RTEMS 6.1-rc2
usart_dma.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _USART_DMA_H_
38#define _USART_DMA_H_
39
40/*----------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43
44#include "chip.h"
45
46/*----------------------------------------------------------------------------
47 * Definitions
48 *----------------------------------------------------------------------------*/
49
51#define USARTD_ERROR 1
52
54#define USARTD_ERROR_LOCK 2
55
56
57#ifdef __cplusplus
58extern "C" {
59#endif
60
61/*----------------------------------------------------------------------------
62 * Types
63 *----------------------------------------------------------------------------*/
64
66typedef void (*UsartdCallback)(uint8_t, void *);
67
73typedef struct {
75 uint8_t *pBuff;
77 uint32_t BuffSize;
79 uint8_t ChNum;
83 void *pArgument;
85 volatile uint8_t dmaProgress;
86 /* DMA LLI structure */
88 /* DMA transfer type */
89 eXdmadProgState dmaProgrammingMode;
90 /* DMA LLI size or num of micro block*/
91 uint16_t dmaBlockSize;
92 /* Flag using ring buffer or FiFo*/
93 uint8_t dmaRingBuffer;
95
98typedef struct {
100 uint8_t usartId;
109} UsartDma;
110
111/*----------------------------------------------------------------------------
112 * Exported functions
113 *----------------------------------------------------------------------------*/
114
115uint32_t USARTD_Configure(UsartDma *pUsartd ,
116 uint8_t USARTId,
117 uint32_t UsartMode,
118 uint32_t BaudRate,
119 uint32_t UsartClk);
120
121uint32_t USARTD_EnableTxChannels(UsartDma *pUsartd, UsartChannel *pTxCh);
122
123uint32_t USARTD_EnableRxChannels(UsartDma *pUsartd, UsartChannel *pRxCh);
124
125uint32_t USARTD_DisableTxChannels(UsartDma *pUsartd, UsartChannel *pTxCh);
126
127uint32_t USARTD_DisableRxChannels(UsartDma *pUsartd, UsartChannel *pTxCh);
128
129uint32_t USARTD_SendData(UsartDma *pUsartd);
130
131uint32_t USARTD_RcvData(UsartDma *pUsartd);
132
133#ifdef __cplusplus
134}
135#endif
136
137#endif /* #ifndef _USART_DMA_ */
enum _XdmadProgState eXdmadProgState
usart Transfer Request prepared by the application upper layer.
Definition: usart_dma.h:73
uint32_t BuffSize
Definition: usart_dma.h:77
UsartdCallback callback
Definition: usart_dma.h:81
uint8_t ChNum
Definition: usart_dma.h:79
uint8_t * pBuff
Definition: usart_dma.h:75
Definition: usart_dma.h:85
void * pArgument
Definition: usart_dma.h:83
Definition: usart_dma.h:98
UsartChannel * pRxChannel
Definition: usart_dma.h:104
sXdmad * pXdmad
Definition: usart_dma.h:108
Usart * pUsartHw
Definition: usart_dma.h:102
uint8_t usartId
Definition: usart_dma.h:100
UsartChannel * pTxChannel
Definition: usart_dma.h:106
Usart hardware registers.
Definition: component_usart.h:41
Structure for storing parameters for DMA view1 that can be performed by the DMA Master transfer.
Definition: xdmad.h:167
Definition: xdmad.h:127
This function disables the appropriate DMA channel for Tx channel of USART.
Definition: usart_dma.c:535
uint32_t USARTD_Configure(UsartDma *pUsartd, uint8_t USARTId, uint32_t UsartMode, uint32_t BaudRate, uint32_t UsartClk)
Initializes the USARTDma structure and the corresponding USART & DMA . hardware select value....
Definition: usart_dma.c:350
Starts a USART master transfer. This is a non blocking function. It will return as soon as the transf...
Definition: usart_dma.c:590
This function initialize the appropriate DMA channel for Rx channel of USART.
Definition: usart_dma.c:392
Definition: usart_dma.c:568
void(* UsartdCallback)(uint8_t, void *)
Definition: usart_dma.h:66
This function initialize the appropriate DMA channel for Tx channel of USART.
Definition: usart_dma.c:447
This function disables the appropriate DMA channel for Rx channel of USART.
Definition: usart_dma.c:501
