution: 800x600, Colors: 256
◆ VBE_R800x600C32K
15-bit mode, Resolution: 800x600, Colors: 32K (1:5:5:5)
◆ VBE_R800x600C64K
15-bit mode, Resolution: 800x600, Colors: 64K (5:6:5)
◆ VBE_refreshRateCtrlMask
If D11 == 0, Use current BIOS default refresh rate
If D11 == 1, Use user specified CRTC values for refresh rate
◆ VBE_RelocWinSupMask
D0 = Relocatable window(s) supported. 0 = Single non-relocatable window only
1 = Relocatable window(s) are supported
◆ VBE_RetCurVBEMod
VBE function - Return Current VBE Mode
◆ VBE_RetVBEConInf
VBE function - Return VBE Controller Information
◆ VBE_RetVBEModInf
VBE function - Return VBE Mode Information
◆ VBE_RetVBEProModInt
VBE function - Return VBE Protected Mode Interface
◆ VBE_RetVBESupSpeInf
Return VBE Supplemental Specification Information
◆ VBE_RsvdBitsUsableMask
D1 = Bits in Rsvd field are usable/reserved. 0 = Bits in Rsvd field are reserved
1 = Bits in Rsvd field are usable by the application
◆ VBE_SavResSta
VBE function - Save/Restore State
◆ VBE_SetGetDACPalFor
VBE function - Set/Get DAC Palette Format
◆ VBE_SetGetDisSta
VBE function - Set/Get Display Start
◆ VBE_SetGetLogScaLinLen
VBE function - Set/Get Logical Scan Line Length
◆ VBE_SetGetPalDat
VBE function - Set/Get Palette Data
◆ VBE_SetVBEMod
VBE function - Set VBE Mode
◆ VBE_SIGNATURE
General VBE signature
◆ VBE_specialRAMDACopMask
D2 = 0 Normal RAMDAC operation
D2 = 1 When programming large blocks of information to the RAMDAC, use the blank bit in Function 09h.
◆ VBE_STUB_VideoModeList
for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1
◆ VBE_supportEVCconnMask
D4 = 0 Stereo signaling supported via external VESA stereo connector
D4 = 1 Stereo signaling supported via VESA EVC connector
◆ VBE_TTYOutSupByBIOSMask
D2 = TTY Output functions supported by BIOS. 0 = TTY Output functions not supported by BIOS
1 = TTY Output functions supported by BIOS
◆ VBE_VerSncPolNegMask
D3 = Vertical sync polarity. 0 = Vertical sync polarity is positive (+)
1 = Vertical sync polarity is negative (-)
◆ VBE_VESAmodeMask
If D8 == 0, this is not a VESA defined VBE mode
If D8 == 1, this is a VESA defined VBE mode
◆ VBE_VGACompModeMask
D5 = VGA compatible mode. 0 = Yes
1 = No
◆ VBE_VGACompWinMemModeMask
D6 = VGA compatible windowed memory mode is available. 0 = Yes
1 = No
◆ VBE_WinReadableMask
D1 = Window readable. 0 = Window is not readable
1 = Window is readable
◆ VBE_WinWritableMask
D2 = Window writeable. 0 = Window is not writeable
1 = Window is writeable
◆ VBEDDC_1SupportedMask
0 - DDC1 not supported; 1 - DDC1 supported
◆ VBEDDC_2SupportedMask
0 - DDC2 not supported; 1 - DDC2 supported
◆ VBEDDC_Capabilities
VBE/DDC subfunction - Report VBE/DDC Capabilities
◆ VBEDDC_ReadEDID
VBE/DDC subfunction - Read EDID
◆ VBEDDC_scrBlnkDatTrMs
0 - Screen not blanked during data transfer
1 - Screen blanked during data transfer
◆ VBESCI_BegSCLSDACtrl
VBE/SCI subfunction - Begin SCL/SDA control
◆ VBESCI_capSCLrdyMask
Can read from SCL clock line
◆ VBESCI_capSCLwrtMask
Can write to SCL clock line
◆ VBESCI_capSDArdyMask
Can read from SDA data line
◆ VBESCI_capSDAwrtMask
Can write to SDA data line
◆ VBESCI_EndSCLSDACtrl
VBE/SCI subfunction - End SCL/SDA control
◆ VBESCI_RdySCLClkLine
VBE/SCI subfunction - Read SCL clock line
◆ VBESCI_RdySDADatLine
VBE/SCI subfunction - Read SDA data line
◆ VBESCI_ReportCapabil
VBE/SCI subfunction - Report VBE/SCI Capabilities
◆ VBESCI_WrtSCLClkLine
VBE/SCI subfunction - Write SCL clock line
◆ VBESCI_WrtSDADatLine
VBE/SCI subfunction - Write SDA data line
